  4. Iobroker startet nicht mehr
24 Beiträge 3 Kommentatoren 2.7k Aufrufe 2 Beobachtet
  • S SR277
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ npm ls source-map
    iobroker.inst@3.0.0 /opt/iobroker
    ├─┬ iobroker.alexa2@3.12.0
    │ └─┬ source-map-support@0.5.21
    │   └── source-map@0.6.1
    └─┬ iobroker.iot@1.11.5
      └─┬ jsdom@19.0.0
        └─┬ escodegen@2.0.0
          └── source-map@0.6.1 deduped
    Thomas BraunT Offline
    @sr277
    Lange das System nicht mehr abgestaubt...
    iob stop
    iob fix
    iob restart
      @sr277
      iob stop
      iob fix
      iob restart
      SR277
      pi@raspberrypi:~ $ iob stop
      pi@raspberrypi:~ $ iob fix
      library: loaded
      Library version=2022-12-09
          Welcome to the ioBroker installation fixer!
          Script version: 2022-12-22
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      Reading package lists... Done
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/4)
          Database maintenance (3/4)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (4/4)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@raspberrypi:~ $ iob restart
      • S SR277
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        @sr277
        iobroker status
          @sr277
          iobroker status
          SR277
          pi@raspberrypi:~ $ iobroker status
           Objects database error: connect ECONNREFUSED 127.0.0.1:9001
           Objects database error: read ECONNRESET
          Uncaught Rejection: /opt/iobroker/node_modules/source-map/lib/base64-vlq.js:91
          0 var di'it;
          SyntaxError: Unexpected token 'var'
              at Object.compileFunction (node:vm:360:18)
              at wrapSafe (node:internal/modules/cjs/loader:1094:15)
              at Module._compile (node:internal/modules/cjs/loader:1129:27)
              at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
              at Module.load (node:internal/modules/cjs/loader:1043:32)
              at Function.Module._load (node:internal/modules/cjs/loader:878:12)
              at Module.require (node:internal/modules/cjs/loader:1067:19)
              at require (node:internal/modules/cjs/helpers:103:18)
              at Object.<anonymous> (/opt/iobroker/node_modules/source-map/lib/source-map-generator.js:8:17)
              at Module._compile (node:internal/modules/cjs/loader:1165:14)
          • S SR277
            0 var di'it;
            @sr277
            Keine Ahnung.
            iob update
            funktioniert vermutlich auch nicht?
              @sr277
              Keine Ahnung.
              iob update
              SR277
              Ne das gleiche. :(
              pi@raspberrypi:~ $ iob update
              0 var di'it;
              • S SR277
                Ne das gleiche. :(
                0 var di'it;
                @sr277
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.alexa2
                sudo -H -u iobroker npm install iobroker.iot
                  @sr277
                  cd /opt/iobroker
                  SR277
                  schrieb am zuletzt editiert von SR277
                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.alexa2
                  npm WARN old lockfile
                  npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                  npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                  npm WARN old lockfile This is a one-time fix-up, please be patient...
                  added 12 packages, removed 121 packages, and changed 31 packages in 1m
                  137 packages are looking for funding
                    run `npm fund` for details
                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.iot
                  added 2 packages, removed 1 package, and changed 1 package in 13s
                  138 packages are looking for funding
                  Blöde Frage: Wie bekomme ich beim nächsten Befehl das "/opt/iobroker $" wieder weg?
                  • S SR277
                    @sr277
                    iob status
                      @sr277
                      iob status
                      SR277
                      pi@raspberrypi:/opt/iobroker $ iob status
                       States database error: connect ECONNREFUSED 127.0.0.1:9000
                       redis get system.host.raspberrypi.alive, error - Connection is closed.
                       redis get system.host.raspberrypi.plugins.sentry.enabled, error - Connection is closed.
                      0 var di'it;
                      • S SR277
                        0 var di'it;
                        @sr277 sagte in Iobroker startet nicht mehr:
                        warum?
                        da bist du richtig!
                        • S SR277
                          0 var di'it;
                          @sr277
                          ls -lAh /opt/iobroker/iobroker-data/
                          Im Prompt steht der Verzeichnispfad, in dem du dich gerade befindest. Vollkommen korrekt für den Moment.
                            @sr277
                            SR277
                            pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
                            total 53M
                            drwxrwxr-x+  2 iobroker iobroker 4.0K Feb 11  2022 backitup
                            drwxrwxr-x+  2 iobroker iobroker  12K Oct  1 20:53 backup-objects
                            drwxrwxr-x+ 70 iobroker iobroker 4.0K May 13  2022 files
                            -rw-rwxr--+  1 iobroker iobroker 5.0K Feb  8  2022 iobroker.json
                            drwxrwxr-x+  3 iobroker iobroker 4.0K Jan 26  2022 jarvis
                            -rw-rwxr--+  1 iobroker iobroker    3 Jan 15 17:19 notifications.json
                            -rw-rwxr--+  1 iobroker iobroker  14M Feb  8  2022 objects.json.bak.migrated
                            -rw-rw-r--+  1 iobroker iobroker  17M Jan 15 17:19 objects.jsonl
                            -rw-rwxr--+  1 iobroker iobroker  14M Feb  8  2022 objects.json.migrated
                            -rw-rwxr--+  1 iobroker iobroker 2.6M Feb  8  2022 states.json.bak.migrated
                            -rw-rw-r--+  1 iobroker iobroker 4.2M Jan 15 17:19 states.jsonl
                            -rw-rwxr--+  1 iobroker iobroker 2.6M Feb  8  2022 states.json.migrated
                            drwxrwxr-x+  2 iobroker iobroker 4.0K May  1  2022 telegram_0
                            drwxrwxr-x+  3 iobroker iobroker 4.0K Feb  8  2022 tmp
                            • S SR277
                              total 53M
                              getfacl /opt/iobroker/iobroker-data/objects.jsonl
                                SR277
                                pi@raspberrypi:/opt/iobroker $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
                                getfacl: Removing leading '/' from absolute path names
                                # file: opt/iobroker/iobroker-data/objects.jsonl
                                # owner: iobroker
                                # group: iobroker
                                user::rw-
                                group::r-x                      #effective:r--
                                group:iobroker:rwx              #effective:rw-
                                mask::rw-
                                other::r--
