  4. Iobroker startet nicht mehr
24 Beiträge 3 Kommentatoren 2.7k Aufrufe 2 Beobachtet
  • S SR277
    So habe es installiert.
    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    v16.19.0
    v16.19.0
    8.19.3
    8.19.3
    4.0.23
    pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    tty
    /home/pi
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists... Done
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
     *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u1 500
    Fehler besteht aber weiterhin:
    pi@raspberrypi:~ $ iob start admin
     Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    Uncaught Rejection: /opt/iobroker/node_modules/source-map/lib/base64-vlq.js:91
    0 var di'it;
    SyntaxError: Unexpected token 'var'
        at Object.compileFunction (node:vm:360:18)
        at wrapSafe (node:internal/modules/cjs/loader:1094:15)
        at Module._compile (node:internal/modules/cjs/loader:1129:27)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
        at Module.load (node:internal/modules/cjs/loader:1043:32)
        at Function.Module._load (node:internal/modules/cjs/loader:878:12)
        at Module.require (node:internal/modules/cjs/loader:1067:19)
        at require (node:internal/modules/cjs/helpers:103:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/source-map/lib/source-map-generator.js:8:17)
        at Module._compile (node:internal/modules/cjs/loader:1165:14)
    Thomas BraunT Offline
    @sr277
    cd /opt/iobroker
    npm ls source-map
      @sr277
      cd /opt/iobroker
      npm ls source-map
      SR277
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ npm ls source-map
      iobroker.inst@3.0.0 /opt/iobroker
      ├─┬ iobroker.alexa2@3.12.0
      │ └─┬ source-map-support@0.5.21
      │   └── source-map@0.6.1
      └─┬ iobroker.iot@1.11.5
        └─┬ jsdom@19.0.0
          └─┬ escodegen@2.0.0
            └── source-map@0.6.1 deduped
      • S SR277
          └─┬ jsdom@19.0.0
            └─┬ escodegen@2.0.0
        @sr277
        Lange das System nicht mehr abgestaubt...
        iob stop
        iob fix
        iob restart
          @sr277
          iob stop
          iob fix
          iob restart
          SR277
          pi@raspberrypi:~ $ iob stop
          pi@raspberrypi:~ $ iob fix
          library: loaded
          Library version=2022-12-09
              Welcome to the ioBroker installation fixer!
              Script version: 2022-12-22
              You might need to enter your password a couple of times.
              Installing prerequisites (1/4)
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/4)
              Database maintenance (3/4)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/states.jsonl
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          Compressed 2 JSONL files. Done
              Checking autostart (4/4)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          pi@raspberrypi:~ $ iob restart
          • S SR277
            library: loaded
            Installed gcc-c++
            Autostart enabled!
            @sr277
            iobroker status
              @sr277
              iobroker status
              SR277
              pi@raspberrypi:~ $ iobroker status
               Objects database error: read ECONNRESET
              0 var di'it;
              • S SR277
                0 var di'it;
                @sr277
                Keine Ahnung.
                iob update
                funktioniert vermutlich auch nicht?
                  @sr277
                  Keine Ahnung.
                  iob update
                  SR277
                  Ne das gleiche. :(
                  pi@raspberrypi:~ $ iob update
                  0 var di'it;
                  • S SR277
                    Ne das gleiche. :(
                    0 var di'it;
                    @sr277
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.alexa2
                    sudo -H -u iobroker npm install iobroker.iot
                      @sr277
                      cd /opt/iobroker
                      SR277
                      schrieb am zuletzt editiert von SR277
                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.alexa2
                      npm WARN old lockfile
                      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                      npm WARN old lockfile This is a one-time fix-up, please be patient...
                      added 12 packages, removed 121 packages, and changed 31 packages in 1m
                      137 packages are looking for funding
                        run `npm fund` for details
                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.iot
                      added 2 packages, removed 1 package, and changed 1 package in 13s
                      138 packages are looking for funding
                      Blöde Frage: Wie bekomme ich beim nächsten Befehl das "/opt/iobroker $" wieder weg?
                      • S SR277
                        @sr277
                        iob status
                          @sr277
                          iob status
                          SR277
                          pi@raspberrypi:/opt/iobroker $ iob status
                           States database error: connect ECONNREFUSED 127.0.0.1:9000
                           redis get system.host.raspberrypi.alive, error - Connection is closed.
                           redis get system.host.raspberrypi.plugins.sentry.enabled, error - Connection is closed.
                          0 var di'it;
                          • S SR277
                            0 var di'it;
                            @sr277 sagte in Iobroker startet nicht mehr:
                            warum?
                            da bist du richtig!
                            • S SR277
                              0 var di'it;
                              @sr277
                              ls -lAh /opt/iobroker/iobroker-data/
                              Im Prompt steht der Verzeichnispfad, in dem du dich gerade befindest. Vollkommen korrekt für den Moment.
                                @sr277
                                SR277
                                pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
                                total 53M
                                drwxrwxr-x+  2 iobroker iobroker 4.0K Feb 11  2022 backitup
                                drwxrwxr-x+  2 iobroker iobroker  12K Oct  1 20:53 backup-objects
                                drwxrwxr-x+ 70 iobroker iobroker 4.0K May 13  2022 files
                                -rw-rwxr--+  1 iobroker iobroker 5.0K Feb  8  2022 iobroker.json
                                drwxrwxr-x+  3 iobroker iobroker 4.0K Jan 26  2022 jarvis
                                -rw-rwxr--+  1 iobroker iobroker    3 Jan 15 17:19 notifications.json
                                -rw-rwxr--+  1 iobroker iobroker  14M Feb  8  2022 objects.json.bak.migrated
                                -rw-rw-r--+  1 iobroker iobroker  17M Jan 15 17:19 objects.jsonl
                                -rw-rwxr--+  1 iobroker iobroker  14M Feb  8  2022 objects.json.migrated
                                -rw-rwxr--+  1 iobroker iobroker 2.6M Feb  8  2022 states.json.bak.migrated
                                -rw-rw-r--+  1 iobroker iobroker 4.2M Jan 15 17:19 states.jsonl
                                -rw-rwxr--+  1 iobroker iobroker 2.6M Feb  8  2022 states.json.migrated
                                drwxrwxr-x+  2 iobroker iobroker 4.0K May  1  2022 telegram_0
                                drwxrwxr-x+  3 iobroker iobroker 4.0K Feb  8  2022 tmp
                                • S SR277
                                  total 53M
                                  getfacl /opt/iobroker/iobroker-data/objects.jsonl
                                    SR277
                                    pi@raspberrypi:/opt/iobroker $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
                                    getfacl: Removing leading '/' from absolute path names
                                    # file: opt/iobroker/iobroker-data/objects.jsonl
                                    # owner: iobroker
                                    # group: iobroker
                                    user::rw-
                                    group::r-x                      #effective:r--
                                    group:iobroker:rwx              #effective:rw-
                                    mask::rw-
                                    other::r--
