  4. Iobroker startet nicht mehr
24 Beiträge 3 Kommentatoren 2.7k Aufrufe 2 Beobachtet
    @sr277
    cd /opt/iobroker
    npm ls source-map
    SR277
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ npm ls source-map
    iobroker.inst@3.0.0 /opt/iobroker
    ├─┬ iobroker.alexa2@3.12.0
    │ └─┬ source-map-support@0.5.21
    │   └── source-map@0.6.1
    └─┬ iobroker.iot@1.11.5
      └─┬ jsdom@19.0.0
        └─┬ escodegen@2.0.0
          └── source-map@0.6.1 deduped
    • S SR277
        └─┬ jsdom@19.0.0
          └─┬ escodegen@2.0.0
      Thomas BraunT Offline
      @sr277
      Lange das System nicht mehr abgestaubt...
      iob stop
      iob fix
      iob restart
        @sr277
        iob stop
        iob fix
        iob restart
        SR277
        pi@raspberrypi:~ $ iob stop
        pi@raspberrypi:~ $ iob fix
        library: loaded
        Library version=2022-12-09
            Welcome to the ioBroker installation fixer!
            Script version: 2022-12-22
            You might need to enter your password a couple of times.
            Installing prerequisites (1/4)
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
        Reading package lists... Done
        Installed gcc-c++
            Checking ioBroker user and directory permissions (2/4)
            Database maintenance (3/4)
        Checking for uncompressed JSONL databases... This might take a while!
        Compressing /opt/iobroker/iobroker-data/states.jsonl
        Compressing /opt/iobroker/iobroker-data/objects.jsonl
        Compressed 2 JSONL files. Done
            Checking autostart (4/4)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        pi@raspberrypi:~ $ iob restart
        • S SR277
          library: loaded
          Installed gcc-c++
          Autostart enabled!
          @sr277
          iobroker status
            @sr277
            iobroker status
            SR277
            pi@raspberrypi:~ $ iobroker status
             Objects database error: connect ECONNREFUSED 127.0.0.1:9001
             Objects database error: read ECONNRESET
            Uncaught Rejection: /opt/iobroker/node_modules/source-map/lib/base64-vlq.js:91
            0 var di'it;
            SyntaxError: Unexpected token 'var'
                at Object.compileFunction (node:vm:360:18)
                at wrapSafe (node:internal/modules/cjs/loader:1094:15)
                at Module._compile (node:internal/modules/cjs/loader:1129:27)
                at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                at Module.load (node:internal/modules/cjs/loader:1043:32)
                at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                at Module.require (node:internal/modules/cjs/loader:1067:19)
                at require (node:internal/modules/cjs/helpers:103:18)
                at Object.<anonymous> (/opt/iobroker/node_modules/source-map/lib/source-map-generator.js:8:17)
                at Module._compile (node:internal/modules/cjs/loader:1165:14)
            • S SR277
              0 var di'it;
              @sr277
              Keine Ahnung.
              iob update
              funktioniert vermutlich auch nicht?
                @sr277
                Keine Ahnung.
                iob update
                SR277
                Ne das gleiche. :(
                pi@raspberrypi:~ $ iob update
                0 var di'it;
                • S SR277
                  Ne das gleiche. :(
                  0 var di'it;
                  @sr277
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.alexa2
                  sudo -H -u iobroker npm install iobroker.iot
                    @sr277
                    cd /opt/iobroker
                    SR277
                    schrieb am zuletzt editiert von SR277
                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.alexa2
                    npm WARN old lockfile
                    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                    npm WARN old lockfile This is a one-time fix-up, please be patient...
                    added 12 packages, removed 121 packages, and changed 31 packages in 1m
                    137 packages are looking for funding
                      run `npm fund` for details
                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.iot
                    added 2 packages, removed 1 package, and changed 1 package in 13s
                    138 packages are looking for funding
                    Blöde Frage: Wie bekomme ich beim nächsten Befehl das "/opt/iobroker $" wieder weg?
                    • S SR277
                      @sr277
                      iob status
                        @sr277
                        iob status
                        SR277
                        pi@raspberrypi:/opt/iobroker $ iob status
                         States database error: connect ECONNREFUSED 127.0.0.1:9000
                         redis get system.host.raspberrypi.alive, error - Connection is closed.
                         redis get system.host.raspberrypi.plugins.sentry.enabled, error - Connection is closed.
                        0 var di'it;
                        • S SR277
                          0 var di'it;
                          @sr277 sagte in Iobroker startet nicht mehr:
                          warum?
                          da bist du richtig!
                          • S SR277
                            0 var di'it;
                            @sr277
                            ls -lAh /opt/iobroker/iobroker-data/
                            Im Prompt steht der Verzeichnispfad, in dem du dich gerade befindest. Vollkommen korrekt für den Moment.
                              @sr277
                              SR277
                              pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
                              total 53M
                              drwxrwxr-x+  2 iobroker iobroker 4.0K Feb 11  2022 backitup
                              drwxrwxr-x+  2 iobroker iobroker  12K Oct  1 20:53 backup-objects
                              drwxrwxr-x+ 70 iobroker iobroker 4.0K May 13  2022 files
                              -rw-rwxr--+  1 iobroker iobroker 5.0K Feb  8  2022 iobroker.json
                              drwxrwxr-x+  3 iobroker iobroker 4.0K Jan 26  2022 jarvis
                              -rw-rwxr--+  1 iobroker iobroker    3 Jan 15 17:19 notifications.json
                              -rw-rwxr--+  1 iobroker iobroker  14M Feb  8  2022 objects.json.bak.migrated
                              -rw-rw-r--+  1 iobroker iobroker  17M Jan 15 17:19 objects.jsonl
                              -rw-rwxr--+  1 iobroker iobroker  14M Feb  8  2022 objects.json.migrated
                              -rw-rwxr--+  1 iobroker iobroker 2.6M Feb  8  2022 states.json.bak.migrated
                              -rw-rw-r--+  1 iobroker iobroker 4.2M Jan 15 17:19 states.jsonl
                              -rw-rwxr--+  1 iobroker iobroker 2.6M Feb  8  2022 states.json.migrated
                              drwxrwxr-x+  2 iobroker iobroker 4.0K May  1  2022 telegram_0
                              drwxrwxr-x+  3 iobroker iobroker 4.0K Feb  8  2022 tmp
                              • S SR277
                                total 53M
                                getfacl /opt/iobroker/iobroker-data/objects.jsonl
                                  SR277
                                  pi@raspberrypi:/opt/iobroker $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
                                  getfacl: Removing leading '/' from absolute path names
                                  # file: opt/iobroker/iobroker-data/objects.jsonl
                                  # owner: iobroker
                                  # group: iobroker
                                  user::rw-
                                  group::r-x                      #effective:r--
                                  group:iobroker:rwx              #effective:rw-
                                  mask::rw-
                                  other::r--
