  4. Iobroker startet nicht mehr
24 Beiträge 3 Kommentatoren 2.7k Aufrufe 2 Beobachtet
    @sr277
    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    sagt?
    SR277
    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    pi@raspberrypi:~ $ uname -m &&type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    v14.18.3
    v14.18.3
    6.14.15
    6.14.15
    4.0.23
    pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    tty
    /home/pi
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease
    Reading package lists... Done
    nodejs:
      Installed: 14.18.3-deb-1nodesource1
      Candidate: 14.21.2-deb-1nodesource1
      Version table:
         14.21.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
     *** 14.18.3-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u1 500
    • S SR277
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      v14.18.3
      v14.18.3
      6.14.15
      6.14.15
      4.0.23
      pi
      tty
      /home/pi
      nodejs:
        Version table:
      Thomas BraunT Offline
      @sr277
      Bring das erstmal auf nodeJS@16.
      Siehe meine Signatur.
        @sr277
        SR277
        Das sieht hier schon sehr komisch aus.
        pi@raspberrypi:~ $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
        │ │ │ ├── github-from-package@0.0.0
        │   ├── github-url-from-git@1.5.0
        │   ├─┬ new-github-release-url@1.0.0
        npm ERR! peer dep missing: @types/express@^4.17.13, required by http-proxy-middleware@2.0.2
        npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
        • S SR277
          @sr277
          Nö, alles i. O.
            @sr277
            Nö, alles i. O.
            SR277
            schrieb am zuletzt editiert von SR277
            So habe es installiert.
            pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            /usr/bin/npx
            v16.19.0
            v16.19.0
            8.19.3
            8.19.3
            4.0.23
            pi
            tty
            /home/pi
            Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
            nodejs:
              Installed: 16.19.0-deb-1nodesource1
              Candidate: 16.19.0-deb-1nodesource1
              Version table:
             *** 16.19.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
            Fehler besteht aber weiterhin:
            pi@raspberrypi:~ $ iob start admin
             Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            Uncaught Rejection: /opt/iobroker/node_modules/source-map/lib/base64-vlq.js:91
            0 var di'it;
            SyntaxError: Unexpected token 'var'
                at Object.compileFunction (node:vm:360:18)
                at wrapSafe (node:internal/modules/cjs/loader:1094:15)
                at Module._compile (node:internal/modules/cjs/loader:1129:27)
                at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                at Module.load (node:internal/modules/cjs/loader:1043:32)
                at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                at Module.require (node:internal/modules/cjs/loader:1067:19)
                at require (node:internal/modules/cjs/helpers:103:18)
                at Object.<anonymous> (/opt/iobroker/node_modules/source-map/lib/source-map-generator.js:8:17)
                at Module._compile (node:internal/modules/cjs/loader:1165:14)
            • S SR277
              armv7l
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              /usr/bin/npx
              v16.19.0
              v16.19.0
              8.19.3
              8.19.3
              4.0.23
              pi
              tty
              /home/pi
              nodejs:
                Version table:
              0 var di'it;
              @sr277
              cd /opt/iobroker
              npm ls source-map
                @sr277
                cd /opt/iobroker
                npm ls source-map
                SR277
                pi@raspberrypi:/opt/iobroker $ npm ls source-map
                iobroker.inst@3.0.0 /opt/iobroker
                ├─┬ iobroker.alexa2@3.12.0
                │ └─┬ source-map-support@0.5.21
                │   └── source-map@0.6.1
                └─┬ iobroker.iot@1.11.5
                  └─┬ jsdom@19.0.0
                    └─┬ escodegen@2.0.0
                      └── source-map@0.6.1 deduped
                • S SR277
                    └─┬ jsdom@19.0.0
                      └─┬ escodegen@2.0.0
                  @sr277
                  Lange das System nicht mehr abgestaubt...
                  iob stop
                  iob fix
                  iob restart
                    @sr277
                    iob stop
                    iob fix
                    iob restart
                    SR277
                    pi@raspberrypi:~ $ iob stop
                    pi@raspberrypi:~ $ iob fix
                    library: loaded
                    Library version=2022-12-09
                        Welcome to the ioBroker installation fixer!
                        Script version: 2022-12-22
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/4)
                    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Installed gcc-c++
                        Checking ioBroker user and directory permissions (2/4)
                        Database maintenance (3/4)
                    Checking for uncompressed JSONL databases... This might take a while!
                    Compressing /opt/iobroker/iobroker-data/states.jsonl
                    Compressing /opt/iobroker/iobroker-data/objects.jsonl
                    Compressed 2 JSONL files. Done
                        Checking autostart (4/4)
                    Enabling autostart...
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    pi@raspberrypi:~ $ iob restart
                    • S SR277
                      library: loaded
                      Installed gcc-c++
                      Autostart enabled!
                      @sr277
                      iobroker status
                        @sr277
                        iobroker status
                        SR277
                        pi@raspberrypi:~ $ iobroker status
                         Objects database error: read ECONNRESET
                        0 var di'it;
                        • S SR277
                          0 var di'it;
                          @sr277
                          Keine Ahnung.
                          iob update
                          funktioniert vermutlich auch nicht?
                            @sr277
                            Keine Ahnung.
                            iob update
                            SR277
                            Ne das gleiche. :(
                            pi@raspberrypi:~ $ iob update
                            0 var di'it;
                            • S SR277
                              Ne das gleiche. :(
                              0 var di'it;
                              @sr277
                              cd /opt/iobroker
                              sudo -H -u iobroker npm install iobroker.alexa2
                              sudo -H -u iobroker npm install iobroker.iot
                                @sr277
                                cd /opt/iobroker
                                SR277
                                pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.alexa2
                                npm WARN old lockfile
                                npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                npm WARN old lockfile This is a one-time fix-up, please be patient...
                                added 12 packages, removed 121 packages, and changed 31 packages in 1m
                                137 packages are looking for funding
                                  run `npm fund` for details
                                pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.iot
                                added 2 packages, removed 1 package, and changed 1 package in 13s
                                138 packages are looking for funding
                                Blöde Frage: Wie bekomme ich beim nächsten Befehl das "/opt/iobroker $" wieder weg?
                                • S SR277
                                  @sr277
                                  iob status
                                    @sr277
                                    iob status
                                    SR277
                                    pi@raspberrypi:/opt/iobroker $ iob status
                                     States database error: connect ECONNREFUSED 127.0.0.1:9000
                                     redis get system.host.raspberrypi.alive, error - Connection is closed.
                                     redis get system.host.raspberrypi.plugins.sentry.enabled, error - Connection is closed.
                                    0 var di'it;
                                    • S SR277
                                      0 var di'it;
                                      @sr277 sagte in Iobroker startet nicht mehr:
                                      warum?
                                      da bist du richtig!
                                      • S SR277
                                        0 var di'it;
                                        @sr277
                                        ls -lAh /opt/iobroker/iobroker-data/
                                        Im Prompt steht der Verzeichnispfad, in dem du dich gerade befindest. Vollkommen korrekt für den Moment.
                                          @sr277
                                          SR277
                                          pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
                                          total 53M
                                          drwxrwxr-x+  2 iobroker iobroker 4.0K Feb 11  2022 backitup
                                          drwxrwxr-x+  2 iobroker iobroker  12K Oct  1 20:53 backup-objects
                                          drwxrwxr-x+ 70 iobroker iobroker 4.0K May 13  2022 files
                                          -rw-rwxr--+  1 iobroker iobroker 5.0K Feb  8  2022 iobroker.json
                                          drwxrwxr-x+  3 iobroker iobroker 4.0K Jan 26  2022 jarvis
                                          -rw-rwxr--+  1 iobroker iobroker    3 Jan 15 17:19 notifications.json
                                          -rw-rwxr--+  1 iobroker iobroker  14M Feb  8  2022 objects.json.bak.migrated
                                          -rw-rw-r--+  1 iobroker iobroker  17M Jan 15 17:19 objects.jsonl
                                          -rw-rwxr--+  1 iobroker iobroker  14M Feb  8  2022 objects.json.migrated
                                          -rw-rwxr--+  1 iobroker iobroker 2.6M Feb  8  2022 states.json.bak.migrated
                                          -rw-rw-r--+  1 iobroker iobroker 4.2M Jan 15 17:19 states.jsonl
                                          -rw-rwxr--+  1 iobroker iobroker 2.6M Feb  8  2022 states.json.migrated
                                          drwxrwxr-x+  2 iobroker iobroker 4.0K May  1  2022 telegram_0
                                          drwxrwxr-x+  3 iobroker iobroker 4.0K Feb  8  2022 tmp
