  4. Iobroker startet nicht mehr
    3.2k
    3.1k
24 Beiträge 3 Kommentatoren 2.5k Aufrufe 2 Beobachtet
    SR277
    leider habe ich keinen Zugriff mehr auf den Iobroker. Kann mir jemand helfen?
    Danke schonmal!
    code_text
    ```pi@raspberrypi:~ $ iob start admin
    Uncaught Rejection: /opt/iobroker/node_modules/source-map/lib/base64-vlq.js:91
    0 var di'it;
    SyntaxError: Unexpected token 'var'
        at wrapSafe (internal/modules/cjs/loader.js:1001:16)
        at Module._compile (internal/modules/cjs/loader.js:1049:27)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
        at Module.load (internal/modules/cjs/loader.js:950:32)
        at Function.Module._load (internal/modules/cjs/loader.js:790:12)
        at Module.require (internal/modules/cjs/loader.js:974:19)
        at require (internal/modules/cjs/helpers.js:93:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/source-map/lib/source-map-generator.js:8:17)
        at Module._compile (internal/modules/cjs/loader.js:1085:14)
    • S SR277
      Danke schonmal!
      code_text
      0 var di'it;
      @sr277
      sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
      uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
      sagt?
        @sr277
        sagt?
        SR277
        pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
        pi@raspberrypi:~ $ uname -m &&type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        /usr/bin/npx
        v14.18.3
        v14.18.3
        6.14.15
        6.14.15
        4.0.23
        pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
        tty
        /home/pi
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease
        Reading package lists... Done
        nodejs:
          Installed: 14.18.3-deb-1nodesource1
          Candidate: 14.21.2-deb-1nodesource1
          Version table:
             14.21.2-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
         *** 14.18.3-deb-1nodesource1 100
             12.22.12~dfsg-1~deb11u1 500
        • S SR277
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          /usr/bin/npx
          v14.18.3
          v14.18.3
          6.14.15
          6.14.15
          4.0.23
          pi
          tty
          /home/pi
          nodejs:
            Version table:
          @sr277
          Bring das erstmal auf nodeJS@16.
          Siehe meine Signatur.
            @sr277
            SR277
            Das sieht hier schon sehr komisch aus.
            pi@raspberrypi:~ $ cd /opt/iobroker
            pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
            │ │ │ ├── github-from-package@0.0.0
            │   ├── github-url-from-git@1.5.0
            │   ├─┬ new-github-release-url@1.0.0
            npm ERR! peer dep missing: @types/express@^4.17.13, required by http-proxy-middleware@2.0.2
            npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
            • S SR277
              @sr277
              Nö, alles i. O.
                @sr277
                Nö, alles i. O.
                SR277
                schrieb am zuletzt editiert von SR277
                So habe es installiert.
                pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                /usr/bin/npx
                v16.19.0
                v16.19.0
                8.19.3
                8.19.3
                4.0.23
                pi
                tty
                /home/pi
                Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                nodejs:
                  Installed: 16.19.0-deb-1nodesource1
                  Candidate: 16.19.0-deb-1nodesource1
                  Version table:
                 *** 16.19.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                Fehler besteht aber weiterhin:
                 Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                0 var di'it;
                    at Object.compileFunction (node:vm:360:18)
                    at wrapSafe (node:internal/modules/cjs/loader:1094:15)
                    at Module._compile (node:internal/modules/cjs/loader:1129:27)
                    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                    at Module.load (node:internal/modules/cjs/loader:1043:32)
                    at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                    at Module.require (node:internal/modules/cjs/loader:1067:19)
                    at require (node:internal/modules/cjs/helpers:103:18)
                    at Module._compile (node:internal/modules/cjs/loader:1165:14)
                • S SR277
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  /usr/bin/npx
                  v16.19.0
                  v16.19.0
                  8.19.3
                  8.19.3
                  4.0.23
                  pi
                  tty
                  /home/pi
                  nodejs:
                    Version table:
                  0 var di'it;
                  @sr277
                  cd /opt/iobroker
                  npm ls source-map
                    @sr277
                    cd /opt/iobroker
                    npm ls source-map
                    SR277
                    pi@raspberrypi:/opt/iobroker $ npm ls source-map
                    iobroker.inst@3.0.0 /opt/iobroker
                    ├─┬ iobroker.alexa2@3.12.0
                    │ └─┬ source-map-support@0.5.21
                    │   └── source-map@0.6.1
                    └─┬ iobroker.iot@1.11.5
                      └─┬ jsdom@19.0.0
                        └─┬ escodegen@2.0.0
                          └── source-map@0.6.1 deduped
                    • S SR277
                        └─┬ jsdom@19.0.0
                          └─┬ escodegen@2.0.0
                      @sr277
                      Lange das System nicht mehr abgestaubt...
                      iob stop
                      iob fix
                      iob restart
                        @sr277
                        iob stop
                        iob fix
                        iob restart
                        SR277
                        pi@raspberrypi:~ $ iob stop
                        pi@raspberrypi:~ $ iob fix
                        library: loaded
                        Library version=2022-12-09
                            Welcome to the ioBroker installation fixer!
                            Script version: 2022-12-22
                            You might need to enter your password a couple of times.
                            Installing prerequisites (1/4)
                        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Installed gcc-c++
                            Checking ioBroker user and directory permissions (2/4)
                            Database maintenance (3/4)
                        Checking for uncompressed JSONL databases... This might take a while!
                        Compressing /opt/iobroker/iobroker-data/states.jsonl
                        Compressing /opt/iobroker/iobroker-data/objects.jsonl
                        Compressed 2 JSONL files. Done
                            Checking autostart (4/4)
                        Enabling autostart...
                        Autostart enabled!
                            Your installation was fixed successfully
                            Run iobroker start to start ioBroker again!
                        pi@raspberrypi:~ $ iob restart
                        • S SR277
                          library: loaded
                          Installed gcc-c++
                          Autostart enabled!
                          @sr277
                          iobroker status
                            @sr277
                            iobroker status
                            SR277
                            pi@raspberrypi:~ $ iobroker status
                             Objects database error: read ECONNRESET
                            0 var di'it;
                            • S SR277
                              0 var di'it;
                              @sr277
                              Keine Ahnung.
                              iob update
                              funktioniert vermutlich auch nicht?
                                @sr277
                                Keine Ahnung.
                                iob update
                                SR277
                                Ne das gleiche. :(
                                pi@raspberrypi:~ $ iob update
                                0 var di'it;
                                • S SR277
                                  Ne das gleiche. :(
                                  0 var di'it;
                                  @sr277
                                  cd /opt/iobroker
                                  sudo -H -u iobroker npm install iobroker.alexa2
                                  sudo -H -u iobroker npm install iobroker.iot
                                    @sr277
                                    cd /opt/iobroker
                                    SR277
                                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.alexa2
                                    npm WARN old lockfile
                                    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                    npm WARN old lockfile This is a one-time fix-up, please be patient...
                                    added 12 packages, removed 121 packages, and changed 31 packages in 1m
                                    137 packages are looking for funding
                                      run `npm fund` for details
                                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.iot
                                    added 2 packages, removed 1 package, and changed 1 package in 13s
                                    138 packages are looking for funding
                                    Blöde Frage: Wie bekomme ich beim nächsten Befehl das "/opt/iobroker $" wieder weg?
                                    • S SR277
                                      @sr277
                                      iob status
                                        @sr277
                                        iob status
                                        SR277
                                        pi@raspberrypi:/opt/iobroker $ iob status
                                         States database error: connect ECONNREFUSED 127.0.0.1:9000
                                         redis get system.host.raspberrypi.alive, error - Connection is closed.
                                         redis get system.host.raspberrypi.plugins.sentry.enabled, error - Connection is closed.
                                        0 var di'it;
                                        • S SR277
                                          0 var di'it;
                                          HomoranH Offline
                                          HomoranH Offline
                                          @sr277 sagte in Iobroker startet nicht mehr:
                                          warum?
                                          da bist du richtig!
