  4. Wasserzähler - Version 2 - all-in-device
wasserzählerversion 2ai on the edgecnnwater meterwater gaugeesp32ov2640neuronale netzehausautomatisierung
3.4k Beiträge 240 Kommentatoren 2.4m Aufrufe 231 Beobachtet
  • M muschelman
    @esp8266 , ich habe jetzt noch einiges probiert, bin aber noch nicht zu einer Lösung gekommen. Als ich das Flash-Tool benutzt habe, ergab sich im Anschluss eine Reboot-Schleife. Deshalb habe ich dies auch noch über das esptool probiert:
    C:\Temp\esp32cam\esptool-v4.4-win64>esptool.exe --port COM5 erase_flash
    esptool.py v4.4
    Serial port COM5
    Connecting....
    Detecting chip type... Unsupported detection protocol, switching and trying again...
    Connecting.....
    Detecting chip type... ESP32
    Chip is ESP32-D0WD-V3 (revision v3.0)
    Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
    Crystal is 40MHz
    MAC: 40:22:d8:76:0c:d8
    Uploading stub...
    Running stub...
    Stub running...
    Erasing flash (this may take a while)...
    Chip erase completed successfully in 3.6s
    Hard resetting via RTS pin...
    C:\Temp\esp32cam\esptool-v4.4-win64>esptool.exe --port COM5 write_flash 0x01000 bootloader.bin 0x08000 partitions.bin 0x10000 firmware.bin
    esptool.py v4.4
    Serial port COM5
    Connecting....
    Connecting....
    Crystal is 40MHz
    Uploading stub...
    Running stub...
    Stub running...
    Configuring flash size...
    Flash will be erased from 0x00001000 to 0x00007fff...
    Flash will be erased from 0x00008000 to 0x00008fff...
    Flash will be erased from 0x00010000 to 0x001dcfff...
    Compressed 26864 bytes to 16248...
    Wrote 26864 bytes (16248 compressed) at 0x00001000 in 1.6 seconds (effective 132.7 kbit/s)...
    Hash of data verified.
    Compressed 3072 bytes to 128...
    Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 659.8 kbit/s)...
    Compressed 1887344 bytes to 1146250...
    Wrote 1887344 bytes (1146250 compressed) at 0x00010000 in 101.0 seconds (effective 149.5 kbit/s)...
    Leaving...
    Aber dies führte ebenfalls zu einer Reebot-Schleife:
    rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0xee
    clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    mode:DIO, clock div:2
    load:0x3fff0030,len:7664
    load:0x40078000,len:15360
    load:0x40080400,len:3744
    entry 0x4008067c
    I (27) boot: ESP-IDF 4.3.2 2nd stage bootloader
    I (27) boot: compile time 20:02:47
    I (27) boot: chip revision: 3
    I (30) boot_comm: chip revision: 3, min. bootloader chip revision: 0
    I (37) boot.esp32: SPI Speed      : 40MHz
    I (42) boot.esp32: SPI Mode       : DIO
    I (46) boot.esp32: SPI Flash Size : 4MB
    I (51) boot: Enabling RNG early entropy source...
    I (56) boot: Partition Table:
    I (60) boot: ## Label            Usage          Type ST Offset   Length
    I (67) boot:  0 nvs              WiFi data        01 02 00009000 00004000
    I (74) boot:  1 otadata          OTA data         01 00 0000d000 00002000
    I (82) boot:  2 phy_init         RF data          01 01 0000f000 00001000
    I (89) boot:  3 ota_0            OTA app          00 10 00010000 001db000
    I (97) boot:  4 ota_1            OTA app          00 11 001f0000 001db000
    I (104) boot: End of partition table
    I (109) boot_comm: chip revision: 3, min. application chip revision: 0
    I (116) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=4df30h (319280) map
    I (247) esp_image: segment 1: paddr=0005df58 vaddr=3ffb0000 size=020c0h (  8384) load
    I (250) esp_image: segment 2: paddr=00060020 vaddr=400d0020 size=15e00ch (1433612) map
    I (801) esp_image: segment 3: paddr=001be034 vaddr=3ffb20c0 size=029f8h ( 10744) load
    I (806) esp_image: segment 4: paddr=001c0a34 vaddr=40080000 size=1c1f4h (115188) load
    I (856) esp_image: segment 5: paddr=001dcc30 vaddr=50000000 size=00010h (    16) load
    I (871) boot: Loaded app from partition at offset 0x10000
    I (871) boot: Disabling RNG early entropy source...
    I (883) psram: This chip is ESP32-D0WD
    E (883) psram: PSRAM ID read error: 0xffffffff
    E (883) cpu_start: Failed to init external RAM!
    Re-enable cpu cache.
    abort() was called at PC 0x40082dcf on core 0
    Backtrace:0x40082c65:0x3ffe3ba0 0x4008f70d:0x3ffe3bc0 0x40096991:0x3ffe3be0 0x40082dcf:0x3ffe3c50 0x4007956d:0x3ffe3c80 |<-CORRUPTED
    ELF file SHA256: 28356ed42df4c694
    Rebooting...
    Die einzige Methode, wie ich es überhaupt hin bekomme, dass der ESP auf Port 80 reagiert, ist der Web-Installer. Aber dort kommen dann halt die Meldungen aus dem letzten Post. Für weitere Hinweise wäre ich sehr dankbar.
    ESP8266E Offline
    ESP8266E Offline
    ESP8266
    schrieb am zuletzt editiert von ESP8266
    #2616
    @muschelman , die Reset Taste drückst du aber nach dem Flashen...oder?
    Auch schon einmal versucht ein WebServer drauf zu flashen?
    Das sind die Fehler aus deinem Log:
    E (10324) psram: PSRAM ID read error: 0xffffffff
    E (10324) spiram: SPI RAM enabled but initialization failed. Bailing out.
    E (10334) MAIN: Failed to initialize PSRAM (-1)!
    E (10344) MAIN: Either your device misses the PSRAM chip or it is broken!
    E (10354) HELPER: New System Status: 0x00000001
    E (10364) MAIN: Not enough Heap memory available. Expected around 4 MBytes, but only 89168 Bytes are available! That is not enough for this firmware!
    E (10374) HELPER: New System Status: 0x00000003
    Es sieht wirklich danach aus, als wäre deine Hardware inkompatibel oder defekt.
    Das habe ich bei keiner meiner 4 Cams gehabt.
    Was wird bloß noch für ein Schrott verkauft!?
    • E Offline
      exitus
      #2617
      hallo
      seit dem ich das neueste firmware dauert das Laden und konfrigation sehr lange und die web oberfläche ist ganz anders woran kann es liegen habe auch die neue HTML dateien auch drauf
      ESP8266E 1 Antwort Letzte Antwort
      • E exitus
        hallo
        ESP8266E Offline
        ESP8266E Offline
        ESP8266
        #2618
        @exitus , man muss nicht immer das neuste drauf machen. Meistens sind die noch in Alpha Stadium. Ich nutzte noch die "master - v11.3.0 - 2022-09-16" und die läuft bei mir Ast Rein.
        Nenne mir Gründe um den Stand nach oben zu upgraden?
        Hier im Thread wurde schon davon berichtet, das die neuste Firmware lahm ist. Bei dir wurde die Webseite noch nicht richtig aufgebaut. Was verlangt man denn von dem überlasteten ESP32 überhaupt? Der läuft teilweise über sein Grenzen hinaus....
        • ESP8266E ESP8266
          exitus
          schrieb am zuletzt editiert von exitus
          #2619
          @esp8266 du hast recht bei mir lief die 10.5.2 gut mache es wieder rückgängig.
          finde aber das relase 11.3.0 nicht & welche html version sollte man nehmen ???
          • E exitus
            ESP8266E Offline
            ESP8266E Offline
            ESP8266
            #2620
            @exitus ,
            Dann nimm die v11.3.1, oder was anderes. Deine Sache....
            Meine HTML version war auch aus September.
            • B bitwicht
              Hallo zusammen.
              Heute sind neue ESP32 CAM Platinen angekommen.
              Optisch sehen sie aus wie die erste Bestellung.
              Beim Flashen aber ein unterschied.
              ESP32-CAM Chip Revision 3 = gehen nicht (starten nicht)
              ESP32-CAM Chip Revision 1 = gehen !!!!
              Das als Hilfestellung.
              Vielleicht kann man die Info "prominenter" stellen.
              Bit
              muschelman
              #2621
              @ESP8266 ich glabe ich habe den Beitrag gefunden, welchen du meintest:
              @bitwicht said in Wasserzähler - Version 2 - all-in-device:
              Hallo zusammen.
              Hat jemand einen Tipp wie ich die Revision ermittle? Steht das irgendwo auf dem Chip, oder kann man das irgendwie abfragen?
              ESP8266E David G.D 2 Antworten Letzte Antwort
              • M muschelman
                Hallo zusammen.
                ESP8266E Offline
                ESP8266E Offline
                ESP8266
                #2622
                @muschelman , das steht in der Wiki.
                https://github.com/jomjol/AI-on-the-edge-device/wiki/Hardware-Compatibility
                Noch was dazu, solche Dinge kaufe ich bei einem deutschen Händler. Auch wenn es ein paar Groschen teurer ist. Ich habe aber dann das Umtauschrecht. Einen Chinamann des Vertauens habe ich zwar auch und wurde dort noch nie angeschissen. Aber die Dinger kaufe ich trotzdem nicht, da es zu viele Unterschiede (auch Fakes) in der Produktion gibt.
                • M muschelman
                  Hallo zusammen.
                  David G.D Online
                  David G.D Online
                  David G.
                  #2623
                  @muschelman sagte in Wasserzähler - Version 2 - all-in-device:
                  Vermute mal, dass es diese Zeile aus deinem Log ist:
                    smarthomeNew
                    schrieb am zuletzt editiert von smarthomeNew
                    #2624
                    Hallo, vielen Dank für dieses super tolle Projekt! Der Hammer. Funktioniert Tip top.
                    Kleine Inspiration für alle, die keinen 3D Drucker fürs Gehäuse haben.
                    Ein 500 g Joghurtbecher passt bei mir perfekt. Habe oben ein Loch für die Kamera reingebohrt und das ganze dann mit schwarzem Gewebeband umwickelt.
                    Die Platine und Kamera habe ich in einem Batteriegehäuse (die Plastikhalterungen für die Batterien mit der Zange rausgebrochen) untergebracht.
                    • S smarthomeNew
                      David G.D Online
                      David G.D Online
                      David G.
                      #2625
                      @smarthomenew
                      Das stimmt.
                      Man muss nur was kreativ sein.
                      Bei mir ist es eine zugeschnittene Plastikflasche.
                      Zugeschnitten sitzt die richtig stabil.
                      Mittlerweile gibt's noch nen schicken Deckel.
                      • E Offline
                        exitus
                        #2626
                        Hallo hate jemand ein Tipp wie ich vom Wasserzähler zu MQTT die Zahl ohne Punkt schicken kann zb.
                        660.3798 zb. so 6603798
                        J S 2 Antworten Letzte Antwort
                        • ESP8266E Offline
                          ESP8266E Offline
                          ESP8266
                          #2627
                          @exitus , glaube kaum das dies so möglich ist. Der Dot (eigentlich ein Komma) gehört auch dort hin und trennt die Digitalen von den Analogen. Wie es auf Wasseruhren üblich ist. Vollkommen Plausibel das ganze. Weswegen man dort kein Punkt haben möchte ist mir nicht klar. Aber das soll jeder nach seinen Wünschen selber machen. Dann musste dir ein Script basteln, der dies ohne Punkt errechnet.
                          Falsche Brille auf....😊
                          • E exitus
                            JoergH
                            #2628
                            @exitus sagte in Wasserzähler - Version 2 - all-in-device:
                            In der Configuration kann man doch das Komma verschieben. Schon mal probiert es ganz nach rechts zu schieben?
                            • J JoergH
                              ESP8266E Offline
                              ESP8266E Offline
                              ESP8266
                              #2629
                              @joergh , damit verschiebt er nur den Punkt. Verschwindet aber nicht und es kommen unplausible Ergebnisse zu Tage.
                              W 1 Antwort Letzte Antwort
                              • ESP8266E ESP8266
                                W Offline
                                W Offline
                                westphh
                                #2630
                                @Joerg-H Ich lese nur die Digital ROIs aus. Da gibt es ja keine Kommastellen. Für die Überwachung reichen für mich die Kubikmeter. Die werden ja auch nur mit den Versorgern abgerechnet,
                                • ESP8266E ESP8266
                                  exitus
                                  #2631
                                  @esp8266 hast recht wollte nur wegen kosten Rechnung es haben , sourceanalytix haben weil das umrechnen nicht klappt habe es mit script erledigt
                                  • E exitus
                                    smarthomeNew
                                    #2632
                                    @exitus mit einem Alias und Konvertierung (Zahl multiplizieren mit z.B. 1000) kannst du das Komma wegbekommen
                                    • E Offline
                                      exitus
                                      #2633
                                      Hallo
                                      gibt es eine möglichkeit wlan zu verstärken oder eine fertige 32cam mit anntene die kompatibel ist??
                                      • ESP8266E Offline
                                        ESP8266E Offline
                                        ESP8266
                                        #2634
                                        @exitus , wie soll denn das Wlan verstärkt werden? Die Dinger senden nur im Normbereich, alles andere wäre illegal. Setz ein Repeater da neben. Das geht auch. Oder...
                                        Die ESP32 Cam besitzt einen Ipex Anschluß, daran kann man jede beliebige Wlan-Antenne anschließen. Such dir einen Anbieter der die 0 Ohm Brücke für einen kleinen Aufpreis gleich mit umlötet, wenn du nicht löten kannst.
                                        Die Dinger gibt es als Set mit MB und Antenne. Aber die Buchse ist noch nicht Aktiv geschaltet.
                                        • C Offline
                                          C4nc3r 0
                                          #2635
                                          ich würde das Projekt auch sehr gerne umsetzten. Finde die Idee dahinter richtig cool. Ich habe nur folgendes Problem:
                                          Ich habe mittlerweile 6 verschiedene ESPs gekauft und jedes mal bekommen ich folgende Meldung nach dem Flashen. Mache ich etwas falsch?
                                          Habe mir unterschiedliche Youtoube Videos angeschaut und auch die ESP aus den Verlinkungen bestellt.
                                          [0d00h00m11s] 2023-01-14T14:31:49 <INF> [SNTP] Time is synced with NTP Server pool.ntp.org
                                          [0d00h00m11s] 2023-01-14T15:31:49 <INF> [SNTP] Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                                          [0d00h00m11s] 2023-01-14T15:31:49 <INF> [MAIN] =================================================
                                          [0d00h00m11s] 2023-01-14T15:31:49 <INF> [MAIN] ================== Main Started =================
                                          [0d00h00m11s] 2023-01-14T15:31:49 <WRN> [MAIN] Web UI version (?) does not match firmware version (04f2f23+) !
                                          [0d00h00m11s] 2023-01-14T15:31:49 <ERR> [MAIN] Failed to initialize PSRAM (-1)!
                                          [0d00h00m11s] 2023-01-14T15:31:49 <ERR> [MAIN] Either your device misses the PSRAM chip or it is broken!
                                          [0d00h00m11s] 2023-01-14T15:31:49 <ERR> [HELPER] New System Status: 0x00000001
                                          [0d00h00m11s] 2023-01-14T15:31:49 <ERR> [MAIN] Not enough Heap memory available. Expected around 4 MBytes, but only 89300 Bytes are available! That is not enough for this firmware!
                                          [0d00h00m11s] 2023-01-14T15:31:49 <ERR> [HELPER] New System Status: 0x00000003
                                          [0d00h00m13s] 2023-01-14T15:31:51 <ERR> [MAIN] Initialization failed. Not starting flows!
                                          [0d00h01m05s] 2023-01-14T15:32:42 <ERR> [MAIN SERVER] We have a critical error, not serving main page!
