  5. Smarter - Handtuchtrockner
26 Beiträge 4 Kommentatoren 1.5k Aufrufe 3 Beobachtet
    @humidor sagte: noch eine Info?
    Nein.
    Zur Verwendung von Variablen habe ich bereits geschrieben.
     <variables>
       <variable id="KD:P[N/_4z@jQ6}[4|~Y">HzgBadButtonAktiviert</variable>
       <variable id="J[g|q0WcCQ$lG(S|TP`p">steckdose</variable>
       <variable id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</variable>
     </variables>
     <block type="comment" id="m|fsyw%~z-7@{pQ@klZ|" x="-238" y="90">
       <field name="COMMENT">Hzg Bad</field>
       <next>
         <block type="on_ext" id="WmaDlVza-%|bE2PC4}$}">
           <value name="OID0">
             <shadow type="field_oid" id="(K%m+UU(oymx/#ZG.8s3">
               <field name="oid">0_userdata.0.AMIS.PVÜberschuss</field>
             </shadow>
           </value>
           <statement name="STATEMENT">
             <block type="controls_if" id="!:6IVLh(.s7Zc7*X2PKe">
               <value name="IF0">
                 <block type="logic_negate" id="K~rgK;sALe4{c~Ujl-i6">
                   <value name="BOOL">
                     <block type="variables_get" id="]y;likc+U,w(YnZm}|~">
                       <field name="VAR" id="KD:P[N/_4z@jQ6}[4|~Y">HzgBadButtonAktiviert</field>
                     </block>
                   </value>
                 </block>
               </value>
               <statement name="DO0">
                 <block type="controls_if" id="h2[afer[}5V$)v@slP7p">
                   <value name="IF0">
                     <block type="logic_operation" id="DW7F}t8zu~$_G8Pa(3e" inline="false">
                       <field name="OP">AND</field>
                       <value name="A">
                         <block type="logic_compare" id="n=Zb^9u~JGi|Z-2qlih">
                           <field name="OP">LT</field>
                           <value name="A">
                             <block type="get_value" id="RO$ii/.eX+hbu0jJElK1">
                               <field name="OID">fritzdect.0.DECT_116300118701.celsius</field>
                             </block>
                           </value>
                           <value name="B">
                             <block type="math_number" id="n|%GCJ*$Tgl4!/hO)HO">
                               <field name="NUM">22</field>
                             </block>
                           </value>
                         </block>
                       </value>
                       <value name="B">
                         <block type="logic_compare" id="UUL3U=9eId#Q,LtbX:V2">
                           <field name="OP">GT</field>
                           <value name="A">
                             <block type="on_source" id="^Zw6;J3NM.=o_QHIfeVw">
                             </block>
                           </value>
                           <value name="B">
                             <block type="math_number" id="Zc~cW;[({xEj*S-%?x4O">
                               <field name="NUM">1200</field>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                     <block type="variables_set" id="Y:uXk([@33O|*EcEvZC-">
                       <field name="VAR" id="J[g|q0WcCQ$lG(S|TP`p">steckdose</field>
                       <value name="VALUE">
                         <block type="logic_boolean" id="k8#sut0s2709:o.nhIS?">
                         </block>
                       </value>
                       <next>
                         <block type="variables_set" id="=XNnI:dF{iPZY{5-gz{%">
                           <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field>
                             <block type="logic_boolean" id="4s?8X2O{mv4dkx!lU;tL">
                             </block>
                           </value>
                         </block>
                       </next>
                     </block>
                   </statement>
                   <value name="IF1">
                     <block type="logic_compare" id="m![RY(f3FtDyAKVqo9Tx">
                       <field name="OP">LTE</field>
                       <value name="A">
                         <block type="on_source" id="PS1t9L#xZ;x(@eHHP10#">
                         </block>
                       </value>
                       <value name="B">
                         <block type="math_number" id="OzBUgjtn~Ed/)o1mWRp">
                           <field name="NUM">0</field>
                         </block>
                       </value>
                     </block>
                   </value>
                   <statement name="DO1">
                     <block type="variables_set" id="/+d#QA(l.c`6Nd.m51_z">
                         <block type="logic_boolean" id="c*Cyjv-G,I3+W|`.#P[a">
                         </block>
                       </value>
                     </block>
                   </statement>
                   <next>
                     <block type="controls_if" id="})tCgv{wBfQw97dX@Xuv">
                       <value name="IF0">
                         <block type="logic_compare" id="TLk|}7X@Qvtl_+?c0n?9">
                           <field name="OP">NEQ</field>
                           <value name="A">
                             <block type="variables_get" id="mR*@R~HWo[L/u1(%D+F:">
                             </block>
                           </value>
                           <value name="B">
                             <block type="get_value" id="KK{JE3@|BkciE$J.kqh">
                               <field name="OID">fritzdect.0.DECT_116300118701.state</field>
                             </block>
                           </value>
                         </block>
                       </value>
                         <block type="control" id="eP7[z/)zQ@T,2a?:Lg6I">
                             <block type="variables_get" id="3;,,Rl..U.T0K`wISUX=">
                             </block>
                           </value>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </statement>
           <next>
             <block type="on" id=",{!!mR4nS4Q$NTlsUW,$">
                 <block type="controls_if" id="plWmx0U+JD:-qOK9v0_p">
                   <value name="IF0">
                     <block type="logic_negate" id="BaJxudKyZ{cTc`wx43.Y">
                       <value name="BOOL">
                         <block type="on_source" id="~yBgynYAtE{~NXHsVeuA">
                         </block>
                       </value>
                     </block>
                   </value>
                     <block type="variables_set" id="X=d18E?zu0fn:~a^N5g]">
                         <block type="logic_boolean" id="x$~YvVoggOL:j%:-TCk">
                         </block>
                       </value>
                       <next>
                         <block type="variables_set" id="gR)1K=HLZ:9nGMvrBmi!">
                             <block type="logic_boolean" id="4u_b=$jq?u6pPc{R~LHL">
                             </block>
                           </value>
                         </block>
                       </next>
                     </block>
                   </statement>
                   <value name="IF1">
                     <block type="logic_negate" id="8gfsgQ[.HE*?Dj}KtS+">
                       <value name="BOOL">
                         <block type="variables_get" id="9vFK#z{rQXnRH_pyLsz">
                         </block>
                       </value>
                     </block>
                   </value>
                     <block type="variables_set" id="tY.{vp+,c/t}#oMfS]%P">
                         <block type="logic_boolean" id="+^XozkhgT@Hd+7)pS97H">
                         </block>
                       </value>
                     </block>
                   </statement>
                 </block>
               </statement>
             </block>
           </next>
         </block>
       </next>
     </block>
    </xml>
    HumidorH Offline
    HumidorH Offline
    Humidor
    @paul53 ok, jetzt hab ich dich verstanden. danke.
    BG
      Nein.
       <variables>
       </variables>
         <next>
             <value name="OID0">
               </shadow>
             </value>
                 <value name="IF0">
                     <value name="BOOL">
                       </block>
                     </value>
                   </block>
                 </value>
                     <value name="IF0">
                         <value name="A">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                         <value name="B">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                         <next>
                               </block>
                             </value>
                           </block>
                         </next>
                       </block>
                     </statement>
                     <value name="IF1">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                       </block>
                     </statement>
                     <next>
                         <value name="IF0">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                               </block>
                             </value>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </statement>
             <next>
                     <value name="IF0">
                         <value name="BOOL">
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                         <next>
                               </block>
                             </value>
                           </block>
                         </next>
                       </block>
                     </statement>
                     <value name="IF1">
                         <value name="BOOL">
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
         </next>
       </block>
      </xml>
      HumidorH Offline
      HumidorH Offline
      Humidor
      schrieb am zuletzt editiert von Humidor
      @paul53 es will nicht funktionieren, bei 0 wird mir der Trockner nicht abgeschaltet, nun habe ich eine weitere Triggervariabel drin, damit weiter die Bedingungen abgearbeitet werden, will auch nicht sauber funktionieren (so ein pfufferl Funktion fkt. wieder nicht, das nerft)
      Frage, warum fkt. der Vergleich nicht? ist das ein Systemfehler?
      warum ist die Variable undefiniert, sollte ein Bool sein
      <block xmlns="https://developers.google.com/blockly/xml" type="controls_if" id="iMG-g)W+/JBa1c0H4o:^" x="-85.99716186523438" y="1943">
      <value name="IF0">
      <block type="logic_compare" id="E7:1rr(1eLtr8iBYg8vs">
      <value name="A">
      <block type="get_value" id="6di?WSeWq5K.PkO_Z)R,">
      </block>
      </value>
      <value name="B">
      <block type="variables_get" id="Z?{k!DyEOM%Mt+vH3eLV">
      <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field>
      </block>
      </value>
      </block>
      </value>
      <block type="control" id="P@rQWr^[Hv%ygfQqqvB">
      <block type="variables_get" id="Pd8cVi{9va:z8,7sY^zL">
      </block>
      </value>
      <next>
      <block type="debug" id="H36r9It9a}%=0]wtY2S/">
      <value name="TEXT">
      <shadow type="text" id="3%y$#U
      }5q=D=LwRvHY8">
      <field name="TEXT">SmartPlug Bad aktiviert</field>
      </shadow>
      <block type="text_join" id="auz3gSf7.WYK1jWJ,d4r">
      <value name="ADD0">
      <block type="text" id="r[Jk^79uVZsQ7=_sJ$bb">
      <field name="TEXT">Smart Plug Bad geändert: </field>
      </block>
      </value>
      <value name="ADD1">
      <block type="convert_tostring" id="hthB0ZM5p?6HbOez-_Jr">
      <block type="variables_get" id="!v5M*M5k)2I`tb0FBRwJ">
      </block>
      </value>
      </block>
      </value>
      </block>
      </value>
      </block>
      </next>
      </block>
      </statement>
      </block>
      nach einer Zeit dann:
      why??
      BG
      • HumidorH Humidor
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="TEXT">
        }5q=D=LwRvHY8">
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        why??
        @humidor sagte: warum ist die Variable undefiniert
        Das ist sie nach Skriptstart. Deshalb initialisiere sie außerhalb der Trigger:
        Da du einiges geändert hast, poste bitte den Export des kompletten Skripts in Code tags.
        Was ist der Trigger-DP "Power"?
        HumidorH 1 Antwort Letzte Antwort
          HumidorH Offline
          HumidorH Offline
          Humidor
          @paul53 wie im Bild oben zu sehen, mache ich die Initialisierung per wahr/falsch (Bool)
          nach einer Zeit hat es dann auch funktioniert, das ist ein zeitliches Fehlverhalten
          für mich ist es damit erledigt, mehr kann ich da dann eh nicht beitragen.
          es gibt gerade ein neues Update von Admin und Skript, ich bin aber nicht der, der sofort auf die letzte Version updated, gebranntes Kind halt.
          BG
          • HumidorH Humidor
            @humidor sagte: wie im Bild oben zu sehen, mache ich die Initialisierung per wahr/falsch (Bool)
            Das ist einen andere Variable.
              HumidorH Offline
              HumidorH Offline
              Humidor
              @paul53 hmm, eine Deklaration mit bool ist doch eindeutig, da gibts doch keine Diskussion und ist bei allen Programmiersprachen die ich kenne. ?
              BG
              • HumidorH Humidor
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @humidor dann zeig Dein komplettes Blockly und lass den Debug unten weg... brauchen wir hier grad nicht um Dir zu helfen... nur das Blockly
                Lehrling seit 1975 !!!
                • DJMarc75D DJMarc75
                  HumidorH Offline
                  HumidorH Offline
                  Humidor
                  @djmarc75 da sind oben noch 2 Plugs, die sind aktuell man vernachlässigbar
                  <variables>
                  <variable id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</variable> <variable id="jIGE4073UZ^0VwC#aJuo">HzgBenPVAktiviert</variable> <variable id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</variable>
                  <variable id="I=r#[:pdyT+h|wsXE$|@">SmartPlugBen</variable>
                  <variable id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</variable>
                  <variable id="KD:P[N/4z@jQ6}[4|~Y">HzgBadButtonAktiviert</variable>
                  </variables>
                  <block type="comment" id="z=dwW7Z^I0)hUWc$k!f" x="-237" y="-213">
                  <field name="COMMENT">INIT--------------</field>
                  <next>
                  <block type="create" id="7Gf_Q8NN|bW1T3agv:sj">
                  <field name="NAME">0_userdata.0.SmartPlugs.SmarPlug_HzgBad</field>
                  <block type="logic_boolean" id="+ABL;uy{pNb(E|1)o5th">
                  </block>
                  </value>
                  <value name="COMMON">
                  <block type="text" id="Xcka@/|Q/tc|Xcv+Yr
                  l">
                  <field name="TEXT">{"name": "SmartPlug_HzgBad","role": "","type": "boolean","desc": "Blockly erzeugt","read": true,"write": true,"def": false}</field>
                  </block>
                  </value>
                  <next>
                  <block type="create" id="==~ZA:E=R{8K~__,(hU4">
                  <field name="NAME">0_userdata.0.SmartPlugs.SmarPlug_HzgBen</field>
                  <block type="logic_boolean" id="0C{lx;ih)A3!zAk3r;S[">
                  </block>
                  </value>
                  <block type="text" id="6)Fe,U(?]d1rrIof}-;"> <field name="TEXT">{"name": "SmartPlug_HzgBen","role": "","type": "boolean","desc": "Blockly erzeugt","read": true,"write": true,"def": false}</field> </block> </value> <next> <block type="comment" id="9FS}{3.hU$!)fvKxe5Z">
                  <field name="COMMENT">Weihnachtsbeleuchtung</field>
                  <next>
                  <block type="astro" id="|acq.X_z?/Lk3dB@w@f"> <field name="TYPE">sunsetStart</field> <field name="OFFSET">0</field> <statement name="STATEMENT"> <block type="control" id="pf#k{+=AWeayqQ(+!lU1"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">shelly.0.SHPLG-S#DCCD03#1.Relay0.Switch</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="pVxA|c4e44c1:K0q8;o">
                  </block>
                  </value>
                  </block>
                  </statement>
                  <next>
                  <block type="schedule" id="#ImvmsMd9}x#E[6,M(?
                  <field name="SCHEDULE">0 21 * * </field>
                  <block type="control" id="51G}JMMom|N~wZe?vuj"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">shelly.0.SHPLG-S#DCCD03#1.Relay0.Switch</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="eAT)89Q7NYX@3)OOY7Ae"> <field name="BOOL">FALSE</field> </block> </value> </block> </statement> <next> <block type="comment" id="}c]x52e-,Jd|e2*e^1$6"> <field name="COMMENT">Ben Heizung</field> <next> <block type="on_ext" id="yJDNB7t[~}.F8FBDdvsc"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="mY2gO+p3v.cztMJvtn:A"> <field name="oid">0_userdata.0.AMIS.PVÜberschuss</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id="(;]E+4={9RA~rvpY_t3">
                  <field name="oid">0_userdata.0.AMIS.Power</field>
                  </shadow>
                  </value>
                  <block type="controls_if" id="NbvOvR?bhvqpF!].RQ)"> <mutation else="1"></mutation> <value name="IF0"> <block type="get_value" id="fco*1g?m:yToN*K~5|Ql"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.SmartPlugs.SmarPlug_HzgBen</field> </block> </value> <statement name="DO0"> <block type="controls_if" id="ApX@gbb0HHAZ?tTJ%DJL"> <value name="IF0"> <block type="logic_negate" id="nn1QFP)lE0/rD:963aMk"> <value name="BOOL"> <block type="variables_get" id="yoNWI)pdSK,NTqyhzXm~"> <field name="VAR" id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</field>
                  </block>
                  </value>
                  </block>
                  </value>
                  <block type="controls_if" id="TB%4pL)wZgd6[u6/qea">
                  <value name="IF0">
                  <block type="logic_compare" id=")h)thl1]/#%wS85^Q[Q">
                  <field name="OP">EQ</field>
                  <value name="A">
                  <block type="get_value" id="k#BmbtWz2WX_]qlAzdxv">
                  <field name="OID">0_userdata.0.AMIS.PVÜberschuss</field>
                  </block>
                  </value>
                  <value name="B">
                  <block type="math_number" id="rO7r2mky
                  c1;[0YTkXV-">
                  </block>
                  </value>
                  </block>
                  </value>
                  <block type="variables_set" id="S%?J(3hgSP1jp%44@@to">
                  <field name="VAR" id="I=r#[:pdyT+h|wsXE$|@">SmartPlugBen</field>
                  <block type="logic_boolean" id="2x:G_I{C[[]D:]r~B@Xt">
                  </block>
                  </value>
                  </block>
                  </statement>
                  <value name="IF1">
                  <block type="logic_operation" id="]4FETZUQq13/MP1l5J$k" inline="false">
                  <value name="A">
                  <block type="logic_compare" id="d:5_6(G=Jw2M6wZ)Jl2r">
                  <value name="A">
                  +,Tgs3I#G(/z[ZqcHN9">
                  </block>
                  </value>
                  <value name="B">
                  <block type="math_number" id="vwD4k;kXx,4uw=4f($g">
                  <field name="NUM">1500</field>
                  </block>
                  </value>
                  </block>
                  </value>
                  <value name="B">
                  <block type="logic_negate" id="cn}Hla6KvyP+G!6M/y5T">
                  <value name="BOOL">
                  <block type="get_value" id="Gr@${G.^|v8%2C%MJ_5">
                  <field name="OID">shelly.0.SHPLG-S#8044C6#1.Relay0.Switch</field>
                  </block>
                  </value>
                  </block>
                  </value>
                  </block>
                  </value>
                  <block type="variables_set" id="p?cvm%eiH?u);h|B}Rdw">
                  <block type="logic_boolean" id="%s0S%px=rB$BMHf7_Kuz">
                  </block>
                  </value>
                  <next>
                  <block type="variables_set" id="|PO~KGr/Z7S);%%8Jq{@">
                  <field name="VAR" id="jIGE4073UZ^0VwC#aJuo">HzgBenPVAktiviert</field>
                  <block type="logic_boolean" id="0umsXwGN(LY/n
                  j:!!V">
                  </block>
                  </value>
                  </block>
                  </next>
                  </block>
                  </statement>
                  <next>
                  <block type="controls_if" id="tb3Zo0VF|DHz7d:vMi)6">
                  <value name="IF0">
                  <block type="logic_compare" id="?bFs^LJ$=[B!q33.415D">
                  <value name="A">
                  <block type="get_value" id="?$mmaTeHDO{Y4Z61PG73">
                  </block>
                  </value>
                  <value name="B">
                  <block type="variables_get" id="r;SW=;$T7Djnss?KYHAD">
                  </block>
                  </value>
                  </block>
                  </value>
                  <block type="control" id="L/m_;ygSV-0ZooeZ1e/m">
                  <block type="variables_get" id="?0v#8xfc_phYg2{nvOIN">
                  </block>
                  </value>
                  </block>
                  </statement>
                  </block>
                  </next>
                  </block>
                  </statement>
                  </block>
                  </statement>
                  <statement name="ELSE">
                  <block type="variables_set" id="hBhgMTUxqcZNK4Q77L+c">
                  <field name="VAR" id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="NR2[Ita|cx-C1Zz3rV.I"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="variables_set" id="gq5NDiz)n.aRg%Vz^I!">
                  <block type="logic_boolean" id="LHRm3e4@=@DT$$?8:Y/8">
                  </block>
                  </value>
                  <next>
                  <block type="control" id="+jCB/N79NQm=1iC^u*k"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">shelly.0.SHPLG-S#8044C6#1.Relay0.Switch</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="*Av;9x]5uPOk+5UHX|E*"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </next> </block> </statement> </block> </statement> <next> <block type="on" id="1ofnM(8^@u410iRm.L#">
                  <block type="controls_if" id="}z+.!1@owb3I_eB];]8B">
                  <value name="IF0">
                  <block type="on_source" id="DA9%A!]GFa%3|^I:_@|=">
                  </block>
                  </value>
                  <block type="controls_if" id="Y|XpQQYR!:D9FqG6S[p6">
                  <value name="IF0">
                  <block type="logic_negate" id="~Pwco5sCao+qz=AE|s^E">
                  <value name="BOOL">
                  <block type="variables_get" id="p7z;5.~.xcJmD5{oi7#}">
                  </block>
                  </value>
                  </block>
                  </value>
                  <block type="variables_set" id="3yl@z{)J|8ci36rY6#e@">
                  <field name="VAR" id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="CICNz3lI-vQ]!Te2Un
                  </block>
                  </value>
                  </block>
                  </statement>
                  </block>
                  </statement>
                  <block type="variables_set" id="C7lB^ijF@U[bI=ip27r"> <field name="VAR" id="I87g3)Bgf+VQPGrP)(w">HzgBenButtonAktiviert</field>
                  <block type="logic_boolean" id="v{,|vk$f?a1ga$WLhK?"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="variables_set" id="@.(V|e@jCGmJv8.QwJ?H"> <field name="VAR" id="jIGE4073UZ^0VwC#aJuo">HzgBenPVAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="BCe|,zQnY~64zY[$V.L">
                  </block>
                  </value>
                  </block>
                  </next>
                  </block>
                  </statement>
                  </block>
                  </statement>
                  <next>
                  <block type="comment" id="m|fsyw%~z-7@{pQ@klZ|">
                  <next>
                  <block type="variables_set" id="VzBqFrD%u{!7;__LjF50">
                  <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="c.R@v_JN,e8J*N0NK4sA"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="on_ext" id="WmaDlVza-%|bE2PC4}$}"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="(K%m+UU(oymx/#ZG.8s3"> <field name="oid">0_userdata.0.AMIS.PVÜberschuss</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id="u)8iDg5W-T:O++#u94nN"> <field name="oid">0_userdata.0.AMIS.Power</field> </shadow> </value> <statement name="STATEMENT"> <block type="debug" id=")00za#hEg2!m1qLnmRCA" disabled="true"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="jNXGQwWFslme^E#Z]rlY"> <field name="TEXT">test</field> </shadow> <block type="text_join" id="l@r?8o.2RlJmmv/8.nq{"> <mutation items="2"></mutation> <value name="ADD0"> <block type="text" id="P-9URIODf0;XyV5rq{^^"> <field name="TEXT">- Status SmartPlugBag: </field> </block> </value> <value name="ADD1"> <block type="variables_get" id="W@W^m!TCqT[)6*1X/v/["> <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field> </block> </value> </block> </value> <next> <block type="controls_if" id="~z(C0Ym)^=1QfSjT7~)">
                  <value name="IF0">
                  <block type="get_value" id="]3^kMmXHdM*X6hxcLT$"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.SmartPlugs.SmarPlug_HzgBad</field> </block> </value> <statement name="DO0"> <block type="controls_if" id="!:6IVLh(.s7Zc7*X2PKe"> <value name="IF0"> <block type="logic_negate" id="K~rgK;sALe4{c~Ujl-i6"> <value name="BOOL"> <block type="variables_get" id="]y;likc+U,w(YnZm}|~">
                  </block>
                  </value>
                  </block>
                  </value>
                  <value name="IF0">
                  <block type="logic_operation" id="|;joh}
                  ;!mA?r5ZiSg#1" inline="false">
                  <value name="A">
                  <block type="logic_operation" id="Nmlt)igIsK,]cTElirIO" inline="false">
                  <field name="OP">OR</field>
                  <value name="A">
                  <value name="A">
                  <block type="get_value" id="8g2XiUBKIj/;R,V+q?%]">
                  </block>
                  </value>
                  <value name="B">
                  <block type="math_number" id="OzBUgjtn~Ed/)o1mWRp"> <field name="NUM">0</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="mL7.f6Y8#0OmaVuk$71L"> <field name="OP">GT</field> <value name="A"> <block type="get_value" id="x!PfMXjU|/Qh^Cf|Sr]-"> <field name="ATTR">val</field> <field name="OID">fritzdect.0.DECT_116300118701.celsius</field> </block> </value> <value name="B"> <block type="math_number" id="wI[/OC#D;vOjTQ97fMcm"> <field name="NUM">25</field> </block> </value> </block> </value> </block> </value> <value name="B"> <block type="variables_get" id="]5o#-y)n;Y#t|.08E6k4"> <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="*|c%1P3R}|bETp:H-Zru"> <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field> <value name="VALUE"> <block type="logic_boolean" id="TTB|-!JB/!/Llp_*?jXy"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="debug" id=":2bpKO5;oqCJ~(~?yU*H"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="twZ%b$:x7:Pk1$7*_oNr"> <field name="TEXT">SmartPlug Bad deaktiviert</field> </shadow> </value> </block> </next> </block> </statement> <value name="IF1"> <block type="logic_operation" id="@YV5It9:.Rwjh0g_hu8P" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_operation" id="DW7F}t8zu~$_G*8Pa(3e" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="n=Zb^9u~JGi|Z-2*qlih"> <field name="OP">LT</field> <value name="A"> <block type="get_value" id="RO$ii/.eX+hbu0jJElK1"> <field name="ATTR">val</field> <field name="OID">fritzdect.0.DECT_116300118701.celsius</field> </block> </value> <value name="B"> <block type="math_number" id="n|%GCJ*$Tgl4!/hO)HO">
                  <field name="NUM">23</field>
                  </block>
                  </value>
                  </block>
                  </value>
                  <value name="B">
                  <value name="A">
                  <block type="get_value" id="j7Og^vZs{Gb@!_FYa^rw">
                  </block>
                  </value>
                  <value name="B">
                  S-%?x4O">
                  </block>
                  </value>
                  </block>
                  </value>
                  </block>
                  </value>
                  <value name="B">
                  <block type="logic_negate" id="BocLR@CABleTMd8S2aK$">
                  <value name="BOOL">
                  <block type="variables_get" id="QH;uW7]]0#@i8DmSXsBI">
                  </block>
                  </value>
                  </block>
                  </value>
                  </block>
                  </value>
                  <block type="variables_set" id="_fw-lf1ke521sTDyD+sc">
                  <block type="logic_boolean" id="x(T:dP4YUgCIhxf.6|"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="variables_set" id="=XNnI:dF{iPZY{5-gz{%"> <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field>
                  </block>
                  </value>
                  <next>
                  <block type="debug" id="5,x6)%(2~s:amdJRme2N">
                  <value name="TEXT">
                  <shadow type="text" id=")8=(EFb/R{t4{8OSW[~|">
                  </shadow>
                  </value>
                  </block>
                  </next>
                  </block>
                  </next>
                  </block>
                  </statement>
                  <next>
                  <block type="controls_if" id="iMG-g)W+/JBa1c0H4o:^">
                  <value name="IF0">
                  <value name="A">
                  </block>
                  </value>
                  <value name="B">
                  </block>
                  </value>
                  </block>
                  </value>
                  qvB">
                  </block>
                  </value>
                  <next>
                  <value name="TEXT">
                  <shadow type="text" id="3%y$#U*}5q=D=LwRvHY8">
                  </shadow>
                  <value name="ADD0">
                  </block>
                  </value>
                  <value name="ADD1">
                  <block type="variables_get" id="!v5MM5k)2Itb0FBRwJ"> <field name="VAR" id=")9+q}i8,EkRfK%y8?m$p">SmartPlugBad</field> </block> </value> </block> </value> </block> </value> </block> </next> </block> </statement> </block> </next> </block> </statement> </block> </statement> <statement name="ELSE"> <block type="controls_if" id="LMAxl+;SZ8E(TlZKxWl">
                  <value name="IF0">
                  <block type="get_value" id="j:Fq]C
                  4d+}EE,zt!CB1">
                  </block>
                  </value>
                  <block type="control" id="kp_2D29pPxyBD?BILdYy">
                  <block type="logic_boolean" id="^Lvuh$RDtEkNp]pH:1Kx">
                  </block>
                  </value>
                  <next>
                  <block type="variables_set" id="fi,8jMb]:;nRjEANg30]">
                  <block type="logic_boolean" id="S,N!K.oxOUE@TF/rg6(K">
                  </block>
                  </value>
                  <next>
                  <block type="variables_set" id="eGU=ps7+5m=7SwxtH|">
                  <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="Opy{.zEg](?ok;}cd1"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="debug" id="SVXtBpd[q?mvCcep~3m5"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="2GJS]MKCljICYnyib-$Z"> <field name="TEXT">SmartPlug Bad ausgeschaltet</field> </shadow> </value> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </statement> </block> </next> </block> </statement> <next> <block type="on" id=",{!!mR4nS4Q$NTlsUW,$"> <field name="OID">fritzdect.0.DECT_116300118701.state</field> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="controls_if" id="n,.3vp!##~_]qz%P/^Ib"> <mutation else="1"></mutation> <value name="IF0"> <block type="on_source" id="jKN0mfg1|:PbOG^Gb|/J"> <field name="ATTR">state.val</field> </block> </value> <statement name="DO0"> <block type="controls_if" id="-BxVSGEfn}b7Ju@-,eep"> <value name="IF0"> <block type="logic_negate" id="8gfsgQ_[.HE*?Dj}KtS+"> <value name="BOOL"> <block type="variables_get" id="9vFK#z{rQXnRH_pyLsz">
                  <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="tY.{vp+,c/t}#oMfS]%P"> <field name="VAR" id="KD:P[N/_4z@jQ6}[4|~Y">HzgBadButtonAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="+^XozkhgT@Hd+7)pS97H"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="debug" id="?Hw8wf.Tjw?6RDCyh[3b"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="f0)M{RAR(rVV_;+OAixu"> <field name="TEXT">- Hzg Bad Button aktiviert</field> </shadow> </value> </block> </next> </block> </statement> </block> </statement> <statement name="ELSE"> <block type="variables_set" id="X=d18E?zu0fn:~a^N5g]"> <field name="VAR" id="KD:P[N/_4z@jQ6}[4|~Y">HzgBadButtonAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="x$~YvVoggOL:j%:-TCk">
                  </block>
                  </value>
                  <next>
                  <field name="VAR" id="G/{R4tGviqeZfGp{,EE">HzgBadPVAktiviert</field> <value name="VALUE"> <block type="logic_boolean" id="4u_b=$jq?u6pPc{R~LHL"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="debug" id="/IL]Z5=@*;.99-BJeE{g"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="+G{;4~G4E2V+}e;^).-">
                  <field name="TEXT">- Hzg Bad Button / PV deaktiviert</field>
                  </shadow>
                  </value>
                  </block>
                  </next>
                  </block>
                  </next>
                  </block>
                  </statement>
                  </block>
                  </statement>
                  </block>
                  </next>
                  </block>
                  </next>
                  </block>
                  </next>
                  </block>
                  </next>
                  </block>
                  </next>
                  </block>
                  </next>
                  </block>
                  </next>
                  </block>
                  </next>
                  </block>
                  </next>
                  </block>
                  </next>
                  </block>
                  </next>
                  </block>
                  </next>
                  </block>
                  </xml>
                  aktuell sehe ich kein Fehlverhalten, es hat nur lange gedauert bis es gelaufen ist, dabei Fehlersuche ohne Erfolg (daher die Debugs)
                  gibt es eine Möglickeit die Variablen (Wert) im Objektbaum zu sehen?
                  BG
                  DJMarc75D paul53P 2 Antworten Letzte Antwort
                  • HumidorH Humidor
                    <variables>
                    </variables>
                    <next>
                    </block>
                    </value>
                    l">
                    </block>
                    </value>
                    <next>
                    </block>
                    </value>
                    <next>
                    </block>
                    </value>
                    </block>
                    </statement>
                    <next>
                    </shadow>
                    </value>
                    </block>
                    </value>
                    </block>
                    </value>
                    <value name="IF0">
                    <value name="A">
                    </block>
                    </value>
                    <value name="B">
                    c1;[0YTkXV-">
                    </block>
                    </value>
                    </block>
                    </value>
                    </block>
                    </value>
                    </block>
                    </statement>
                    <value name="IF1">
                    <value name="A">
                    <value name="A">
                    </block>
                    </value>
                    <value name="B">
                    </block>
                    </value>
                    </block>
                    </value>
                    <value name="B">
                    <value name="BOOL">
                    </block>
                    </value>
                    </block>
                    </value>
                    </block>
                    </value>
                    </block>
                    </value>
                    <next>
                    j:!!V">
                    </block>
                    </value>
                    </block>
                    </next>
                    </block>
                    </statement>
                    <next>
                    <value name="IF0">
                    <value name="A">
                    </block>
                    </value>
                    <value name="B">
                    </block>
                    </value>
                    </block>
                    </value>
                    </block>
                    </value>
                    </block>
                    </statement>
                    </block>
                    </next>
                    </block>
                    </statement>
                    </block>
                    </statement>
                    </block>
                    </value>
                    <next>
                    <value name="IF0">
                    </block>
                    </value>
                    <value name="IF0">
                    <value name="BOOL">
                    </block>
                    </value>
                    </block>
                    </value>
                    </block>
                    </value>
                    </block>
                    </statement>
                    </block>
                    </statement>
                    </block>
                    </value>
                    </block>
                    </next>
                    </block>
                    </statement>
                    </block>
                    </statement>
                    <next>
                    <next>
                    <value name="IF0">
                    </block>
                    </value>
                    </block>
                    </value>
                    <value name="IF0">
                    <value name="A">
                    <value name="A">
                    <value name="A">
                    </block>
                    </value>
                    <value name="B">
                    </block>
                    </value>
                    </block>
                    </value>
                    <value name="B">
                    <value name="A">
                    </block>
                    </value>
                    <value name="B">
                    S-%?x4O">
                    </block>
                    </value>
                    </block>
                    </value>
                    </block>
                    </value>
                    <value name="B">
                    <value name="BOOL">
                    </block>
                    </value>
                    </block>
                    </value>
                    </block>
                    </value>
                    </block>
                    </value>
                    <next>
                    <value name="TEXT">
                    </shadow>
                    </value>
                    </block>
                    </next>
                    </block>
                    </next>
                    </block>
                    </statement>
                    <next>
                    <value name="IF0">
                    <value name="A">
                    </block>
                    </value>
                    <value name="B">
                    </block>
                    </value>
                    </block>
                    </value>
                    qvB">
                    </block>
                    </value>
                    <next>
                    <value name="TEXT">
                    </shadow>
                    <value name="ADD0">
                    </block>
                    </value>
                    <value name="ADD1">
                    <value name="IF0">
                    4d+}EE,zt!CB1">
                    </block>
                    </value>
                    </block>
                    </value>
                    <next>
                    </block>
                    </value>
                    <next>
                    </block>
                    </value>
                    <next>
                    </shadow>
                    </value>
                    </block>
                    </next>
                    </block>
                    </next>
                    </block>
                    </statement>
                    </block>
                    </statement>
                    </block>
                    </next>
                    </block>
                    </next>
                    </block>
                    </next>
                    </block>
                    </next>
                    </block>
                    </next>
                    </block>
                    </next>
                    </block>
                    </next>
                    </block>
                    </next>
                    </block>
                    </next>
                    </block>
                    </next>
                    </block>
                    </next>
                    </block>
                    </next>
                    </block>
                    </xml>
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    @humidor sagte in Smarter - Handtuchtrockner:
                    ja klar, indem Du die Variablen an das Debug hängst...
                      HumidorH Offline
                      HumidorH Offline
                      Humidor
                      @djmarc75 auch mit direktem Bezug auf die Variable - undefined
                      hatte heute einen Restart vom Raspi, seither fkt. es wieder nicht.
                      BG
                      • HumidorH Humidor
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        @humidor Na wenn die Variable, laut Deinem Screenshot, keinen Wert bekommt, dann ist diese halt auch "undefined"
                          HumidorH Offline
                          HumidorH Offline
                          Humidor
                          @djmarc75 true/false wäre ja definiert
                          BG
                          HumidorH paul53P 2 Antworten Letzte Antwort
                          • HumidorH Humidor
                            HumidorH Offline
                            HumidorH Offline
                            Humidor
                            @humidor ach ich Idiot, die Variable die ich debugge, war nicht definiert.... so ein Depp
                            dennoch schalet mir das Spiel gerade nicht...
                            BG
                            • HumidorH Humidor
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              @humidor warum setzt Du die Variablen 2 mal ??
                              macht keinen Sinn !
                              • HumidorH Humidor
                                @humidor sagte: true/false wäre ja definiert
                                Die Variablen SmartPlugBad und SmartPlugBen müssen initialisiert werden! Bei den anderen Variablen ist es nicht nötig.
                                EDIT: Wie hoch ist die Leistungsaufnahme der beiden Heizungen?
                                • HumidorH Humidor
                                  <variables>
                                  </variables>
                                  <next>
                                  </block>
                                  </value>
                                  l">
                                  </block>
                                  </value>
                                  <next>
                                  </block>
                                  </value>
                                  <next>
                                  </block>
                                  </value>
                                  </block>
                                  </statement>
                                  <next>
                                  </shadow>
                                  </value>
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  <value name="IF0">
                                  <value name="A">
                                  </block>
                                  </value>
                                  <value name="B">
                                  c1;[0YTkXV-">
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  </block>
                                  </statement>
                                  <value name="IF1">
                                  <value name="A">
                                  <value name="A">
                                  </block>
                                  </value>
                                  <value name="B">
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  <value name="B">
                                  <value name="BOOL">
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  <next>
                                  j:!!V">
                                  </block>
                                  </value>
                                  </block>
                                  </next>
                                  </block>
                                  </statement>
                                  <next>
                                  <value name="IF0">
                                  <value name="A">
                                  </block>
                                  </value>
                                  <value name="B">
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  </block>
                                  </statement>
                                  </block>
                                  </next>
                                  </block>
                                  </statement>
                                  </block>
                                  </statement>
                                  </block>
                                  </value>
                                  <next>
                                  <value name="IF0">
                                  </block>
                                  </value>
                                  <value name="IF0">
                                  <value name="BOOL">
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  </block>
                                  </statement>
                                  </block>
                                  </statement>
                                  </block>
                                  </value>
                                  </block>
                                  </next>
                                  </block>
                                  </statement>
                                  </block>
                                  </statement>
                                  <next>
                                  <next>
                                  <value name="IF0">
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  <value name="IF0">
                                  <value name="A">
                                  <value name="A">
                                  <value name="A">
                                  </block>
                                  </value>
                                  <value name="B">
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  <value name="B">
                                  <value name="A">
                                  </block>
                                  </value>
                                  <value name="B">
                                  S-%?x4O">
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  <value name="B">
                                  <value name="BOOL">
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  <next>
                                  <value name="TEXT">
                                  </shadow>
                                  </value>
                                  </block>
                                  </next>
                                  </block>
                                  </next>
                                  </block>
                                  </statement>
                                  <next>
                                  <value name="IF0">
                                  <value name="A">
                                  </block>
                                  </value>
                                  <value name="B">
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  qvB">
                                  </block>
                                  </value>
                                  <next>
                                  <value name="TEXT">
                                  </shadow>
                                  <value name="ADD0">
                                  </block>
                                  </value>
                                  <value name="ADD1">
                                  <value name="IF0">
                                  4d+}EE,zt!CB1">
                                  </block>
                                  </value>
                                  </block>
                                  </value>
                                  <next>
                                  </block>
                                  </value>
                                  <next>
                                  </block>
                                  </value>
                                  <next>
                                  </shadow>
                                  </value>
                                  </block>
                                  </next>
                                  </block>
                                  </next>
                                  </block>
                                  </statement>
                                  </block>
                                  </statement>
                                  </block>
                                  </next>
                                  </block>
                                  </next>
                                  </block>
                                  </next>
                                  </block>
                                  </next>
                                  </block>
                                  </next>
                                  </block>
                                  </next>
                                  </block>
                                  </next>
                                  </block>
                                  </next>
                                  </block>
                                  </next>
                                  </block>
                                  </next>
                                  </block>
                                  </next>
                                  </block>
                                  </next>
                                  </block>
                                  </xml>
                                  @humidor
                                  Ich habe mal die Ausschaltbedingung für beide Heizungen auf Überschuss < 100 geändert und den doppelten Trigger entfernt.
                                   <variables>
                                     <variable id="HLabyAd:2nQ}/NML;EAq">Temperatur</variable>
                                   </variables>
                                   <block type="comment" id="z=dwW7Z^I0)hUWc$k!f" x="-136" y="-260">
                                     <next>
                                           </block>
                                         </value>
                                           <block type="text" id="Xcka@/|Q/tc|Xcv+Yrl">
                                           </block>
                                         </value>
                                         <next>
                                               </block>
                                             </value>
                                               </block>
                                             </value>
                                             <next>
                                                 <next>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </statement>
                                                     <next>
                                                       <block type="schedule" id="#ImvmsMd9}x#E[6,M(?">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </statement>
                                                         <next>
                                                           <block type="variables_set" id="T:OJh$QAE@dYyx%-Zseu">
                                                               <block type="get_value" id="wi0;LmRK]|?-9g[9yO51">
                                                               </block>
                                                             </value>
                                                             <next>
        <block type="get_value" id="|A_Y-a*[tt%7[kH+v#Ps">
        </block>
        </value>
        <next>
        <value name="OID0">
        </shadow>
        </value>
        <next>
        <value name="IF0">
        </block>
        </value>
        <value name="IF0">
        <value name="BOOL">
        </block>
        </value>
        </block>
        </value>
        <value name="IF0">
        <value name="A">
        <block type="on_source" id="Hy=tG%V,OewFti1.fXz`">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="rO7r2mkyc1;[0YTkXV-">
        <field name="NUM">100</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <value name="IF1">
        <value name="A">
        <block type="on_source" id="=pLg:aB#k0O/WJH7Wv`5">
        </block>
        </value>
        <value name="B">
        <field name="NUM">1600</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="logic_boolean" id="0umsXwGN(LY/nj:!!V">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        <value name="IF1">
        <block type="get_value" id="(aYkcX/I(pzVo|`X$sEE">
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <next>
        <value name="IF0">
        </block>
        </value>
        <value name="IF0">
        <value name="BOOL">
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="N,/~h9;9.JbWzU8$~1a*">
        <field name="VAR" id="HLabyAd:2nQ}/NML;EAq">Temperatur</field>
        </block>
        </value>
        <next>
        <value name="IF0">
        <value name="A">
        <value name="A">
        <block type="on_source" id="!ar_r$01pMg+XNiz*t@!">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <field name="OP">GTE</field>
        <value name="A">
        <block type="variables_get" id="i=)iIh}a]G1RSa2XRI=|">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <value name="IF1">
        <value name="A">
        <value name="A">
        <block type="variables_get" id="?+f0rAV,pn$;)/tcql[K">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <value name="A">
        <block type="on_source" id="B5i4y6y,UwZDHs]C[*rR">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="Zc~cW;[({xEjS-%?x4O">
        <field name="NUM">1300</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        <value name="IF1">
        <block type="get_value" id="j:Fq]C4d+}EE,zt!CB1">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="IF0">
        </block>
        </value>
        <value name="IF0">
        <value name="BOOL">
        </block>
        </value>
        </block>
        </value>
        <block type="logic_boolean" id="CICNz3lI-vQ]!Te2Un">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        <next>
        <value name="IF0">
        </block>
        </value>
        <value name="IF0">
        <value name="BOOL">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                  </xml>
                                  Was hat die Weihnachtsbeleuchtung in diesem Skript zu suchen?
                                    @humidor
                                     <variables>
                                     </variables>
                                       <next>
                                             </block>
                                           </value>
                                             </block>
                                           </value>
                                           <next>
                                                 </block>
                                               </value>
                                                 </block>
                                               </value>
                                               <next>
                                                   <next>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </statement>
                                                       <next>
        </block>
                                                               </value>
                                                             </block>
                                                           </statement>
                                                           <next>
        </block>
                                                               </value>
                                                               <next>
        </block>
        </value>
        <next>
        <value name="OID0">
        </shadow>
        </value>
        <next>
        <value name="IF0">
        </block>
        </value>
        <value name="IF0">
        <value name="BOOL">
        </block>
        </value>
        </block>
        </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <value name="IF1">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        <value name="IF1">
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <next>
        <value name="IF0">
        </block>
        </value>
        <value name="IF0">
        <value name="BOOL">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="IF0">
        <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <value name="IF1">
        <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        <value name="IF1">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="IF0">
        </block>
        </value>
        <value name="IF0">
        <value name="BOOL">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        <next>
        <value name="IF0">
        </block>
        </value>
        <value name="IF0">
        <value name="BOOL">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                    </xml>
                                    HumidorH Offline
                                    HumidorH Offline
                                    Humidor
                                    @paul53 Morgen!
                                    Ja ich weiß, dass das wahr/falsch da nicht hingehört, es war ein Test.
                                    Nachdem ich mich aber auf die falschen Variablen konzentriert haben, waren die SmartPluxx nicht deklariert und daher auch undefined, also alles richtig
                                    ich sagte auch, dass die 2 anderen zu vernachlässigen sind
                                    da ich die Heizkörper manuell per Soft-Schalter de-/aktiviere, passen die Werte schon.
                                    BG
                                    • HumidorH Humidor
                                      @paul53 Morgen!
                                      HumidorH Offline
                                      HumidorH Offline
                                      Humidor
                                      @humidor ich habe das lange beobachtet
                                      der Trigger fkt. nicht .
                                      1. Triggervariable ist 0
                                      2. Triggervariable ist im Minus
                                        damit kommt kein Trigger mehr, der Handtuchtrockner bleibt mir aktiv
                                      umgestellt auf Trigger/Sekunde, funktioniert.
                                      BG
                                      • HumidorH Humidor
                                        wendy2702W Online
                                        wendy2702W Online
                                        ich will etwas ähnliches realisieren. Funktioniert dein Blockly jetzt?
                                        Falls ja, kannst du vielleicht einen Export bereitsstellen.
