  4. Problem nach Update Admin adapter auf 6.3.5
    5.6k
42 Beiträge 5 Kommentatoren 4.8k Aufrufe 5 Beobachtet
  • L Laser
    pi@Heizung:~ $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    Kein Docker
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.19.0
    v16.19.0
    8.19.3
    4.0.23
    pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    tty
    /home/pi
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists... Done
    All packages are up to date.
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
     *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u1 500
    Laser
    schrieb am zuletzt editiert von Laser
    pi@Heizung:~ $ iobroker upgrade admin --debug
    This upgrade of "admin" will introduce the following changes:
    -> 6.3.5:
    Corrected reading of node.js version
    Would you like to upgrade admin from @6.3.4 to @6.3.5 now? [(y)es, (n)o]: y
    Update admin from @6.3.4 to @6.3.5
    host.Heizung Adapter "system.adapter.admin.3" is stopped.
    NPM version: 8.19.3
    Installing iobroker.admin@6.3.5... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/axios
    npm ERR! dest /opt/iobroker/node_modules/.axios-5PaJDuuS
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/axios' -> '/opt/iobroker/node_modules/.axios-5PaJDuuS'
    npm ERR!     /home/iobroker/.npm/_logs/2022-12-22T16_18_51_868Z-debug-0.log
    host.Heizung Cannot install iobroker.admin@6.3.5: 217
    was ist vorher passiert: neue SSD eingerichtet. Debian 1 + IOBroker install-Script. Ging, bis ich auf die dumme Idee kam, den Adapter upzudaten, weil es angeboten wurde...
    Thomas BraunT 3 Antworten Letzte Antwort
    • L Laser
      -> 6.3.5:
      NPM version: 8.19.3
      npm ERR! errno -39
      @laser
      https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
      • L Laser
        -> 6.3.5:
        NPM version: 8.19.3
        npm ERR! errno -39
        @laser sagte in Problem nach Update Admin adapter auf 6.3.5:
        Warum soll die Idee dumm sein? Die ist natürlich grundsätzlich sehr richtig.
        L 1 Antwort Letzte Antwort
        • L Laser
          -> 6.3.5:
          NPM version: 8.19.3
          npm ERR! errno -39
          admin.3
          Warum denn gleich vier Instanzen des admins? Ist wohl ein wenig zu viel des Guten...
            Laser
            Schon klar. Muß ja funktionieren. Habe dieses Script (Befehlszeile) aus dem Verweis ausgeführt. Nun ist Alles tot😕
            4 Instanzen, damit ich wieder eine Bedienoberfläche habe. Die fliegen wieder raus!
            • L Laser
              Kann eigentlich nicht sein.
              iobroker status
              iobroker restart
              Konsole, gut ist...
                iobroker status
                iobroker restart
                Konsole, gut ist...
                Laser
                pi@Heizung:~ $ iobroker status
                Objects type: jsonl
                States  type: jsonl
                kann den Admin aber nicht öffnen. Schon den Pi rebootet.
                Die VIS- Oberfläche funktioniert.
                • L Laser
                  Objects type: jsonl
                  States  type: jsonl
                  @laser
                  iobroker list instances
                    @laser
                    Laser
                    pi@Heizung:~ $ iobroker list instances
                      system.adapter.admin.1                  : admin                 : Heizung                                  - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.admin.3                  : admin                 : Heizung                                  - disabled, port: 8089, bind: 0.0.0.0, run as: admin
                    + system.adapter.backitup.0               : backitup              : Heizung                                  -  enabled
                    + system.adapter.discovery.0              : discovery             : Heizung                                  -  enabled
                    + system.adapter.echarts.0                : echarts               : Heizung                                  -  enabled
                      system.adapter.flot.0                   : flot                  : Heizung                                  - disabled
                    + system.adapter.history.0                : history               : Heizung                                  -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : Heizung                                  -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : Heizung                                  -  enabled, port: 0
                    + system.adapter.hm-rpc.1                 : hm-rpc                : Heizung                                  -  enabled, port: 0
                    + system.adapter.info.0                   : info                  : Heizung                                  -  enabled
                    + system.adapter.javascript.0             : javascript            : Heizung                                  -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : Heizung                                  -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.net-tools.0              : net-tools             : Heizung                                  -  enabled
                    + system.adapter.owfs.0                   : owfs                  : Heizung                                  -  enabled, port: 4304
                    + system.adapter.rpi2.0                   : rpi2                  : Heizung                                  -  enabled
                    + system.adapter.shelly.1                 : shelly                : Heizung                                  -  enabled, port: 1882, bind: 0.0.0.0
                      system.adapter.vis-bars.0               : vis-bars              : Heizung                                  - disabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Heizung                                  - disabled
                      system.adapter.vis.0                    : vis                   : Heizung                                  -  enabled
                    + system.adapter.web.0                    : web                   : Heizung                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.zigbee.0                 : zigbee                : Heizung                                  -  enabled, port: /dev/ttyACM0
                    + instance is alive
                    • L Laser
                      + instance is alive
                      adapter.admin.1
                      Der will natürlich gestartet werden:
                      iobroker start admin.1
                        adapter.admin.1
                        Laser
                        Der lässt sich wieder starten? "iobroker start admin.3" (Port 8089) hatte ich vergeblich versucht. Den admin.1 hatte ich gar nicht versucht!
                        Der admin.1 läuft wieder!
                        Das Update klappt aber nicht.
                        • L Laser
                          Warum nicht? Meldungen? Glaskugel ist trübe...
                            Laser
                            Meine beiden Glaskugeln sind auch bald trübe! Wenn ich das Update starte, steht wieder (sinngemäß): Adapter gestoppt, runder Kreis dreht sich, und das war es. Wird nie fertig.
                            Gestartet aus der Adapter Übersicht, dieses Mal.
                            • L Laser
                              @laser
                              Nimm die Konsole her...
                                @laser
                                Laser
                                soll heißen: "Update über die Konsole ausführen?"
                                • L Laser
                                  @laser
                                  Natürlich. Ist eh viel besser, da siehste nämlich mehr. Insbesondere wenn mit --debug installiert wird.
                                    @laser
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    @thomas-braun sagte in Problem nach Update Admin adapter auf 6.3.5:
                                    wenn man per admin, wird sowieso ein --debug ausgeführt, sehe da genauso viel wie auf der Konsole
                                      @crunchip
                                      Gibt aber durchaus auch Ausgaben, die im Admin gefiltert sind und in der Konsole voll durchlaufen. Und die Konsole funktioniert auch ohne laufende Admin-Instanz.
                                      • L Offline
                                        Laser
                                        habe "iobroker upgrade admin" gemacht. Nicht passiert in Pkt. Neuversion!
                                        • L Laser
                                          Und wo sehe ich jetzt die Ausgabe dazu?
                                          Darüber hinaus:
                                          ist gefragt.
