  3. Entwicklung
  4. Adapter: Worx Landroid v2.x.x
1.2k Beiträge 121 Kommentatoren 735.8k Aufrufe 64 Beobachtet
  • D
    D
    Dirk
    #112
    Guten Tag zusammen,
    leider funktioniert der Adapter bei mir nicht, auch die Fehlermeldung ist etwas "komisch".
    Hier die Infos:
    Windows 7 - 64 bit auf einem PC
    open SSL 64 bit installiert und auch die "landroid-cloud.js angepasst
    if (process.platform === 'win32') {
    // use custom config, otherwise fallbacks to /usr/local/ssl/openssl.cnf
    process.env.OPENSSL_CONF = path.join('C:', 'OpenSSL-Win64', 'bin', 'openssl.cfg');
    // use bundled openssl executable
    pem.config({
    pathOpenSSL: path.join('C:', 'OpenSSL-Win64', 'bin', 'openssl.exe')
    Log in ioBrocker:
    host.TVServer	2017-08-06 12:08:34.884	info	Do not restart adapter system.adapter.landroid-s.0 because disabled or deleted
    host.TVServer	2017-08-06 12:08:34.884	error	instance system.adapter.landroid-s.0 terminated with code 3 (Adapter disabled or invalid config)
    host.TVServer	2017-08-06 12:08:09.113	info	object change system.adapter.landroid-s.0
    host.TVServer	2017-08-06 12:08:03.372	info	Restart adapter system.adapter.landroid-s.0 because enabled
    host.TVServer	2017-08-06 12:08:03.372	error	instance system.adapter.landroid-s.0 terminated with code 0 (OK)
    landroid-s.0	2017-08-06 12:08:03.341	info	cleaned everything up...
    landroid-s.0	2017-08-06 12:08:03.341	error	at endReadableNT (_stream_readable.js:921:12)
    landroid-s.0	2017-08-06 12:08:03.341	error	at IncomingMessage.emit (events.js:166:7)
    landroid-s.0	2017-08-06 12:08:03.341	error	at emitNone (events.js:72:20)
    landroid-s.0	2017-08-06 12:08:03.341	error	at IncomingMessage. (C:\ioBroker\node_modules\iobroker.landroid-s\node_modules\najax\lib\najax.js:198:9)
    landroid-s.0	2017-08-06 12:08:03.341	error	at dataHandler (C:\ioBroker\node_modules\iobroker.landroid-s\node_modules\najax\lib\najax.js:173:9)
    landroid-s.0	2017-08-06 12:08:03.341	error	at onError (C:\ioBroker\node_modules\iobroker.landroid-s\node_modules\najax\lib\najax.js:208:9)
    landroid-s.0	2017-08-06 12:08:03.341	error	at Object.self.fire [as reject] (C:\ioBroker\node_modules\iobroker.landroid-s\node_modules\najax\node_modules\jquery-deferred\lib\jquery-callbacks.js:195:10)
    landroid-s.0	2017-08-06 12:08:03.341	error	at Object.self.fireWith (C:\ioBroker\node_modules\iobroker.landroid-s\node_modules\najax\node_modules\jquery-deferred\lib\jquery-callbacks.js:188:7)
    landroid-s.0	2017-08-06 12:08:03.341	error	at fire (C:\ioBroker\node_modules\iobroker.landroid-s\node_modules\najax\node_modules\jquery-deferred\lib\jquery-callbacks.js:78:30)
    landroid-s.0	2017-08-06 12:08:03.341	error	at Object.najax.error (C:\ioBroker\node_modules\iobroker.landroid-s\lib\landroid-cloud.js:325:19)
    landroid-s.0	2017-08-06 12:08:03.341	error	TypeError: Cannot read property 'log' of undefined
    landroid-s.0	2017-08-06 12:08:03.341	error	uncaught exception: Cannot read property 'log' of undefined
    landroid-s.0	2017-08-06 12:08:02.919	info	API token set to xxxxxxxxxxxxxxxxxxxxxxx
    landroid-s.0	2017-08-06 12:08:02.919	info	Downloaded guest token
    landroid-s.0	2017-08-06 12:08:02.685	info	starting. Version 0.3.0 in C:/ioBroker/node_modules/iobroker.landroid-s, node: v4.5.0
    host.TVServer	2017-08-06 12:08:01.235	info	instance system.adapter.landroid-s.0 started with pid 2904
    host.TVServer	2017-08-06 12:07:31.230	info	Restart adapter system.adapter.landroid-s.0 because enabled
    host.TVServer	2017-08-06 12:07:31.228	error	instance system.adapter.landroid-s.0 terminated with code 0 (OK)
    landroid-s.0	2017-08-06 12:07:31.198	info	cleaned everything up...
    landroid-s.0	2017-08-06 12:07:31.197	error	at endReadableNT (_stream_readable.js:921:12)
    landroid-s.0	2017-08-06 12:07:31.197	error	at IncomingMessage.emit (events.js:166:7)
    landroid-s.0	2017-08-06 12:07:31.197	error	at emitNone (events.js:72:20)
    landroid-s.0	2017-08-06 12:07:31.197	error	at IncomingMessage. (C:\ioBroker\node_modules\iobroker.landroid-s\node_modules\najax\lib\najax.js:198:9)
    landroid-s.0	2017-08-06 12:07:31.197	error	at dataHandler (C:\ioBroker\node_modules\iobroker.landroid-s\node_modules\najax\lib\najax.js:173:9)
    landroid-s.0	2017-08-06 12:07:31.197	error	at onError (C:\ioBroker\node_modules\iobroker.landroid-s\node_modules\najax\lib\najax.js:208:9)
    landroid-s.0	2017-08-06 12:07:31.197	error	at Object.self.fire [as reject] (C:\ioBroker\node_modules\iobroker.landroid-s\node_modules\najax\node_modules\jquery-deferred\lib\jquery-callbacks.js:195:10)
    landroid-s.0	2017-08-06 12:07:31.197	error	at Object.self.fireWith (C:\ioBroker\node_modules\iobroker.landroid-s\node_modules\najax\node_modules\jquery-deferred\lib\jquery-callbacks.js:188:7)
    landroid-s.0	2017-08-06 12:07:31.197	error	at fire (C:\ioBroker\node_modules\iobroker.landroid-s\node_modules\najax\node_modules\jquery-deferred\lib\jquery-callbacks.js:78:30)
    landroid-s.0	2017-08-06 12:07:31.197	error	at Object.najax.error (C:\ioBroker\node_modules\iobroker.landroid-s\lib\landroid-cloud.js:325:19)
    landroid-s.0	2017-08-06 12:07:31.197	error	TypeError: Cannot read property 'log' of undefined
    landroid-s.0	2017-08-06 12:07:31.194	error	uncaught exception: Cannot read property 'log' of undefined
    landroid-s.0	2017-08-06 12:07:30.789	info	API token set to xxxxxxxxxxxxxxxxxxxxx
    landroid-s.0	2017-08-06 12:07:30.788	info	Downloaded guest token
    landroid-s.0	2017-08-06 12:07:30.570	info	starting. Version 0.3.0 in C:/ioBroker/node_modules/iobroker.landroid-s, node: v4.5.0
    host.TVServer	2017-08-06 12:07:29.130	info	instance system.adapter.landroid-s.0 started with pid 728
    host.TVServer	2017-08-06 12:06:59.111	info	Restart adapter system.adapter.landroid-s.0 because enabled
    host.TVServer	2017-08-06 12:06:59.111	error	instance system.adapter.landroid-s.0 terminated with code 0 (OK)
    landroid-s.0	2017-08-06 12:06:59.095	info	cleaned everything up...
    Das - API token set to xxxxxxxxxxxxxxxxxxxxx habe ich mal geXt - da ich nicht genau weiß ob ich das hier schreiben sollte.
    Anschl. habe ich im Log alle 60 sek.
    Könnt ihr helfen bitte.
    Dirk
    • MeistertrM
      MeistertrM
      Meistertr
      #113
      Versuche mal dieses SSL
      http://slproweb.com/products/Win32OpenSSL.html damit sollte es gehen
      • D
        D
        Dirk
        #114
        Hallo Meistertr,
        danke für die schnelle Antwort.
        Ein großes Entschuldigung - ich Dep - habe das falsche Passwort genutzt.
        Mit dem richtigen Passwort funktioniert es auch.
        Dirk
        • B
          B
          bku
          #115
          Hallo Meistertr,
          nutze begeistert deinen Adapter für meinen neuen Landroid-S - Danke dafür!
          Die Info-Daten habe ich im VIS schon sichtbar.
          Nun sehe ich gerade dein Widget für die Zeitentabelle im Roboter-Forum. Da ich für so eine Umsetzung wahrscheinlich zwei Wochen bräuchte, könntest du das Widget exportieren und als PN schicken? Wäre super-nett!
          Gruß Bernd
          • MeistertrM
            MeistertrM
            Meistertr
            #116
            @bku:
            Hallo Meistertr,
            Gruß Bernd `
            Du meinst dies? ich Stelle es zur Verfügung, sobald ich fertig bin (ich brauche da auch zwei Wochen für ;) ) bin noch nicht ganz fertig, da die Logik im Hintergrund noch geschrieben werden muss, und ich noch überlege wie ich die mähzeiten grafisch darstellen kann,
            • B
              B
              bku
              #117
              Super, vielen Dank schon mal!
              Gruß Bernd
              • B
                B
                bku
                #118
                Hallo MeisterTR,
                leider bekomme ich die Version 0.3.0 nicht installiert, mache ich was falsch?
                instance system.adapter.vis.0 terminated while should be started once
                vis.0	2017-08-07 19:45:51.251	info	vis license is OK.
                vis.0	2017-08-07 19:45:51.012	info	starting. Version 0.15.5 in /opt/iobroker/node_modules/iobroker.vis, node: v4.8.0
                host.DiskStation	2017-08-07 19:45:50.246	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                iobroker	2017-08-07 19:45:50.032	info	exit 0
                iobroker	2017-08-07 19:45:49.953	info	upload [0] landroid-s /opt/iobroker/node_modules/iobroker.landroid-s/www/README.md README.md text/x-markdown
                iobroker	2017-08-07 19:45:49.896	info	upload [1] landroid-s /opt/iobroker/node_modules/iobroker.landroid-s/www/index.html index.html text/html
                iobroker	2017-08-07 19:45:49.875	info	Adapter "system.adapter.vis.0" restarted.got /opt/iobroker/node_modules/iobroker.landroid-s/www
                host.DiskStation	2017-08-07 19:45:49.849	info	"system.adapter.vis.0" enabled
                host.DiskStation	2017-08-07 19:45:49.848	info	object change system.adapter.vis.0
                host.DiskStation	2017-08-07 19:45:49.830	info	"system.adapter.vis.0" disabled
                host.DiskStation	2017-08-07 19:45:49.830	info	object change system.adapter.vis.0
                iobroker	2017-08-07 19:45:49.717	info	upload [0] landroid-s.admin /opt/iobroker/node_modules/iobroker.landroid-s/admin/index.html index.html text/html
                iobroker	2017-08-07 19:45:49.646	info	upload [1] landroid-s.admin /opt/iobroker/node_modules/iobroker.landroid-s/admin/landroid-s.png landroid-s.png image/png
                iobroker	2017-08-07 19:45:49.554	info	upload [2] landroid-s.admin /opt/iobroker/node_modules/iobroker.landroid-s/admin/words.js words.js application/javascript
                iobroker	2017-08-07 19:45:49.528	info	got /opt/iobroker/node_modules/iobroker.landroid-s/admin
                iobroker	2017-08-07 19:45:49.197	info	└── mqtt@1.3.5 (inherits@2.0.3, xtend@4.0.1, minimist@1.2.0, commist@1.0.0, readable-stream@1.0.34, end-of-stream@1.4.0, mqtt-connection@2.1.1, mqtt-packet@3.4.8, help-me@0.1.0, concat-stream@1.6.0, w
                iobroker	2017-08-07 19:45:49.197	info	├── aws-iot-device-sdk@2.0.1 (minimist@1.2.0, crypto-js@3.1.6, websocket-stream@3.3.3, mqtt@2.2.1)
                iobroker	2017-08-07 19:45:49.197	info	├── najax@1.0.3 (lodash.defaultsdeep@4.6.0, jquery-deferred@0.3.1, qs@6.5.0)
                iobroker	2017-08-07 19:45:49.197	info	├── pem@1.9.7 (os-tmpdir@1.0.2, which@1.3.0)
                iobroker	2017-08-07 19:45:49.197	info	iobroker.landroid-s@0.3.0 iobroker/node_modules/iobroker.landroid-s├── uuid@3.1.0
                iobroker	2017-08-07 19:45:40.098	info	WARN optional dep failed, continuing bufferutil@1.1.0
                iobroker	2017-08-07 19:45:40.095	info	npm
                iobroker	2017-08-07 19:45:40.093	info	WARN optional dep failed, continuing utf-8-validate@1.1.0
                iobroker	2017-08-07 19:45:40.092	info
                iobroker	2017-08-07 19:45:40.087	info	npm
                iobroker	2017-08-07 19:45:40.073	info	gyp ERR! not ok
                iobroker	2017-08-07 19:45:40.073	info	gyp ERR! node-gyp -v v3.4.0
                iobroker	2017-08-07 19:45:40.073	info	ERR! cwd /opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutilgyp ERR! node -v v4.8.0
                iobroker	2017-08-07 19:45:40.069	info	gyp
                iobroker	2017-08-07 19:45:40.069	info	gyp ERR! System Linux 3.10.102gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                iobroker	2017-08-07 19:45:40.068	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
                iobroker	2017-08-07 19:45:40.067	info	gyp ERR! stack at ChildProcess.emit (events.js:172:7)
                iobroker	2017-08-07 19:45:40.067	info	gyp ERR! stack at emitTwo (events.js:87:13)
                iobroker	2017-08-07 19:45:40.067	info	gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                iobroker	2017-08-07 19:45:40.062	info	gyp ERR! build error
                iobroker	2017-08-07 19:45:40.061	info	make: Leaving directory '/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil/build'make: *** [Release/obj.target/buf
                iobroker	2017-08-07 19:45:40.059	info	bufferutil.target.mk:98: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
                iobroker	2017-08-07 19:45:39.833	info	^
                iobroker	2017-08-07 19:45:39.833	info	return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
                iobroker	2017-08-07 19:45:39.833	info	../node_modules/nan/nan.h:683:12: error: 'Use' is not a member of 'node::Buffer'
                iobroker	2017-08-07 19:45:39.833	info	../node_modules/nan/nan.h: In function 'v8::Local NanBufferUse(char*, uint32_t)':
                iobroker	2017-08-07 19:45:39.833	info	return node::Buffer::New(v8::Isolate::GetCurrent(), size);
                iobroker	2017-08-07 19:45:39.833	info	../node_modules/nan/nan.h:676:61: error: could not convert 'node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))' from 'v8::MaybeLocal' to 'v8::Local'
                iobroker	2017-08-07 19:45:39.833	info	In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function 'v8::Local NanNewBufferHandle(uint32_t)':
                iobroker	2017-08-07 19:45:39.832	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil/.node-gyp/4.8.0/include/node/node_buffer.h:46:40: note: no know
                iobroker	2017-08-07 19:45:39.832	info	^
                iobroker	2017-08-07 19:45:39.832	info	NODE_EXTERN v8::MaybeLocal New(v8::Isolate* isolate,
                iobroker	2017-08-07 19:45:39.832	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil/.node-gyp/4.8.0/include/node/node_buffer.h:46:40: note: v8::Maybe
                iobroker	2017-08-07 19:45:39.832	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil/.node-gyp/4.8.0/include/node/node_buffer.h:34:40: note: no know
                iobroker	2017-08-07 19:45:39.832	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil/.node-gyp/4.8.0/include/node/node_buffer.h:34:40: note: v8::Maybe
                iobroker	2017-08-07 19:45:39.832	info	In file included from ../src/bufferutil.cc:10:0:
                iobroker	2017-08-07 19:45:39.832	info	../node_modules/nan/nan.h:672:67: note: candidates are:
                iobroker	2017-08-07 19:45:39.832	info	return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
                iobroker	2017-08-07 19:45:39.832	info	../node_modules/nan/nan.h:672:67: error: call of overloaded 'New(v8::Isolate*, const char*&, uint32_t&)' is ambiguous
                iobroker	2017-08-07 19:45:39.832	info	../node_modules/nan/nan.h: In function 'v8::Local NanNewBufferHandle(const char*, uint32_t)':
                iobroker	2017-08-07 19:45:39.832	info	v8::Isolate::GetCurrent(), data, length, callback, hint);
                iobroker	2017-08-07 19:45:39.832	info	../node_modules/nan/nan.h:665:60: error: 'hint' was not declared in this scope
                iobroker	2017-08-07 19:45:39.832	info	../node_modules/nan/nan.h: In function 'v8::Local NanNewBufferHandle(char*, size_t, int)':../node_modules/nan/nan.h:665:50: error: 'callback' was not declared in this scope
                iobroker	2017-08-07 19:45:39.831	info	^
                iobroker	2017-08-07 19:45:39.831	info	, node::smalloc::FreeCallback callback
                iobroker	2017-08-07 19:45:39.831	info	../node_modules/nan/nan.h:661:35: error: expected ',' or '...' before 'callback'
                iobroker	2017-08-07 19:45:39.831	info	../node_modules/nan/nan.h:661:13: error: 'node::smalloc' has not been declared , node::smalloc::FreeCallback callback
                iobroker	2017-08-07 19:45:39.814	info	^
                iobroker	2017-08-07 19:45:39.814	info	../node_modules/nan/nan.h:256:25: note: 'template v8::Local _NanEnsureLocal(v8::Handle)' previously declared here NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
                iobroker	2017-08-07 19:45:39.813	info	^
                iobroker	2017-08-07 19:45:39.813	info	NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
                iobroker	2017-08-07 19:45:39.813	info	In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:261:25: error: redefinition of 'template v8::Local _NanEnsureLocal(v8::Local)'
                iobroker	2017-08-07 19:45:39.047	info	CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                iobroker	2017-08-07 19:45:39.043	info	make: Entering directory '/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil/build'
                iobroker	2017-08-07 19:45:36.893	info	WARN EACCES user "undefined" does not have permission to access the dev dir "/root/.node-gyp/4.8.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker
                iobroker	2017-08-07 19:45:36.891	info
                iobroker	2017-08-07 19:45:36.888	info	gyp
                iobroker	2017-08-07 19:45:35.817	info	> node-gyp rebuild
                iobroker	2017-08-07 19:45:35.817	info	> bufferutil@1.1.0 install /opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil
                iobroker	2017-08-07 19:45:35.804	info	gyp ERR! not ok
                iobroker	2017-08-07 19:45:35.804	info	ERR! node -v v4.8.0gyp ERR! node-gyp -v v3.4.0
                iobroker	2017-08-07 19:45:35.801	info	gyp
                iobroker	2017-08-07 19:45:35.801	info	gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_module
                iobroker	2017-08-07 19:45:35.799	info	gyp ERR! System Linux 3.10.102
                iobroker	2017-08-07 19:45:35.798	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
                iobroker	2017-08-07 19:45:35.798	info	gyp ERR! stack at ChildProcess.emit (events.js:172:7)
                iobroker	2017-08-07 19:45:35.798	info	gyp ERR! stack at emitTwo (events.js:87:13)
                iobroker	2017-08-07 19:45:35.798	info	ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                iobroker	2017-08-07 19:45:35.797	info	gyp
                iobroker	2017-08-07 19:45:35.786	info	gyp ERR! build error
                iobroker	2017-08-07 19:45:35.785	info	make: Leaving directory '/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate/build'make: *** [Release/obj.target
                iobroker	2017-08-07 19:45:35.784	info	validation.target.mk:98: recipe for target 'Release/obj.target/validation/src/validation.o' failed
                iobroker	2017-08-07 19:45:35.626	info	^
                iobroker	2017-08-07 19:45:35.626	info	return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
                iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h:683:12: error: 'Use' is not a member of 'node::Buffer'
                iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h: In function 'v8::Local NanBufferUse(char*, uint32_t)':
                iobroker	2017-08-07 19:45:35.626	info	return node::Buffer::New(v8::Isolate::GetCurrent(), size);
                iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h:676:61: error: could not convert 'node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))' from 'v8::MaybeLocal' to 'v8::Local'
                iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h: In function 'v8::Local NanNewBufferHandle(uint32_t)':
                iobroker	2017-08-07 19:45:35.626	info	In file included from ../src/validation.cc:15:0:
                iobroker	2017-08-07 19:45:35.626	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate/.node-gyp/4.8.0/include/node/node_buffer.h:46:40: note: no
                iobroker	2017-08-07 19:45:35.626	info	NODE_EXTERN v8::MaybeLocal New(v8::Isolate* isolate,
                iobroker	2017-08-07 19:45:35.626	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate/.node-gyp/4.8.0/include/node/node_buffer.h:46:40: note: v8::M
                iobroker	2017-08-07 19:45:35.626	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate/.node-gyp/4.8.0/include/node/node_buffer.h:34:40: note: no
                iobroker	2017-08-07 19:45:35.626	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate/.node-gyp/4.8.0/include/node/node_buffer.h:34:40: note: v8::M
                iobroker	2017-08-07 19:45:35.626	info	In file included from ../src/validation.cc:10:0:
                iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h:672:67: note: candidates are:
                iobroker	2017-08-07 19:45:35.626	info	return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
                iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h:672:67: error: call of overloaded 'New(v8::Isolate*, const char*&, uint32_t&)' is ambiguous
                iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h: In function 'v8::Local NanNewBufferHandle(const char*, uint32_t)':
                iobroker	2017-08-07 19:45:35.626	info	v8::Isolate::GetCurrent(), data, length, callback, hint);
                iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h:665:60: error: 'hint' was not declared in this scope
                iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h: In function 'v8::Local NanNewBufferHandle(char*, size_t, int)':../node_modules/nan/nan.h:665:50: error: 'callback' was not declared in this scope
                iobroker	2017-08-07 19:45:35.625	info	^
                iobroker	2017-08-07 19:45:35.625	info	, node::smalloc::FreeCallback callback
                iobroker	2017-08-07 19:45:35.625	info	../node_modules/nan/nan.h:661:35: error: expected ',' or '...' before 'callback'
                iobroker	2017-08-07 19:45:35.625	info	../node_modules/nan/nan.h:661:13: error: 'node::smalloc' has not been declared , node::smalloc::FreeCallback callback
                iobroker	2017-08-07 19:45:35.610	info	^
                iobroker	2017-08-07 19:45:35.610	info	../node_modules/nan/nan.h:256:25: note: 'template v8::Local _NanEnsureLocal(v8::Handle)' previously declared here NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
                iobroker	2017-08-07 19:45:35.609	info	^
                iobroker	2017-08-07 19:45:35.609	info	NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
                iobroker	2017-08-07 19:45:35.609	info	In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:261:25: error: redefinition of 'template v8::Local _NanEnsureLocal(v8::Local)'
                iobroker	2017-08-07 19:45:34.855	info	CXX(target) Release/obj.target/validation/src/validation.o
                iobroker	2017-08-07 19:45:34.852	info	make: Entering directory '/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate/build'
                iobroker	2017-08-07 19:45:32.228	info	WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate
                iobroker	2017-08-07 19:45:32.226	info	WARN EACCES user "undefined" does not have permission to access the dev dir "/root/.node-gyp/4.8.0"gyp
                iobroker	2017-08-07 19:45:32.222	info	gyp
                iobroker	2017-08-07 19:45:31.056	info	> node-gyp rebuild
                iobroker	2017-08-07 19:45:31.056	info	> utf-8-validate@1.1.0 install /opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate
                iobroker	2017-08-07 19:45:18.710	info	npm install https://github.com/MeisterTR/iobroker.landroid-s/tarball/master --production --prefix "/opt/iobroker" (System call)
                iobroker	2017-08-07 19:45:18.501	info	install https://github.com/MeisterTR/iobroker.landroid-s/tarball/master
                javascript.0	2017-08-07 19:45:18.415	info	script.js.bku.Info.StromDverbrauch: --> Solar: 246 Zähler: 167 VB-akt: 79 VB-avg: 135
                iobroker	2017-08-07 19:45:17.820	info	url "https://github.com/MeisterTR/iobroker.landroid-s" --debug
                Danke und Gruß,
                Bernd
                • MeistertrM
                  MeistertrM
                  Meistertr
                  #119
                  @bku:
                  Hallo MeisterTR,
                  Danke und Gruß,
                  Bernd `
                  Bist du sich dass sie nicht inslalliert ist? der Log sagt was anderes. dass da ein paar fehlermeldungen kommen ist "normal" aber installirt sollte er eigentlich sein.
                  • S
                    S
                    Stoni
                    #120
                    Changelog im Vergleich zur 0.25?
                    Gesendet von meinem ONEPLUS A3003 mit Tapatalk
                    • lobomauL
                      lobomauL
                      lobomau
                      #121
                      @Stoni:
                      Gesendet von meinem ONEPLUS A3003 mit Tapatalk Steht doch auf github: > 0.3.0 (05.08.2017)
                      (MeisterTR) add rawData `
                      Für Normaluser wie mich wohl eher nicht so wichtig.
                      Host: NUC8i3 mit Proxmox:
                      • Slave: Pi4
                      • MeistertrM
                        MeistertrM
                        Meistertr
                        #122
                        Viele Kleinigkeiten, Testmodis entfernt Und die Rohdaten und senden als Objekt hinzugefügt zur schnellen Weiterverarbeitung in Scripten (ins besondere Mahlzeiten ändern für vis so kann man die Daten leicht aus den Rohdaten ziehen anstatt alle Datenpunkte abzuarbeiten).
                        Gesendet von meinem Handy
                        • lobomauL
                          lobomauL
                          lobomau
                          #123
                          Adapter ist wieder verbunden nachdem ich die Handy-App ausprobiert habe.
                          Der Adapter hat sich um 11:20 Uhr abgemeldet und verbindet sich seitdem nicht mehr. Habe nichts gemacht. Ich schwör :)
                          Über Handy-App verbinden funktioniert.
                          landroid-s.0	2017-08-08 11:54:07.369	info	Connected to MQTT broker - subscribing to DB510/MAC-Adresse/commandOut
                          landroid-s.0	2017-08-08 11:54:06.911	info	Connecting to MQTT broker
                          landroid-s.0	2017-08-08 11:54:06.750	info	Fetching root CA
                          landroid-s.0	2017-08-08 11:54:06.672	info	Certificate retrieved
                          landroid-s.0	2017-08-08 11:54:06.361	info	API token set to token2
                          landroid-s.0	2017-08-08 11:54:06.360	info	Logged in as email@gmail.com - user token retrieved from API
                          landroid-s.0	2017-08-08 11:54:05.845	info	API token set to token1
                          landroid-s.0	2017-08-08 11:54:05.843	info	Downloaded guest token
                          landroid-s.0	2017-08-08 11:54:05.623	info	starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.11.2
                          landroid-s.0	2017-08-08 11:53:58.696	info	terminating
                          landroid-s.0	2017-08-08 11:53:58.677	info	cleaned everything up...
                          landroid-s.0	2017-08-08 11:53:28.716	info	Connected to MQTT broker - subscribing to DB510/MAC-Adresse/commandOut
                          landroid-s.0	2017-08-08 11:53:28.246	info	Connecting to MQTT broker
                          landroid-s.0	2017-08-08 11:53:27.606	info	Fetching root CA
                          landroid-s.0	2017-08-08 11:53:27.548	info	Certificate retrieved
                          landroid-s.0	2017-08-08 11:53:27.197	info	API token set to token2
                          landroid-s.0	2017-08-08 11:53:27.196	info	Logged in as email@gmail.com - user token retrieved from API
                          landroid-s.0	2017-08-08 11:53:26.666	info	API token set to token1
                          landroid-s.0	2017-08-08 11:53:26.662	info	Downloaded guest token
                          landroid-s.0	2017-08-08 11:53:26.071	info	starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.11.2
                          landroid-s.0	2017-08-08 11:53:22.218	info	terminating
                          landroid-s.0	2017-08-08 11:53:22.205	info	cleaned everything up...
                          landroid-s.0	2017-08-08 11:20:49.699	info	Disconnect from mower
                          landroid-s.0	2017-08-08 10:40:06.797	info	Connected to mower
                          landroid-s.0	2017-08-08 10:39:49.474	info	Disconnect from mower
                          hab nur paar Daten verfremdet, wie email, token und mac-adresse
                          • Slave: Pi4
                          • MeistertrM
                            MeistertrM
                            Meistertr
                            #124
                            @lobomau:
                            hab nur paar Daten verfremdet, wie email, token und mac-adresse ` Und nun geht's wieder? Bei mir ist es anders herum. Wenn der Adapter verbunden ist, bekomme ich nur manchmal Verbindung zur App. Welche fw hast du drauf?
                            • lobomauL
                              lobomauL
                              lobomau
                              #125
                              Ja, geht wieder. Kurz nach 12 Uhr war es weiterhin etwas unruhig… der Adapter hatte paar Mal die Verbindung verloren, aber nach 1s wieder verbunden.
                              Ich kann immer auch gleichzeitig per App drauf zu greifen.
                              FW ist 2.75.. war mit 2.59 auch so.
                              • Slave: Pi4
                              • S
                                S
                                Sebastian
                                #126
                                Schau mal hier:
                                https://github.com/MeisterTR/iobroker.l … /README.md
                                0.3.0 (05.08.2017)
                                Sebastian
                                • S
                                  S
                                  Stefan1984
                                  #127
                                  Etwas Offtopic:
                                  Kann mir jemand sagen, wie ich die Variablen in die CCU bekomme? Ich möchte gern die Gartenbewässerung erst schalten, wenn der Mäher in der Station steht. Rasi ist zwar gerade in der Reparatur, aber das heißt ja nicht, dass ich untätig sein muss. [emoji6] Cux ist installiert. Über eine kurze Anleitung wäre ich dankbar.
                                  Scripte sind leider nicht so meins.
                                  Vielen Dank im Voraus.
                                  Grüße,
                                  Stefan
                                  • lobomauL
                                    lobomauL
                                    lobomau
                                    #128
                                    Ja, ist etwas offtopic.
                                    Hast du den hm-rega-Adapter installiert? Damit siehst du alle Variablen der CCU und kannst diese schalten. Musst nur die Variablen in der CCU anlegen. Das Programm für die Gartenbewässerung läuft wahrscheinlich schon auf der CCU, ansonsten kannst du ja ein Programm in ioBroker machen. Ist auch schwieriger, ich finde sogar einfacher als mit homematic.
                                    CuxD brauchst du nicht, um die Variablen der CCU zu sehen/steuern.
                                    Edit: um ein kleines Programm in ioB kommst du ja nicht drumherum, welches die Variable in der CCU schaltet.
                                    Edit2: hier wurde das Thema behandelt:
                                    http://forum.iobroker.net/viewtopic.php … ble#p78274
                                    • Slave: Pi4
                                    • S
                                      S
                                      Stefan1984
                                      #129
                                      Die Bewässerung steuere ich normal über Homematic Schaltaktor. Entsprechende Programme sind in der CCU hinterlegt. Generell habe ich alle Programme in der CCU. Ich würde gern vermeiden, dass ich die Programme mal hier und mal da habe. Den Rega hab ich installiert, da bekomme ich alle Variablen in io.Broker angezeigt. Aber eigentlich möchte ich es gern anders herum. Ist das auch ohne weiteres möglich?
                                      • M
                                        M
                                        MeraLuna
                                        #130
                                        Hi Zusammen erstmal super cool der Adapter und Läuft genial, mit IoBroker befasse ich mich noch nicht so lange erst 1 Woche ca. also Neuer Neuling.
                                        mein Tab was ich zur Steuerung benutze sieht so aus wie auf dem Bild unten, ich würde jedoch gern noch einbauen was er gerade macht also ob Tornado lädt fährt oder Warnmeldungen Stecke fest, das heist die States im Grunde das schaffe ich aber nur zur Ausgabe als zahl nicht der betreffende Text also z.b 7 was heist das er Fährt usw.
                                        geht das mit wingets ? oder mus ich das mit nen Skript umwandeln also 0 heist das usw. ?
                                        LG Luna
                                        • M
                                          M
                                          Mighty
                                          #131
                                          Habe jetzt auf die neuste Version geupdated. Dazu den alten Adapter gelöscht und neu installiert. Dabei gehen alle History Einstellungen verloren.
                                          Geht das auch einfacher?
                                          Grüße Mighty
                                          ps kleiner Schreibfehler:
                                          landroid-s.0.areas.actualAreaIndecator -> landroid-s.0.areas.actualAreaIndicator
                                          WR105SI - FW 2.85 - APP 1.6.9 - Rasen 200 m²
                                          Loxone Smart Home
                                          84.2k
