  4. [2.5.9 Fehler existiert] - Backup-Adapter erzeugt Fehler
    5.6k
66 Beiträge 6 Kommentatoren 8.4k Aufrufe 5 Beobachtet
    @skinni
    Buster ist tot. Installier da das aktuelle stable release 'Bullseye'.
    skinni
    @thomas-braun hab jetzt auch im backup adapter den Fehler, das bullseye upgrade werde ich dieses WE angehen, erst mal sd-card klonen
    ted iobroker ...
    [DEBUG] [mount] - mount activ... umount is started before mount!!
    [DEBUG] [mount] - umount successfully completed
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=pi,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.88.110/PIBackup /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [ERROR] [iobroker] - node:internal/bootstrap/switches/does_own_process_state:126
        cachedCwd = rawMethods.cwd();
    Error: ENOENT: no such file or directory, uv_cwd
        at process.wrappedCwd (node:internal/bootstrap/switches/does_own_process_state:126:28)
        at Object.process.cwd (/opt/iobroker/node_modules/graceful-fs/polyfills.js:10:19)
        at fe.Yargs (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/index.cjs:1:61304)
        at Argv (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:12:16)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:7:1)
        at Module._compile (node:internal/modules/cjs/loader:1155:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
        at Module.load (node:internal/modules/cjs/loader:1033:32)
        at Function.Module._load (node:internal/modules/cjs/loader:868:12)
        at Module.require (node:internal/modules/cjs/loader:1057:19) {
      errno: -2,
      code: 'ENOENT',
      syscall: 'uv_cwd'
    Siggi0904S 1 Antwort Letzte Antwort
    • S skinni
      ted iobroker ...
        errno: -2,
        code: 'ENOENT',
        syscall: 'uv_cwd'
      Siggi0904S Offline
      Siggi0904S Offline
      Siggi0904
      @skinni Start mal den Rechner neu. Du wirst sehen, dann ist der Fehler weg.
      • Siggi0904S Siggi0904
        skinni
        @siggi0904 Der Fehler verschwindet auch von alleine, genauso wie er kommt. Das soll nicht meine Lösung sein. Hab jetzt mal das Update auf bullseye gemacht, das lief überraschend gut. Hab mich dabei an die Anleitung https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye gehalten
        Thomas BraunT Siggi0904S 2 Antworten Letzte Antwort
        • S skinni
          @skinni
          Jag den Fixer mal drüber.
          iob stop
          iob fix
          iob start
          Und wie startest du das Backup?
            @skinni
            iob stop
            iob fix
            iob start
            skinni
            @thomas-braun Die Frage versteh ich nicht. Ich starte das Backup eigentlich gar nicht, das macht ja der backitup Adapter jede Nacht und ist dabei erfolgreich, oder manchmal auch nicht. Das da oben hatte ich im backitup Adapter manuell gestartet durch Klick auf "Jetzt sichern" unter iobroker im backitup Adapter. Das funktioniert jetzt aktuell auch gerade wieder - bis es dann in ein paar Tragen vermutlich nicht mehr geht ;)
            Den fixer hatte ich heute nach dem bullseye upgrade schon drüber laufen lassen, sicher ist sicher.
            Thomas BraunT simatecS 2 Antworten Letzte Antwort
            • S skinni
              @skinni sagte in [wieder geöffnet] - Backup-Adapter erzeugt Fehler:
              Das war genau die Frage. Die Meldung kommt eigentlich wenn man da mit einem user in einem Verzeichnis steht, dieses verändert wird und das dann alles 'in der Luft' hängt.
              • S skinni
                Siggi0904S Offline
                Siggi0904S Offline
                Siggi0904
                @skinni Bei mir verschwindet der Fehler nicht automatisch.
                Wenn er einmal auftritt, bleibt er bis zum Neustart stehen.
                  skinni
                  schrieb am zuletzt editiert von skinni
                  Lief jetzt bis heute ohne Probleme, musste aber erstmal zurück auf buster weil mein conbee II nicht mehr funktioniert hat :/
                  • S skinni
                    Das ist kein Grund, der läuft natürlich auch unter 'bullseye'.
                      simatecS Offline
                      simatecS Offline
                      simatec
                      @siggi0904 Tritt der Fehler in v2.5.9 bei dir noch auf?
                      • Besuche meine Github Seite
                      • HowTo Restore ioBroker
                      Siggi0904S 3 Antworten Letzte Antwort
                      • S skinni
                        simatecS Offline
                        simatecS Offline
                        simatec
                        @skinni Welche Version von Backitup ist installiert? In v2.5.9 ist etwas eingebaut, um den fehler abzufangen.
                        Wenn der Fehler auftreten sollte, starte mal den Adapter neu und poste den Debug Log
                        • simatecS simatec
                          Siggi0904S Offline
                          Siggi0904S Offline
                          Siggi0904
                          @simatec Ich habe erst gerade die neue Version erhalten.
                          Das muss ich erst testen. Danke für den Hinweis.
                          • simatecS simatec
                            Siggi0904S Offline
                            Siggi0904S Offline
                            Siggi0904
                            @simatec Tests sind durch, auch die automatischen Backups liefen heute ohne Probleme durch.
                            Ich hatte bei der alten Version den Fehler, ohne Neustart mit der neuen Version läuft alles super.
                            Ich setze das Thema auf erledigt.
                            • simatecS simatec
                              Siggi0904S Offline
                              Siggi0904S Offline
                              Siggi0904
                              @simatec Das Problem ist heute wieder aufgetreten. 😠
                                simatecS Offline
                                simatecS Offline
                                simatec
                                @siggi0904 Kannst du bitte den Log posten?
                                Das Problem muss tiefer liegen und mit großer Wahrscheinlichkeit in nodejs liegen
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  @siggi0904 Wurde der Adapter vor auftreten des Problems neu gestartet? Wenn ja auch hier bitte den Debuglog vom restart des Adapters posten
                                  • simatecS simatec
                                    Siggi0904S Offline
                                    Siggi0904S Offline
                                    Siggi0904
                                    @simatec Hallo, nein. Ich hab über das System auf die neue Version aktualisiert und am folgenden Tag (vor 3 Tagen) lief es sauber durch.
                                    Heute Morgen ist der Fehler aufgetreten.
                                    Hast du eine Mail-Adresse, an die ich das senden kann?
                                    Ist ja erstens viel und zweitens mit persönlichen Daten.
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      @siggi0904 Bitte poste hier nur den teil des Backups. Da sind keine Daten sichtbar
                                      • simatecS simatec
                                        Siggi0904S Offline
                                        Siggi0904S Offline
                                        Siggi0904
                                        @simatec
                                        Super, der Fehler tritt nach dem Neustart des Adapters im Debug-Mode nicht auf.
                                        Dann muss ich wieder ein paar Tage warten, bis der Fehler auftritt.
                                        Dann hier die Logs:
                                        Startup der Instanz mit Debug-Mode
                                        2022-12-19 16:09:08.926 - info: backitup.0 (3064907) Got terminate signal TERMINATE_YOURSELF
                                        2022-12-19 16:09:08.927 - info: backitup.0 (3064907) cleaned everything up...
                                        2022-12-19 16:09:08.928 - info: backitup.0 (3064907) terminating
                                        2022-12-19 16:09:08.929 - info: backitup.0 (3064907) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2022-12-19 16:09:09.162 - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
                                        2022-12-19 16:09:09.671 - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2022-12-19 16:09:12.300 - info: host.iobroker instance system.adapter.backitup.0 started with pid 989622
                                        2022-12-19 16:09:13.615 - debug: backitup.0 (989622) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2022-12-19 16:09:13.660 - debug: backitup.0 (989622) Objects client ready ... initialize now
                                        2022-12-19 16:09:13.756 - debug: backitup.0 (989622) Objects create System PubSub Client
                                        2022-12-19 16:09:13.757 - debug: backitup.0 (989622) Objects create User PubSub Client
                                        2022-12-19 16:09:13.890 - debug: backitup.0 (989622) Objects client initialize lua scripts
                                        2022-12-19 16:09:13.903 - debug: backitup.0 (989622) Objects connected to redis: 127.0.0.1:9001
                                        2022-12-19 16:09:13.951 - debug: backitup.0 (989622) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2022-12-19 16:09:14.046 - debug: backitup.0 (989622) States create System PubSub Client
                                        2022-12-19 16:09:14.047 - debug: backitup.0 (989622) States create User PubSub Client
                                        2022-12-19 16:09:14.123 - debug: backitup.0 (989622) States connected to redis: 127.0.0.1:9000
                                        2022-12-19 16:09:14.282 - debug: backitup.0 (989622) Plugin sentry Initialize Plugin (enabled=true)
                                        2022-12-19 16:09:14.938 - info: backitup.0 (989622) starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
                                        2022-12-19 16:09:14.999 - debug: backitup.0 (989622) Backitup has recognized a linux system
                                        2022-12-19 16:09:15.085 - info: backitup.0 (989622) [iobroker] backup was activated at 01:00 every 2 day(s)
                                        2022-12-19 16:09:15.158 - debug: backitup.0 (989622) [iobroker] 10 00 01 */2 * *
                                        2022-12-19 16:09:15.159 - info: backitup.0 (989622) [ccu] backup was activated at 01:15 every 3 day(s)
                                        2022-12-19 16:09:15.176 - debug: backitup.0 (989622) [ccu] 10 15 01 */3 * *
                                        2022-12-19 16:09:15.218 - debug: backitup.0 (989622) noserverino option: false
                                        2022-12-19 16:09:15.218 - debug: backitup.0 (989622) cifs-mount command: "sudo mount -t cifs -o username=admin,password=****,rw,file_mode=0777,dir_mode=0777,vers=2.0 //Datenschlampe/Backup/Homematic-Pi/iobroker/standard /opt/iobroker/backups"
                                        2022-12-19 16:09:20.159 - debug: backitup.0 (989622) mount successfully completed
                                        2022-12-19 16:09:22.891 - debug: backitup.0 (989622) detect backup file 1 from NAS: iobroker_2022_12_03-01_00_27_backupiobroker.tar.gz
                                        2022-12-19 16:09:22.891 - debug: backitup.0 (989622) detect backup file 2 from NAS: iobroker_2022_12_05-01_00_24_backupiobroker.tar.gz
                                        2022-12-19 16:09:22.892 - debug: backitup.0 (989622) detect backup file 3 from NAS: iobroker_2022_12_07-01_00_27_backupiobroker.tar.gz
                                        2022-12-19 16:09:22.892 - debug: backitup.0 (989622) detect backup file 4 from NAS: iobroker_2022_12_15-01_00_25_backupiobroker.tar.gz
                                        2022-12-19 16:09:22.892 - debug: backitup.0 (989622) detect backup file 5 from NAS: iobroker_2022_12_17-01_00_25_backupiobroker.tar.gz
                                        2022-12-19 16:09:22.893 - debug: backitup.0 (989622) detect last backup file: iobroker_2022_12_17-01_00_25_backupiobroker.tar.gz
                                        2022-12-19 16:09:25.087 - debug: backitup.0 (989622) mount activ... umount in 2 Seconds!!
                                        2022-12-19 16:09:27.493 - debug: backitup.0 (989622) umount successfully completed
                                        Log vom Backup (Leider ohne Fehler):
                                        2022-12-19 16:12:26.816 - debug: backitup.0 (989622) Backup has started ...
                                        2022-12-19 16:12:36.816 - debug: backitup.0 (989622) [iobroker/mount] noserverino option: false
                                        2022-12-19 16:12:36.817 - debug: backitup.0 (989622) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=admin,password=****,rw,file_mode=0777,dir_mode=0777,vers=2.0 //Datenschlampe/Backup/Homematic-Pi/iobroker/standard /opt/iobroker/backups"
                                        2022-12-19 16:12:41.581 - debug: backitup.0 (989622) [iobroker/mount] mount successfully completed
                                        2022-12-19 16:12:41.583 - debug: backitup.0 (989622) [iobroker/mount] done
                                        2022-12-19 16:12:44.936 - debug: backitup.0 (989622) [iobroker/iobroker] host.iobroker 7667 states saved
                                        2022-12-19 16:12:45.076 - debug: backitup.0 (989622) [iobroker/iobroker] host.iobroker 9295 objects saved
                                        2022-12-19 16:12:48.650 - debug: backitup.0 (989622) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2022_12_19-16_12_41_backupiobroker.tar.gz
                                        2022-12-19 16:12:49.718 - debug: backitup.0 (989622) [iobroker/iobroker] done
                                        2022-12-19 16:12:50.022 - debug: backitup.0 (989622) [iobroker/mysql] MySql-Backup started ...
                                        2022-12-19 16:14:36.723 - debug: backitup.0 (989622) [iobroker/mysql] MySql File deleted!
                                        2022-12-19 16:14:36.726 - debug: backitup.0 (989622) [iobroker/mysql] MySql-Backup for is finish
                                        2022-12-19 16:14:36.726 - debug: backitup.0 (989622) [iobroker/mysql] done
                                        2022-12-19 16:14:37.977 - debug: backitup.0 (989622) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                                        2022-12-19 16:14:38.312 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Klima-Wohnzimmer
                                        2022-12-19 16:14:38.313 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Wechselschaltung
                                        2022-12-19 16:14:38.313 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Fenster_geschlossen
                                        2022-12-19 16:14:38.313 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Klima-Bad
                                        2022-12-19 16:14:38.314 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Klima-Schlafzimmer
                                        2022-12-19 16:14:38.314 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Tests
                                        2022-12-19 16:14:38.314 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Fenster_geschlossen
                                        2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: BattUeberwachung
                                        2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: FensterOffenLichtAnSteckdosenEin
                                        2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Licht_überall_aus
                                        2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Steckdosen_überall_aus
                                        2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Eingangstür_offen
                                        2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: BattUeberwachungAlexa
                                        2022-12-19 16:14:38.318 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Alarmanlage
                                        2022-12-19 16:14:38.319 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: ErreichbarkeitAlexa
                                        2022-12-19 16:14:38.319 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Aqara_Zauberwürfel
                                        2022-12-19 16:14:38.319 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: MorgensLichtEinArbeit
                                        2022-12-19 16:14:38.320 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: EingangstürAlexa
                                        2022-12-19 16:14:38.321 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TemperaturAnsage
                                        2022-12-19 16:14:38.321 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftfeuchtigkeitAnsage
                                        2022-12-19 16:14:38.322 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftdruckAnsage
                                        2022-12-19 16:14:38.322 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftfeuchtigkeitAnsage
                                        2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftfeuchtigkeitAnsage
                                        2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AnwesenheitTaster
                                        2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AnwesenheitHandy
                                        2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TestHandyErreichbarkeit
                                        2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: PersonKommt
                                        2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: WillkommenZuhause
                                        2022-12-19 16:14:38.324 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: HandyLaden100%
                                        2022-12-19 16:14:38.324 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: HandystatusAnsage
                                        2022-12-19 16:14:38.326 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: HandyAkkustandMinimal
                                        2022-12-19 16:14:38.326 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TabletStatusAnsage
                                        2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TabletAkkustandMinimal
                                        2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TabletLaden100%
                                        2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AdapterNeustarten
                                        2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: CarportLichtAus
                                        2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: CarportLichtMorgensEin
                                        2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: CarportLichtAbendsEin
                                        2022-12-19 16:14:38.328 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AstroDaten
                                        2022-12-19 16:14:38.328 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Jalousiesteuerung
                                        2022-12-19 16:14:38.328 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Helligkeit-AußenAnsage
                                        2022-12-19 16:14:38.330 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Klima-AußenAnsage
                                        2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Jalousiesteuerung
                                        2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Xiaomi_Geräte
                                        2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftreinigerEinAus
                                        2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftqualitätAnsage
                                        2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Nachtmodus
                                        2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: BenzinpreiseAnsage
                                        2022-12-19 16:14:38.332 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: NachttischAus
                                        2022-12-19 16:14:38.332 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: StatusHomeMatic
                                        2022-12-19 16:14:38.332 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: WeckerAusUrlaubKrank
                                        2022-12-19 16:14:38.332 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: IchBinWeg
                                        2022-12-19 16:14:38.335 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AnwesenheitBewegung
                                        2022-12-19 16:14:38.335 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Eiswarnung
                                        2022-12-19 16:14:38.931 - debug: backitup.0 (989622) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                                        2022-12-19 16:14:39.085 - debug: backitup.0 (989622) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                                        2022-12-19 16:14:39.086 - debug: backitup.0 (989622) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2022_12_19-16_14_37_backupiobroker.tar.gz
                                        2022-12-19 16:14:39.086 - debug: backitup.0 (989622) [iobroker/javascripts] done
                                        2022-12-19 16:14:39.538 - debug: backitup.0 (989622) [iobroker/cifs] used copy path: /Backup/Homematic-Pi/iobroker/standard
                                        2022-12-19 16:14:39.538 - debug: backitup.0 (989622) [iobroker/cifs] done
                                        2022-12-19 16:14:40.141 - debug: backitup.0 (989622) [iobroker/clean] done
                                        2022-12-19 16:14:41.057 - debug: backitup.0 (989622) [iobroker/historyHTML] new history html values created
                                        2022-12-19 16:14:41.058 - debug: backitup.0 (989622) [iobroker/historyHTML] done
                                        2022-12-19 16:14:41.322 - debug: backitup.0 (989622) [iobroker/historyJSON] new history json values created
                                        2022-12-19 16:14:41.323 - debug: backitup.0 (989622) [iobroker/historyJSON] done
                                        2022-12-19 16:14:41.492 - debug: backitup.0 (989622) [iobroker/umount] mount activ, umount is started ...
                                        2022-12-19 16:14:46.709 - debug: backitup.0 (989622) [iobroker/umount] umount successfully completed
                                        2022-12-19 16:14:46.711 - debug: backitup.0 (989622) [iobroker/umount] done
                                        2022-12-19 16:14:46.863 - debug: backitup.0 (989622) [iobroker] exec: done
                                        Aus der Historie (log von heute vor dem Restart des Adapters), der Fehler:
                                        2022-12-19 15:44:32.227 - error: backitup.0 (3064907) [iobroker/iobroker] node:internal/bootstrap/switches/does_own_process_state:126
                                        2022-12-19 15:44:32.229 - error: backitup.0 (3064907) [iobroker/iobroker] cachedCwd = rawMethods.cwd();
                                        2022-12-19 15:44:32.229 - error: backitup.0 (3064907) [iobroker/iobroker] ^
                                        2022-12-19 15:44:32.229 - error: backitup.0 (3064907) [iobroker/iobroker] Error: ENOENT: no such file or directory, uv_cwd
                                        2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at process.wrappedCwd (node:internal/bootstrap/switches/does_own_process_state:126:28)
                                        2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at Object.process.cwd (/opt/iobroker/node_modules/graceful-fs/polyfills.js:10:19)
                                        2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at fe.Yargs (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/index.cjs:1:61304)
                                        2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at Argv (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:12:16)
                                        2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at Object. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:7:1)
                                        2022-12-19 15:44:32.235 - error: backitup.0 (3064907) [iobroker/iobroker] at Module._compile (node:internal/modules/cjs/loader:1155:14)
                                        2022-12-19 15:44:32.235 - error: backitup.0 (3064907) [iobroker/iobroker] at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
                                        2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] at Module.load (node:internal/modules/cjs/loader:1033:32)
                                        2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] at Function.Module._load (node:internal/modules/cjs/loader:868:12)
                                        2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] at Module.require (node:internal/modules/cjs/loader:1057:19) {
                                        2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] errno: -2,
                                        2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] code: 'ENOENT',
                                        2022-12-19 15:44:32.237 - error: backitup.0 (3064907) [iobroker/iobroker] syscall: 'uv_cwd'
                                        2022-12-19 15:44:32.237 - error: backitup.0 (3064907) [iobroker/iobroker] }
                                          @simatec
                                          Dann hier die Logs:
                                          @siggi0904
                                          Smb vers=2.0 dürfte falsch sein. Mittlerweile sollte eigentlich alles auf Version 3 sein.
