  4. Diskussion zum HowTo nodejs-Installation und upgrade
nodejs
844 Beiträge 91 Kommentatoren 327.7k Aufrufe 63 Beobachtet
  • K knopers1
    pi@raspberrypi:/opt/iobroker $ sudo rm /etc/apt/sources.list.d/nodesource.list
    pi@raspberrypi:/opt/iobroker $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
    ## Installing the NodeSource Node.js 16.x repo...
    ## Populating apt-get cache...
    + apt-get update
    OK:1 http://archive.raspberrypi.org/debian buster InRelease
    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    ## Confirming "buster" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
    gpg: WARNUNG: Unsicheres Besitzverhältnis des Home-Verzeichnis `/home/pi/.gnupg'
    ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    Holen:3 https://deb.nodesource.com/node_16.x buster InRelease [4.584 B]
    Holen:4 https://deb.nodesource.com/node_16.x buster/main armhf Packages [781 B]
    Es wurden 5.365 B in 1 s geholt (3.662 B/s).
    ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    #435
    @knopers1
    sudo apt update
    apt policy nodejs
    Und dann kannst/solltest du den Schwung auf 'bullseye' machen.
      @knopers1
      sudo apt update
      apt policy nodejs
      knopers1
      #436
      pi@raspberrypi:/opt/iobroker $ sudo apt update
      OK:3 https://deb.nodesource.com/node_16.x buster InRelease
      Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
      pi@raspberrypi:/opt/iobroker $ apt policy nodejs
      nodejs:
        Installiert:           12.22.12-deb-1nodesource1
        Installationskandidat: 16.18.1-deb-1nodesource1
        Versionstabelle:
           16.18.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
       *** 12.22.12-deb-1nodesource1 100
           10.24.0~dfsg-1~deb10u2 500
      • K knopers1
        nodejs:
          Versionstabelle:
        #437
        @knopers1
        Dann jetzt upgraden und dann halt wie in der Anleitung auf bullseye springen.
          @knopers1
          knopers1
          schrieb am zuletzt editiert von knopers1
          #438
          pi@raspberrypi:/opt/iobroker $ sudo apt upgrade
          Paketaktualisierung (Upgrade) wird berechnet... Fertig
          Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
            rpi-eeprom-images
          Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
            nodejs
          1 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
          Es müssen 24,2 MB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 34,0 MB Plattenplatz zusätzlich benutzt.
          Möchten Sie fortfahren? [J/n] j
          Holen:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.18.1-deb-1nodesource1 [24,2 MB]
          Es wurden 24,2 MB in 3 s geholt (7.030 kB/s).
          Changelogs werden gelesen... Fertig
          (Lese Datenbank ... 52692 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../nodejs_16.18.1-deb-1nodesource1_armhf.deb ...
          Entpacken von nodejs (16.18.1-deb-1nodesource1) über (12.22.12-deb-1nodesource1) ...
          nodejs (16.18.1-deb-1nodesource1) wird eingerichtet ...
          Trigger für man-db (2.8.5-2) werden verarbeitet ...
          pi@raspberrypi:/opt/iobroker $ ^C
          • K knopers1
              rpi-eeprom-images
              nodejs
            knopers1
            #439
            @knopers1
            Thomas weiter hiermit?
            sudo sed -i 's/bullseye\/updates/bullseye-security/g' /etc/apt/sources.list
            sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list
            sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list.d/*
            • K knopers1
              @knopers1
              #440
              @knopers1
              Ja, wie im entsprechenden HowTo drin.
                @knopers1
                knopers1
                #441
                was soll ich an dieser Stelle tun?
                • K knopers1
                  #442
                  @knopers1
                  Weiter gehen. Ist halt der ReadMe-Kram bei Release-Upgrades.
                    @knopers1
                    knopers1
                    #443
                    mit Enter komm i9ch ja nicht weiter.... muss ich etwas eingeben?
                    • K knopers1
                      #444
                      @knopers1
                      q für quit mal versucht?
                        @knopers1
                        knopers1
                        #445
                        ja, habe nicht gesehen, dass man den Kramm nach unten schieben kann....
                        Auf yes nehme ich an?
                        • K knopers1
                          #446
                          @knopers1
                          Ja, es sei denn du willst das die SSH-Verbindung abreißt.
                          Vermutlich willst du das aber nicht.
                            @knopers1
                            knopers1
                            #447
                            puhh, ich möchte die Installation zu Ende bringen....
                            Soll ich auf Yes drücken Thomas?
                            • K knopers1
                              #448
                              @knopers1
                              Ja, natürlich.
                                @knopers1
                                Ja, natürlich.
                                knopers1
                                #449
                                läuft weiter.... Riesen Dank vorab... ich bin aber noch nicht durch 😧
                                • K knopers1
                                  knopers1
                                  #450
                                  • K knopers1
                                    #451
                                    @knopers1
                                    Bei Rückfragen, welche Version der Konfigurationsdateien muss mal reinschauen, ob man da ggf. eigene Anpassungen getätigt hat, ansonsten würde ich die neue Version des Maintainers übernehmen.
                                      @knopers1
                                      knopers1
                                      #452
                                      also nehme ich eine neue Version ....?
                                      • K knopers1
                                        #453
                                        @knopers1
                                        Kann ich dir nicht sagen, ich weiß ja nicht was/ob du da Änderungen getätigt hast. Wenn nicht gilt halt vorheriges.
                                          @knopers1
                                          knopers1
                                          #454
                                          unter /etc/default/useradd
                                          habe ich so nie etwas geändert.. dann doch dann mit N weiter?
