  4. ZigBee neue Version 1.8.x
385 Beiträge 55 Kommentatoren 110.9k Aufrufe 49 Beobachtet
  • amg_666A amg_666
    Also ich hab jetzt über github die 1.8.7 installiert.
    Adapter ist grün, scheint auch zu funktionieren, aber im Log habe ich jede Menge Warnungen:
    zigbee.0
    	2022-12-01 23:32:10.003	warn	DeviceAvailability:Failed to ping 0x00124b00235279d6 ZB-CL01
    zigbee.0
    	2022-12-01 23:32:09.356	warn	DeviceAvailability:Failed to ping 0x00124b00234ca487 ZB-CL01
    zigbee.0
    	2022-12-01 23:31:46.707	warn	This object will not be created in future versions. Please report this to the developer.
    zigbee.0
    	2022-12-01 23:31:46.707	warn	Object zigbee.0.84fd27fffecf6567.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    zigbee.0
    	2022-12-01 23:31:46.702	warn	This object will not be created in future versions. Please report this to the developer.
    zigbee.0
    	2022-12-01 23:31:46.701	warn	Object zigbee.0.84fd27fffecf6567.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    zigbee.0
    	2022-12-01 23:31:46.534	warn	This object will not be created in future versions. Please report this to the developer.
    zigbee.0
    	2022-12-01 23:31:46.533	warn	Object 84fd27fffecf6567.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    zigbee.0
    	2022-12-01 23:31:46.532	warn	This object will not be created in future versions. Please report this to the developer.
    zigbee.0
    	2022-12-01 23:31:46.531	warn	Object 84fd27fffecf6567.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    zigbee.0
    	2022-12-01 23:31:45.404	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
    zigbee.0
    	2022-12-01 23:31:45.401	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
    zigbee.0
    	2022-12-01 23:31:45.398	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
    zigbee.0
    	2022-12-01 23:31:45.395	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
    zigbee.0
    	2022-12-01 23:31:45.389	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
    zigbee.0
    	2022-12-01 23:31:45.386	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
    zigbee.0
    	2022-12-01 23:31:45.383	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
    zigbee.0
    	2022-12-01 23:31:45.380	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
    zigbee.0
    	2022-12-01 23:31:45.375	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
    zigbee.0
    	2022-12-01 23:31:45.353	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
    zigbee.0
    	2022-12-01 23:31:45.350	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
    zigbee.0
    	2022-12-01 23:31:45.347	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
    zigbee.0
    	2022-12-01 23:31:45.326	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
    zigbee.0
    	2022-12-01 23:31:45.312	info	Zigbee started
    arteckA Offline
    arteckA Offline
    arteck
    @amg_666 sagte in ZigBee neue Version 1.8.x:
    84fd27fffecf6567
    zeig mal die Datenpunkte von dem und die Kachel mit der Infoseite
    für den Rest hier
    https://github.com/ioBroker/ioBroker.zigbee/wiki/Missing-icons-after-adatapter-Update
    @spotterblog
    54ef44100044c6af
    von dem auch Kachel und die Infoseite
    • S spotterblog
      1.8.7 läuft soweit.
      Firmware Updates haben jetzt auch funktioniert.
      Lediglich meine Steckdosenleiste hat leider in der neuen Version immer noch keinen vollen Support.
      Nach dem Starten kommt immer dieser Fehler:
      DeviceConfigure:Failed to DeviceConfigure.configure 0x70b3d52b60012015 TS011F (Error: Read 0x70b3d52b60012015/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received) at DeconzAdapter.sendZclFrameToEndpoint (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:658:23) at Endpoint.sendRequest (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:299:20) at Endpoint.read (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:472:28) at Object.configureMagicPacket (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/tuya.js:1179:9) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/useelink.js:36:13) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:134:13) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:112:17) at DeviceConfigure.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:54:21) at async Promise.all (index 1))
      Dann alle 5min dieser:
      DeviceConfigure:Failed to DeviceConfigure.configure 0x70b3d52b60012015 TS011F (TypeError: Cannot read properties of undefined (reading 'debug') at Object.configureMagicPacket (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/tuya.js:1184:20) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/useelink.js:36:13) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:134:13) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:112:17))
      arteckA Offline
      arteckA Offline
      arteck
      @spotterblog sagte in ZigBee neue Version 1.8.x:
      am conbee ?? dann mach erst ein firmwareupdate von dem Teil
      • L Offline
        legro
        @arteck said in ZigBee neue Version 1.8.x:
        es ist mal wieder eine neue Version da..
        diesmal hat sich nicht viel getan..
        Heißt das auch, dass hinsichtlich der BITRON-Sirenen sich nichts getan hat? 😕 Dort funktioniert die Konfiguration der Geräte payload ja nicht mehr richtig.
        Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
        • L legro
          arteckA Offline
          arteckA Offline
          arteck
          @legro schau im chanege log..
          ich war an der Sirene nicht dran
          • arteckA arteck
            diesmal hat sich nicht viel getan..ausser neue Geräte wurden aktualisiert
            alles zu der Version hier rein
            @arteck 1.8.7 ohne Mucken im Log, super, Danke!
            Statesmapping auch wieder komplett richtig da.
            • P Offline
              Pap
              1.8.7 läuft nicht. Sämtliche Silvercrast Steckdosenleisten werden als Steckdose angezeigt und lassen sich nicht mehr steuern.
              • P Pap
                arteckA Offline
                arteckA Offline
                arteck
                @pap das ist schön..ich hol mal die Glaskugel
                • P Offline
                  Pap
                  @arteck
                  Die Lidl HG06338 Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) 2827565c-d139-457f-8162-63d45213ca49-image.png
                  wird als
                  Protokoll:
                  2022-12-02 09:33:15.545 - error: zigbee.1 (1460235) No state available for 'TS011F_plug_3' with key 'state_l2'
                  • P Pap
                    @arteck
                    wird als
                    Protokoll:
                    amg_666A Offline
                    amg_666A Offline
                    amg_666
                    schrieb am zuletzt editiert von amg_666
                    @pap Kann ich exakt so bestätigen :-(
                    Im Adapter wird die 3er Steckdose so angezeigt:
                    Brightness/Color temperature etc sind auch Unsinn bei einer Steckdose
                    • arteckA Offline
                      arteckA Offline
                      arteck
                      ahh...schau ich später .. die hab ich auch hier verpackt
                      so installiert mal von GIT
                      ist ein Fehler im converter nicht bei uns..sollte aber wieder tun mit der GIT version
                      • arteckA arteck
                        amg_666A Offline
                        amg_666A Offline
                        amg_666
                        @arteck Mit der github Installation sieht das jetzt wieder besser aus:
                        Ich bin mir nicht sicher, aber ich glaube Color Temp etc war früher auch schon drin obwohl es keinen Sinn macht.
                        • amg_666A amg_666
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @amg_666 drückmal den hier
                          dann immer noch.. ??
                          • arteckA arteck
                            so neue version ist unterwegs.. 1.8.7 da sollte wieder alles tun
                            L Online
                            L Online
                            Lucky_ESA
                            @arteck Bist du so nett und fügst die 4 ICON noch hinzu. Dein automatischer upload funktioniert nicht da die nicht per writeFile() hinzugefügt werden. Muss das immer manuell machen😁
                            https://www.zigbee2mqtt.io/images/devices/HG06620.jpg
                            https://www.zigbee2mqtt.io/images/devices/HG06337.jpg
                            https://www.zigbee2mqtt.io/images/devices/HG08383A.jpg
                            https://www.zigbee2mqtt.io/images/devices/FB20-002.jpg
                            Gruß//Lucky
                            • P Offline
                              Pap
                              @arteck State Cleanup wird die Steckdose wieder korrekt angezeigt, aber weiterhin kein schalten möglich.
                              Wenn die Steckdosenleiste neu angelernt wird, dann wird sie korrekt erkannt und lässt sich wieder schalten
                              • arteckA arteck
                                amg_666A Offline
                                amg_666A Offline
                                amg_666
                                @arteck Yepp, jetzt sind die "orphan states" weg. 👍
                                • P Offline
                                  Pap
                                  einmal Iobroker fix (ob es was bringt). Danach Touchlink zurücksetzen und koppeln und Tada Lidl 3 Fach Steckdose korrekt angezeigt und schalten auch wieder.
                                  • L Lucky_ESA
                                    Gruß//Lucky
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @lucky_esa na so einfah ist es nicht..
                                    warum werden die nicht hinzugefügt ?? wie ist den der link zu zigbee2mqtt ?? der sollte im LOG stehen
                                    L 1 Antwort Letzte Antwort
                                    • arteckA arteck
                                      L Online
                                      L Online
                                      Lucky_ESA
                                      @arteck sagte in ZigBee neue Version 1.8.x:
                                      Stehen doch in meinem Beitrag. Wenn du Dateien mit fs speicherst werden diese nicht in die _data.json eingefügt und stehen somit auch nicht zur Verfügung.
                                      Gruß//Lucky
                                      • arteckA arteck
                                        84fd27fffecf6567
                                        für den Rest hier
                                        @spotterblog
                                        54ef44100044c6af
                                        spotterblog
                                        @spotterblog
                                        54ef44100044c6af
                                        Bitteschön.
                                        Bildschirmfoto 2022-12-02 um 17.02.02.png Bildschirmfoto 2022-12-02 um 17.02.15.png Bildschirmfoto 2022-12-02 um 17.01.29.png
                                        • arteckA arteck
                                          spotterblog
                                          @arteck
                                          Laut der Seite bin ich aktuell:
                                          https://deconz.dresden-elektronik.de/deconz-firmware/
                                          0x26780700
                                          Habe ich erst vorgestern geflasht.
