  4. Adapter: fritzdect
Adapter: fritzdect
706 Beiträge 90 Kommentatoren 305.5k Aufrufe 27 Beobachtet
  • N Offline
    N Offline
    noxx
    #82
    ok, ich kann da aber nix erkennen im LOG
    hab 2-3x manuell hin und her geschaltet
    fritzdect.0	2017-06-24 20:04:33.899	debug	stateChange fritzdect.0.DECT200_087610163304.state {"val":false,"ack":false,"ts":1498327473882,"q":0,"from":"system.adapter.admin.0","lc":1498327473882}
    fritzdect.0	2017-06-24 20:04:33.889	debug	inMem message fritzdect.0.* fritzdect.0.DECT200_087610163304.state val=false, ack=false, ts=1498327473882, q=0, from=system.adapter.admin.0, lc=1498327473882
    fritzdect.0	2017-06-24 20:04:08.186	debug	stateChange fritzdect.0.DECT200_087610163304.state {"val":true,"ack":false,"ts":1498327448169,"q":0,"from":"system.adapter.admin.0","lc":1498327424272}
    fritzdect.0	2017-06-24 20:04:08.181	debug	inMem message fritzdect.0.* fritzdect.0.DECT200_087610163304.state val=true, ack=false, ts=1498327448169, q=0, from=system.adapter.admin.0, lc=1498327424272
    fritzdect.0	2017-06-24 20:03:44.313	debug	stateChange fritzdect.0.DECT200_087610163304.energy {"val":310312,"ack":true,"ts":1498327424284,"q":0,"from":"system.adapter.fritzdect.0","lc":1498327368355}
    fritzdect.0	2017-06-24 20:03:44.295	debug	inMem message fritzdect.0.* fritzdect.0.DECT200_087610163304.energy val=310312, ack=true, ts=1498327424284, q=0, from=system.adapter.fritzdect.0, lc=1498327368355
    fritzdect.0	2017-06-24 20:03:44.285	debug	stateChange fritzdect.0.DECT200_087610163304.state {"val":true,"ack":false,"ts":1498327424272,"q":0,"from":"system.adapter.admin.0","lc":1498327424272}
    fritzdect.0	2017-06-24 20:03:44.281	debug	inMem message fritzdect.0.* fritzdect.0.DECT200_087610163304.state val=true, ack=false, ts=1498327424272, q=0, from=system.adapter.admin.0, lc=1498327424272
    fritzdect.0	2017-06-24 20:03:43.357	debug	stateChange fritzdect.0.DECT200_087610163304.power {"val":0,"ack":true,"ts":1498327423326,"q":0,"from":"system.adapter.fritzdect.0","lc":1498327367204}
    fritzdect.0	2017-06-24 20:03:43.347	debug	inMem message fritzdect.0.* fritzdect.0.DECT200_087610163304.power val=0, ack=true, ts=1498327423326, q=0, from=system.adapter.fritzdect.0, lc=1498327367204
    fritzdect.0	2017-06-24 20:03:42.332	debug	stateChange fritzdect.0.DECT200_087610163304.temp {"val":20.5,"ack":true,"ts":1498327422312,"q":0,"from":"system.adapter.fritzdect.0","lc":1498325564253}
    fritzdect.0	2017-06-24 20:03:42.328	debug	inMem message fritzdect.0.* fritzdect.0.DECT200_087610163304.temp val=20.5, ack=true, ts=1498327422312, q=0, from=system.adapter.fritzdect.0, lc=1498325564253
    fritzdect.0	2017-06-24 20:03:41.192	debug	stateChange fritzdect.0.DECT200_087610163304.present {"val":true,"ack":true,"ts":1498327421173,"q":0,"from":"system.adapter.fritzdect.0","lc":1498299530244}
    fritzdect.0	2017-06-24 20:03:41.184	debug	inMem message fritzdect.0.* fritzdect.0.DECT200_087610163304.present val=true, ack=true, ts=1498327421173, q=0, from=system.adapter.fritzdect.0, lc=1498299530244
    fritzdect.0	2017-06-24 20:03:40.420	debug	stateChange fritzdect.0.DECT200_087610163304.state {"val":false,"ack":true,"ts":1498327420405,"q":0,"from":"system.adapter.fritzdect.0","lc":1498327364185}
    fritzdect.0	2017-06-24 20:03:40.415	debug	inMem message fritzdect.0.* fritzdect.0.DECT200_087610163304.state val=false, ack=true, ts=1498327420405, q=0, from=system.adapter.fritzdect.0, lc=1498327364185
    fritzdect.0	2017-06-24 20:03:39.318	debug	stateChange fritzdect.0.DECT200_087610163304.name {"val":"Poolfilter","ack":true,"ts":1498327419283,"q":0,"from":"system.adapter.fritzdect.0","lc":1498299528240}
    fritzdect.0	2017-06-24 20:03:39.300	debug	inMem message fritzdect.0.* fritzdect.0.DECT200_087610163304.name val=Poolfilter, ack=true, ts=1498327419283, q=0, from=system.adapter.fritzdect.0, lc=1498299528240
    fritzdect.0	2017-06-24 20:03:33.125	info	polling! fritzdect is alive
    fritzdect.0	2017-06-24 20:03:33.036	info	starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v6.11.0
    host.PI-Hole	2017-06-24 20:03:27.361	info	instance system.adapter.fritzdect.0 started with pid 4376
    host.PI-Hole	2017-06-24 20:03:24.932	info	instance system.adapter.fritzdect.0 terminated with code 0 (OK)
    host.PI-Hole	2017-06-24 20:03:24.797	info	stopInstance system.adapter.fritzdect.0 killing pid 782
    host.PI-Hole	2017-06-24 20:03:24.794	info	stopInstance system.adapter.fritzdect.0
    host.PI-Hole	2017-06-24 20:03:24.773	info	object change system.adapter.fritzdect.0
    fritzdect.0	2017-06-24 20:02:39.448	info	polling! fritzdect is alive
    und hier mit VIS
    fritzdect.0	2017-06-24 20:06:05.322	debug	stateChange fritzdect.0.DECT200_087610163304.state {"val":1,"ack":false,"ts":1498327565296,"q":0,"from":"system.adapter.web.0","lc":1498327565296}
    fritzdect.0	2017-06-24 20:06:05.320	debug	inMem message fritzdect.0.* fritzdect.0.DECT200_087610163304.state
    fritzdect.0	2017-06-24 20:06:03.430	debug	stateChange fritzdect.0.DECT200_087610163304.state {"val":0,"ack":false,"ts":1498327563403,"q":0,"from":"system.adapter.web.0","lc":1498327563403}
    fritzdect.0	2017-06-24 20:06:03.428	debug	inMem message fritzdect.0.* fritzdect.0.DECT200_087610163304.state
    fritzdect.0	2017-06-24 20:06:01.033	debug	stateChange fritzdect.0.DECT200_087610163304.state {"val":1,"ack":false,"ts":1498327560926,"q":0,"from":"system.adapter.web.0","lc":1498327560926}
    fritzdect.0	2017-06-24 20:06:01.031	debug	inMem message fritzdect.0.* fritzdect.0.DECT200_087610163304.state
    • H Offline
      HeRo
      #83
      Hallo noxx,
      habe einen ioBroker neu auf einem Raspberry installiert, die DECT 200 lässt sich sofort schalten.
      Hast Du alle Einstellungen in der FritzBox gemacht?
      Roland
      • F Offline
        foxthefox
        #84
        @noxx:
        hab 2-3x manuell hin und her geschaltet `
        sieht erstmal nicht so schlecht aus.
        Eigentlich hätte es noch ein paar .info Meldungen mehr haben müssen. Waren die ausgeblendet?
        Für die Freigabe in der Fritzbox hab ich noch nen screenshot gemacht.
        Ansonsten hab ich grad keine Idee weiter. Der Adapter koppelt ordnungsgemäß und die Werte werden auch korrekt angezeigt. Das Schalten sollte also an der Einstellung liegen.
        Welche Fritzbox ist es denn und welche FW-Version?
        Klaus
        Adapterüberblick: Profil Github;
        Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
        Ein Aufruf: video
        • N Offline
          N Offline
          noxx
          #85
          Fritz 7390, FW aktuell
          Kann Montag mehr infos geben.
          Mit fhem schalten geht aber
          Gesendet von meinem GT-I9195 mit Tapatalk
            diwou
            #86
            Ich habe es gerade mal mit einer 7580 und einer 7490 probiert. Beide mit Firmware 6.83 und der aktuellen Beta probiert.
            Er findet irgendwann die DECT 200 Teile, fragt danach aber nicht mehr den Status ab und schalten geht auch nicht.
            Wenn man ins Log der Fritz Box schaut, sieht man nur, dass die Authentifizierung des Users nicht funktioniert, weil
            angeblich falsches Password. Habe sogar testweise einen extra User angelegt, aber klappt nicht.
            Es gibt für die CCU2 auch so einen ähnlichen Adapter. Der funktioniert seit der 6.83 auch nicht mehr und man findet im
            Log der Firtzbox dann auch diesen Authentifizierungsfehler.
            Vermutlich hat AVM da irgend etwas geändert.
            • H Offline
              Heartloop
              #87
              Auch bei mir funktioniert das schalten nicht. Meine Steckdosen werden zwar angezeigt, aber der Schaltbefehl wird nicht übernommen. Das Log zeigt beim Versuch zu Schalten das folgende:
              fritzdect.0	2017-07-27 22:28:19.080	info	SWITCH ID: 087610194364 identified for command
              fritzdect.0	2017-07-27 22:28:19.070	debug	ack is not set! -> command
              fritzdect.0	2017-07-27 22:28:19.067	debug	stateChange fritzdect.0.DECT200_087610194364.state {"val":false,"ack":false,"ts":1501187299030,"q":0,"from":"system.adapter.admin.0","lc":1501187299030}
              inMem	2017-07-27 22:28:19.051	debug	message fritzdect.0.* fritzdect.0.DECT200_087610194364.state val=false, ack=false, ts=1501187299030, q=0, from=system.adapter.admin.0, lc=1501187299030
              Im Übrigen wird auch die Temperatur nicht ausgelesen
              Fritzbox ist eine 7360 auf FritzOS 6.30 (neuer geht nicht für diese Box).
              • F Offline
                foxthefox
                #88
                @Heartloop:
                Fritzbox ist eine 7360 auf FritzOS 6.30 (neuer geht nicht für diese Box). `
                Nach dem "Switch Id xxx identified" sollte als nächstes die Meldung "turned xxx off" kommen.
                Das Kommando scheint nicht erfolgreich zu sein.
                Bin noch ratlos. Ich recherchiere mal bei der eingebundenen Bibliothek.
                Ein Aufruf: video
                • H Offline
                  Heartloop
                  #89
                  Falls es hilft: Das ganze ist auf einer frischen Installation auf einem RPI 1 (vom aktuellsten Image). Auch ein Aktualisieren aller installierten Pakete hat keine Besserung gebracht.
                  Die Steckdosen werden weiterhin erkannt, und wenn man von woanders schaltet (FritzFon, Knopf an der Steckdose) wir der neue Schaltzustand und der Stromverbrauch auch mit etwas Verzögerung aktualisiert.
                  Nur das Schalten klappt leider nicht.
                  Viele Grüße,
                  Heartloop
                  • F Offline
                    foxthefox
                    #90
                    @Heartloop:
                    Viele Grüße,
                    Heartloop `
                    Das ist doch mal ein Hinweis.
                    Werde heute Abend hoffentlich Zeit finden etwas probieren.
                    Ein Aufruf: video
                    • F Offline
                      foxthefox
                      #91
                      ich hab mal eine Version 0.0.8 auf github eingestellt.
                      Nur damit es nicht wegen 0 oder false oder off bzw. 1 oder true oder ON die Ursache der Probleme sind, hab ich dies nun als valide Werte mit dazugefügt.
                      Bei mir funktioniert es mit dem Schalten.
                      Bitte mal prüfen ob die 0.0.8 die Lösung bringt.
                      Klaus
                      Ein Aufruf: video
                        diwou
                        #92
                        @foxthefox:
                        Bitte mal prüfen ob die 0.0.8 die Lösung bringt. `
                        Funktioniert jetzt wieder. Er schaltet auch die DECT 210, wenn auch als DECT200 angezeigt.
                        • H Offline
                          Heartloop
                          #93
                          @foxthefox:
                          ich hab mal eine Version 0.0.8 auf github eingestellt. `
                          Bei mir funktioniert es weiterhin nicht. Der letzte log Eintrag ist dann jeweils "SwitchXXXXX identfied for command".
                          • Z Offline
                            Z Offline
                            zuvielx9
                            #94
                            Vielen Dank, für den tollen Adapter. Funktioniert auch soweit.
                            Nur leider klappt es bei mir mit dem Schalten auch nicht.
                            • F Offline
                              foxthefox
                              #95
                              @Heartloop:
                              @foxthefox:
                              Bei mir funktioniert es weiterhin nicht. Der letzte log Eintrag ist dann jeweils "SwitchXXXXX identfied for command". `
                              Ich hab in der Version 0.0.9 auf github noch die '0' und '1' als Text für OFF/ON dazugenommen.
                              Evtl. hilft das ja weiter, falls 0 und 1 als Text übergeben werden sollten.
                              Habe außerdem noch die Meldung "SwitchXXXXX identfied for command" um den übergebenen Zustand erweitert.
                              Ich bin gespannt, was ihr berichtet.
                              Klaus
                              Ein Aufruf: video
                              • H Offline
                                Heartloop
                                #96
                                vielen Dank für deine Mühe und die inzwischen zweite neue Version. Leider kann ich trotzdem noch nicht schalten 😢 😢
                                fritzdect.0	2017-08-14 19:06:07.815	info	SWITCH ID: 087610194364 identified for command : false
                                fritzdect.0	2017-08-14 19:06:07.813	debug	ack is not set! -> command
                                fritzdect.0	2017-08-14 19:06:07.810	debug	stateChange fritzdect.0.DECT200_087610194364.state {"val":false,"ack":false,"ts":1502730367784,"q":0,"from":"system.adapter.admin.0","lc":1502730367784}
                                fritzdect.0	2017-08-14 19:06:07.790	debug	redis pmessage io.fritzdect.0.* io.fritzdect.0.DECT200_087610194364.state {"val":false,"ack":false,"ts":1502730367784,"q":0,"from":"system.adapter.admin.0","lc":1502730367784}
                                Das ist alles was das Log hergibt, wenn ich versuche, eine eingeschaltete Steckdose auszuschalten.
                                Ich werde nachher mal versuchen, iobroker zu Testzwecken auf einem anderen System zu installieren.
                                • F Offline
                                  foxthefox
                                  #97
                                  @Heartloop:
                                  Ich werde nachher mal versuchen, iobroker zu Testzwecken auf einem anderen System zu installieren. `
                                  Das ist natürlich blöde. "False" sollte korrekt ausgewertet werden. Entweder schaffe ich es noch irgendwelche Fehlermeldung von der fritzbox zu bekommen oder ich muss die nächste Variante vom node_modul implementieren.
                                  Zum vergewissern: Die Bedienung von Remote ist auf der fritzbox freigegeben? Siehe post#88
                                  Ein Aufruf: video
                                    diwou
                                    #98
                                    Seit der 0.0.8er Version klappt das Schalten wieder bei mir problemlos. Auch das auslesen klappt wieder. Benutze derzeit eine Fritz Box 7580 mit
                                    der Labor Firmware 06.88-45906 BETA. Mit der 0.0.7er Version klappte das Schalten nicht, auch wurden die Werte nur sehr selten ausgelesen.
                                    2017-08-14 20:21:04.675  - info: fritzdect.0 SWITCH ID: 087610373208 identified for command
                                    2017-08-14 20:21:04.679  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.alive {"val":true,"ack":true,"ts":1502734864678,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734669586}
                                    2017-08-14 20:21:04.681  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.connected {"val":true,"ack":true,"ts":1502734864681,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734669588}
                                    2017-08-14 20:21:04.683  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.memRss {"val":36.46,"ack":true,"ts":1502734864683,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734849667}
                                    2017-08-14 20:21:04.685  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.memHeapTotal {"val":19.82,"ack":true,"ts":1502734864684,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734849669}
                                    2017-08-14 20:21:04.686  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.memHeapUsed {"val":14.72,"ack":true,"ts":1502734864686,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734864686}
                                    2017-08-14 20:21:04.688  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.uptime {"val":198,"ack":true,"ts":1502734864687,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734864687}
                                    2017-08-14 20:21:04.690  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.inputCount {"val":1,"ack":true,"ts":1502734864689,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734849675}
                                    2017-08-14 20:21:04.691  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.outputCount {"val":8,"ack":true,"ts":1502734864691,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734699610}
                                    2017-08-14 20:21:05.172  - debug: fritzdect.0 Turned switch 087610373208 on
                                    2017-08-14 20:21:17.987  - debug: fritzdect.0 redis pmessage  io.fritzdect.0.* io.fritzdect.0.DECT200_087610373208.state {"val":false,"ack":false,"ts":1502734877986,"q":0,"from":"system.adapter.admin.0","lc":1502734877986}
                                    2017-08-14 20:21:17.990  - debug: fritzdect.0 stateChange fritzdect.0.DECT200_087610373208.state {"val":false,"ack":false,"ts":1502734877986,"q":0,"from":"system.adapter.admin.0","lc":1502734877986}
                                    2017-08-14 20:21:17.992  - debug: fritzdect.0 ack is not set! -> command
                                    2017-08-14 20:21:17.993  - info: fritzdect.0 SWITCH ID: 087610373208 identified for command
                                    2017-08-14 20:21:18.469  - debug: fritzdect.0 Turned switch 087610373208 off
                                    2017-08-14 20:21:19.675  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.alive {"val":true,"ack":true,"ts":1502734879674,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734669586}
                                    2017-08-14 20:21:19.677  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.connected {"val":true,"ack":true,"ts":1502734879677,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734669588}
                                    2017-08-14 20:21:19.679  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.memRss {"val":36.75,"ack":true,"ts":1502734879679,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734879679}
                                    2017-08-14 20:21:19.681  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.memHeapTotal {"val":19.82,"ack":true,"ts":1502734879681,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734849669}
                                    2017-08-14 20:21:19.683  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.memHeapUsed {"val":15.1,"ack":true,"ts":1502734879683,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734879683}
                                    2017-08-14 20:21:19.685  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.uptime {"val":213,"ack":true,"ts":1502734879685,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734879685}
                                    2017-08-14 20:21:19.687  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.inputCount {"val":1,"ack":true,"ts":1502734879687,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734849675}
                                    2017-08-14 20:21:19.690  - debug: fritzdect.0 redis publish io.system.adapter.fritzdect.0.outputCount {"val":8,"ack":true,"ts":1502734879689,"q":0,"from":"system.adapter.fritzdect.0","lc":1502734699610}
                                    • H Offline
                                      Heartloop
                                      #99
                                      ` > Das ist natürlich blöde. "False" sollte korrekt ausgewertet werden. Entweder schaffe ich es noch irgendwelche Fehlermeldung von der fritzbox zu bekommen oder ich muss die nächste Variante vom node_modul implementieren.
                                      Zum vergewissern: Die Bedienung von Remote ist auf der fritzbox freigegeben? Siehe post#88 `
                                      Das Problem scheint irgendwo in der Fritzbox zu liegen. Eine Testinstallation von IOBroker auf OSX hat genau das selbe verhalten. In der Fritzbox habe ich den login per User und Kennwort aktiviert und diesem User erlaubt, Smart Home Geräte zu schalten. Bei den Geräten Selber ist manuell schalten ebenfalls aktiv, und ein Schalten über die Fritzbox App funktioniert auch.
                                      Es werden auch (bis auf die Temperatur) alle Werte korrekt und Zuverlässig ausgelesen, also aktueller Stromverbrauch der Steckdosen, Namen der Steckdosen etc.
                                      Allerdings ist ja auf der FritzBox Hardwarebedingt nicht das neuste FritzOS installiert. Es läuft FritzOS 6.30 drauf, die 7360 bekommt ja keine weiteren updates.
                                      • H Offline
                                        HeRo
                                        #100
                                        ist auch die Anmeldung mit Benutzername an?
                                        Roland
                                        • H Offline
                                          Heartloop
                                          #101
                                          Ja, Login mit Benutzernamen und Kennwort auf der Fritzbox ist an.
