    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • ArmilarA Armilar
    @michael_4358
    Austauschen, nicht auskommentieren. Sonst gibt es eine Type-Verletzung
    Das Problem ist der Teil
    mqtt.0.SmartHome.NSPanel_1.stat.
    Dürfte ja bei dir im mqtt etwas anders aussehen...
    EDIT: Gehe davon aus, dass dann alles läuft...
    michael_4358
    #961
    @armilar said in SONOFF NSPanel mit Lovelace UI:
    @michael_4358
    habe ich ausgetauscht
    	info	javascript.0 (31320) script.js.NSPanel.PV_Panel: registered 13 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
    21:30:31.305	warn	javascript.0 (31320) at script.js.NSPanel.PV_Panel:1139:46
    21:30:31.305	warn	javascript.0 (31320) at step (script.js.NSPanel.PV_Panel:33:23)
    21:30:31.305	warn	javascript.0 (31320) at Object.next (script.js.NSPanel.PV_Panel:14:53)
    21:30:31.305	warn	javascript.0 (31320) at fulfilled (script.js.NSPanel.PV_Panel:5:58)
    und ich habe auf dem Panel oben links nun ein kleinen "Tür symbol" und oben links eine kleine "Glühlampe"
    • M michael_4358
      @armilar
      verison 6.1.4
      Fehler werden weniger
      21:17:18.226	warn	javascript.0 (31320) at script.js.NSPanel.PV_Panel:1139:46
      21:17:18.226	warn	javascript.0 (31320) at step (script.js.NSPanel.PV_Panel:33:23)
      21:17:18.227	warn	javascript.0 (31320) at Object.next (script.js.NSPanel.PV_Panel:14:53)
      21:17:18.227	warn	javascript.0 (31320) at fulfilled (script.js.NSPanel.PV_Panel:5:58)
      21:17:49.050	warn	javascript.0 (31320) at HandleScreensaverUpdate (script.js.NSPanel.PV_Panel:4402:29)
      21:17:49.050	warn	javascript.0 (31320) at HandleScreensaver (script.js.NSPanel.PV_Panel:4032:5)
      21:17:49.050	warn	javascript.0 (31320) at HandleMessage (script.js.NSPanel.PV_Panel:1604:21)
      21:17:49.051	warn	javascript.0 (31320) at Object.<anonymous> (script.js.NSPanel.PV_Panel:1541:17)
      21:17:49.053	warn	javascript.0 (31320) at HandleScreensaverUpdate (script.js.NSPanel.PV_Panel:4409:34)
      21:17:49.053	warn	javascript.0 (31320) at HandleScreensaver (script.js.NSPanel.PV_Panel:4032:5)
      21:17:49.054	warn	javascript.0 (31320) at HandleMessage (script.js.NSPanel.PV_Panel:1604:21)
      21:17:49.054	warn	javascript.0 (31320) at Object.<anonymous> (script.js.NSPanel.PV_Panel:1541:17)
      21:17:49.056	warn	javascript.0 (31320) at HandleScreensaverUpdate (script.js.NSPanel.PV_Panel:4423:29)
      21:17:49.056	warn	javascript.0 (31320) at HandleScreensaver (script.js.NSPanel.PV_Panel:4032:5)
      21:17:49.056	warn	javascript.0 (31320) at HandleMessage (script.js.NSPanel.PV_Panel:1604:21)
      21:17:49.057	warn	javascript.0 (31320) at Object.<anonymous> (script.js.NSPanel.PV_Panel:1541:17)
      21:17:49.059	warn	javascript.0 (31320) at HandleScreensaverUpdate (script.js.NSPanel.PV_Panel:4430:34)
      wenn ich die beiden Zeilen auskommentiere wird alles rot ;)
      javascript.0 (31320) script.js.NSPanel.PV_Panel: TypeScript compilation failed: export const config: Config = { ^ ERROR: Type '{ panelRecvTopic: string; panelSendTopic: string; firstScreensaverEntity: { ScreensaverEntity: string; ScreensaverEntityIcon: string; ScreensaverEntityText: string; ScreensaverEntityUnitText: string; ScreensaverEntityIconColor: { ...; }; }; ... 21 more ...; button2Page: null; }' is missing the following properties from type 'Config': mrIcon1ScreensaverEntity, mrIcon2ScreensaverEntity
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      #962
      @michael_4358
      In meinem Post (siehe Link unten) stehen schon die korrigierten Strings (fertige Lösung) drin. Daher nur mit den beiden falschen Zeilen in deiner Config tauschen.
      https://forum.iobroker.net/post/901471
      EDIT: war wohl parallel ;-)
      • M michael_4358
        @michael_4358
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        #963
        @michael_4358 sagte in SONOFF NSPanel mit Lovelace UI:
        Sollte eigentlich ein Schalter sein. Du hast ja 2 Schalter am Panel und das sind die aktuellen Zustände. Icons kannst du anpassen in den beiden Zeilen
        • ArmilarA Armilar
          @michael_4358
          michael_4358
          schrieb am zuletzt editiert von michael_4358
          #964
          @michael_4358
          hab ich ;)
          aber nun hab ich halt die Symbole
          EdiT:
          Tatkraft sind sie wirklich❗️ danke dir ❗️
          ArmilarA 2 Antworten Letzte Antwort
          • M michael_4358
            @michael_4358
            hab ich ;)
            EdiT:
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #965
            @michael_4358
            Sag bescheid, wenn die restlichen 4 Warnungen bleiben. Bekommen wir auch noch eliminiert
            Also ich finde das Ergebnis schon ziemlich gut ;-)
            Viel Spaß noch... und wirf gerne einen Blick in die Doku (Wiki). Da steht echt ne Menge drin...
            • ArmilarA Armilar
              @michael_4358
              michael_4358
              #966
              @michael_4358
              Die vier sind bis jetzt nur beim ersten Mal.
              Also wenn das Script neu zugeladen wird
              • M michael_4358
                @michael_4358
                hab ich ;)
                EdiT:
                ArmilarA Offline
                ArmilarA Offline
                Armilar
                #967
                @michael_4358
                Ach übrigens. Wenn du jetzt schon an dem Punkt angekommen bist, könntest du eigentlich auch das Upgrade auf v3.6.0.2 mitnehmen ;-)
                Unteren Teil der Scriptes ab:
                ------------- ab hier keine Änderungen mehr ...------------------
                aus der aktuellen Version tauschen und 3 Farbkonstanten hinzufügen.
                ~~https://forum.iobroker.net/post/901471~~
                EDIT: falscher Link
                https://forum.iobroker.net/post/900735
                • ArmilarA Armilar
                  @michael_4358
                  EDIT: falscher Link
                  michael_4358
                  #968
                  @armilar
                  Das mache ich dann morgen 😅
                  • M michael_4358
                    @armilar
                    ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    #969
                    @michael_4358
                    Ja perfekt... Irgendwann glüht der Kopf 💡 😊
                    • ArmilarA Armilar
                      @sufra
                      Welche Warnung?
                      SuFra
                      #970
                      @armilar sagte in SONOFF NSPanel mit Lovelace UI:
                      @sufra
                      Welche Warnung?
                      Bei Neustart :
                      2022-11-30 10:15:18.201 - info: admin.0 (3522) ==> Connected system.user.admin from ::ffff:192.168.25.15
                      2022-11-30 10:15:25.516 - info: javascript.0 (3560) script.js.NSPanel.Panel_2: compiling TypeScript source...
                      2022-11-30 10:15:25.842 - info: javascript.0 (3560) script.js.NSPanel.Panel_2: source code did not change, using cached compilation result...
                      2022-11-30 10:15:25.874 - info: javascript.0 (3560) script.js.NSPanel.Panel_2: registered 11 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
                      2022-11-30 10:15:26.213 - warn: javascript.0 (3560) You are assigning a string to the state "0_userdata.0.NSPanel.2.Berry_Driver.currentVersion" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
                      2022-11-30 10:15:26.214 - warn: javascript.0 (3560) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1689:20)
                      2022-11-30 10:15:26.214 - warn: javascript.0 (3560) at /opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:82:16
                      2022-11-30 10:15:26.214 - warn: javascript.0 (3560) at new Promise ()
                      2022-11-30 10:15:26.214 - warn: javascript.0 (3560) at /opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:81:16
                      2022-11-30 10:15:26.214 - warn: javascript.0 (3560) at script.js.NSPanel.Panel_2:1114:46
                      2022-11-30 10:15:26.215 - warn: javascript.0 (3560) at step (script.js.NSPanel.Panel_2:33:23)
                      2022-11-30 10:15:26.215 - warn: javascript.0 (3560) at Object.next (script.js.NSPanel.Panel_2:14:53)
                      2022-11-30 10:15:26.215 - warn: javascript.0 (3560) at fulfilled (script.js.NSPanel.Panel_2:5:58)
                      2022-11-30 10:15:26.219 - info: javascript.0 (3560) State value to set for "0_userdata.0.NSPanel.2.Berry_Driver.currentVersion" has to be type "number" but received type "string"
                      HA-Cluster 1x NUC11TNHI50L00, 2x NUC11TNHI30L00, 1x BSi3, 1x BSi5
                      LXC's: PiHole, Grafana, MariaDB, TasmoAdmin, NTP Server, PeaNUT, ESPHome, paperless-ai, ollama
                      VM's: PBS, ioBroker, frigate, paperless, trueNAS (Plex)
                      • S SuFra
                        @sufra
                        Welche Warnung?
                        Bei Neustart :
                        ArmilarA Offline
                        ArmilarA Offline
                        Armilar
                        #971
                        @sufra sagte in SONOFF NSPanel mit Lovelace UI:
                        Den Datenpunkt unter Objekte entweder löschen und neu anlegen lassen
                        oder den Datenpunkt von string in number ändern und eine 6 reinschreiben.
                        Initial werde ich den künfig als number und vorbelegter Versions-Nummer befüllen
                        • ArmilarA Armilar
                          SuFra
                          #972
                          Wenn ich die Meldung richtig verstehe ist der Wert ein String und der Datenpunkt eine Nummer.. ?
                          Steht irgendwie falsch in dem Object was Tasmota liefert... ?
                          • S SuFra
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #973
                            @sufra
                            Ist interessant. Ggf. weil die Datenpunkte schon älter sind. Ich habe da einen Typ mixed drin.
                            Stimmt anscheinend:
                            Per Script wird ein Datenpunkt number angelegt. Dummerweise dann ein Alias auf string
                            Danach folgt ein Vergleich (ohne Typ) mit string und definierter numerischer Versionsnummer im Script.
                            Ist definitiv ein Fehler und wird behoben...
                            Für den Anfang sollte es reichen, wenn der Datenpunkt als string oder mixed angelegt ist.
                            • W Offline
                              W Offline
                              wello
                              #974
                              ich nutze seit 2 Tagen ein NSPanel, komme soweit auch, mehr oder weniger, zurecht.
                              Bei 2 Sachen hänge ich aber gerade, und zwar:
                              • Hat jemand einen Homematic Funk-Rollladenaktor (HM-LC-Bl1PBU-FM) im Einsatz mit dem Panel? Da hänge ich total, weil es ja kein "open" und "close" gibt!
                              • Ich habe 2 Yeelight Smart LED Bulb 1S in einer Stehlampe im Einsatz, bisher hab ichs mir einfach gemacht, in Alexa eine Gruppe angelegt, "Stehlampe" und darüber schalte ich die
                                Jetzt wäre es perfekt, beide als "Gruppe" über das NSPanel zu steuern, hier hänge ich auch, da mir das Wissen fehlt ob so etwas per Skript zu lösen wäre
                              Die Lampen sind erstmal zweitrangig, schöner wäre es, den Rollo übers Panel nutzen zu können!!
                              Falls da jemand eine Idee hat, immer her damit und schonmal Danke im Voraus!
                              • W wello
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #975
                                @wello
                                Was hat der denn für Datenpunkte?
                                funktioniert das nicht leichter über den Yeelight-Adapter?
                                Und ebenfalls herzlich willkommen...
                                • ArmilarA Armilar
                                  @wello
                                  lobomauL Offline
                                  lobomauL Offline
                                  lobomau
                                  schrieb am zuletzt editiert von lobomau
                                  #976
                                  @wello
                                  @wello
                                  Joh, "Hoch", "Runter" gibt`s nicht. ABer mit der STellungsanzeige komme ich klar. Und "Stop" geht ja auch 👍
                                  P.S. bin auch neu dabei mit dem NSPanel und habe erstes Script-Update hinter mir auf 3.6.0. Tolles Projekt!
                                  Host: NUC8i3 mit Proxmox:
                                  • Slave: Pi4
                                  • lobomauL lobomau
                                    @wello
                                    @wello
                                    ArmilarA Offline
                                    ArmilarA Offline
                                    Armilar
                                    #977
                                    @lobomau
                                    Was macht DIRECTION denn? Sieht aus, als wären hinter NONE(0) noch weitere Möglichkeiten?
                                    EDIT: Sieht aus, als wäre Direction = 1 = Open und Direction = 2 = Close
                                    • ArmilarA Armilar
                                      @lobomau
                                      lobomauL Offline
                                      lobomauL Offline
                                      lobomau
                                      #978
                                      @armilar ja, hast fast Recht: NONE (0), UP(1), DOWN(2)
                                      Aber es scheint kein DP zu sein mit dem ich steuern kann. Wenn ich den setze, bewegt sich nichts. Nur umgekehrt, wenn ich level setze ändert sich DIRECTION.
                                      • Slave: Pi4
                                      • lobomauL lobomau
                                        ArmilarA Offline
                                        ArmilarA Offline
                                        Armilar
                                        #979
                                        @lobomau sagte in SONOFF NSPanel mit Lovelace UI:
                                        Kann man also mit zusätzlichen Datenpunkten und z.B. Blockly umsetzen (z.B. in 0_userdata).
                                        UP = true (aktualisiert) --> Level = 100
                                        DOWN = true (aktualisiert) --> Level = 0
                                        Dann Alias auf diese Datenpunkte. Sollte nachbildbar sein...
                                        lobomauL B 2 Antworten Letzte Antwort
                                        • ArmilarA Armilar
                                          lobomauL Offline
                                          lobomauL Offline
                                          lobomau
                                          #980
                                          @armilar also UP und DOWN steht da nur während der Bewegung, also wenn WORKING = true. Ist erstmal unabhängig vom LEVEL.
                                          • Slave: Pi4
