    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • ArmilarA Armilar
    @sufra
    Welche Warnung?
    SuFra
    #970
    @armilar sagte in SONOFF NSPanel mit Lovelace UI:
    @sufra
    Welche Warnung?
    Bei Neustart :
    2022-11-30 10:15:18.201 - info: admin.0 (3522) ==> Connected system.user.admin from ::ffff:192.168.25.15
    2022-11-30 10:15:25.516 - info: javascript.0 (3560) script.js.NSPanel.Panel_2: compiling TypeScript source...
    2022-11-30 10:15:25.842 - info: javascript.0 (3560) script.js.NSPanel.Panel_2: source code did not change, using cached compilation result...
    2022-11-30 10:15:25.874 - info: javascript.0 (3560) script.js.NSPanel.Panel_2: registered 11 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
    2022-11-30 10:15:26.213 - warn: javascript.0 (3560) You are assigning a string to the state "0_userdata.0.NSPanel.2.Berry_Driver.currentVersion" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    2022-11-30 10:15:26.214 - warn: javascript.0 (3560) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1689:20)
    2022-11-30 10:15:26.214 - warn: javascript.0 (3560) at /opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:82:16
    2022-11-30 10:15:26.214 - warn: javascript.0 (3560) at new Promise ()
    2022-11-30 10:15:26.214 - warn: javascript.0 (3560) at /opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:81:16
    2022-11-30 10:15:26.214 - warn: javascript.0 (3560) at script.js.NSPanel.Panel_2:1114:46
    2022-11-30 10:15:26.215 - warn: javascript.0 (3560) at step (script.js.NSPanel.Panel_2:33:23)
    2022-11-30 10:15:26.215 - warn: javascript.0 (3560) at Object.next (script.js.NSPanel.Panel_2:14:53)
    2022-11-30 10:15:26.215 - warn: javascript.0 (3560) at fulfilled (script.js.NSPanel.Panel_2:5:58)
    2022-11-30 10:15:26.219 - info: javascript.0 (3560) State value to set for "0_userdata.0.NSPanel.2.Berry_Driver.currentVersion" has to be type "number" but received type "string"
    HA-Cluster 1x NUC11TNHI50L00, 2x NUC11TNHI30L00, 1x BSi3, 1x BSi5
    LXC's: PiHole, Grafana, MariaDB, TasmoAdmin, NTP Server, PeaNUT, ESPHome, paperless-ai, ollama
    VM's: PBS, ioBroker, frigate, paperless, trueNAS (Plex)
    • S SuFra
      @sufra
      Welche Warnung?
      Bei Neustart :
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      #971
      @sufra sagte in SONOFF NSPanel mit Lovelace UI:
      Den Datenpunkt unter Objekte entweder löschen und neu anlegen lassen
      oder den Datenpunkt von string in number ändern und eine 6 reinschreiben.
      Initial werde ich den künfig als number und vorbelegter Versions-Nummer befüllen
      • ArmilarA Armilar
        SuFra
        #972
        Wenn ich die Meldung richtig verstehe ist der Wert ein String und der Datenpunkt eine Nummer.. ?
        Steht irgendwie falsch in dem Object was Tasmota liefert... ?
        • S SuFra
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #973
          @sufra
          Ist interessant. Ggf. weil die Datenpunkte schon älter sind. Ich habe da einen Typ mixed drin.
          Stimmt anscheinend:
          Per Script wird ein Datenpunkt number angelegt. Dummerweise dann ein Alias auf string
          Danach folgt ein Vergleich (ohne Typ) mit string und definierter numerischer Versionsnummer im Script.
          Ist definitiv ein Fehler und wird behoben...
          Für den Anfang sollte es reichen, wenn der Datenpunkt als string oder mixed angelegt ist.
          • W Offline
            W Offline
            wello
            #974
            ich nutze seit 2 Tagen ein NSPanel, komme soweit auch, mehr oder weniger, zurecht.
            Bei 2 Sachen hänge ich aber gerade, und zwar:
            • Hat jemand einen Homematic Funk-Rollladenaktor (HM-LC-Bl1PBU-FM) im Einsatz mit dem Panel? Da hänge ich total, weil es ja kein "open" und "close" gibt!
            • Ich habe 2 Yeelight Smart LED Bulb 1S in einer Stehlampe im Einsatz, bisher hab ichs mir einfach gemacht, in Alexa eine Gruppe angelegt, "Stehlampe" und darüber schalte ich die
              Jetzt wäre es perfekt, beide als "Gruppe" über das NSPanel zu steuern, hier hänge ich auch, da mir das Wissen fehlt ob so etwas per Skript zu lösen wäre
            Die Lampen sind erstmal zweitrangig, schöner wäre es, den Rollo übers Panel nutzen zu können!!
            Falls da jemand eine Idee hat, immer her damit und schonmal Danke im Voraus!
            • W wello
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #975
              @wello
              Was hat der denn für Datenpunkte?
              funktioniert das nicht leichter über den Yeelight-Adapter?
              Und ebenfalls herzlich willkommen...
              • ArmilarA Armilar
                @wello
                lobomauL Offline
                lobomauL Offline
                lobomau
                schrieb am zuletzt editiert von lobomau
                #976
                @wello
                @wello
                Joh, "Hoch", "Runter" gibt`s nicht. ABer mit der STellungsanzeige komme ich klar. Und "Stop" geht ja auch 👍
                P.S. bin auch neu dabei mit dem NSPanel und habe erstes Script-Update hinter mir auf 3.6.0. Tolles Projekt!
                Host: NUC8i3 mit Proxmox:
                • Slave: Pi4
                • lobomauL lobomau
                  @wello
                  @wello
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #977
                  @lobomau
                  Was macht DIRECTION denn? Sieht aus, als wären hinter NONE(0) noch weitere Möglichkeiten?
                  EDIT: Sieht aus, als wäre Direction = 1 = Open und Direction = 2 = Close
                  • ArmilarA Armilar
                    @lobomau
                    lobomauL Offline
                    lobomauL Offline
                    lobomau
                    #978
                    @armilar ja, hast fast Recht: NONE (0), UP(1), DOWN(2)
                    Aber es scheint kein DP zu sein mit dem ich steuern kann. Wenn ich den setze, bewegt sich nichts. Nur umgekehrt, wenn ich level setze ändert sich DIRECTION.
                    • Slave: Pi4
                    • lobomauL lobomau
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #979
                      @lobomau sagte in SONOFF NSPanel mit Lovelace UI:
                      Kann man also mit zusätzlichen Datenpunkten und z.B. Blockly umsetzen (z.B. in 0_userdata).
                      UP = true (aktualisiert) --> Level = 100
                      DOWN = true (aktualisiert) --> Level = 0
                      Dann Alias auf diese Datenpunkte. Sollte nachbildbar sein...
                      lobomauL B 2 Antworten Letzte Antwort
                      • ArmilarA Armilar
                        lobomauL Offline
                        lobomauL Offline
                        lobomau
                        #980
                        @armilar also UP und DOWN steht da nur während der Bewegung, also wenn WORKING = true. Ist erstmal unabhängig vom LEVEL.
                        • Slave: Pi4
                        • lobomauL lobomau
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #981
                          @lobomau
                          Ich meine nicht mehr DIRECTION, sondern DP's in 0_userdata. Beispiel:
                          • 0_userdata.Rolladenschalter.1.Up
                          • 0_userdata.Rolladenschalter.1.Down
                          • ArmilarA Armilar
                            @lobomau
                            lobomauL Offline
                            lobomauL Offline
                            lobomau
                            #982
                            @armilar jetzt habe ich erst das kapiert, was du vorher geschrieben hast. Ja, genial. So wird es gehen! :-)
                            Edit.: nach etwas Überlegung.... Bei deinem unteren Vorschlag, würde das Rollo ja immer auf 100% fahren sobald UP da steht, dann geht es aber nicht, wenn ich von 0 auf 50% fahren möchte. Geht natürlich auch anders, wenn man das Script irgendwie anpasst.
                            • Slave: Pi4
                            • ArmilarA Armilar
                              @matze_hh
                              In diesem Fall ist es leicht...
                              Den unteren Teil ab
                              // _________________________________ Ab hier keine Konfiguration mehr ____________
                              einfach ersetzten und die 3 Farbkonstanten (nachfolgend Zeile 3 - 5) hinzufügen.
                              //Screensaver Default Theme Colors
                              const scbackground:     RGB = { red:   0, green:    0, blue:   0};
                              const scbackgroundInd1: RGB = { red: 255, green:   0,  blue:   0};
                              const scbackgroundInd2: RGB = { red: 121, green: 222,  blue: 121};
                              const scbackgroundInd3: RGB = { red: 255, green: 255,  blue:   0};
                              Den Rest macht das TS-Script mit dem ersten Start selbst.
                              Ach ja und
                              FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.6.0.tft
                              in der Tasmota-Console ausführen.
                              Das wäre dann schon alles...
                              michael_4358
                              #983
                              @armilar said in SONOFF NSPanel mit Lovelace UI:
                              hab ich gemacht erhalte nun einen error...
                              javascript.0 (31320) script.js.NSPanel.PV_Panel: TypeScript compilation failed: const scbackground: RGB = { red: 0, green: 0, blue: 0 }; ^ ERROR: Cannot redeclare block-scoped variable 'scbackground'. const scbackground: RGB = { red: 0, green: 0, blue: 0 }; ^ ERROR: Cannot redeclare block-scoped variable 'scbackground'.
                              • M michael_4358
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #984
                                @michael_4358
                                Ist die jetzt doppelt?
                                Sieh mal nach, falls zweimal vorhanden, eine Zeile löschen. Falls nicht, kurz den oberen Teil senden.
                                • lobomauL lobomau
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #985
                                  @lobomau
                                  So sollte es gehen:
                                  W 1 Antwort Letzte Antwort
                                  • ArmilarA Armilar
                                    @michael_4358
                                    michael_4358
                                    #986
                                    war zweimal vorhanden.
                                    danke dir
                                    • M michael_4358
                                      danke dir
                                      danny_v1
                                      #987
                                      ich habe gestern das erste NSPanel mit der Lovelace UI eingerichtet, bin vom ESP32 mit Nextion Editor auf ein richtiges Panel umgestiegen, daher war Skript und die Hälfte der Einrichtung schon erledigt daher war das fix gemacht.
                                      Bei der Einrichtung sind mir ein paar Dinge aufgefallen:
                                      1. Mit der aktuellen tasmota32de.bin habe ich das Panel nicht ins WLAN bekommen mit der tasmota32-nspanel hat es auf Anhieb funktioniert. Ist das Problem bekannt?
                                      2. Für Statusanzeigen im Lovelace werden noch nicht alle Sensoren unterstützt (Türen und Fenster funktionieren, Bewegungsmelder und andere nicht, kommt dafür noch eine Unterstützung?
                                      3. Ist eher eine Anfrage, ist es möglich eine wie onColor und offColor auch ein onIcon und offIcon sowie einen onText und OffText einzubinden, dann könnte man Punkt 2 damit auch erschlagen.
                                      4. Bei der Medien Karte mit Alexa2 Adapter wird bei mir anstatt Pause und Play Icon eine Nummer angezeigt, woran liegt das?
                                      5. Ist schon abzusehen wann eine WLED Karte kommt?
                                      Ansonsten ist die Umsetzung Top!!! Vielen Dank für die super Arbeit!
                                      lobomauL ArmilarA 2 Antworten Letzte Antwort
                                      • ArmilarA Armilar
                                        @lobomau
                                        So sollte es gehen:
                                        W Offline
                                        W Offline
                                        wello
                                        #988
                                        @armilar
                                        Das mit dem Script funktioniert so, drücken auf den Pfeil nach unten, Rollo fährt bis 0. Pfeil nach oben, Rollo fährt hoch bis zum angegebenen Wert, der im Script hinterlegt ist, bei mir 100.
                                        und bezüglich Yeelight, der Adapter ist echt rudimentär. Da gibts keine Möglichkeit eine Gruppe zu bilden oder ähnliches.
                                        Wie gesagt, Rollo hatte Vorrang. Licht ist nur ein "nice to have" und kein "must".
                                        Noch Danke für die Begrüßung und für die Mühe und die Arbeit die bereits in dieses Projekt gesteckt wurde!
                                        • D danny_v1
                                          lobomauL Offline
                                          lobomauL Offline
                                          lobomau
                                          #989
                                          @danny_v1 sagte in SONOFF NSPanel mit Lovelace UI:
                                          Ich hatte auch mit einer tasmota32de.bin (12.2.0) gestartet und hatte kein Problem mit WLAN
                                          1. Für Statusanzeigen im Lovelace werden noch nicht alle Sensoren unterstützt (Türen und Fenster funktionieren, Bewegungsmelder und andere nicht, kommt dafür noch eine Unterstützung?
                                          Edit: zum Bewegungsmelder, ich habe es mit Lovelace ohne NSPanel verwechselt, wo ich es im Einsatz habe. Am NSPanel teste ich mal.
                                          Bewegungsmelder funktionieren bei mir. Ich habe homematic und aqara (über deconz) im Einsatz. Folgende Einstellunge habe ich:
                                          • Slave: Pi4
