  4. Zigbee iobroker Error while opening serialport
    6.6k
231 Beiträge 28 Kommentatoren 64.1k Aufrufe 24 Beobachtet
    @yoshi
    systemctl status deconz deconz-gui
    Y Offline
    Y Offline
    Yoshi
    #79
    pi@raspberrypi4-iob:~ $ systemctl status deconz deconz-gui
    ● deconz.service - deCONZ: ZigBee gateway -- REST API
         Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset>
         Active: active (running) since Mon 2022-08-15 18:51:20 CEST; 18min ago
       Main PID: 349 (deCONZ)
          Tasks: 4 (limit: 4915)
         CGroup: /system.slice/deconz.service
                 └─349 /usr/bin/deCONZ -platform minimal --http-port=80
    Aug 15 18:52:14 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
    Aug 15 18:52:16 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
    Aug 15 18:53:15 raspberrypi4-iob deCONZ[349]: "Keine derartige Schnittstelle »o>
    Aug 15 18:59:34 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
    Aug 15 19:02:31 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
    Aug 15 19:04:37 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
    Aug 15 19:04:53 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
    Aug 15 19:04:55 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
    Aug 15 19:05:11 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
    {1}
    ● deconz-gui.service - deCONZ: ZigBee gateway -- GUI/REST API
         Loaded: loaded (/lib/systemd/system/deconz-gui.service; enabled; vendor pr>
         Active: activating (auto-restart) (Result: signal) since Mon 2022-08-15 19>
        Process: 16935 ExecStart=/usr/bin/deCONZ --http-port=80 (code=killed, signa>
    lines 1-23
    {1}
    {1}
    • Y Yoshi
      {1}
      lines 1-23
      {1}
      {1}
      #80
      @yoshi
      sudo systemctl stop deconz
      sudo systemctl disable deconz
      sudo systemctl stop deconz-gui
      sudo systemctl disable deconz-gui
      Y 1 Antwort Letzte Antwort
        @yoshi
        Y Offline
        Y Offline
        Yoshi
        #81
        Hey Thomas, wenn du ne Frau wärest würde ich dich glatt heiraten. :-)
        Vielen Dank. Nun läuft es, ich hoffe auch nach einem Neustart
        • Y Yoshi
          #82
          @yoshi sagte in Zigbee iobroker Error while opening serialport:
          Wenn du beide Services disabled hast ja.
            Y Offline
            Y Offline
            Yoshi
            #83
            Ja, hab das gemacht.
            Muss ich alle Teilnehmer neu anlernen ? ich sehe sie zwar in der Geräteübersicht aber sie sind nicht verbunden.
            • Y Yoshi
              #84
              Möglich. Vielleicht sind die noch mit dem deconz verheiratet.
                #85
                Und @Asgothian ein "soooooooooooooooory fürs 'derailing'". Kommt nicht wieder vor. 😗
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  #86
                  @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
                  Wieso derailing - beim deconz war ich auch schon. Auch die Frage ob der noch läuft. Aber von Unterwegs konnte ich nicht die korrekten Befehle Posten :)
                  • H Offline
                    Harry87
                    schrieb am zuletzt editiert von Harry87
                    #87
                    Servus,
                    ich hatte denselben Fehler, dass kein Zugriff mehr auf den Serial Port möglich war.
                    2022-10-14 18:38:07.286  - error: zigbee.0 (3145) Error herdsman start
                    2022-10-14 18:38:17.289  - info: zigbee.0 (3145) Try to reconnect. 1 attempts left
                    2022-10-14 18:38:17.290  - info: zigbee.0 (3145) Starting Zigbee  npm ...
                    2022-10-14 18:38:17.311  - info: zigbee.0 (3145) Installed Version: iobroker.zigbee@1.7.5
                    2022-10-14 18:38:17.475  - error: zigbee.0 (3145) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                    2022-10-14 18:38:17.476  - error: zigbee.0 (3145) Failed to start Zigbee
                    2022-10-14 18:38:17.476  - error: zigbee.0 (3145) Error herdsman start
                    Ursache war, dass auf dem gleichen Raspberry Debmatic läuft und dort der CUxDeamon den Serial-Port belegt hat.
                    Man kann dem CUxDeamon sagen, dass er einen bestimmten Port nicht verwenden soll, indem man im CUxD-Setup unten folgende Zeile ergänzt:
                    TTYASSIGN=ttyUSB0:NC
                    Obacht: Port "USB0" kann abweichen!
                    Danach Raspberry neu starten und schon lief der Zigbee-Adapter im ioBroker wieder.
                      klausiy123
                      schrieb am zuletzt editiert von klausiy123
                      #88
                      Hallo
                      Mein cc26x2 mag, warum auch immer, nicht mehr. Vielleicht kann mir jemand helfen. Vielen Dank im voraus.
                      2022-11-22 16:46:21.405 - info: host.orangepiplus2e "system.adapter.zigbee.0" enabled
                      2022-11-22 16:46:22.201 - info: host.orangepiplus2e instance system.adapter.zigbee.0 started with pid 1538
                      2022-11-22 16:46:34.269 - info: zigbee.0 (1538) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.23
                      2022-11-22 16:46:34.577 - info: zigbee.0 (1538) delete old Backup files. keep only last 10
                      2022-11-22 16:46:34.584 - info: zigbee.0 (1538) Starting Zigbee npm ...
                      2022-11-22 16:46:36.030 - info: zigbee.0 (1538) Installed Version: iobroker.zigbee@1.7.5
                      2022-11-22 16:46:56.485 - error: zigbee.0 (1538) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                      2022-11-22 16:46:56.488 - error: zigbee.0 (1538) Failed to start Zigbee
                      2022-11-22 16:46:56.490 - error: zigbee.0 (1538) Error herdsman start
                      2022-11-22 16:47:06.502 - info: zigbee.0 (1538) Try to reconnect. 1 attempts left
                      2022-11-22 16:47:06.506 - info: zigbee.0 (1538) Starting Zigbee npm ...
                      2022-11-22 16:47:06.561 - info: zigbee.0 (1538) Installed Version: iobroker.zigbee@1.7.5
                      2022-11-22 16:47:07.170 - error: zigbee.0 (1538) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                      2022-11-22 16:47:07.174 - error: zigbee.0 (1538) Failed to start Zigbee
                      2022-11-22 16:47:07.175 - error: zigbee.0 (1538) Error herdsman start
                      • K klausiy123
                        Hallo
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #89
                        @klausiy123 zieh den coordinator ab und steck den wieder rein
                        • arteckA arteck
                          klausiy123
                          #90
                          @arteck besten Dank, das war wohl der Fehler, auch wenn ich nicht verstehe warum das nach Jahren erstmals auftrat und das Teil nie bewegt wurde.
                          • G Offline
                            Galli2k
                            #91
                            Hallo zusammen, auch ich bin verzweifelt den Zigbee adapter mit dem CC1352p-2 coordinator zum laufen zu bringen.
                            Hier mal einiges was ich so gemacht hab. Ich hoffe jemand kann mir Helfen. Danke
                            PS: ioBroker läuft auf ein LXC in Proxmox
                            2022-12-07 18:50:59.448 - info: backitup.0 (385) [iobroker] backup was activated at 02:40 every 1 day(s)
                            2022-12-07 18:56:16.554 - info: admin.0 (343) ==> Connected system.user.admin from ::ffff:192.168.178.68
                            2022-12-07 18:59:17.572 - info: host.ioBroker "system.adapter.zigbee.0" enabled
                            2022-12-07 18:59:17.587 - info: host.ioBroker instance system.adapter.zigbee.0 started with pid 416
                            2022-12-07 18:59:18.664 - info: zigbee.0 (416) starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.23
                            2022-12-07 18:59:18.704 - info: zigbee.0 (416) Starting Zigbee npm ...
                            2022-12-07 18:59:18.916 - info: zigbee.0 (416) Installed Version: iobroker.zigbee@1.7.6
                            2022-12-07 18:59:18.953 - error: zigbee.0 (416) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00'"
                            2022-12-07 18:59:18.954 - error: zigbee.0 (416) Failed to start Zigbee
                            2022-12-07 18:59:18.954 - error: zigbee.0 (416) Error herdsman start
                            2022-12-07 18:59:21.505 - info: admin.0 (343) ==> Connected system.user.admin from ::ffff:192.168.178.68
                            2022-12-07 18:59:21.555 - error: zigbee.0 (416) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                            2022-12-07 18:59:28.956 - info: zigbee.0 (416) Try to reconnect. 1 attempts left
                            2022-12-07 18:59:28.957 - info: zigbee.0 (416) Starting Zigbee npm ...
                            2022-12-07 18:59:28.964 - info: zigbee.0 (416) Installed Version: iobroker.zigbee@1.7.6
                            2022-12-07 18:59:29.047 - error: zigbee.0 (416) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00'"
                            2022-12-07 18:59:29.048 - error: zigbee.0 (416) Failed to start Zigbee
                            2022-12-07 18:59:29.048 - error: zigbee.0 (416) Error herdsman start
                            2022-12-07 18:59:32.398 - info: admin.0 (343) <== Disconnect system.user.admin from ::ffff:192.168.178.68
                            root@ioBroker:~# ls -l /dev
                            total 0
                            crw--w---- 1 root   tty     136, 0 Dec  7 18:50 console
                            lrwxrwxrwx 1 root   root        11 Dec  7 18:50 core -> /proc/kcore
                            lrwxrwxrwx 1 root   root        13 Dec  7 18:50 fd -> /proc/self/fd
                            crw-rw-rw- 1 nobody nogroup   1, 7 Dec  7 12:41 full
                            lrwxrwxrwx 1 root   root        12 Dec  7 18:50 initctl -> /run/initctl
                            lrwxrwxrwx 1 root   root        28 Dec  7 18:50 log -> /run/systemd/journal/dev-log
                            drwxrwxrwt 2 nobody nogroup     40 Dec  7 18:50 mqueue
                            crw-rw-rw- 1 nobody nogroup   1, 3 Dec  7 12:41 null
                            crw-rw-rw- 1 root   root      5, 2 Dec  7 19:20 ptmx
                            drwxr-xr-x 2 root   root         0 Dec  7 18:50 pts
                            crw-rw-rw- 1 nobody nogroup   1, 8 Dec  7 12:41 random
                            drwxr-xr-x 3 root   root        60 Dec  7 18:50 serial
                            drwxrwxrwt 2 root   root        40 Dec  7 18:50 shm
                            lrwxrwxrwx 1 root   root        15 Dec  7 18:50 stderr -> /proc/self/fd/2
                            lrwxrwxrwx 1 root   root        15 Dec  7 18:50 stdin -> /proc/self/fd/0
                            lrwxrwxrwx 1 root   root        15 Dec  7 18:50 stdout -> /proc/self/fd/1
                            crw-rw-rw- 1 nobody nogroup   5, 0 Dec  7 12:41 tty
                            crw------- 1 root   tty     136, 1 Dec  7 19:20 tty1
                            crw--w---- 1 root   tty     136, 2 Dec  7 18:50 tty2
                            crw-rw-rw- 1 nobody nogroup 166, 0 Dec  7 12:41 ttyACM0
                            crw-rw-rw- 1 nobody nogroup 188, 0 Dec  7 12:41 ttyUSB0
                            crw-rw-rw- 1 nobody nogroup   1, 9 Dec  7 12:41 urandom
                            crw-rw-rw- 1 nobody nogroup   1, 5 Dec  7 12:41 zero
                            Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                            Bus 001 Device 004: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
                            Bus 001 Device 003: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
                            Bus 001 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
                            root@Intel:~# ls /dev/serial/by-id/
                            usb-FTDI_FT232R_USB_UART_A90782OJ-if00-port0  usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00  usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if03
                            root@Intel:~#
                            root@Intel:~# ls -l /dev/serial/by-id
                            total 0
                            lrwxrwxrwx 1 root root 13 Dec  7 12:41 usb-FTDI_FT232R_USB_UART_A90782OJ-if00-port0 -> ../../ttyUSB0
                            lrwxrwxrwx 1 root root 13 Dec  7 12:41 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00 -> ../../ttyACM0
                            lrwxrwxrwx 1 root root 13 Dec  7 12:41 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if03 -> ../../ttyACM1
                            root@Intel:~#
                              GNU nano 5.4        100.conf
                            arch: amd64
                            cores: 2
                            features: nesting=1
                            hostname: ioBroker
                            memory: 4096
                            net0: name=eth0,bridge=vmbr0,firewall=1,hwaddr=1A:BA:1E:27:F0:F7,ip=dhcp,ip6=dhcp,type=veth
                            ostype: ubuntu
                            rootfs: local-lvm:vm-100-disk-0,size=16G
                            swap: 512
                            unprivileged: 1
                            lxc.cgroup2.devices.allow: c 189:* rwm
                            lxc.mount.entry: usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00 dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00 none bind,optional,create=file
                            lxc.cgroup2.devices.allow: c 166:* rwm
                            lxc.mount.entry: /dev/ttyACM0 dev/ttyACM0 none bind,optional,create=file
                            lxc.mount.entry: usb-FTDI_FT232R_USB_UART_A90782OJ-if00-port0 dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A90782OJ-if00-port0 none bind,optional,create=file
                            lxc.cgroup2.devices.allow: c 188:* rwm
                            lxc.mount.entry: /dev/ttyUSB0 dev/ttyUSB0 none bind,optional,create=file
                            • G Galli2k
                              total 0
                              root@Intel:~#
                              total 0
                              root@Intel:~#
                              arch: amd64
                              cores: 2
                              features: nesting=1
                              hostname: ioBroker
                              memory: 4096
                              ostype: ubuntu
                              swap: 512
                              unprivileged: 1
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #92
                              @galli2k Du hast ein Problem damit das die Berechtigungen zum zugriff auf die serielle Schnittstelle nicht ausreicht. Das ist ein Problem des LXC Setups - da musst du suchen.
                              Mehr kann ich dazu nicht sagen - ich setze das nicht ein.
                              A
                              G 1 Antwort Letzte Antwort
                              • AsgothianA Asgothian
                                A
                                Galli2k
                                #93
                                @asgothian Falls es jemanden helfen sollte:
                                Ich hatte vorher beim Anlegen des Lxc im Netzwerk DHCP gewählt.
                                Nun habe ich einen neuen Container mit einer statische IP angelegt und alles läuft wunderbar.
                                • G Galli2k
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #94
                                  @galli2k sagte in Zigbee iobroker Error while opening serialport:
                                  da muss noch mehr gewesen sein .. DHCP hat nix mit USB belegun gzu tun.
                                  • W Offline
                                    W Offline
                                    woupi
                                    #95
                                    leider muss ich dieses Thema nochmal hervorholen.
                                    Ich habe heute einen Sonoff Zigbee Stick bekommen.
                                    Ich habe ihn in den NUC gesteckt und in Proxmox zur VM iobroker durch gereicht.
                                    ls -la /dev/serial/by-id/ ergibt
                                    total 0
                                    drwxr-xr-x 2 root root 80 Nov  7 17:44 .
                                    drwxr-xr-x 4 root root 80 Nov  7 17:44 ..
                                    lrwxrwxrwx 1 root root 13 Nov  7 17:44 usb-1a86_USB_Serial-if00-port0 -> ../../t        tyUSB1
                                    lrwxrwxrwx 1 root root 13 Nov  7 17:44 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Pl        us_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0 -> ../../ttyUSB0
                                    Eingegeben unter COM-Anschluss im Adapter habe ich
                                    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0
                                    Hier der komplette log
                                    zigbee.0
                                    2023-11-07 19:16:24.684	error	Error herdsman start
                                    zigbee.0
                                    2023-11-07 19:16:24.684	error	Failed to start Zigbee
                                    zigbee.0
                                    2023-11-07 19:16:24.684	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                    zigbee.0
                                    2023-11-07 19:16:24.604	info	Installed Version: iobroker.zigbee@1.8.23
                                    zigbee.0
                                    2023-11-07 19:16:24.596	info	Starting Zigbee npm ...
                                    zigbee.0
                                    2023-11-07 19:16:24.596	info	Try to reconnect. 1 attempts left
                                    zigbee.0
                                    2023-11-07 19:16:14.595	error	Error herdsman start
                                    zigbee.0
                                    2023-11-07 19:16:14.594	error	Failed to start Zigbee
                                    zigbee.0
                                    2023-11-07 19:16:14.594	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                    zigbee.0
                                    2023-11-07 19:16:14.532	error	Re-commissioning your network will require re-pairing of all devices!
                                    zigbee.0
                                    2023-11-07 19:16:14.532	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                                    zigbee.0
                                    2023-11-07 19:16:14.532	error	Please update configuration to prevent further issues.
                                    zigbee.0
                                    2023-11-07 19:16:14.532	error	- Channel List: configured=11, adapter=11
                                    zigbee.0
                                    2023-11-07 19:16:14.532	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                                    zigbee.0
                                    2023-11-07 19:16:14.531	error	- Extended PAN ID: configured=dfddfddddddddeed, adapter=00124b002b48282c
                                    zigbee.0
                                    2023-11-07 19:16:14.531	error	- PAN ID: configured=6258, adapter=6258
                                    zigbee.0
                                    2023-11-07 19:16:14.531	error	Configuration is not consistent with adapter state/backup!
                                    zigbee.0
                                    2023-11-07 19:16:14.261	info	Installed Version: iobroker.zigbee@1.8.23
                                    zigbee.0
                                    2023-11-07 19:16:14.159	info	Starting Zigbee npm ...
                                    zigbee.0
                                    2023-11-07 19:16:14.097	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
                                    zigbee.0
                                    2023-11-07 19:15:37.122	info	terminating
                                    zigbee.0
                                    2023-11-07 19:15:36.683	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    zigbee.0
                                    2023-11-07 19:15:36.683	info	terminating
                                    zigbee.0
                                    2023-11-07 19:15:36.674	warn	Failed to stop zigbee during startup
                                    zigbee.0
                                    2023-11-07 19:15:36.625	info	Zigbee: disabling joining new devices.
                                    zigbee.0
                                    2023-11-07 19:15:36.622	info	cleaned everything up...
                                    zigbee.0
                                    2023-11-07 19:15:36.621	info	Got terminate signal TERMINATE_YOURSELF
                                    zigbee.0
                                    2023-11-07 19:09:56.448	info	List of port: [{"path":"/dev/ttyUSB1","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"c24d83bbb59ded11acdcdba5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
                                    zigbee.0
                                    2023-11-07 19:09:56.370	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                    zigbee.0
                                    2023-11-07 18:28:27.996	info	List of port: [{"path":"/dev/ttyUSB1","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"c24d83bbb59ded11acdcdba5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
                                    zigbee.0
                                    2023-11-07 18:28:27.938	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                    zigbee.0
                                    2023-11-07 18:26:08.388	error	Error herdsman start
                                    zigbee.0
                                    2023-11-07 18:26:08.388	error	Failed to start Zigbee
                                    zigbee.0
                                    2023-11-07 18:26:08.388	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                    zigbee.0
                                    2023-11-07 18:26:08.293	info	Installed Version: iobroker.zigbee@1.8.23
                                    zigbee.0
                                    2023-11-07 18:26:08.278	info	Starting Zigbee npm ...
                                    zigbee.0
                                    2023-11-07 18:26:08.277	info	Try to reconnect. 1 attempts left
                                    zigbee.0
                                    2023-11-07 18:25:58.275	error	Error herdsman start
                                    zigbee.0
                                    2023-11-07 18:25:58.275	error	Failed to start Zigbee
                                    zigbee.0
                                    2023-11-07 18:25:58.275	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                    zigbee.0
                                    2023-11-07 18:25:58.233	error	Re-commissioning your network will require re-pairing of all devices!
                                    zigbee.0
                                    2023-11-07 18:25:58.233	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                                    zigbee.0
                                    2023-11-07 18:25:58.233	error	Please update configuration to prevent further issues.
                                    zigbee.0
                                    2023-11-07 18:25:58.233	error	- Channel List: configured=11, adapter=11
                                    zigbee.0
                                    2023-11-07 18:25:58.232	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                                    zigbee.0
                                    2023-11-07 18:25:58.232	error	- Extended PAN ID: configured=dfddfddddddddeed, adapter=00124b002b48282c
                                    zigbee.0
                                    2023-11-07 18:25:58.232	error	- PAN ID: configured=6258, adapter=6258
                                    zigbee.0
                                    2023-11-07 18:25:58.232	error	Configuration is not consistent with adapter state/backup!
                                    zigbee.0
                                    2023-11-07 18:25:57.935	info	Installed Version: iobroker.zigbee@1.8.23
                                    zigbee.0
                                    2023-11-07 18:25:57.803	info	Starting Zigbee npm ...
                                    zigbee.0
                                    2023-11-07 18:25:57.758	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
                                    zigbee.0
                                    2023-11-07 18:25:54.553	info	Terminated (NO_ERROR): Without reason
                                    zigbee.0
                                    2023-11-07 18:25:54.552	info	terminating
                                    zigbee.0
                                    2023-11-07 18:25:54.122	error	Error herdsman start
                                    zigbee.0
                                    2023-11-07 18:25:54.122	error	Failed to start Zigbee
                                    zigbee.0
                                    2023-11-07 18:25:54.121	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                    zigbee.0
                                    2023-11-07 18:25:54.075	error	Re-commissioning your network will require re-pairing of all devices!
                                    zigbee.0
                                    2023-11-07 18:25:54.075	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                                    zigbee.0
                                    2023-11-07 18:25:54.075	error	Please update configuration to prevent further issues.
                                    zigbee.0
                                    2023-11-07 18:25:54.074	error	- Channel List: configured=11, adapter=11
                                    zigbee.0
                                    2023-11-07 18:25:54.074	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                                    zigbee.0
                                    2023-11-07 18:25:54.074	error	- Extended PAN ID: configured=dfddfddddddddeed, adapter=00124b002b48282c
                                    zigbee.0
                                    2023-11-07 18:25:54.074	error	- PAN ID: configured=6258, adapter=6258
                                    zigbee.0
                                    2023-11-07 18:25:54.074	error	Configuration is not consistent with adapter state/backup!
                                    zigbee.0
                                    2023-11-07 18:25:54.052	info	Zigbee: disabling joining new devices.
                                    zigbee.0
                                    2023-11-07 18:25:54.049	info	cleaned everything up...
                                    zigbee.0
                                    2023-11-07 18:25:53.725	info	Installed Version: iobroker.zigbee@1.8.23
                                    zigbee.0
                                    2023-11-07 18:25:53.628	info	Starting Zigbee npm ...
                                    zigbee.0
                                    2023-11-07 18:25:53.582	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
                                    zigbee.0
                                    2023-11-07 18:25:21.806	info	terminating
                                    zigbee.0
                                    2023-11-07 18:25:21.336	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    zigbee.0
                                    2023-11-07 18:25:21.335	info	terminating
                                    zigbee.0
                                    2023-11-07 18:25:21.335	warn	Failed to stop zigbee during startup
                                    zigbee.0
                                    2023-11-07 18:25:21.309	info	Zigbee: disabling joining new devices.
                                    zigbee.0
                                    2023-11-07 18:25:21.306	info	cleaned everything up...
                                    zigbee.0
                                    2023-11-07 18:25:21.299	error	Cannot read properties of undefined (reading 'getClients')
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    Wenn ich es richtig verstanden habe, stimmt etwas nicht mit dem Adapterstatus/Backup überein.
                                    Ich habe allerdings keine Ahnung was und auch nicht wo ich etwas ändern kann.
                                    Ich würde mich freuen, wenn einem unwissenden etwas unter die Arme gegriffen werden könnte.
                                    Vielen Dank und VG
                                    NUC10i3, Proxmox, VM Ubuntu iobroker, lxc ubuntu influxdb, grafana, lxc ubuntu SAE, lxc ubuntu MotionEye, WP Panasonic Jeisha 5kW mit Heishamon, Shelly 2.5 und 2pm Rolladensteuerung, OpenWB Wallbox
                                    • W woupi
                                      total 0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      Vielen Dank und VG
                                      #96
                                      @woupi
                                      Die Werte müssen übereinstimmen.
                                      W 1 Antwort Letzte Antwort
                                        @woupi
                                        W Offline
                                        W Offline
                                        woupi
                                        #97
                                        00124b002b48282c
                                        Super, vielen Dank. Ich habe mich nicht getraut das einzutragen, jetzt habe ich es einfach rein kopiert und siehe da funktioniert.
                                        Nochmal vielen Dank
                                        • tiobbT Offline
                                          tiobbT Offline
                                          tiobb
                                          #98
                                          Hallo, ich hänge mich hier mal rein. Mein Zigbee will auch einfach nicht laufen, habe schon einiges ausprobiert was hier so geschrieben wurde, leider ohne Erfolg. Ich hoffe ihr könnt mir helfen. Wie ihr wisst, bin ich ein absoluter Anfänger, wenn möglich für ganz ganz doofe erklären.
                                          permitted by applicable law.
                                          Last login: Fri Nov  3 17:54:35 2023 from 192.168.178.45
                                          pi@raspberrypi:~ $ ls -la /dev/serial/by-id/
                                          insgesamt 0
                                          drwxr-xr-x 2 root root 60 Nov 13 14:01 .
                                          drwxr-xr-x 4 root root 80 Nov 13 14:01 ..
                                          lrwxrwxrwx 1 root root 13 Nov 13 14:01 usb-Texas_Instruments_TI_CC2531_USB_CDC__
                                          Opera Momentaufnahme_2023-11-13_151230_192.168.178.76.png Opera Momentaufnahme_2023-11-13_151201_192.168.178.76.png Opera Momentaufnahme_2023-11-13_151139_192.168.178.76.png Opera Momentaufnahme_2023-11-13_151104_192.168.178.76.png
                                          Raspberry Pi 4 8gb
