  4. Zigbee iobroker Error while opening serialport
    6.6k
231 Beiträge 28 Kommentatoren 64.1k Aufrufe 24 Beobachtet
  • GlasfaserG Glasfaser
    @yoshi sagte in Zigbee iobroker Error while opening serialport:
    leider das gleich Problem,
    BITTE keine Aussagen .... immer Log´s dazu zeigen !!!
    Y Offline
    Y Offline
    Yoshi
    schrieb am zuletzt editiert von Yoshi
    #78
    @glasfaser
    zigbee.0
    2022-08-15 19:03:06.791	error	Error herdsman start
    zigbee.0
    2022-08-15 19:03:06.791	error	Failed to start Zigbee
    zigbee.0
    2022-08-15 19:03:06.789	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2149258-if00'"
    zigbee.0
    2022-08-15 19:03:06.561	info	Installed Version: iobroker.zigbee@1.7.6
    zigbee.0
    2022-08-15 19:03:06.539	info	Starting Zigbee npm ...
    zigbee.0
    2022-08-15 19:03:06.537	info	Try to reconnect. 1 attempts left
    zigbee.0
    2022-08-15 19:02:56.537	info	Installed Version: iobroker.zigbee@1.7.6
    zigbee.0
    2022-08-15 19:02:56.534	error	Error herdsman start
    zigbee.0
    2022-08-15 19:02:56.533	error	Failed to start Zigbee
    zigbee.0
    2022-08-15 19:02:56.532	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2149258-if00'"
    zigbee.0
    2022-08-15 19:02:55.925	info	Starting Zigbee npm ...
    zigbee.0
    2022-08-15 19:02:55.922	info	delete old Backup files. keep only last 10
    zigbee.0
    2022-08-15 19:02:55.809	info	starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
    host.raspberrypi4-iob
    2022-08-15 19:02:51.679	info	instance system.adapter.zigbee.0 started with pid 12761
    2022-08-15 19:02:51.472	info	"system.adapter.zigbee.0" enabled
      @yoshi
      systemctl status deconz deconz-gui
      Y Offline
      Y Offline
      Yoshi
      #79
      pi@raspberrypi4-iob:~ $ systemctl status deconz deconz-gui
      ● deconz.service - deCONZ: ZigBee gateway -- REST API
           Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset>
           Active: active (running) since Mon 2022-08-15 18:51:20 CEST; 18min ago
         Main PID: 349 (deCONZ)
            Tasks: 4 (limit: 4915)
           CGroup: /system.slice/deconz.service
                   └─349 /usr/bin/deCONZ -platform minimal --http-port=80
      Aug 15 18:52:14 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
      Aug 15 18:52:16 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
      Aug 15 18:53:15 raspberrypi4-iob deCONZ[349]: "Keine derartige Schnittstelle »o>
      Aug 15 18:59:34 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
      Aug 15 19:02:31 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
      Aug 15 19:04:37 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
      Aug 15 19:04:53 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
      Aug 15 19:04:55 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
      Aug 15 19:05:11 raspberrypi4-iob deCONZ[349]: This plugin does not support prop>
      {1}
      ● deconz-gui.service - deCONZ: ZigBee gateway -- GUI/REST API
           Loaded: loaded (/lib/systemd/system/deconz-gui.service; enabled; vendor pr>
           Active: activating (auto-restart) (Result: signal) since Mon 2022-08-15 19>
          Process: 16935 ExecStart=/usr/bin/deCONZ --http-port=80 (code=killed, signa>
      lines 1-23
      {1}
      {1}
      • Y Yoshi
        {1}
        lines 1-23
        {1}
        {1}
        #80
        @yoshi
        sudo systemctl stop deconz
        sudo systemctl disable deconz
        sudo systemctl stop deconz-gui
        sudo systemctl disable deconz-gui
        Y 1 Antwort Letzte Antwort
          @yoshi
          Y Offline
          Y Offline
          Yoshi
          #81
          Hey Thomas, wenn du ne Frau wärest würde ich dich glatt heiraten. :-)
          Vielen Dank. Nun läuft es, ich hoffe auch nach einem Neustart
          • Y Yoshi
            #82
            Wenn du beide Services disabled hast ja.
              Y Offline
              Y Offline
              Yoshi
              #83
              Ja, hab das gemacht.
              Muss ich alle Teilnehmer neu anlernen ? ich sehe sie zwar in der Geräteübersicht aber sie sind nicht verbunden.
              • Y Yoshi
                #84
                Möglich. Vielleicht sind die noch mit dem deconz verheiratet.
                  #85
                  Und @Asgothian ein "soooooooooooooooory fürs 'derailing'". Kommt nicht wieder vor. 😗
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #86
                    @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
                    Wieso derailing - beim deconz war ich auch schon. Auch die Frage ob der noch läuft. Aber von Unterwegs konnte ich nicht die korrekten Befehle Posten :)
                    • H Offline
                      Harry87
                      schrieb am zuletzt editiert von Harry87
                      #87
                      Servus,
                      ich hatte denselben Fehler, dass kein Zugriff mehr auf den Serial Port möglich war.
                      2022-10-14 18:38:07.286  - error: zigbee.0 (3145) Error herdsman start
                      2022-10-14 18:38:17.289  - info: zigbee.0 (3145) Try to reconnect. 1 attempts left
                      2022-10-14 18:38:17.290  - info: zigbee.0 (3145) Starting Zigbee  npm ...
                      2022-10-14 18:38:17.311  - info: zigbee.0 (3145) Installed Version: iobroker.zigbee@1.7.5
                      2022-10-14 18:38:17.475  - error: zigbee.0 (3145) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                      2022-10-14 18:38:17.476  - error: zigbee.0 (3145) Failed to start Zigbee
                      2022-10-14 18:38:17.476  - error: zigbee.0 (3145) Error herdsman start
                      Ursache war, dass auf dem gleichen Raspberry Debmatic läuft und dort der CUxDeamon den Serial-Port belegt hat.
                      Man kann dem CUxDeamon sagen, dass er einen bestimmten Port nicht verwenden soll, indem man im CUxD-Setup unten folgende Zeile ergänzt:
                      TTYASSIGN=ttyUSB0:NC
                      Obacht: Port "USB0" kann abweichen!
                      Danach Raspberry neu starten und schon lief der Zigbee-Adapter im ioBroker wieder.
                        klausiy123
                        schrieb am zuletzt editiert von klausiy123
                        #88
                        Hallo
                        Mein cc26x2 mag, warum auch immer, nicht mehr. Vielleicht kann mir jemand helfen. Vielen Dank im voraus.
                        2022-11-22 16:46:21.405 - info: host.orangepiplus2e "system.adapter.zigbee.0" enabled
                        2022-11-22 16:46:22.201 - info: host.orangepiplus2e instance system.adapter.zigbee.0 started with pid 1538
                        2022-11-22 16:46:34.269 - info: zigbee.0 (1538) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.23
                        2022-11-22 16:46:34.577 - info: zigbee.0 (1538) delete old Backup files. keep only last 10
                        2022-11-22 16:46:34.584 - info: zigbee.0 (1538) Starting Zigbee npm ...
                        2022-11-22 16:46:36.030 - info: zigbee.0 (1538) Installed Version: iobroker.zigbee@1.7.5
                        2022-11-22 16:46:56.485 - error: zigbee.0 (1538) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                        2022-11-22 16:46:56.488 - error: zigbee.0 (1538) Failed to start Zigbee
                        2022-11-22 16:46:56.490 - error: zigbee.0 (1538) Error herdsman start
                        2022-11-22 16:47:06.502 - info: zigbee.0 (1538) Try to reconnect. 1 attempts left
                        2022-11-22 16:47:06.506 - info: zigbee.0 (1538) Starting Zigbee npm ...
                        2022-11-22 16:47:06.561 - info: zigbee.0 (1538) Installed Version: iobroker.zigbee@1.7.5
                        2022-11-22 16:47:07.170 - error: zigbee.0 (1538) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                        2022-11-22 16:47:07.174 - error: zigbee.0 (1538) Failed to start Zigbee
                        2022-11-22 16:47:07.175 - error: zigbee.0 (1538) Error herdsman start
                        • K klausiy123
                          Hallo
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #89
                          @klausiy123 zieh den coordinator ab und steck den wieder rein
                          • arteckA arteck
                            klausiy123
                            #90
                            @arteck besten Dank, das war wohl der Fehler, auch wenn ich nicht verstehe warum das nach Jahren erstmals auftrat und das Teil nie bewegt wurde.
                            • G Offline
                              Galli2k
                              #91
                              Hallo zusammen, auch ich bin verzweifelt den Zigbee adapter mit dem CC1352p-2 coordinator zum laufen zu bringen.
                              Hier mal einiges was ich so gemacht hab. Ich hoffe jemand kann mir Helfen. Danke
                              PS: ioBroker läuft auf ein LXC in Proxmox
                              2022-12-07 18:50:59.448 - info: backitup.0 (385) [iobroker] backup was activated at 02:40 every 1 day(s)
                              2022-12-07 18:56:16.554 - info: admin.0 (343) ==> Connected system.user.admin from ::ffff:192.168.178.68
                              2022-12-07 18:59:17.572 - info: host.ioBroker "system.adapter.zigbee.0" enabled
                              2022-12-07 18:59:17.587 - info: host.ioBroker instance system.adapter.zigbee.0 started with pid 416
                              2022-12-07 18:59:18.664 - info: zigbee.0 (416) starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.23
                              2022-12-07 18:59:18.704 - info: zigbee.0 (416) Starting Zigbee npm ...
                              2022-12-07 18:59:18.916 - info: zigbee.0 (416) Installed Version: iobroker.zigbee@1.7.6
                              2022-12-07 18:59:18.953 - error: zigbee.0 (416) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00'"
                              2022-12-07 18:59:18.954 - error: zigbee.0 (416) Failed to start Zigbee
                              2022-12-07 18:59:18.954 - error: zigbee.0 (416) Error herdsman start
                              2022-12-07 18:59:21.505 - info: admin.0 (343) ==> Connected system.user.admin from ::ffff:192.168.178.68
                              2022-12-07 18:59:21.555 - error: zigbee.0 (416) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                              2022-12-07 18:59:28.956 - info: zigbee.0 (416) Try to reconnect. 1 attempts left
                              2022-12-07 18:59:28.957 - info: zigbee.0 (416) Starting Zigbee npm ...
                              2022-12-07 18:59:28.964 - info: zigbee.0 (416) Installed Version: iobroker.zigbee@1.7.6
                              2022-12-07 18:59:29.047 - error: zigbee.0 (416) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00'"
                              2022-12-07 18:59:29.048 - error: zigbee.0 (416) Failed to start Zigbee
                              2022-12-07 18:59:29.048 - error: zigbee.0 (416) Error herdsman start
                              2022-12-07 18:59:32.398 - info: admin.0 (343) <== Disconnect system.user.admin from ::ffff:192.168.178.68
                              root@ioBroker:~# ls -l /dev
                              total 0
                              crw--w---- 1 root   tty     136, 0 Dec  7 18:50 console
                              lrwxrwxrwx 1 root   root        11 Dec  7 18:50 core -> /proc/kcore
                              lrwxrwxrwx 1 root   root        13 Dec  7 18:50 fd -> /proc/self/fd
                              crw-rw-rw- 1 nobody nogroup   1, 7 Dec  7 12:41 full
                              lrwxrwxrwx 1 root   root        12 Dec  7 18:50 initctl -> /run/initctl
                              lrwxrwxrwx 1 root   root        28 Dec  7 18:50 log -> /run/systemd/journal/dev-log
                              drwxrwxrwt 2 nobody nogroup     40 Dec  7 18:50 mqueue
                              crw-rw-rw- 1 nobody nogroup   1, 3 Dec  7 12:41 null
                              crw-rw-rw- 1 root   root      5, 2 Dec  7 19:20 ptmx
                              drwxr-xr-x 2 root   root         0 Dec  7 18:50 pts
                              crw-rw-rw- 1 nobody nogroup   1, 8 Dec  7 12:41 random
                              drwxr-xr-x 3 root   root        60 Dec  7 18:50 serial
                              drwxrwxrwt 2 root   root        40 Dec  7 18:50 shm
                              lrwxrwxrwx 1 root   root        15 Dec  7 18:50 stderr -> /proc/self/fd/2
                              lrwxrwxrwx 1 root   root        15 Dec  7 18:50 stdin -> /proc/self/fd/0
                              lrwxrwxrwx 1 root   root        15 Dec  7 18:50 stdout -> /proc/self/fd/1
                              crw-rw-rw- 1 nobody nogroup   5, 0 Dec  7 12:41 tty
                              crw------- 1 root   tty     136, 1 Dec  7 19:20 tty1
                              crw--w---- 1 root   tty     136, 2 Dec  7 18:50 tty2
                              crw-rw-rw- 1 nobody nogroup 166, 0 Dec  7 12:41 ttyACM0
                              crw-rw-rw- 1 nobody nogroup 188, 0 Dec  7 12:41 ttyUSB0
                              crw-rw-rw- 1 nobody nogroup   1, 9 Dec  7 12:41 urandom
                              crw-rw-rw- 1 nobody nogroup   1, 5 Dec  7 12:41 zero
                              Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                              Bus 001 Device 004: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
                              Bus 001 Device 003: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
                              Bus 001 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
                              root@Intel:~# ls /dev/serial/by-id/
                              usb-FTDI_FT232R_USB_UART_A90782OJ-if00-port0  usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00  usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if03
                              root@Intel:~#
                              root@Intel:~# ls -l /dev/serial/by-id
                              total 0
                              lrwxrwxrwx 1 root root 13 Dec  7 12:41 usb-FTDI_FT232R_USB_UART_A90782OJ-if00-port0 -> ../../ttyUSB0
                              lrwxrwxrwx 1 root root 13 Dec  7 12:41 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00 -> ../../ttyACM0
                              lrwxrwxrwx 1 root root 13 Dec  7 12:41 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if03 -> ../../ttyACM1
                              root@Intel:~#
                                GNU nano 5.4        100.conf
                              arch: amd64
                              cores: 2
                              features: nesting=1
                              hostname: ioBroker
                              memory: 4096
                              net0: name=eth0,bridge=vmbr0,firewall=1,hwaddr=1A:BA:1E:27:F0:F7,ip=dhcp,ip6=dhcp,type=veth
                              ostype: ubuntu
                              rootfs: local-lvm:vm-100-disk-0,size=16G
                              swap: 512
                              unprivileged: 1
                              lxc.cgroup2.devices.allow: c 189:* rwm
                              lxc.mount.entry: usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00 dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L430042O-if00 none bind,optional,create=file
                              lxc.cgroup2.devices.allow: c 166:* rwm
                              lxc.mount.entry: /dev/ttyACM0 dev/ttyACM0 none bind,optional,create=file
                              lxc.mount.entry: usb-FTDI_FT232R_USB_UART_A90782OJ-if00-port0 dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A90782OJ-if00-port0 none bind,optional,create=file
                              lxc.cgroup2.devices.allow: c 188:* rwm
                              lxc.mount.entry: /dev/ttyUSB0 dev/ttyUSB0 none bind,optional,create=file
                              • G Galli2k
                                total 0
                                root@Intel:~#
                                total 0
                                root@Intel:~#
                                arch: amd64
                                cores: 2
                                features: nesting=1
                                hostname: ioBroker
                                memory: 4096
                                ostype: ubuntu
                                swap: 512
                                unprivileged: 1
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #92
                                @galli2k Du hast ein Problem damit das die Berechtigungen zum zugriff auf die serielle Schnittstelle nicht ausreicht. Das ist ein Problem des LXC Setups - da musst du suchen.
                                Mehr kann ich dazu nicht sagen - ich setze das nicht ein.
                                A
                                G 1 Antwort Letzte Antwort
                                • AsgothianA Asgothian
                                  A
                                  Galli2k
                                  #93
                                  @asgothian Falls es jemanden helfen sollte:
                                  Ich hatte vorher beim Anlegen des Lxc im Netzwerk DHCP gewählt.
                                  Nun habe ich einen neuen Container mit einer statische IP angelegt und alles läuft wunderbar.
                                  • G Galli2k
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #94
                                    @galli2k sagte in Zigbee iobroker Error while opening serialport:
                                    da muss noch mehr gewesen sein .. DHCP hat nix mit USB belegun gzu tun.
                                    • W Offline
                                      W Offline
                                      woupi
                                      #95
                                      leider muss ich dieses Thema nochmal hervorholen.
                                      Ich habe heute einen Sonoff Zigbee Stick bekommen.
                                      Ich habe ihn in den NUC gesteckt und in Proxmox zur VM iobroker durch gereicht.
                                      ls -la /dev/serial/by-id/ ergibt
                                      total 0
                                      drwxr-xr-x 2 root root 80 Nov  7 17:44 .
                                      drwxr-xr-x 4 root root 80 Nov  7 17:44 ..
                                      lrwxrwxrwx 1 root root 13 Nov  7 17:44 usb-1a86_USB_Serial-if00-port0 -> ../../t        tyUSB1
                                      lrwxrwxrwx 1 root root 13 Nov  7 17:44 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Pl        us_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0 -> ../../ttyUSB0
                                      Eingegeben unter COM-Anschluss im Adapter habe ich
                                      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0
                                      Hier der komplette log
                                      zigbee.0
                                      2023-11-07 19:16:24.684	error	Error herdsman start
                                      zigbee.0
                                      2023-11-07 19:16:24.684	error	Failed to start Zigbee
                                      zigbee.0
                                      2023-11-07 19:16:24.684	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                      zigbee.0
                                      2023-11-07 19:16:24.604	info	Installed Version: iobroker.zigbee@1.8.23
                                      zigbee.0
                                      2023-11-07 19:16:24.596	info	Starting Zigbee npm ...
                                      zigbee.0
                                      2023-11-07 19:16:24.596	info	Try to reconnect. 1 attempts left
                                      zigbee.0
                                      2023-11-07 19:16:14.595	error	Error herdsman start
                                      zigbee.0
                                      2023-11-07 19:16:14.594	error	Failed to start Zigbee
                                      zigbee.0
                                      2023-11-07 19:16:14.594	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                      zigbee.0
                                      2023-11-07 19:16:14.532	error	Re-commissioning your network will require re-pairing of all devices!
                                      zigbee.0
                                      2023-11-07 19:16:14.532	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                                      zigbee.0
                                      2023-11-07 19:16:14.532	error	Please update configuration to prevent further issues.
                                      zigbee.0
                                      2023-11-07 19:16:14.532	error	- Channel List: configured=11, adapter=11
                                      zigbee.0
                                      2023-11-07 19:16:14.532	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                                      zigbee.0
                                      2023-11-07 19:16:14.531	error	- Extended PAN ID: configured=dfddfddddddddeed, adapter=00124b002b48282c
                                      zigbee.0
                                      2023-11-07 19:16:14.531	error	- PAN ID: configured=6258, adapter=6258
                                      zigbee.0
                                      2023-11-07 19:16:14.531	error	Configuration is not consistent with adapter state/backup!
                                      zigbee.0
                                      2023-11-07 19:16:14.261	info	Installed Version: iobroker.zigbee@1.8.23
                                      zigbee.0
                                      2023-11-07 19:16:14.159	info	Starting Zigbee npm ...
                                      zigbee.0
                                      2023-11-07 19:16:14.097	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
                                      zigbee.0
                                      2023-11-07 19:15:37.122	info	terminating
                                      zigbee.0
                                      2023-11-07 19:15:36.683	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      zigbee.0
                                      2023-11-07 19:15:36.683	info	terminating
                                      zigbee.0
                                      2023-11-07 19:15:36.674	warn	Failed to stop zigbee during startup
                                      zigbee.0
                                      2023-11-07 19:15:36.625	info	Zigbee: disabling joining new devices.
                                      zigbee.0
                                      2023-11-07 19:15:36.622	info	cleaned everything up...
                                      zigbee.0
                                      2023-11-07 19:15:36.621	info	Got terminate signal TERMINATE_YOURSELF
                                      zigbee.0
                                      2023-11-07 19:09:56.448	info	List of port: [{"path":"/dev/ttyUSB1","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"c24d83bbb59ded11acdcdba5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
                                      zigbee.0
                                      2023-11-07 19:09:56.370	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                      zigbee.0
                                      2023-11-07 18:28:27.996	info	List of port: [{"path":"/dev/ttyUSB1","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"c24d83bbb59ded11acdcdba5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
                                      zigbee.0
                                      2023-11-07 18:28:27.938	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                      zigbee.0
                                      2023-11-07 18:26:08.388	error	Error herdsman start
                                      zigbee.0
                                      2023-11-07 18:26:08.388	error	Failed to start Zigbee
                                      zigbee.0
                                      2023-11-07 18:26:08.388	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                      zigbee.0
                                      2023-11-07 18:26:08.293	info	Installed Version: iobroker.zigbee@1.8.23
                                      zigbee.0
                                      2023-11-07 18:26:08.278	info	Starting Zigbee npm ...
                                      zigbee.0
                                      2023-11-07 18:26:08.277	info	Try to reconnect. 1 attempts left
                                      zigbee.0
                                      2023-11-07 18:25:58.275	error	Error herdsman start
                                      zigbee.0
                                      2023-11-07 18:25:58.275	error	Failed to start Zigbee
                                      zigbee.0
                                      2023-11-07 18:25:58.275	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                      zigbee.0
                                      2023-11-07 18:25:58.233	error	Re-commissioning your network will require re-pairing of all devices!
                                      zigbee.0
                                      2023-11-07 18:25:58.233	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                                      zigbee.0
                                      2023-11-07 18:25:58.233	error	Please update configuration to prevent further issues.
                                      zigbee.0
                                      2023-11-07 18:25:58.233	error	- Channel List: configured=11, adapter=11
                                      zigbee.0
                                      2023-11-07 18:25:58.232	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                                      zigbee.0
                                      2023-11-07 18:25:58.232	error	- Extended PAN ID: configured=dfddfddddddddeed, adapter=00124b002b48282c
                                      zigbee.0
                                      2023-11-07 18:25:58.232	error	- PAN ID: configured=6258, adapter=6258
                                      zigbee.0
                                      2023-11-07 18:25:58.232	error	Configuration is not consistent with adapter state/backup!
                                      zigbee.0
                                      2023-11-07 18:25:57.935	info	Installed Version: iobroker.zigbee@1.8.23
                                      zigbee.0
                                      2023-11-07 18:25:57.803	info	Starting Zigbee npm ...
                                      zigbee.0
                                      2023-11-07 18:25:57.758	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
                                      zigbee.0
                                      2023-11-07 18:25:54.553	info	Terminated (NO_ERROR): Without reason
                                      zigbee.0
                                      2023-11-07 18:25:54.552	info	terminating
                                      zigbee.0
                                      2023-11-07 18:25:54.122	error	Error herdsman start
                                      zigbee.0
                                      2023-11-07 18:25:54.122	error	Failed to start Zigbee
                                      zigbee.0
                                      2023-11-07 18:25:54.121	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                      zigbee.0
                                      2023-11-07 18:25:54.075	error	Re-commissioning your network will require re-pairing of all devices!
                                      zigbee.0
                                      2023-11-07 18:25:54.075	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                                      zigbee.0
                                      2023-11-07 18:25:54.075	error	Please update configuration to prevent further issues.
                                      zigbee.0
                                      2023-11-07 18:25:54.074	error	- Channel List: configured=11, adapter=11
                                      zigbee.0
                                      2023-11-07 18:25:54.074	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                                      zigbee.0
                                      2023-11-07 18:25:54.074	error	- Extended PAN ID: configured=dfddfddddddddeed, adapter=00124b002b48282c
                                      zigbee.0
                                      2023-11-07 18:25:54.074	error	- PAN ID: configured=6258, adapter=6258
                                      zigbee.0
                                      2023-11-07 18:25:54.074	error	Configuration is not consistent with adapter state/backup!
                                      zigbee.0
                                      2023-11-07 18:25:54.052	info	Zigbee: disabling joining new devices.
                                      zigbee.0
                                      2023-11-07 18:25:54.049	info	cleaned everything up...
                                      zigbee.0
                                      2023-11-07 18:25:53.725	info	Installed Version: iobroker.zigbee@1.8.23
                                      zigbee.0
                                      2023-11-07 18:25:53.628	info	Starting Zigbee npm ...
                                      zigbee.0
                                      2023-11-07 18:25:53.582	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
                                      zigbee.0
                                      2023-11-07 18:25:21.806	info	terminating
                                      zigbee.0
                                      2023-11-07 18:25:21.336	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      zigbee.0
                                      2023-11-07 18:25:21.335	info	terminating
                                      zigbee.0
                                      2023-11-07 18:25:21.335	warn	Failed to stop zigbee during startup
                                      zigbee.0
                                      2023-11-07 18:25:21.309	info	Zigbee: disabling joining new devices.
                                      zigbee.0
                                      2023-11-07 18:25:21.306	info	cleaned everything up...
                                      zigbee.0
                                      2023-11-07 18:25:21.299	error	Cannot read properties of undefined (reading 'getClients')
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      Wenn ich es richtig verstanden habe, stimmt etwas nicht mit dem Adapterstatus/Backup überein.
                                      Ich habe allerdings keine Ahnung was und auch nicht wo ich etwas ändern kann.
                                      Ich würde mich freuen, wenn einem unwissenden etwas unter die Arme gegriffen werden könnte.
                                      Vielen Dank und VG
                                      NUC10i3, Proxmox, VM Ubuntu iobroker, lxc ubuntu influxdb, grafana, lxc ubuntu SAE, lxc ubuntu MotionEye, WP Panasonic Jeisha 5kW mit Heishamon, Shelly 2.5 und 2pm Rolladensteuerung, OpenWB Wallbox
                                      • W woupi
                                        total 0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        Vielen Dank und VG
                                        #96
                                        @woupi
                                        Die Werte müssen übereinstimmen.
                                        W 1 Antwort Letzte Antwort
                                          @woupi
                                          W Offline
                                          W Offline
                                          woupi
                                          #97
                                          00124b002b48282c
                                          Super, vielen Dank. Ich habe mich nicht getraut das einzutragen, jetzt habe ich es einfach rein kopiert und siehe da funktioniert.
                                          Nochmal vielen Dank
