  4. Geöst Alexa2 Fehler nach Pi-Hole DHCP Server geändert
47 Beiträge 3 Kommentatoren 1.7k Aufrufe 3 Beobachtet
    @thomas-braun ich habe den DNS Server neu installiert und ne neue DNS eingestellt
    Soll ich mal Fix
    @marcel-drzal
    Ich weiß nicht was du da genau wie und wo eingestellt hast.
    War aber offenbar falsch und die Namensauflösung funktioniert nicht mehr.
    ? 2 Antworten Letzte Antwort
      @marcel-drzal
      was kann ich da machen? Habe schon Fix versucht. geht auch nicht
      marcel@iobroker:/opt/iobroker$ iob upgrade self
      Server Configured backup period 120 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
      Host    "iobroker"       is up to date.
      marcel@iobroker:/opt/iobroker$ iob start
      marcel@iobroker:/opt/iobroker$ sudo apt update
      [sudo] password for marcel:
      Err:1 http://security.debian.org/debian-security bullseye-security InRelease
        Temporary failure resolving 'security.debian.org'
      Err:2 https://repos.influxdata.com/debian buster InRelease
        Temporary failure resolving 'repos.influxdata.com'
      Err:3 https://deb.nodesource.com/node_16.x bullseye InRelease
        Temporary failure resolving 'deb.nodesource.com'
      Err:4 https://dl.yarnpkg.com/debian stable InRelease
        Temporary failure resolving 'dl.yarnpkg.com'
      Err:5 http://deb.debian.org/debian bullseye InRelease
        Temporary failure resolving 'deb.debian.org'
      Err:6 http://deb.debian.org/debian bullseye-updates InRelease
      Reading package lists... Done
      All packages are up to date.
      W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Temporary failure resolving 'deb.debian.org'
      W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Temporary failure resolving 'deb.debian.org'
      W: Failed to fetch http://security.debian.org/debian-security/dists/bullseye-security/InRelease  Temporary failure resolving 'security.debian.org'
      W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  Temporary failure resolving 'repos.influxdata.com'
      W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Temporary failure resolving 'deb.nodesource.com'
      W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  Temporary failure resolving 'dl.yarnpkg.com'
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      marcel@iobroker:/opt/iobroker$ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      x86_64
      Kein Docker
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.1
      v16.17.1
      8.15.0
      4.0.23
      marcel
      marcel sudo iobroker
      tty
      /opt/iobroker
      Err:4 http://deb.debian.org/debian bullseye InRelease
      Err:5 https://dl.yarnpkg.com/debian stable InRelease
      nodejs:
        Installed: 16.17.1-deb-1nodesource1
        Candidate: 16.17.1-deb-1nodesource1
        Version table:
       *** 16.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
           12.22.12~dfsg-1~deb11u1 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      • Thomas BraunT Online
        @marcel-drzal
        Mit dem iobroker hat das nichts zu tun, das ist ein Knoten im Netzwerk-Setup.
          @codierknecht ja habe den DNS Server eine IP gegeben im Router
          CodierknechtC Offline
          Codierknecht
          @marcel-drzal sagte in Alexa2 Fehler nach Pi-Hole DHCP Server geändert:
          Ich kann da nicht ganz folgen.
          Du hast dem DNS Deiner Proxmox gesagt, dass der Router die Namen auflöst?
          Kann ja nicht - Dein Router löst doch keine öffentlichen Domainnamen in IP's auf.
          Ich kenne Proxmox nicht.
          Hat das 'nen eigenen DNS? Kannst Du dem sagen, dass der Primary "1.1.1.1" und der Secondary "8.8.8.8" sein soll?
          Das Netzwerkproblem kann der ioBroker auch nicht lösen ;-)
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
            @marcel-drzal
            Danke noch mal
            DNS Server in Proxmox nicht umgestellt.
            es kann so einfach sein
            noch eine Frage, die Version v16.17.1 ist die richtige? da ich auf dem Rasperry die v16.17.0 habe?
            CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
              Danke noch mal
              Codierknecht
              Meine sind jedenfalls neuer:
              Update schadet nicht - gibt sonst wieder Mecker vom Chef ;-)
                Danke noch mal
                @marcel-drzal
                Spiel halt Updates regelmäßig per üblichem Vorgehen ein.
                sudo apt update
                sudo apt full-upgrade
                Schwupps, schon ist sie Kiste auf aktuellem Stand.
                  @marcel-drzal
                  sudo apt update
                  @thomas-braun sagte in Geöst Alexa2 Fehler nach Pi-Hole DHCP Server geändert:
                  sudo apt update
                  pi@pi-Slave1:/ $ sudo apt-get update
                  Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                  Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                  Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                  Err:2 http://deb.debian.org/debian bullseye InRelease
                    Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
                  Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                  Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [196 kB]
                  Get:7 http://security.debian.org/debian-security bullseye-security/main armhf Packages [197 kB]
                  Get:8 http://security.debian.org/debian-security bullseye-security/main Translation-en [130 kB]
                  Err:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                    Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
                  Fetched 571 kB in 3s (182 kB/s)
                  Reading package lists... Error!
                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://deb.debian.org/debian bullseye InRelease: Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_16.x bullseye InRelease: Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
                  W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
                  W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
                  E: Splitting of clearsigned file /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease failed as it doesn't contain all expected parts
                  E: The package lists or status file could not be parsed or opened.
                  pi@pi-Slave1:/ $ sudo apt update
                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  pi@pi-Slave1:/ $
                  Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                  Hit:3 http://deb.debian.org/debian bullseye InRelease
                  Err:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                  Err:3 http://deb.debian.org/debian bullseye InRelease
                  Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
                  pi@pi-Slave1:~ $
                  pi@pi-Slave1:/etc/network $ sudo systemctl status dhcpcd
                  ● dhcpcd.service - DHCP Client Daemon
                       Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset>
                       Active: active (running) since Wed 2022-11-16 17:39:53 CET; 18h ago
                         Docs: man:dhcpcd(8)
                      Process: 411 ExecStart=/usr/sbin/dhcpcd -b -q (code=exited, status=0/SUCCES>
                     Main PID: 469 (dhcpcd)
                        Tasks: 2 (limit: 779)
                          CPU: 14.446s
                       CGroup: /system.slice/dhcpcd.service
                               ├─469 /usr/sbin/dhcpcd -b -q
                               └─548 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf >
                  Nov 17 11:34:35 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                  Nov 17 11:34:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                  Nov 17 11:34:43 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                  Nov 17 11:36:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                  Nov 17 11:45:36 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                  Nov 17 11:51:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                  Nov 17 11:52:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                  Nov 17 11:57:00 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                  Nov 17 12:06:24 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                  Nov 17 12:06:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                  lines 1-22/22 (END)
                       Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
                         Docs: man:dhcpcd(8)
                      Process: 411 ExecStart=/usr/sbin/dhcpcd -b -q (code=exited, status=0/SUCCESS)
                          CPU: 14.446s
                               └─548 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
                  Nov 17 11:34:35 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                  Nov 17 11:34:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                  Nov 17 11:34:43 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                  Nov 17 11:36:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                  Nov 17 11:45:36 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                  Nov 17 11:51:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                  Nov 17 11:52:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                  Nov 17 11:57:00 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                  Nov 17 12:06:24 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                  Nov 17 12:06:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                  auf meinen Raspi, Hier stell ich doch keinen DHCP ein oder? wo schau ich das nach?
                    sudo apt update
                    pi@pi-Slave1:/ $
                    pi@pi-Slave1:~ $
                           Docs: man:dhcpcd(8)
                            CPU: 14.446s
                    lines 1-22/22 (END)
                           Docs: man:dhcpcd(8)
                            CPU: 14.446s
                    @marcel-drzal
                    Nee, da sind deine Repos falsch. Kann das aber im Moment nicht gut nachvollziehen, da am Handy unterwegs.
                      Systemdata Bitte Ausfüllen
                      Hardwaresystem: NUC/Pi3/etc.
                      Arbeitsspeicher: 1GB
                      Festplattenart: SD-Karte/SSD/HDD
                      Betriebssystem: Ubuntu/Windows/Mac
                      Node-Version: v16.17.1
                      Nodejs-Version: v16.17.1
                      NPM-Version: v8.15.0
                      Installationsart: Skript/Manuell
                      Image genutzt: Ja/Nein
                      Ort/Name der Imagedatei: Link
                      Hallo Zusammen,
                      ich habe den Pasperry Pi auf einen Container Proxmox umgezogen.
                      Soweit habe ich die neue DHCP Adresse überall eingetragen.
                      Jetzt bekomme ich eine Fehlermeldung bei dem Alexa2 Adapter.
                      Nun habe ich den Alexa 2 Adapter gelscht, und kann ihn nicht mehr Installieren.
                      x86_64
                      Kein Docker
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.17.1
                      v16.17.1
                      8.15.0
                      4.0.23
                      marcel
                      tty
                      /opt/iobroker
                      nodejs:
                        Version table:
                      folgedne Fehlermelung erhalte ich im iOBroker bei der Installation:
                      $ iobroker add alexa2 auto --host iobroker --debug
                      NPM version: 8.15.0
                      Installing iobroker.alexa2@3.21.0... (System call)
                      **npm ERR! code ETARGET
                      host.iobroker Cannot install iobroker.alexa2@3.21.0: 1
                      ERROR: Process exited with code 25**
                      Ich hoffe ihr könnt mir helfen.
                      sudo rm /var/lib/apt/lists/* dann ging es
                        @marcel-drzal
                        Dann lass jetzt mal ein
                        sudo apt update
                        sehen. Und bitte auch
                        df -h
                          @marcel-drzal
                          sudo apt update
                          df -h
                          sudo apt update
                          bei Rasperry Pi-Slave
                          pi@pi-Slave1:~ $ sudo apt update
                          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:4 http://deb.debian.org/debian bullseye InRelease
                          Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                          pi@pi-Slave1:~ $ df -h
                          Filesystem      Size  Used Avail Use% Mounted on
                          /dev/root        29G  4.0G   24G  15% /
                          devtmpfs        325M     0  325M   0% /dev
                          tmpfs           455M     0  455M   0% /dev/shm
                          tmpfs           182M  1.1M  181M   1% /run
                          tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                          /dev/mmcblk0p1  255M   31M  225M  12% /boot
                          tmpfs            91M   20K   91M   1% /run/user/1000
                          bei Rasperry pi-Test
                          pi@pi-Test:~ $ sudo apt update
                          OK:1 http://archive.raspberrypi.org/debian buster InRelease
                          OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                          Alle Pakete sind aktuell.
                          pi@pi-Test:~ $ df -h
                          Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                          /dev/root        30G    4,5G   24G   17% /
                          devtmpfs        430M       0  430M    0% /dev
                          tmpfs           462M       0  462M    0% /dev/shm
                          tmpfs           462M     12M  450M    3% /run
                          tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                          tmpfs           462M       0  462M    0% /sys/fs/cgroup
                          /dev/mmcblk0p1  253M     49M  204M   20% /boot
                          tmpfs            93M       0   93M    0% /run/user/1000
                          pi@pi-Test:~ $
                            sudo apt update
                            pi@pi-Test:~ $
                            @marcel-drzal sagte in Geöst Alexa2 Fehler nach Pi-Hole DHCP Server geändert:
                            Auf pi-Test stimmt die nodesource-Quelle nicht, wenn da als OS buster läuft. Die release names sollen übereinstimmen.
                            Und auf dem dritten System schaut es wie aus?
                              @marcel-drzal
                              sudo nano /etc/apt/sources.list
                              vom Pik-Slave
                              deb http://deb.debian.org/debian bullseye main contrib non-free
                              deb http://security.debian.org/debian-security bullseye-security main contrib non-free
                              deb http://deb.debian.org/debian bullseye-updates main contrib non-free
                              # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
                              #deb-src http://deb.debian.org/debian bullseye main contrib non-free
                              #deb-src http://security.debian.org/debian-security bullseye-security main contrib non-free
                              #deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
                              vom Pi-Test
                              deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
                              # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                              #deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
                                vom Pik-Slave
                                vom Pi-Test
                                @marcel-drzal
                                Was ist das für eine Datei?
                                ? 3 Antworten Letzte Antwort
                                  @marcel-drzal
                                    @marcel-drzal
                                    @thomas-braun Gibt es einen unterschied zwischen
                                    apt
                                    apt-get?
                                      @marcel-drzal
                                      Möglich.
                                      Und die /etc/apt/sources.list.d/nodesource.list auf pi-Test?
                                        apt
                                        apt-get?
                                        apt
                                        apt-get?
                                        Ja, gibt es. apt ist neuer und tickt etwas anders als apt-get.
                                        Das ist wiederum stabiler und für skripte besser geeignet.
                                          @marcel-drzal
                                          Möglich.
                                          Pi Test
                                          #deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main
                                          #deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster$
                                          deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye ma$
                                          deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullsey$
