  4. Skript LOWBAT
Skript LOWBAT
201 Beiträge 44 Kommentatoren 78.0k Aufrufe 14 Beobachtet
  • blauholstenB
    blauholstenB
    blauholsten
    #67
    @baluderbär:
    Servus Jungs,
    kann jemand ein passendes Widget posten, welches die Anzahl der offenen Fenster (bzw. eingeschalteten Lichter oder Servicemeldungen) anzeigt, so wie es Freddy auf der ersten Seite gezeigt hat?
    Welches Widget wurde hier genau benutzt?
    Danke im Voraus und viele Grüße
    Balu `
    kannst du z.B. ein Metro tile Dialog / Badge Number nehmen.
    Bsp.
    [{"tpl":"tplMetroTileStringDialogNumber","data":{"visibility-cond":"==","visibility-val":1,"hover":"true","transform":"true","bg_class":"bg-taupe","icon_class":"","badge_bg_class":"bg-lightPink","brand_bg_class":"bg-steel","dialog_fontSize":"20px","dialog_padding":"0px 0px 0px 0px","dialog_draggable":"true","dialog_icon_class":"","gestures-offsetX":0,"gestures-offsetY":0,"name":"CCU","dialog_oid":"","number_oid":"","icon_src":"","icon_height":"71","icon_width":"71","icon_top":"20","icon_left":"25","label":"CCU","dialog_width":"700","dialog_height":"450","class":"","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"770px","top":"20px","width":"180","height":"180","font-weight":"","z-index":"3","font-family":""},"widgetSet":"metro"}]
    Einfach den Text nehmen und bei Widget importieren eintragen. Danach noch deine Datenpunkte eintragen
    - Alarm Adapter
    • B
      B
      baluderbär
      #68
      super, vielen Dank. Genau das was ich gesucht habe.
      Gruß Balu
      ioBroker auf VM Proxmox (Intel NUC-Kit i3-7100U 2.4GHz HD620 NUC7I3BNH)
      • D
        D
        Dice19
        #69
        Moin,
        habe mir das Script geladen und in Skripte hinzugefügt.
        Welches Widget kann ich zum einbinden der Low Bat Anzeigen nehmen? Würde gern den ganzen Aktor Namen anzeigen lassen…
        • D
          D
          Dice19
          #70
          Kann ich die Anzahl der Lichter reduzieren um 1 ?
          Bei mir zählt er einen Zwischenstecker mit Messfunktion als Licht mit…
          Tobias
          • T
            T
            tempestas
            #71
            Eventuell habe ich es übersehen aber als In fo:
            Bei Homematic IP heißt der state nicht mehr "LOWBAT" sondern LOW_BAT
            müsste man also im Skript noch ein weiteres
               cacheSelectorLOW_BAT.each(function (id, i) {                         // Schleife für jedes gefundenen Element *.LOW_BAT, Homematic IP
                  var status = getState(id).val;                                  // Zustand *.LOW_BAT abfragen (jedes Element)
                  var obj    = getObject(id);
                  if (status === true) {                                          // wenn Zustand = true, dann wird die Anzahl der Geräte hochgezählt
                     textLOWBAT.push(obj.common.name);                           // Zu Array hinzufügen
            einsetzen sowie entsprechend den "on" function noch ergänzen
            Nachtrag:
            wenn ich das Skript von der HP so einsetze, ergibt sich etwas nicht logsiches im Log:
            > javascript.0 script.js.common.Batteriestatus: Anzahl Geräte: 0 # davon LOWBAT erkannt: 38
            ich glaube, im Skript muss es nicht heißen:
                  ++anzahlLOWBAT;
            sondern:
                  ++moeglicheLOWBAT;
            <size="85">ioBroker | 21 Adapter | Ubuntu Server | intel NUC | Homematic CCU2 | Hue | Osram Lightify| Sonos | 2x Instar Cam | Samsung Tab A 2016 im Holzrahmen| 3x Echo dot | 1x Echo | Neato Botvac D5</size>
            • N
              N
              noxx
              #72
              funktioniert das skript bei jedem sensor?
              ich verstehe hier nicht den Zusammenhang zwischen Lichter und Batteriestatus (LOWBAT)! :?
              ich möchte mir zb den Batteriestatus von folgenden Geräten anzueigen:
              rflink.0.channels.Cresta_4.BAT
              false
              • P
                P
                pix
                #73
                es gibt keinen Zusammenhang zwischen Lichtern und Batteriestatus. Man kan eben alle gleichnamigen Datenpunkte mit bestimmten Wert zählen. Lichter haben häufig den Datenpunkt STATE (=true wenn an) und sind zB dem Gewerk "Lichter" zugeordnet, der Batteriestatus eines Gerätes ist häufig LOWBAT. Wenn du nur BAT zählen willst, dann brauchst du das Skript nur minimal abwandeln (LOWBAT zu BAT)
                Pix
                • N
                  N
                  noxx
                  #74
                  es reicht Zeile 4 anzupassen?
                  createState('zählenLowbat.möglicheLOWBAT', 0); // wenn benötigt: Anzahl der vorhandenen LOWBAT
                  createState('zählenLowbat.anzahlLOWBAT', 0); // wenn benötigt: Anzahl der vorhandenen LOWBAT
                  createState('zählenLowbat.textLOWBAT', " "); // Anzahl LOWBAT, die an sind als Variable unter Javascript.0 anlegen
                  ! var cacheSelectorLOWBAT = $('channel[state.id=*.BAT]');
                  ! function countLowbat(obj) {
                  // Setzt die Zähler vor dem Durchlauf aller Elemente *.LOWBAT auf 0
                  var moeglicheLOWBAT = 0;
                  var anzahlLOWBAT = 0;
                  var textLOWBAT = [];
                  ! if (obj) {
                  log('Auslösender Aktor: ' + obj.id + ': ' + obj.newState.val); // Info im Log, welcher Zustand sich geändert hat
                  } else {
                  log('Ausgelöst bei Timer');
                  ! cacheSelectorLOWBAT.each(function (id, i) { // Schleife für jedes gefundenen Element *.LOWBAT
                  var status = getState(id).val; // Zustand *.LOWBAT abfragen (jedes Element)
                  log("Geräte Nr. " + i + ": " + getObject(id).common.name + ": " + status);
                  ++anzahlLOWBAT; // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
                  ! // Schleife ist durchlaufen. Im Log wird der aktuelle Status (Anzahl, davon LOWBAT zutreffend) ausgegeben
                  log("Text: " + textLOWBAT);
                  log("Anzahl Geräte: " + moeglicheLOWBAT + " # davon LOWBAT erkannt: " + anzahlLOWBAT);
                  ! // die ermittelten Werte werden als javascript.0. Variable in ioBroker gespeichert (z.B. für die Verarbeitung in VIS)
                  setState("zählenLowbat.textLOWBAT", textLOWBAT.join(',
                  ')); // Schreibt die aktuelle Namen der Geräte mit LOWBAT Meldung
                  setState("zählenLowbat.anzahlLOWBAT", textLOWBAT.length); // Schreibt die aktuelle Anzahl der Geräte im System
                  setState("zählenLowbat.möglicheLOWBAT", moeglicheLOWBAT); // Schreibt die aktuelle Anzahl der vorhandene Geräte
                  ! cacheSelectorLOWBAT.on(function(obj) { // bei Zustandänderung . LOWBAT in allen Gewerken
                  countLowbat(obj);
                  schedule("
                  /60 * * * *", function () { //oder!! soll entweder ausgelöst werden alle 10 Minuten
                  log("===>Will be triggered every 60 minutes!");
                  countLowbat();
                  • P
                    P
                    pix
                    #75
                    Yep! Sollte reichen.
                    Klappt es?
                    • N
                      N
                      noxx
                      #76
                      weiß ich noch nicht….
                      08:57:45.984	[info]	javascript.0 Start javascript script.js.common.Batteriestatus
                      08:57:45.985	[info]	javascript.0 script.js.common.Batteriestatus: registered 4 subscriptions and 1 schedule
                      09:00:01.013	[info]	javascript.0 script.js.common.Batteriestatus: ===>Will be triggered every 60 minutes!
                      09:00:01.015	[info]	javascript.0 script.js.common.Batteriestatus: Ausgelöst bei Timer
                      09:00:01.015	[info]	javascript.0 script.js.common.Batteriestatus: Geräte Nr. 0: Cresta_ 1 Low battery: false
                      09:00:01.016	[info]	javascript.0 script.js.common.Batteriestatus: Geräte Nr. 1: Cresta_ 2 Low battery: false
                      09:00:01.016	[info]	javascript.0 script.js.common.Batteriestatus: Geräte Nr. 2: Cresta_ 4 Low battery: false
                      09:00:01.016	[info]	javascript.0 script.js.common.Batteriestatus: Geräte Nr. 3: Cresta_ 5 Low battery: false
                      09:00:01.017	[info]	javascript.0 script.js.common.Batteriestatus: Text:
                      09:00:01.017	[info]	javascript.0 script.js.common.Batteriestatus: Anzahl Geräte: 0 # davon LOWBAT erkannt: 4
                      Wie binde ich denn zb eine Benachrichtigung per pushover ein, wenn eine Batterie leer ist?
                      EDIT
                      Mich verwirren die letzten beiden LOG Zeilen
                      Zeile 1 ist nach "Text:" leer
                      Zeile 2 hätte ich jetzt eher "Anzahl Geräte: 4" und "LOWBAT erkannt: 0" erwartet. Also 4 Geräte gefunden und keine Batterie leer.
                      • T
                        T
                        tempestas
                        #77
                        @noxx:
                        Zeile 2 hätte ich jetzt eher "Anzahl Geräte: 4" und "LOWBAT erkannt: 0" erwartet. Also 4 Geräte gefunden und keine Batterie leer. `
                        Hallo noxx,
                        schau mal 6 Beiträge weiter oben. Dort habe ich genau das angemerkt und korrigiert. Ist ein Dreher im Skript von der Homepage.
                        • paul53P
                          paul53P
                          #78
                          @tempestas:
                          Ist ein Dreher im Skript von der Homepage. `
                          Stimmt, war einer meiner ersten Versuche in Javascript. Hier die Korrektur:
                          ! var cacheSelectorLOWBAT = $('channel[state.id=*.LOWBAT]');
                          ! if (obj) {
                          } else {
                          ++moeglicheLOWBAT; // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
                          log("Text: " + textLOWBAT.join(', '));
                          log("Anzahl Geräte: " + moeglicheLOWBAT + " # davon LOWBAT erkannt: " + textLOWBAT.length);
                          countLowbat(obj);
                          schedule("
                          countLowbat();
                          Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
                          • S
                            S
                            starfish
                            #79
                            ist zwar trivial, aber auf Zeile 29 fehlt ein ")"
                            • paul53P
                              paul53P
                              #80
                              @starfish:
                              auf Zeile 29 fehlt ein ") `
                              Danke, ist korrigiert.
                              • kmxakK
                                kmxakK
                                kmxak
                                #81
                                bekomme teilweise paar fehler:
                                javascript.0	2017-10-07 11:00:00.731	error	at script.js.User.Homematic.Batterie_Check:24:51
                                javascript.0	2017-10-07 11:00:00.731	error	Error in callback: TypeError: Cannot read property 'common' of null
                                javascript.0	2017-10-07 11:00:00.730	warn	Object "hm-rpc.3.NEQ0000566.0.LOWBAT" does not exist
                                javascript.0	2017-10-07 11:00:00.730	warn	at script.js.User.Homematic.Batterie_Check:19:20
                                javascript.0	2017-10-07 11:00:00.729	warn	State "hm-rpc.3.NEQ0000566.0.LOWBAT" not found
                                javascript.0	2017-10-07 11:00:00.729	info	script.js.User.Homematic.Batterie_Check: Geräte Nr. 35: undefined: null
                                javascript.0	2017-10-07 11:00:00.729	warn	at script.js.User.Homematic.Batterie_Check:19:20
                                javascript.0	2017-10-07 11:00:00.729	warn	State "hm-rpc.2.OEQ0181147.0.LOWBAT" not found
                                Gruß Alex
                                • T
                                  T
                                  tempestas
                                  #82
                                  Sind das homematic Ip Geräte?
                                  Die haben als Datenpunkt Low_Bat nicht Lowbat.
                                  Steht hier imho auch schon im thread in einem meiner Postings
                                  Edit:
                                  Jup, eine Seite weiter vorne… War nicht schwer zu finden
                                  • kmxakK
                                    kmxakK
                                    kmxak
                                    #83
                                    ein fertiges Script gibt es aber noch nicht?
                                    Das sind ja nur die Warnungen
                                    Der Error kommt von dem CuxD Gerät
                                    Gruß Alex
                                    • T
                                      T
                                      tempestas
                                      #84
                                      Was steht denn in Zeile 24 bei dir im Skript.
                                      Zum Thema "ein fertiges Skript gibts nicht?":
                                      doch, hier im Thread. Für Homematic IP einfach ergänzen, wie es auf der Vorseite dargestellt ist
                                      • kmxakK
                                        kmxakK
                                        kmxak
                                        #85
                                        24 in der Mitte.
                                        ich wusste gestern nicht wo hin mit der ergänzung
                                        hier das angepasste script weiß aber nicht ob das richtig ist und das mit der on änderung weiß ich nicht wie.
                                        ! if (obj) {
                                        } else {
                                        countLowbat(obj);
                                        schedule("
                                        countLowbat();
                                        Gruß Alex
                                        • T
                                          T
                                          tempestas
                                          #86
                                          Also bei mir heißen CUXD nicht z.B. NEQ….. oder OEQ..
                                          das sollten schon "echte" HM Geräte sein imho
                                          createState('zählenLowbat.möglicheLOWBAT', 0); // wenn benötigt: Anzahl der vorhandenen Geräte
                                          ! var cacheSelectorLOWBAT = $('channel[state.id=.LOWBAT]');
                                          var cacheSelectorLOW_BAT = $('channel[state.id=
                                          .LOW_BAT]'); // für Homematic IP, dort LOWBAT in LOW_BAT umbenannt
                                          ! if (obj) {
                                          } else {
                                          ! cacheSelectorLOW_BAT.each(function (id, i) { // Schleife für jedes gefundenen Element *.LOW_BAT, Homematic IP
                                          ! cacheSelectorLOWBAT.on(function(obj) { // bei Zustandänderung *. LOWBAT in allen Gewerken
                                          countLowbat(obj);
                                          ! cacheSelectorLOW_BAT.on(function(obj) { // bei Zustandänderung *. LOW_BAT in allen Gewerken
                                          countLowbat(obj);
                                          ! schedule("0 */6 * * *", function () { //ausgelöst alle 6 Stunden
                                          countLowbat();
                                          84.3k
