  5. Daten aus URL in blocky
45 Beiträge 3 Kommentatoren 8.7k Aufrufe 1 Beobachtet
  • ingranuI ingranu
    @paul53 so ?
    @ingranu sagte: so ?
    Nein, result muss unverändert bleiben. So:
    Noch besser so:
    ingranuI 1 Antwort Letzte Antwort
      Noch besser so:
      ingranuI Offline
      ingranuI Offline
      ingranu
      @paul53 Folgende Ausgabe erhalte ich so:
      15:53:48.504	info	javascript.0 (4987) script.js.common.Mediola_states6: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
      15:53:50.003	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
      15:53:55.002	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
      15:54:00.002	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
      15:54:05.002	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
      15:54:07.465	info	javascript.0 (4987) Stop script script.js.common.Mediola_states6
      • ingranuI ingranu
        @ingranu sagte: Folgende Ausgabe erhalte ich so:
        Da hilft nur Debuggen:
          ingranuI Offline
          ingranuI Offline
          ingranu
          @paul53 said in Daten aus URL in blocky:
          Folgende Ausgabe nun:
          16:06:45.063	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'010','state':'FF:FF'}
          16:06:45.064	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'b3930080','state':'FF:FF'}
          16:06:45.063	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'ELRO','adr':'100550','state':'00:FF'}
          16:06:45.063	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'1db90080','state':'FF:FF'}
          16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'7f450080','state':'FF:FF'}
          16:06:45.064	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'2e340080','state':'06:B2'}
          16:06:45.064	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'a5430080','state':'FF:FF'}
          16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'44240080','state':'06:1E'}
          16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'FS20','adr':'1a0132','state':'FF:FF'}
          16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'25ca0080','state':'06:FF'}
          16:06:45.066	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'EVENT','adr':'01','state':'0'}
          16:06:45.066	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'60b5a280','state':'FF:FF'}
          16:06:45.066	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'518b1181','state':'06:86'}
          16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'6616a881','state':'FF:FF'}
          16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'00','state':'FF:FF'}
          16:06:45.068	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'a1234561','state':'FF:FF'}
          16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'60b5a282','state':'06:60'}
          16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'44205800','state':'FF:FF'}
          16:06:45.068	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'af760080','state':'06:1E'}
          16:06:45.068	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'13b80080','state':'FF:FF'}
          16:06:45.069	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'6616a880','state':'06:B2'}
          • ingranuI ingranu
            @ingranu sagte:
            Hinter dieser Zeile 11 müsste noch eine Ausgabe
            06:1E
            hinterher kommen und die Schleife abgebrochen werden.
            Poste bitte den erzeugten Javascript-Code in Code tags, denn im Blockly kann ich keinen Fehler erkennen.
            ingranuI 2 Antworten Letzte Antwort
              @ingranu sagte:
              06:1E
              ingranuI Offline
              ingranuI Offline
              ingranu
              @paul53 Also eine Ausgabe das es ins LOG geschrieben wird oder welche?
                @ingranu sagte:
                06:1E
                ingranuI Offline
                ingranuI Offline
                ingranu
                @ingranu sagte:
                06:1E
                  <variables>
                    <variable id="a53#cD`9m.m^/sDvE|%/">result</variable>
                    <variable id="pggQh3[cd#U:nf-=7B}2">arrayStart</variable>
                    <variable id="OsWBYNgKRnY1AT._O^]O">json</variable>
                    <variable id="T[V(!A,H,F8FBIfq_jn^">obj</variable>
                  </variables>
                  <block type="schedule" id="D]Ns;]+7ol~%34IWt{0e" x="-862" y="-1137">
                    <field name="SCHEDULE">*/5 * * * * *</field>
                    <statement name="STATEMENT">
                      <block type="request" id="%by~Y1|my.FF[3LR)p8O">
                        <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                        <field name="WITH_STATEMENT">TRUE</field>
                        <field name="LOG">log</field>
                        <value name="URL">
                          <shadow type="text" id="/uoTPJtK:4`s1yeNPV`c">
                            <field name="TEXT">http://192.168.3.97/command?XC_USER=admin&amp;XC_PASS=D000000&amp;XC_FNC=getstates</field>
                          </shadow>
                        </value>
                          <block type="debug" id="_P!k1cg`T%frNRj1/|^p">
                            <field name="Severity">debug</field>
                            <value name="TEXT">
                              <shadow type="text">
                              </shadow>
                              <block type="variables_get" id="{~hez)S@#_:Ne|E;`h]e">
                                <field name="VAR" id="a53#cD`9m.m^/sDvE|%/">result</field>
                              </block>
                            </value>
                            <next>
                              <block type="controls_if" id="Z+k7e33N~b+5?+NN/7LZ">
                                <value name="IF0">
                                  <block type="variables_get" id="#qSkV3?-?Y]8n-o}8v^=">
                                  </block>
                                </value>
                                <statement name="DO0">
                                  <block type="variables_set" id="j#0`q5Y2LNM^Z8@j;btG">
                                    <field name="VAR" id="pggQh3[cd#U:nf-=7B}2">arrayStart</field>
                                    <value name="VALUE">
                                      <block type="text_indexOf" id="fghnaP5Z,6Xp]vQ{4-mg">
                                        <field name="END">FIRST</field>
                                          <block type="variables_get" id="5lw,irPU/N4OBfLbmO;C">
                                          </block>
                                        </value>
                                        <value name="FIND">
                                          <shadow type="text" id="QWdXUZxDk+OaWER}058N">
                                            <field name="TEXT">[</field>
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                      <block type="variables_set" id="b[i]jip4Oy;w)`8#1*S[">
                                        <field name="VAR" id="OsWBYNgKRnY1AT._O^]O">json</field>
                                          <block type="text_getSubstring" id="x-8rm|IpRnTt_m)k%VX2">
                                            <mutation at1="true" at2="false"></mutation>
                                            <field name="WHERE1">FROM_START</field>
                                            <field name="WHERE2">LAST</field>
                                            <value name="STRING">
                                              <block type="variables_get" id="o~s|WPoNyhUb;Vl@|B1i">
                                              </block>
                                            </value>
                                            <value name="AT1">
                                              <block type="variables_get" id="/)d^~Jn+Y-6]7F(,,wm;">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="debug" id="S(eR(-#t91[Y)ZJ|DYs!">
                                            <value name="TEXT">
                                              <shadow type="text" id="2/2ub}SKk)9zAWV4FTvK">
                                              </shadow>
                                              <block type="variables_get" id="f4k,FmPzkG:Ql.EsZswV">
                                              </block>
                                            </value>
                                            <next>
                                              <block type="controls_forEach" id="?8QxPrns1xMcVUonzy;C">
                                                <field name="VAR" id="T[V(!A,H,F8FBIfq_jn^">obj</field>
                                                <value name="LIST">
                                                  <block type="convert_json2object" id="Nu09x`s%H3?Qr#SYjx@2">
                                                      <block type="variables_get" id="ieUi9aOpO4:+9HT^Z$9E">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <statement name="DO">
                                                  <block type="debug" id="WwKX./zJO!bQdy7Dp#RQ">
                                                    <value name="TEXT">
                                                      </shadow>
                                                      <block type="variables_get" id="f!8O3?=+]3|2t+Sd0iWS">
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="controls_if" id="Q^MF/(]`v@bN=auz8e4:">
                                                        <value name="IF0">
                                                          <block type="logic_operation" id="Ddp+,dBTw~dWG7$Wvr^o" inline="false">
                                                            <field name="OP">AND</field>
                                                            <value name="A">
                                                              <block type="get_attr" id="AB}QS3Katqvs2HzfGPA0">
        <value name="PATH">
        <shadow type="text" id="*F=*NkXztw%R)UGbTgSU">
        <field name="TEXT">type</field>
        </shadow>
        </value>
        <value name="OBJECT">
        <block type="logic_compare" id="m3U*;T=Gj7lvn?69?VlB">
        <field name="OP">EQ</field>
        <value name="A">
        <block type="variables_get" id="?nz#C/d0i`,R4#gg*/7.">
        </block>
        </value>
        <value name="B">
        <block type="text" id="Q3jHkZF?)$q#V,KAmAxj">
        <field name="TEXT">IT</field>
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <block type="get_attr" id=",6Q30We6V(OpV$J.,Z:I">
        <value name="PATH">
        <shadow type="text" id="V(^430l{^2BEGNn5lXO7">
        <field name="TEXT">adr</field>
        </shadow>
        </value>
        <block type="logic_compare" id="(MO0RnbIZ6d6WR@C_%U$">
        <value name="A">
        <block type="variables_get" id="3k`ILAOI;-[3HBa4yC~;">
        </block>
        </value>
        <value name="B">
        <block type="text" id="-dmm]cBqu[i,MU;=hS}6">
        <field name="TEXT">44240080</field>
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                          <block type="debug" id="uh@rKCjV,Ib@SX7W_3S;">
                                                            <value name="TEXT">
                                                              <shadow type="text" id="#q^Tr+m{O3]i+=3z{fY7">
        <field name="TEXT">state</field>
                                                              </shadow>
                                                              <block type="get_attr" id="-NNE,jc@4qz=!9E-4lO~">
        <value name="PATH">
        <shadow type="text" id="Nw?A#mALg$Kvu`k/2IZk">
        </shadow>
        </value>
        <block type="variables_get" id="wOPFu7erG.7NDn*en9t;">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <next>
                                                              <block type="update" id="a%[3P:karCgR(B3M$}~K">
        <field name="OID">0_userdata.0.FS20</field>
        <block type="get_attr" id="rQ$pWfT!1`AwYS_EQ`wV">
        <value name="PATH">
        <shadow type="text" id="HYsU9Dol@9GPv[CH8(*?">
        <field name="TEXT">state.state</field>
        </shadow>
        </value>
        <block type="variables_get" id="w|Ul2(,0)!,^%(}X@QCW">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="controls_flow_statements" id="y[YT8RCRfpgN.[u?V{%G">
        <field name="FLOW">BREAK</field>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </statement>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </statement>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </statement>
                  </block>
                </xml>
                • ingranuI ingranu
                  @ingranu
                  Habe jetzt den Fehler gesehen: Die Blöcke sind falsch verschachtelt. Richtig:
                  Der Vergleich außen und innen "Attribut type vom Objekt obj".
                    @ingranu
                    ingranuI Offline
                    ingranuI Offline
                    ingranu
                    @paul53 ist ja so drin. stimmt das nicht?
                    • ingranuI ingranu
                      @ingranu sagte: ist ja so drin.
                      Nein, ist so drin:
                      obj wird mit den Strings verglichen.
                        Nein, ist so drin:
                        ingranuI Offline
                        ingranuI Offline
                        ingranu
                        @paul53 okey hab geändert Ausgabe nun so:
                        BlocklyJavascriptTypeScriptRules
                        Skript läuft nicht
                        16:26:05.003	info	javascript.0 (4987) script.js.common.Mediola_states7: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
                        16:26:05.056	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'443525','state':'00:B5'}
                        16:26:05.056	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'2b063b','state':'FF:FF'}
                        16:26:05.057	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'EVENT','adr':'02','state':'1'}
                        16:26:05.057	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'8d3700','state':'FF:FF'}
                        16:26:05.057	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'aaf900','state':'FF:FF'}
                        16:26:05.058	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'20d600','state':'FF:FF'}
                        16:26:05.058	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'EVENT','adr':'03','state':'1'}
                        16:26:05.058	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'903702','state':'FF:FF'}
                        16:26:05.058	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'1c291e','state':'FF:FF'}
                        16:26:05.059	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'8d3702','state':'FF:FF'}
                        16:26:05.059	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'0b3212','state':'FF:FF'}
                        16:26:05.059	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'ffffa9','state':'FF:FF'}
                        16:26:05.059	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'015301','state':'FF:FF'}
                        16:26:05.064	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'231a42','state':'FF:FF'}
                        16:26:05.065	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'ELRO','adr':'123409','state':'FF:FF'}
                        16:26:05.065	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'ffff01','state':'FF:FF'}
                        16:26:05.066	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'aa3c0080','state':'FF:FF'}
                        16:26:05.066	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'271b20','state':'FF:FF'}
                        16:26:05.066	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'800001','state':'FF:FF'}
                        16:26:05.066	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'ELRO','adr':'000550','state':'00:21'}
                        16:26:05.067	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'518b1180','state':'06:21'}
                        16:26:05.067	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'010','state':'FF:FF'}
                        16:26:05.067	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'ELRO','adr':'100550','state':'00:FF'}
                        16:26:05.068	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'1db90080','state':'FF:FF'}
                        16:26:05.068	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'b3930080','state':'FF:FF'}
                        16:26:05.069	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'2e340080','state':'06:B5'}
                        16:26:05.069	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'a5430080','state':'FF:FF'}
                        16:26:05.069	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'7f450080','state':'FF:FF'}
                        16:26:05.070	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'44240080','state':'06:21'}
                          Nein, ist so drin:
                          ingranuI Offline
                          ingranuI Offline
                          ingranu
                          schrieb am zuletzt editiert von ingranu
                          @ingranu Es wird nun ein Wert geschrieben.
                          • ingranuI ingranu
                            Skript läuft nicht
                            @ingranu sagte: Ausgabe nun so:
                            Nach der letzten Zeile müsste noch kommen:
                            06:21
                            Der Schleifenabbruch erfolgte anscheinend (falls es nicht der letzte Eintrag im Array war).
                              06:21
                              ingranuI Offline
                              ingranuI Offline
                              ingranu
                              • ingranuI ingranu
                                @ingranu
                                Passt. Was soll mit der Variable id passieren?
                                Die Debug-Blöcke können nun deaktiviert oder gelöscht werden.
                                  @ingranu
                                  ingranuI Offline
                                  ingranuI Offline
                                  ingranu
                                  @paul53 Sorry das mit dem Block ID ist falsch habe ich raus.
                                  Aber für mein Verständnis: Das Script schreibt nun nur von meinem Gerät 44240080 ins Logfile?
                                  • ingranuI ingranu
                                    @ingranu sagte: Das Script schreibt nun nur von meinem Gerät 44240080 ins Logfile?
                                    Das Script schreibt nur von diesem Gerät in den Datenpunkt "FS20".
                                    Sollen mehrere Datenpunkte geschrieben werden, sind innerhalb der Schleife weitere Abfragen erforderlich.
                                      ingranuI Offline
                                      ingranuI Offline
                                      ingranu
                                      @paul53 In der TAT es geht :-) Vielen Dank, ohne Dich hätte ich das niemals hingekriegt !!
                                      Bewundere sowas echt das hier einem so toll geholfen wird!
                                      Danke dir für den tollen Support!
