  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 504.3k Aufrufe 82 Beobachtet
  • D dirkhe
    @nu_81 ich bräuchte noch ein bisschen mehr log von vorher, irgendwann muss der status ja auf aktiv gesetzt werden. Tip, du kannst das log als text kopieren und per </> hier einfügen.
    bitte auch nochmal die adapterversion dszu schreiben
    N Offline
    N Offline
    nu_81
    #932
    @dirkhe
    Hab den Adapter neugestartet und das Problem im Log festgehalten.
    Die Version des Adapters ist v3.4.2
    2022-10-02 00:46:33.409 - debug: mihome-vacuum.0 (15213) Receive <<< Helo <<< 21310020000000000705a24f6338c349ffffffffffffffffffffffffffffffff
    2022-10-02 00:46:43.413 - debug: mihome-vacuum.0 (15213) Receive <<< Helo <<< 21310020000000000705a24f6338c353ffffffffffffffffffffffffffffffff
    2022-10-02 00:46:44.788 - info: host.raspberrypi "system.adapter.mihome-vacuum.0" disabled
    2022-10-02 00:46:44.799 - info: host.raspberrypi stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
    2022-10-02 00:46:44.811 - info: mihome-vacuum.0 (15213) Got terminate signal TERMINATE_YOURSELF
    2022-10-02 00:46:44.813 - info: host.raspberrypi stopInstance system.adapter.mihome-vacuum.0 send kill signal
    2022-10-02 00:46:44.815 - error: mihome-vacuum.0 (15213) Socket Close
    2022-10-02 00:46:44.816 - info: mihome-vacuum.0 (15213) terminating
    2022-10-02 00:46:44.817 - debug: mihome-vacuum.0 (15213) Plugin sentry destroyed
    2022-10-02 00:46:44.817 - info: mihome-vacuum.0 (15213) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-10-02 00:46:45.488 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-10-02 00:46:48.004 - info: host.raspberrypi "system.adapter.mihome-vacuum.0" enabled
    2022-10-02 00:46:48.436 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 6937
    2022-10-02 00:46:50.324 - debug: mihome-vacuum.0 (6937) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-10-02 00:46:50.378 - debug: mihome-vacuum.0 (6937) Objects client ready ... initialize now
    2022-10-02 00:46:50.380 - debug: mihome-vacuum.0 (6937) Objects create System PubSub Client
    2022-10-02 00:46:50.381 - debug: mihome-vacuum.0 (6937) Objects create User PubSub Client
    2022-10-02 00:46:50.447 - debug: mihome-vacuum.0 (6937) Objects client initialize lua scripts
    2022-10-02 00:46:50.454 - debug: mihome-vacuum.0 (6937) Objects connected to redis: 127.0.0.1:9001
    2022-10-02 00:46:50.491 - debug: mihome-vacuum.0 (6937) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-10-02 00:46:50.515 - debug: mihome-vacuum.0 (6937) States create System PubSub Client
    2022-10-02 00:46:50.516 - debug: mihome-vacuum.0 (6937) States create User PubSub Client
    2022-10-02 00:46:50.551 - debug: mihome-vacuum.0 (6937) States connected to redis: 127.0.0.1:9000
    2022-10-02 00:46:50.710 - debug: mihome-vacuum.0 (6937) Plugin sentry Initialize Plugin (enabled=true)
    2022-10-02 00:46:51.113 - info: mihome-vacuum.0 (6937) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.20.0, js-controller: 4.0.23
    2022-10-02 00:46:51.191 - debug: mihome-vacuum.0 (6937) Create State for deviceInfo
    2022-10-02 00:46:51.192 - debug: mihome-vacuum.0 (6937) Create State for deviceInfomac
    2022-10-02 00:46:51.193 - debug: mihome-vacuum.0 (6937) Create State for deviceInfomodel
    2022-10-02 00:46:51.193 - debug: mihome-vacuum.0 (6937) Create State for deviceInfofw_ver
    2022-10-02 00:46:51.194 - debug: mihome-vacuum.0 (6937) Create State for deviceInfowifi_signal
    2022-10-02 00:46:51.195 - debug: mihome-vacuum.0 (6937) MIIO: Config: ip:192.168.2.134 token: 7870644854724e426337496a42754d47
    2022-10-02 00:46:51.201 - info: mihome-vacuum.0 (6937) IOT enabled, create state
    2022-10-02 00:46:51.206 - debug: mihome-vacuum.0 (6937) server started on 0.0.0.0:53421
    2022-10-02 00:46:51.214 - debug: mihome-vacuum.0 (6937) Receive <<< Helo <<< 21310020000000000705a24f6338c35bffffffffffffffffffffffffffffffff
    2022-10-02 00:46:51.215 - debug: mihome-vacuum.0 (6937) MAIN: Connected to device, try to get model..
    2022-10-02 00:46:51.221 - debug: mihome-vacuum.0 (6937) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5","ack":true,"ts":1664642335233,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1628340109797}
    2022-10-02 00:46:51.224 - debug: mihome-vacuum.0 (6937) Message= {"id":1,"method":"miIO.info"}
    2022-10-02 00:46:51.237 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_001856","ap":{"ssid":"FigaFigo7412","bssid":"38:10:D5:F8:28:64","rssi":-65},"netif":{"localIp":"192.168.2.134","mask":"255.255.255.0","gw":"192.168.2.1"},"model":"roborock.vacuum.s5","mac":"40:31:3C:A8:4A:D4","token":"7870644854724e426337496a42754d47","life":75542}}
    2022-10-02 00:46:51.238 - debug: mihome-vacuum.0 (6937) GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_001856","ap":{"ssid":"FigaFigo7412","bssid":"38:10:D5:F8:28:64","rssi":-65},"netif":{"localIp":"192.168.2.134","mask":"255.255.255.0","gw":"192.168.2.1"},"model":"roborock.vacuum.s5","mac":"40:31:3C:A8:4A:D4","token":"7870644854724e426337496a42754d47","life":75542}}
    2022-10-02 00:46:51.239 - debug: mihome-vacuum.0 (6937) Get Device data..0
    2022-10-02 00:46:51.239 - debug: mihome-vacuum.0 (6937) Get Device data from robot.. {"hw_ver":"Linux","fw_ver":"3.3.9_001856","ap":{"ssid":"FigaFigo7412","bssid":"38:10:D5:F8:28:64","rssi":-65},"netif":{"localIp":"192.168.2.134","mask":"255.255.255.0","gw":"192.168.2.1"},"model":"roborock.vacuum.s5","mac":"40:31:3C:A8:4A:D4","token":"7870644854724e426337496a42754d47","life":75542}
    2022-10-02 00:46:51.318 - debug: mihome-vacuum.0 (6937) DeviceModel selected to: roborock.vacuum.s5
    2022-10-02 00:46:51.320 - info: mihome-vacuum.0 (6937) select standard vacuum protocol....
    2022-10-02 00:46:51.338 - debug: mihome-vacuum.0 (6937) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2022-10-02 00:46:51.432 - debug: mihome-vacuum.0 (6937) Create State for control: {"id":"mihome-vacuum.0.control"}
    2022-10-02 00:46:51.447 - debug: mihome-vacuum.0 (6937) Create State for Queue: queue
    2022-10-02 00:46:51.448 - debug: mihome-vacuum.0 (6937) Create State for Queue: clearQueue
    2022-10-02 00:46:51.453 - info: mihome-vacuum.0 (6937) Map not selected delete states...
    2022-10-02 00:46:51.454 - debug: mihome-vacuum.0 (6937) Create State done!
    2022-10-02 00:46:51.455 - debug: mihome-vacuum.0 (6937) get params for stock Vacuum
    2022-10-02 00:46:51.456 - debug: mihome-vacuum.0 (6937) Message= {"id":2,"method":"get_status"}
    2022-10-02 00:46:51.464 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":4053,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"fan_power":60,"dnd_enabled":0}],"id":2}
    2022-10-02 00:46:51.465 - debug: mihome-vacuum.0 (6937) setGetStatus {"msg_ver":2,"msg_seq":4053,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
    2022-10-02 00:46:51.514 - warn: mihome-vacuum.0 (6937) State "mihome-vacuum.0.cleanmap.actualMap" has no existing object, this might lead to an error in future versions
    2022-10-02 00:46:51.584 - warn: mihome-vacuum.0 (6937) State "mihome-vacuum.0.cleanmap.mapStatus" has no existing object, this might lead to an error in future versions
    2022-10-02 00:46:51.592 - debug: mihome-vacuum.0 (6937) Message= {"id":3,"method":"get_map_v1"}
    2022-10-02 00:46:51.600 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":["robomap%2F117809743%2F7"],"id":3}
    2022-10-02 00:46:51.601 - debug: mihome-vacuum.0 (6937) Mappointer_updated
    2022-10-02 00:46:51.603 - debug: mihome-vacuum.0 (6937) Message= {"id":4,"method":"get_room_mapping"}
    2022-10-02 00:46:51.611 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":"unknown_method","id":4}
    2022-10-02 00:46:51.615 - debug: mihome-vacuum.0 (6937) Message= {"id":5,"method":"get_consumable"}
    2022-10-02 00:46:51.618 - debug: mihome-vacuum.0 (6937) Message= {"id":6,"method":"get_network_info"}
    2022-10-02 00:46:51.627 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[{"main_brush_work_time":163063,"side_brush_work_time":163063,"filter_work_time":34038,"sensor_dirty_time":34038}],"id":5}
    2022-10-02 00:46:51.630 - debug: mihome-vacuum.0 (6937) Message= {"id":7,"method":"get_clean_summary"}
    2022-10-02 00:46:51.633 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":"unknown_method","id":6}
    2022-10-02 00:46:51.635 - debug: mihome-vacuum.0 (6937) Message= {"id":8,"method":"get_sound_volume"}
    2022-10-02 00:46:51.644 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[3446411,45495882500,3295,[1664642862,1664642360,1664642154,1664613114,1664613111,1664472894,1664472602,1664472531,1664472412,1664472275,1664472198,1664472170,1664471353,1664471315,1664470984,1664470961,1664470888,1664461718,1664461716,1664448171]],"id":7}
    2022-10-02 00:46:51.648 - debug: mihome-vacuum.0 (6937) Message= {"id":9,"method":"get_clean_record","params":[1664642862]}
    2022-10-02 00:46:51.652 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[90],"id":8}
    2022-10-02 00:46:51.654 - debug: mihome-vacuum.0 (6937) Message= {"id":10,"method":"get_multi_maps_list"}
    2022-10-02 00:46:51.665 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664642862,1664642871,8,0,0,0]],"id":9}
    2022-10-02 00:46:51.668 - debug: mihome-vacuum.0 (6937) Message= {"id":11,"method":"get_clean_record","params":[1664642360]}
    2022-10-02 00:46:51.671 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":"unknown_method","id":10}
    2022-10-02 00:46:51.672 - debug: mihome-vacuum.0 (6937) Startup: getMultiMapsList Answer: true
    2022-10-02 00:46:51.673 - debug: mihome-vacuum.0 (6937) Startup: Delete getMultiMapsList
    2022-10-02 00:46:51.673 - debug: mihome-vacuum.0 (6937) Message= {"id":12,"method":"get_clean_summary"}
    2022-10-02 00:46:51.675 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664642360,1664642370,9,0,4,0]],"id":11}
    2022-10-02 00:46:51.677 - debug: mihome-vacuum.0 (6937) Message= {"id":13,"method":"get_clean_record","params":[1664642154]}
    2022-10-02 00:46:51.686 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[3446411,45495882500,3295,[1664642862,1664642360,1664642154,1664613114,1664613111,1664472894,1664472602,1664472531,1664472412,1664472275,1664472198,1664472170,1664471353,1664471315,1664470984,1664470961,1664470888,1664461718,1664461716,1664448171]],"id":12}
    2022-10-02 00:46:51.688 - debug: mihome-vacuum.0 (6937) Startup: setGetCleanSummary Answer: true
    2022-10-02 00:46:51.689 - debug: mihome-vacuum.0 (6937) Startup: Delete setGetCleanSummary
    2022-10-02 00:46:51.690 - debug: mihome-vacuum.0 (6937) Message= {"id":14,"method":"get_consumable"}
    2022-10-02 00:46:51.693 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664642154,1664642156,2,0,0,0]],"id":13}
    2022-10-02 00:46:51.694 - debug: mihome-vacuum.0 (6937) Message= {"id":15,"method":"get_clean_record","params":[1664613114]}
    2022-10-02 00:46:51.704 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[{"main_brush_work_time":163063,"side_brush_work_time":163063,"filter_work_time":34038,"sensor_dirty_time":34038}],"id":14}
    2022-10-02 00:46:51.706 - debug: mihome-vacuum.0 (6937) Startup: setGetConsumable Answer: true
    2022-10-02 00:46:51.707 - debug: mihome-vacuum.0 (6937) Startup: Delete setGetConsumable
    2022-10-02 00:46:51.707 - debug: mihome-vacuum.0 (6937) Message= {"id":16,"method":"get_map_v1"}
    2022-10-02 00:46:51.709 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664613114,1664616245,3131,46390000,0,1]],"id":15}
    2022-10-02 00:46:51.711 - debug: mihome-vacuum.0 (6937) Message= {"id":17,"method":"get_clean_record","params":[1664613111]}
    2022-10-02 00:46:51.713 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":["robomap%2F117809743%2F7"],"id":16}
    2022-10-02 00:46:51.714 - debug: mihome-vacuum.0 (6937) Mappointer_updated
    2022-10-02 00:46:51.715 - debug: mihome-vacuum.0 (6937) Message= {"id":18,"method":"get_carpet_mode"}
    2022-10-02 00:46:51.741 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664613111,1664613113,2,0,0,0]],"id":17}
    2022-10-02 00:46:51.742 - debug: mihome-vacuum.0 (6937) Message= {"id":19,"method":"get_clean_record","params":[1664472894]}
    2022-10-02 00:46:51.744 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[{"enable":0,"current_integral":0,"current_high":0,"current_low":0,"stall_time":10}],"id":18}
    2022-10-02 00:46:51.746 - info: mihome-vacuum.0 (6937) create state for carpet_mode
    2022-10-02 00:46:51.747 - debug: mihome-vacuum.0 (6937) Message= {"id":20,"method":"get_carpet_mode"}
    2022-10-02 00:46:51.769 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664472894,1664472904,10,0,0,1]],"id":19}
    2022-10-02 00:46:51.770 - debug: mihome-vacuum.0 (6937) Message= {"id":21,"method":"get_clean_record","params":[1664472602]}
    2022-10-02 00:46:51.772 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[{"enable":0,"current_integral":0,"current_high":0,"current_low":0,"stall_time":10}],"id":20}
    2022-10-02 00:46:51.783 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664472602,1664472881,41,122500,0,0]],"id":21}
    2022-10-02 00:46:51.785 - debug: mihome-vacuum.0 (6937) Message= {"id":22,"method":"get_clean_record","params":[1664472531]}
    2022-10-02 00:46:51.796 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664472531,1664472537,6,0,0,0]],"id":22}
    2022-10-02 00:46:51.797 - debug: mihome-vacuum.0 (6937) Message= {"id":23,"method":"get_clean_record","params":[1664472412]}
    2022-10-02 00:46:51.804 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664472412,1664472530,8,0,0,0]],"id":23}
    2022-10-02 00:46:51.805 - debug: mihome-vacuum.0 (6937) Message= {"id":24,"method":"get_clean_record","params":[1664472275]}
    2022-10-02 00:46:51.812 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664472275,1664472321,46,0,0,0]],"id":24}
    2022-10-02 00:46:51.813 - debug: mihome-vacuum.0 (6937) Message= {"id":25,"method":"get_clean_record","params":[1664472198]}
    2022-10-02 00:46:51.820 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664472198,1664472214,16,0,0,0]],"id":25}
    2022-10-02 00:46:51.821 - debug: mihome-vacuum.0 (6937) Message= {"id":26,"method":"get_clean_record","params":[1664472170]}
    2022-10-02 00:46:51.831 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664472170,1664472173,3,0,0,0]],"id":26}
    2022-10-02 00:46:51.832 - debug: mihome-vacuum.0 (6937) Message= {"id":27,"method":"get_clean_record","params":[1664471353]}
    2022-10-02 00:46:51.850 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664471353,1664472170,6,0,0,0]],"id":27}
    2022-10-02 00:46:51.852 - debug: mihome-vacuum.0 (6937) Message= {"id":28,"method":"get_clean_record","params":[1664471315]}
    2022-10-02 00:46:51.861 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664471315,1664471329,14,0,0,0]],"id":28}
    2022-10-02 00:46:51.862 - debug: mihome-vacuum.0 (6937) Message= {"id":29,"method":"get_clean_record","params":[1664470984]}
    2022-10-02 00:46:51.868 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664470984,1664471003,19,0,0,0]],"id":29}
    2022-10-02 00:46:51.869 - debug: mihome-vacuum.0 (6937) Message= {"id":30,"method":"get_clean_record","params":[1664470961]}
    2022-10-02 00:46:51.877 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664470961,1664470962,1,0,0,0]],"id":30}
    2022-10-02 00:46:51.878 - debug: mihome-vacuum.0 (6937) Message= {"id":31,"method":"get_clean_record","params":[1664470888]}
    2022-10-02 00:46:51.886 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664470888,1664470890,1,0,0,0]],"id":31}
    2022-10-02 00:46:51.887 - debug: mihome-vacuum.0 (6937) Message= {"id":32,"method":"get_clean_record","params":[1664461718]}
    2022-10-02 00:46:51.897 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664461718,1664464657,2939,46382500,0,1]],"id":32}
    2022-10-02 00:46:51.898 - debug: mihome-vacuum.0 (6937) Message= {"id":33,"method":"get_clean_record","params":[1664461716]}
    2022-10-02 00:46:51.907 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664461716,1664461717,1,0,0,0]],"id":33}
    2022-10-02 00:46:51.908 - debug: mihome-vacuum.0 (6937) Message= {"id":34,"method":"get_clean_record","params":[1664448171]}
    2022-10-02 00:46:51.914 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[[1664448171,1664448173,2,0,0,0]],"id":34}
    2022-10-02 00:46:51.915 - debug: mihome-vacuum.0 (6937) finish logs all [{"Datum":"1.10","Start":"18:47","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"1.10","Start":"18:39","Saugzeit":"0 min","Fläche":"0 m²","Error":4,"Ende":false},{"Datum":"1.10","Start":"18:35","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"1.10","Start":"10:31","Saugzeit":"52 min","Fläche":"46.39 m²","Error":0,"Ende":true},{"Datum":"1.10","Start":"10:31","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"29.9","Start":"19:34","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":true},{"Datum":"29.9","Start":"19:30","Saugzeit":"1 min","Fläche":"0.12 m²","Error":0,"Ende":false},{"Datum":"29.9","Start":"19:28","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"29.9","Start":"19:26","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"29.9","Start":"19:24","Saugzeit":"1 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"29.9","Start":"19:23","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"29.9","Start":"19:22","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"29.9","Start":"19:09","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"29.9","Start":"19:08","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"29.9","Start":"19:03","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"29.9","Start":"19:02","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"29.9","Start":"19:01","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"29.9","Start":"16:28","Saugzeit":"49 min","Fläche":"46.38 m²","Error":0,"Ende":true},{"Datum":"29.9","Start":"16:28","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"29.9","Start":"12:42","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false}]
    2022-10-02 00:46:51.923 - info: mihome-vacuum.0 (6937) settest next timer: not available
    2022-10-02 00:47:01.223 - debug: mihome-vacuum.0 (6937) Receive <<< Helo <<< 21310020000000000705a24f6338c365ffffffffffffffffffffffffffffffff
    2022-10-02 00:47:08.877 - debug: mihome-vacuum.0 (6937) command: start parent: control
    2022-10-02 00:47:08.883 - debug: mihome-vacuum.0 (6937) start Cleaning: 5 MObj: {}
    2022-10-02 00:47:08.885 - info: mihome-vacuum.0 (6937) trigger cleaning all
    2022-10-02 00:47:08.886 - debug: mihome-vacuum.0 (6937) Message= {"id":35,"method":"app_start"}
    2022-10-02 00:47:08.896 - debug: mihome-vacuum.0 (6937) We are in onMessage:{"command":"startVacuuming","message":null,"from":"system.adapter.mihome-vacuum.0","_id":43856167}
    2022-10-02 00:47:08.898 - debug: mihome-vacuum.0 (6937) Message= {"id":36,"method":"app_start"}
    2022-10-02 00:47:08.912 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":["ok"],"id":35}
    2022-10-02 00:47:08.915 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":["ok"],"id":36}
    2022-10-02 00:47:10.917 - debug: mihome-vacuum.0 (6937) ERROR at setGetStatus: TypeError: Cannot read property 'sendMessage' of undefined
    2022-10-02 00:47:11.867 - debug: mihome-vacuum.0 (6937) get params for stock Vacuum
    2022-10-02 00:47:11.868 - debug: mihome-vacuum.0 (6937) Message= {"id":37,"method":"get_status"}
    2022-10-02 00:47:12.086 - debug: mihome-vacuum.0 (6937) Receive <<< Helo <<< 21310020000000000705a24f6338c370ffffffffffffffffffffffffffffffff
    2022-10-02 00:47:12.090 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":4055,"state":5,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":1,"fan_power":60,"dnd_enabled":0}],"id":37}
    2022-10-02 00:47:12.093 - debug: mihome-vacuum.0 (6937) setGetStatus {"msg_ver":2,"msg_seq":4055,"state":5,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":1,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
    2022-10-02 00:47:12.096 - debug: mihome-vacuum.0 (6937) Message= {"id":38,"method":"get_network_info"}
    2022-10-02 00:47:12.109 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":"unknown_method","id":38}
    2022-10-02 00:47:12.111 - debug: mihome-vacuum.0 (6937) Message= {"id":39,"method":"get_sound_volume"}
    2022-10-02 00:47:12.122 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[90],"id":39}
    2022-10-02 00:47:12.124 - debug: mihome-vacuum.0 (6937) Message= {"id":40,"method":"get_map_v1"}
    2022-10-02 00:47:12.137 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":["robomap%2F117809743%2F9"],"id":40}
    2022-10-02 00:47:12.139 - debug: mihome-vacuum.0 (6937) Mappointer_updated
    2022-10-02 00:47:12.140 - debug: mihome-vacuum.0 (6937) Message= {"id":41,"method":"get_carpet_mode"}
    2022-10-02 00:47:12.154 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[{"enable":0,"current_integral":0,"current_high":0,"current_low":0,"stall_time":10}],"id":41}
    2022-10-02 00:47:12.648 - debug: mihome-vacuum.0 (6937) command: spotclean parent: control
    2022-10-02 00:47:12.649 - debug: mihome-vacuum.0 (6937) start Cleaning: 11 MObj: {}
    2022-10-02 00:47:12.649 - info: mihome-vacuum.0 (6937) should trigger cleaning spot , but is currently active(5). Add to queue
    2022-10-02 00:47:22.092 - debug: mihome-vacuum.0 (6937) Receive <<< Helo <<< 21310020000000000705a24f6338c37affffffffffffffffffffffffffffffff
    2022-10-02 00:47:30.842 - debug: mihome-vacuum.0 (6937) command: zoneClean parent: control
    2022-10-02 00:47:30.846 - debug: mihome-vacuum.0 (6937) We are in onMessage:{"command":"cleanZone","message":"[23265,26335,24965,28485,1]","from":"system.adapter.mihome-vacuum.0","_id":43856168}
    2022-10-02 00:47:30.852 - debug: mihome-vacuum.0 (6937) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2022-10-02 00:47:30.895 - debug: mihome-vacuum.0 (6937) search channels for [23265,26335,24965,28485,1] ->
    2022-10-02 00:47:30.896 - debug: mihome-vacuum.0 (6937) We are in onMessage:{"command":"cleanZone","message":"[23265,26335,24965,28485,1]","from":"system.adapter.mihome-vacuum.0","_id":43856168,"zones":["[23265,26335,24965,28485,1]"],"channels":null}
    2022-10-02 00:47:30.897 - debug: mihome-vacuum.0 (6937) start Cleaning: 17 MObj: {"command":"cleanZone","message":"[23265,26335,24965,28485,1]","from":"system.adapter.mihome-vacuum.0","_id":43856168,"zones":["[23265,26335,24965,28485,1]"],"channels":null}
    2022-10-02 00:47:30.897 - info: mihome-vacuum.0 (6937) should trigger cleaning zone [23265,26335,24965,28485,1], but is currently active(5). Add to queue
    2022-10-02 00:47:32.096 - debug: mihome-vacuum.0 (6937) Receive <<< Helo <<< 21310020000000000705a24f6338c384ffffffffffffffffffffffffffffffff
    2022-10-02 00:47:32.270 - debug: mihome-vacuum.0 (6937) get params for stock Vacuum
    2022-10-02 00:47:32.274 - debug: mihome-vacuum.0 (6937) Message= {"id":42,"method":"get_status"}
    2022-10-02 00:47:32.285 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":4065,"state":10,"battery":100,"clean_time":12,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":1,"fan_power":60,"dnd_enabled":0}],"id":42}
    2022-10-02 00:47:32.286 - debug: mihome-vacuum.0 (6937) setGetStatus {"msg_ver":2,"msg_seq":4065,"state":10,"battery":100,"clean_time":12,"clean_area":140000,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":1,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
    2022-10-02 00:47:32.287 - debug: mihome-vacuum.0 (6937) Message= {"id":43,"method":"get_network_info"}
    2022-10-02 00:47:32.293 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":"unknown_method","id":43}
    2022-10-02 00:47:32.294 - debug: mihome-vacuum.0 (6937) Message= {"id":44,"method":"get_sound_volume"}
    2022-10-02 00:47:32.301 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[90],"id":44}
    2022-10-02 00:47:32.302 - debug: mihome-vacuum.0 (6937) Message= {"id":45,"method":"get_map_v1"}
    2022-10-02 00:47:32.308 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":["robomap%2F117809743%2F15"],"id":45}
    2022-10-02 00:47:32.309 - debug: mihome-vacuum.0 (6937) Mappointer_updated
    2022-10-02 00:47:32.310 - debug: mihome-vacuum.0 (6937) Message= {"id":46,"method":"get_carpet_mode"}
    2022-10-02 00:47:32.320 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[{"enable":0,"current_integral":0,"current_high":0,"current_low":0,"stall_time":10}],"id":46}
    2022-10-02 00:47:42.186 - debug: mihome-vacuum.0 (6937) Receive <<< Helo <<< 21310020000000000705a24f6338c38effffffffffffffffffffffffffffffff
    2022-10-02 00:47:51.154 - info: fahrplan.0 (23159) Updated 2 routes, 2 enabled and 0 disabled
    2022-10-02 00:47:51.155 - info: fahrplan.0 (23159) No departure timetabled defined
    2022-10-02 00:47:52.192 - debug: mihome-vacuum.0 (6937) Receive <<< Helo <<< 21310020000000000705a24f6338c398ffffffffffffffffffffffffffffffff
    2022-10-02 00:47:52.409 - debug: mihome-vacuum.0 (6937) get params for stock Vacuum
    2022-10-02 00:47:52.410 - debug: mihome-vacuum.0 (6937) Message= {"id":47,"method":"get_status"}
    2022-10-02 00:47:52.421 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":4076,"state":10,"battery":100,"clean_time":12,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":1,"fan_power":60,"dnd_enabled":0}],"id":47}
    2022-10-02 00:47:52.422 - debug: mihome-vacuum.0 (6937) setGetStatus {"msg_ver":2,"msg_seq":4076,"state":10,"battery":100,"clean_time":12,"clean_area":140000,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":1,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
    2022-10-02 00:47:52.423 - debug: mihome-vacuum.0 (6937) Message= {"id":48,"method":"get_network_info"}
    2022-10-02 00:47:52.433 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":"unknown_method","id":48}
    2022-10-02 00:47:52.433 - debug: mihome-vacuum.0 (6937) Message= {"id":49,"method":"get_sound_volume"}
    2022-10-02 00:47:52.446 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[90],"id":49}
    2022-10-02 00:47:52.448 - debug: mihome-vacuum.0 (6937) Message= {"id":50,"method":"get_map_v1"}
    2022-10-02 00:47:52.457 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":["robomap%2F117809743%2F5"],"id":50}
    2022-10-02 00:47:52.458 - debug: mihome-vacuum.0 (6937) Mappointer_updated
    2022-10-02 00:47:52.459 - debug: mihome-vacuum.0 (6937) Message= {"id":51,"method":"get_carpet_mode"}
    2022-10-02 00:47:52.468 - debug: mihome-vacuum.0 (6937) MIIO RECIVE: {"result":[{"enable":0,"current_integral":0,"current_high":0,"current_low":0,"stall_time":10}],"id":51}
    • N nu_81
      @dirkhe
      dirkhe
      #933
      @nu_81 das scheint bei dir irgdendwie doppelt getriggert zu werden, du hast am anfang ja start gedrückt und das wurde sofort 2mal an den robbi geschickt.allerdings einmal mit fehler. Als du dann clean zone geschickt hadt, ist das verhalten ja richtig, weil er noch zugange war.
      Ich habe gerade mal geschaut, ich glaube, ich habe da mal was am 1.mai gefixt. Installiere mal die aktuelle version 3.6
      • MichaelFM MichaelF
        ich hab ein Roborock s7 der Adapter funktioniert bis auf die Karte.
        Diese wird einmal aktualisiert und dann hängt sich der ganze Adapter auf, Speicherkarte des Pi´s läuft voll.
        Nach meiner Recherche geht wohl nur ein 64 bit System, ist das so ? oder habe ich noch irgendwas irgendwo falsch gemacht ???
        Mooo
        #934
        @michaelf said in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
        Selber Roborock, selbes Problem.
        Nach dem zweiten mal voll laufen habe ich alles gesichert, formatiert und 64bit aufgesetzt.
        Jetzt funktioniert die Karte wie sie soll.
        Gruss
        MichaelFM 1 Antwort Letzte Antwort
        • M Mooo
          Gruss
          MichaelFM Offline
          MichaelFM Offline
          MichaelF
          #935
          @mooo
          ist das wirklich die einzige Lösung was machen die anderen Adapter laufen die ohne Probleme auch mit dem 64 bit System ?
            @mooo
            #936
            @michaelf sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
            Die Adapter laufen in nodeJS als Laufzeitumgebung. Und da gibt es natürlich auch eine 64bit-Version.
            echad@chet:/opt/iobroker $ apt policy nodejs
            nodejs:
              Installed: 18.9.1-deb-1nodesource1
              Candidate: 18.9.1-deb-1nodesource1
              Version table:
             *** 18.9.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              nodejs:
                Version table:
              MichaelFM Offline
              MichaelFM Offline
              MichaelF
              #937
              Wäre es möglich mit einem 2 pi 4 4gb ram ein multihost System aufzusetzen wo das 64bit System drauf läuft ?
              Ich hätte noch ein pi übrig und wenn er den jetzigen auch noch entlastet wäre es ja auf kein Fall schlechter.
              Grüsse
                Grüsse
                #938
                @michaelf
                Möglich ist alles.
                • bahnuhrB bahnuhr
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #939
                  @bahnuhr verschoben
                  Mit besten Grüßen
                  Andy
                  • Damrak2022D Damrak2022
                    @bahnuhr verschoben
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    #940
                    @damrak2022 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                    @bahnuhr verschoben
                    Danke.
                    • MeistertrM Meistertr
                      Aktuelle Test Version 3.1.6
                      Veröffentlichungsdatum 18.4.2021
                      Github Link https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum
                      Lange hats gedauert aber langsam komm ich zum Ende (wobei das dann wahrscheinlich der Anfang ist :) ).
                      Was hat sich geändert? Alles und nix kann kann man sagen.
                      Der Adapter wurde komplett neu aufgesetzt und dem Aktuellen stand angepasst.
                      vorher:
                      • Nachrichten an den Roboter wurden willkürlich geschickt und gehofft das eine Antwort kommt.
                      • Die Erkennung des Roboters (Modell und Marke und Firmware) wurden durch Ankommende Nachrichten oder das Ausbleiben erkannt
                      • comact mode nicht möglich da zig Timeouts liefen
                      • Keine neuen/anderen Sauger integrierbar da alles in einer Datei lag
                      jetzt:
                      • beim start wird zwingend das Modell ermittelt wonach dann die richtige Datei für den jeweiligen Sauger geladen wird
                      • danach werden Strukturiert die Sonderfunktionen ermittelt und freigegeben
                      • Nachrichten werden nicht mehr willkürlich gesendet sonders strukturiert und jede Nachricht bekommt eine Antwort
                      • comact mode möglich da alle timer zentral gelagert sind
                      ich habe mich bemüht die Objekte zum Vorgänger gleich zu lassen. also Optisch ist nicht viel neu aber wie gesagt unterm Kleid alles was man im debug log sehen sollte.
                      ich habe noch nicht viele Sauger in der Datenbank also kann es zu warn log einträgen kommen, dann bitte modell und bezeichnung posten dann nehm ich sie mit rein.
                      Bitte alles Testen da ich viel ohne Testen umgeschrieben habe (bei über 2000 Zeilen) konnte ich nicht alles direkt testen.
                      Stand Aktuell:
                      Jetzt sollte alles gehen was bei der 2er auch geht. und mehr
                      Was sollte gehen:
                      • alles wie beim alten außer die map (folgt in kürze)
                      • viomi Modelle die sonst über meinen Fork liefen sind nun mit drin
                      • support für den S7 (letztes update hat die History kaputt gemacht)
                      • Map wir unterstützt
                      Fixes:
                      • Map bei zwei Saugern funtionieren
                      • Map wird zuverlässig(er) geladen
                      • 3.0.2 Manueller Map Reload Button funktionert
                      • 3.0.4/ 3.0.7 Timer geht wieder
                      • 3.0.5 Disable map_slot warning, add start button, fix error while sending messages without selected device, fix water_box value
                      • 3.0.6 fix queue States, fix cleaning Buttons.
                      • 3.0.8 fix map for Valetudo
                      • 3.1.0 aktuelle Goto und Zones werden gespeichert
                      • 3.1.1 fix queue
                      • 3.1.3 Map bugfix, add Multimap Support
                      • 3.1.3 fix missing Wifi Signal
                      • 3.1.4 Fix Connrection after reboot/ now wifi
                        3.1.6:
                      • fixed Disk I/O
                      • added get States when map is changed
                      • minimize Messages
                      • changed logentrys from warn to debug
                      • added Donate button
                      folgt in Kürze:
                      - Koordinaten von goto und Zonen werden angezeigt (in den jeweiligen states)
                      • dreame support über miot
                      • compactmode
                        - map
                      • map für history
                      • material tabel
                      • led Status S7
                      • neues Logo
                      • Doku aufbereiten
                      Installieren bitte über https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum (einfach von git)
                      Bitte Vorher den alten Adapter vollständig löschen.
                      Dies ist die Alpha also BITTE nur installieren wenn ihr wisst was ihr macht und einen qualifizierten Bugreport liefern könnt
                      Bitte in dieses Thema NUR Fehler oder Requests die den Adapter betreffen. KEINE Installationsfehler oder sonstige Fragen. macht dafür bitte wenn die Suche nichts ergeben hat ein neues Thema auf damit es hier nicht so überläuft wie in den alten Threads..
                      gelberlemmyG Offline
                      gelberlemmy
                      schrieb am zuletzt editiert von gelberlemmy
                      #941
                      @meistertr ich habe jetzt mein System geupdatet. Zum anderen das Node.js 16.18.0
                      Nun habe ich ein Problem mal wieder mit Canvas. Folgende Fehlermeldung bekomme ich ständig
                      mihome-vacuum.0
                      2022-10-28 18:32:47.610	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
                      wenn ich dann in die Console npm list canvas eingebe, bekomme ich folgende Meldung mit unterschiedlichen Versionen
                      pi@IOBroker-Proxmox:/opt/iobroker$ npm ls canvas
                      iobroker.inst@3.0.0 /opt/iobroker
                      +-- iobroker.energiefluss@1.3.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#410151c990ec5f34351dbe28f14355cbc956be2d)
                      | `-- canvas@2.10.1
                      +-- iobroker.iot@1.12.2
                      | +-- canvas@2.10.1
                      | `-- jsdom@20.0.1
                      |   `-- canvas@2.9.3 deduped
                      `-- iobroker.mihome-vacuum@3.6.0
                        `-- canvas@2.9.3
                      Was könnte ich da machen ? Ich habe da auch schon versucht dies manuell zu installieren via npm
                      Gruß André
                      • TimoGoerlichT Offline
                        TimoGoerlich
                        schrieb am zuletzt editiert von TimoGoerlich
                        #942
                        erst einmal danke für den tollen Adapter.
                        Besteht die Möglichkeit über den Adapter die Zykluszahl einer Zimmerreinigung, die man in der App auswählen kann (1x, 2x, 3x), zu steuern? Mir ist bewusst, dass ich einen Raum auch einfach per Skript 2 oder 3 mal reinigen kann. der Vorteil beim Zyklusreinigen ist aber, dass der Roboter den 2. bzw. 3. Zyklus in einer anderen Richtung fährt.
                        • TimoGoerlichT TimoGoerlich
                          dirkhe
                          #943
                          @timogoerlich das geht über zonen, da kann man die Anzahl angeben- Das kannst du entweder über script machen oder du legst dir mit den koordnaten einen manuellen Raum an, den kannst du dann immer wieder starten
                          • stony2kS Offline
                            stony2kS Offline
                            stony2k
                            #944
                            @Meistertr Ist zufällig auch eine Integration vom aktuellen Dreame L10s Ultra geplant?
                            • stony2kS stony2k
                              bob der 1.
                              #945
                              @stony2k sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                              Schau mal hier rein....da steht zu Dreame ein paar Zeilen
                              https://forum.iobroker.net/topic/59480/test-für-mihome-vacuum/53?_=1667542533242
                              stony2kS 1 Antwort Letzte Antwort
                              • B bob der 1.
                                stony2kS Offline
                                stony2kS Offline
                                stony2k
                                #946
                                @bob-der-1 Vielen Dank. Verstehe, es werden Programmierer gesucht (laut dem 1. Post). Leider habe ich zwar das Gerät, aber 0 Ahnung von der Architektur, als auch nur die Spur einer Idee wie ich hier ansatzweise helfen könnte. In dem von die verlinkten Beitrag auf Seite 3 konnte ich nichts finden, du beziehst dich also wahrscheinlich auf den Thread im Allgemeinen, richtig?
                                • stony2kS stony2k
                                  bob der 1.
                                  #947
                                  @stony2k
                                  Joop,Dreameentwickler fehlen leider
                                    vorher:
                                    jetzt:
                                    Stand Aktuell:
                                    Was sollte gehen:
                                    Fixes:
                                    • 3.1.1 fix queue
                                      3.1.6:
                                    • fixed Disk I/O
                                    • minimize Messages
                                    folgt in Kürze:
                                    • compactmode
                                      - map
                                    • map für history
                                    • material tabel
                                    • led Status S7
                                    • neues Logo
                                    • Doku aufbereiten
                                    gelberlemmy
                                    #948
                                    @meistertr guten Morgen,
                                    ich bekomme seit dem letzten Update öfter einmal ein paar Fehlermeldungen und kann diese nicht wirklich zuordnen:
                                    mihome-vacuum.0
                                    2022-11-06 08:11:40.994	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: �������$T��*�g oK=<3�[#ň�e_Lan","ip":"192.168.171.83","mac":"b0:4a:39:2c:f0:44","bssid":"3c:37:12:db:23:00","rssi":0},"exe_time":51}
                                    mihome-vacuum.0
                                    2022-11-06 08:11:40.992	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: �������$T��*�g oK=<3�[#ň�e_Lan","ip":"192.168.171.83","mac":"b0:4a:39:2c:f0:44","bssid":"3c:37:12:db:23:00","rssi":0},"exe_time":51}
                                    mihome-vacuum.0
                                    2022-11-06 08:01:09.393	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                    mihome-vacuum.0
                                    2022-11-06 08:01:09.391	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                    mihome-vacuum.0
                                    2022-11-06 07:58:03.430	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: :#��֝`>��O�!I�A5v�,��<�@�����5Q�ب��$�wm�m�݌�$u����"��/XG��G���Ee�}�Oji}�2(Ⱥ�hǫ}��Y�,�7�#�� G�0","rssi":0},"exe_time":52}
                                    mihome-vacuum.0
                                    2022-11-06 07:58:03.429	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: :#��֝`>��O�!I�A5v�,��<�@�����5Q�ب��$�wm�m�݌�$u����"��/XG��G���Ee�}�Oji}�2(Ⱥ�hǫ}��Y�,�7�#�� G�0","rssi":0},"exe_time":52}
                                    mihome-vacuum.0
                                    2022-11-06 07:58:03.427	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: :#��֝`>��O�!I�A5v�,��<�@�����5Q�ب��$�wm�m�݌�$u����"��/XG��G���Ee�}�Oji}�2(Ⱥ�hǫ}��Y�,�7�#�� G�0","rssi":0},"exe_time":52}
                                    mihome-vacuum.0
                                    2022-11-06 07:28:03.014	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: H�H8��P/���Z� �1�z���0s�D���=>��|�J3>�T��Ǿ���e�"%[��MJc":"b0:4a:39:2c:f0:44","bssid":"3c:37:12:db:23:00","rssi":0},"exe_time":51}
                                    mihome-vacuum.0
                                    2022-11-06 07:28:03.013	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: H�H8��P/���Z� �1�z���0s�D���=>��|�J3>�T��Ǿ���e�"%[��MJc":"b0:4a:39:2c:f0:44","bssid":"3c:37:12:db:23:00","rssi":0},"exe_time":51}
                                    mihome-vacuum.0
                                    2022-11-06 07:26:57.276	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    2022-11-06 07:20:28.483	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: {"id":1015,"result":[{"msg_ver":2,"msg_seq":5640,"state":8,"battery":100,"clean_time":3020,"clean_area":27145000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_typ�%LNyj3�lۗ@m| W(K�u�1�ƀ*X�H��{��o5^q �մC��j� e�U}��y�P�SYɚ��y�U06�yht���D^ʃ�N=J�Em����+&KF���save_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    2022-11-06 07:20:28.482	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: {"id":1015,"result":[{"msg_ver":2,"msg_seq":5640,"state":8,"battery":100,"clean_time":3020,"clean_area":27145000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_typ�%LNyj3�lۗ@m| W(K�u�1�ƀ*X�H��{��o5^q �մC��j� e�U}��y�P�SYɚ��y�U06�yht���D^ʃ�N=J�Em����+&KF���save_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                    mihome-vacuum.0
                                    2022-11-06 07:18:25.336	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: W+���SI�n8�6��d�,􄤾\�{�6me":52}
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    2022-11-06 06:38:13.940	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                    mihome-vacuum.0
                                    2022-11-06 06:38:13.939	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                    • DiginixD Offline
                                      DiginixD Offline
                                      Diginix
                                      #949
                                      @Meistertr bzw @dirkhe Woher kommen eigentlich die anderen Map Farben bei v3.8.x verglichen mit v3.6?
                                      Bin aufgrund div. Probleme wieder auf 3.6 und finde die Farben dort viel angenehmer und vom Kontrast in meiner VIS besser. Bei der 3.8er Map war alles dunkler.
                                      ..:: So long! Tom ::..
                                      • DiginixD Diginix
                                        #950
                                        @diginix die Farben kommen daher, da @Meistertr in die Version 3.7 ein Update der Map eingebaut hat, wird wohl auch Teppich erkannt .. konnte leider nicht lange testen, da ich auch auf die 3.6. zurueck bin, da die 3.8.3 zuviele Warnings raus wirft und mir mein Log und Platte voll machte.. ( Bei 4 Saugern echt heftig.. :-)
                                        • D3ltoroxpD Offline
                                          D3ltoroxpD Offline
                                          D3ltoroxp
                                          #951
                                          Wie kann ich denn auf eine ältere Version zurückspringen ?
                                          da_WoodyD W 2 Antworten Letzte Antwort
