  4. JavaScript
  5. [Vorlage] Flexibles Timerskript + Vis
javascripttemplate
500 Beiträge 40 Kommentatoren 165.5k Aufrufe 63 Beobachtet
    @diamand2k22
    Mit dem Adapter ist alles i.O.:
    echad@chet:~ $ iobroker add icons-mfd-svg --debug
    NPM version: 8.18.0
    Installing iobroker.icons-mfd-svg@1.1.0... (System call)
    added 1 package in 9s
    86 packages are looking for funding
      run `npm fund` for details
    host.chet install adapter icons-mfd-svg
    upload [1] icons-mfd-svg.admin /opt/iobroker/node_modules/iobroker.icons-mfd-svg/admin/icons-mfd-svg.png icons-mfd-svg.png image/png
    upload [0] icons-mfd-svg.admin /opt/iobroker/node_modules/iobroker.icons-mfd-svg/admin/index.html index.html text/html
    upload [931] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/audio_audio.svg audio_audio.svg image/svg+xml
    upload [900] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/control_3.svg control_3.svg image/svg+xml
    upload [850] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/control_building_flat_s.svg control_building_flat_s.svg image/svg+xml
    upload [800] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/control_building_modern_s_okg_int_dg.svg control_building_modern_s_okg_int_dg.svg image/svg+xml
    upload [750] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/control_return.svg control_return.svg image/svg+xml
    upload [700] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/fts_blade_arc_80.svg fts_blade_arc_80.svg image/svg+xml
    upload [650] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/fts_entrance_boom_open.svg fts_entrance_boom_open.svg image/svg+xml
    upload [600] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/fts_shutter_vert_blade_100.svg fts_shutter_vert_blade_100.svg image/svg+xml
    upload [550] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/fts_window_roof_shutter_50.svg fts_window_roof_shutter_50.svg image/svg+xml
    upload [500] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/light_ceiling_infrared.svg light_ceiling_infrared.svg image/svg+xml
    upload [450] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/light_plant.svg light_plant.svg image/svg+xml
    upload [400] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/measure_pond_30.svg measure_pond_30.svg image/svg+xml
    upload [350] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/message_socket_ch.svg message_socket_ch.svg image/svg+xml
    upload [300] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/sani_pool_filter_pump.svg sani_pool_filter_pump.svg image/svg+xml
    upload [250] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/scene_dressing_room.svg scene_dressing_room.svg image/svg+xml
    upload [200] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/scene_robo_lawnmower_active.svg scene_robo_lawnmower_active.svg image/svg+xml
    upload [150] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/secur_open.svg secur_open.svg image/svg+xml
    upload [100] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/time_eco_mode.svg time_eco_mode.svg image/svg+xml
    upload [90] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/user_ext_away.svg user_ext_away.svg image/svg+xml
    upload [80] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/vent_low_pressure_protection_unit.svg vent_low_pressure_protection_unit.svg image/svg+xml
    upload [70] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/vent_ventilation_level_3.svg vent_ventilation_level_3.svg image/svg+xml
    upload [60] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_directions_nw.svg weather_directions_nw.svg image/svg+xml
    upload [50] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_humidity_abs.svg weather_humidity_abs.svg image/svg+xml
    upload [40] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_moon_phases_7_half.svg weather_moon_phases_7_half.svg image/svg+xml
    upload [30] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_rain_heavy.svg weather_rain_heavy.svg image/svg+xml
    upload [20] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_station_quadra.svg weather_station_quadra.svg image/svg+xml
    upload [19] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_storm.svg weather_storm.svg image/svg+xml
    upload [18] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_summer.svg weather_summer.svg image/svg+xml
    upload [17] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_sun.svg weather_sun.svg image/svg+xml
    upload [16] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_sunrise.svg weather_sunrise.svg image/svg+xml
    upload [15] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_sunset.svg weather_sunset.svg image/svg+xml
    upload [14] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_thunderstorm.svg weather_thunderstorm.svg image/svg+xml
    upload [13] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind.svg weather_wind.svg image/svg+xml
    upload [12] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_e.svg weather_wind_directions_e.svg image/svg+xml
    upload [11] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_n.svg weather_wind_directions_n.svg image/svg+xml
    upload [10] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_ne.svg weather_wind_directions_ne.svg image/svg+xml
    upload [9] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_nw.svg weather_wind_directions_nw.svg image/svg+xml
    upload [8] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_s.svg weather_wind_directions_s.svg image/svg+xml
    upload [7] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_se.svg weather_wind_directions_se.svg image/svg+xml
    upload [6] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_sw.svg weather_wind_directions_sw.svg image/svg+xml
    upload [5] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_w.svg weather_wind_directions_w.svg image/svg+xml
    upload [4] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_no_wind.svg weather_wind_no_wind.svg image/svg+xml
    upload [3] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_speed.svg weather_wind_speed.svg image/svg+xml
    upload [2] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_speed_bft.svg weather_wind_speed_bft.svg image/svg+xml
    upload [1] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_speed_ms.svg weather_wind_speed_ms.svg image/svg+xml
    upload [0] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_winter.svg weather_winter.svg image/svg+xml
    host.chet object system.adapter.icons-mfd-svg created/updated
    host.chet create instance icons-mfd-svg
    host.chet object system.adapter.icons-mfd-svg.upload created
    host.chet object system.adapter.icons-mfd-svg.0 created
    echad@chet:~ $ ls -lA /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/
    total 9848
    -rw-rw-r--+ 1 iobroker iobroker   1088 Sep 10 23:34 audio_audio.svg
    -rw-rw-r--+ 1 iobroker iobroker   6227 Sep 10 23:34 audio_desync.svg
    -rw-rw-r--+ 1 iobroker iobroker   1340 Sep 10 23:34 audio_eject.svg
    -rw-rw-r--+ 1 iobroker iobroker   2005 Sep 10 23:34 audio_eq.svg
    -rw-rw-r--+ 1 iobroker iobroker   8912 Sep 10 23:34 audio_fade.svg
    -rw-rw-r--+ 1 iobroker iobroker   1592 Sep 10 23:34 audio_ff.svg
    -rw-rw-r--+ 1 iobroker iobroker   2446 Sep 10 23:34 audio_headphone.svg
    -rw-rw-r--+ 1 iobroker iobroker   9042 Sep 10 23:34 audio_loudness.svg
    -rw-rw-r--+ 1 iobroker iobroker  14201 Sep 10 23:34 audio_ls_51_center.svg
    -rw-rw-r--+ 1 iobroker iobroker  14726 Sep 10 23:34 audio_ls_51_front.svg
    -rw-rw-r--+ 1 iobroker iobroker  14742 Sep 10 23:34 audio_ls_51_rear.svg
    -rw-rw-r--+ 1 iobroker iobroker  14471 Sep 10 23:34 audio_ls_51_sub.svg
    -rw-rw-r--+ 1 iobroker iobroker  13662 Sep 10 23:34 audio_ls_51.svg
    Usw, usw
    Diamand2k22
    #439
    Hallo Thomas,
    über Konsole hat es nun funktioniert.
    danke dir!
    pi4b@pi4b:~ $ iobroker add icons-mfd-svg --debug
    NPM version: 8.15.0
    added 1 package in 7s
    61 packages are looking for funding
    host.pi4b install adapter icons-mfd-svg
    host.pi4b object system.adapter.icons-mfd-svg created/updated
    host.pi4b create instance icons-mfd-svg
    host.pi4b object system.adapter.icons-mfd-svg.upload created
    host.pi4b object system.adapter.icons-mfd-svg.0 created
      mpl1338
      #440
      ich bekomme bei jedem schaltvorgang einen fehler
      javascript.0
      2022-10-08 09:00:00.015	error	at processTimers (node:internal/timers:502:7)
      javascript.0
      2022-10-08 09:00:00.015	error	at listOnTimeout (node:internal/timers:559:17)
      javascript.0
      2022-10-08 09:00:00.015	error	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
      javascript.0
      2022-10-08 09:00:00.015	error	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
      javascript.0
      2022-10-08 09:00:00.015	error	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
      javascript.0
      2022-10-08 09:00:00.015	error	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1565:34)
      javascript.0
      2022-10-08 09:00:00.015	error	at Object.<anonymous> (script.js.jarvis.TimerScript:621:13)
      javascript.0
      2022-10-08 09:00:00.015	error	at DoAction (script.js.jarvis.TimerScript:771:60)
      javascript.0
      2022-10-08 09:00:00.015	error	at GetDeviceName (script.js.jarvis.TimerScript:500:41)
      javascript.0
      2022-10-08 09:00:00.015	error	Error in callback: TypeError: Cannot read properties of null (reading 'common')
      javascript.0
      2022-10-08 06:02:00.005	error	at processTimers (node:internal/timers:502:7)
      javascript.0
      2022-10-08 06:02:00.005	error	at listOnTimeout (node:internal/timers:559:17)
      javascript.0
      2022-10-08 06:02:00.005	error	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
      javascript.0
      2022-10-08 06:02:00.005	error	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
      javascript.0
      2022-10-08 06:02:00.004	error	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
      javascript.0
      2022-10-08 06:02:00.004	error	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1565:34)
      javascript.0
      2022-10-08 06:02:00.004	error	at Object.<anonymous> (script.js.jarvis.TimerScript:621:13)
      javascript.0
      2022-10-08 06:02:00.004	error	at DoAction (script.js.jarvis.TimerScript:781:60)
      javascript.0
      2022-10-08 06:02:00.004	error	at GetDeviceName (script.js.jarvis.TimerScript:500:41)
      javascript.0
      2022-10-08 06:02:00.004	error	Error in callback: TypeError: Cannot read properties of null (reading 'common')
      P 1 Antwort Letzte Antwort
      • M mpl1338
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        Pittini
        #441
        @mpl1338 sagte in [Vorlage] Flexibles Timerskript + Vis:
        2022-10-08 09:00:00.015 error at GetDeviceName (script.js.jarvis.TimerScript:500:41) javascript.0
        Naja, steht ja fast im Klartext da was das Problem ist, Irgendein Devicename hat nen Null Wert. Mehr kann ich auch nicht sagen bei so wenig Infos.
        • P Pittini
          mpl1338
          #442
          @pittini
          das sind die verwendeten objekte. Über IOB und Visu funktioniert es.
          • M mpl1338
            @pittini
            Pittini
            #443
            @mpl1338 Ich brauch den ganzen Zweig vom Objektbaum, nicht nur den letzten channel. Denk da gibts ne ungewöhliche Struktur evtl, kann ich bei dem Ausschnitt aber nicht feststellen
            • U Offline
              U Offline
              UncleB
              #444
              Super Script @Pittini
              Hat auf Anhieb geklappt, bei mir steht im Zielname der Ordner in dem der DP liegt,
              Übersichtlicher wärs für mich wenn hier wirklich der Name des DPs stehen würde.
              Hast ne Idee was ich falsch gemacht habe?
              • U UncleB
                Dominik F.D Offline
                Dominik F.D Offline
                Dominik F.
                #445
                @uncleb
                Benenne dir das doch einfach um wie du es haben möchtest. Das Timerscript bietet dafür in der Vis die Möglichkeit.
                U 1 Antwort Letzte Antwort
                • Dominik F.D Dominik F.
                  @uncleb
                  U Offline
                  U Offline
                  UncleB
                  #446
                  @dominik-f Ahhh das habv ich überlesen in der Doku, klappt danke
                  • P Pittini
                    mpl1338
                    #447
                    @pittini said in [Vorlage] Flexibles Timerskript + Vis:
                    • M mpl1338
                      Pittini
                      #448
                      @mpl1338 Ja, seh schon das Problem, liegt aber nicht direkt am Skript, sondern an Deiner unüblichen Struktur. Das Skript erwartet übergeordnet nen channel. Du hast aber keinen (was an sich nicht korrekt ist) und das löst den Fehler bzgl. dem null Wert aus. Lösen kannst das Problem auf 2 Arten. Du kannst aus dem "nichts" nen channel machen, oder Du legst Dir für den Datenpunkt nen Alias an und verweist darauf.
                      • P Pittini
                        mpl1338
                        #449
                        @pittini die Struktur kommt durch die ETS bzw durch den KNX Adapter und spiegelt die KNX ETS Struktur wieder. Wenn ich das was an der Struktur ändere bekomme ich mit dem KNX Adapter wahrscheinlich Problem. Aber dieses Problem muss eigentlich jeder haben, der mit dem KNX Adapter arbeitet
                        • M mpl1338
                          Pittini
                          #450
                          Glaub ich nicht mal, Du änderst ja nicht die Struktur an sich, sondern wandelst mur ein "nichts" in ein Objekt (was wiederum dann nen Namen hat, welchen das Skript abrufen möchte) um. Aber ich hab Dir ja auch nen Alternativvorschlag oben schon gemacht - Alias.
                            diwoma
                            #451
                            ich eine vielleicht unnötige Frage und es wird vielleicht nicht gehen, aber trotzdem:
                            Zur Zeit steure ich Zeitpläne mit Adapter Time-Switch zur vollsten Zufriedenheit mit der Funktion an sich.
                            Mich stört eigentlich nur das große Layout in der Vis.
                            Die Ausgaben in Tabellenform sind mir für die Übersicht eigentlich lieber.
                            Aber hier habe ich einen für mich eigentlich sehr wichtigen Vorteil:
                            1. Alle Zeiten sind zu einem Datenpunkt zugeordnet sichtbar, also zusammenhängend
                            2. Ich kann den Zustand des Datenpunktes in dieser Kachel einfach ändern und damit den Timer "übersteuern"
                            Diese Möglichkeiten sind in diesem Skript aber anscheinend nicht gegeben, oder?
                            -- diwoma
                            ioBroker in LX-Container in Proxmox
                            Zigbee-Coordinator: CC2652P2-TCP FW: 20230507
                            F 1 Antwort Letzte Antwort
                            • D diwoma
                              FuXXz2
                              #452
                              @diwoma Vor allem sind die Zeilen nicht sortierbar. Nach spätestens 20 Timern drehste durch :)
                              Übersichtlich ist diese Tabelle also gar nicht.
                              • F FuXXz2
                                Dominik F.D Offline
                                Dominik F.D Offline
                                Dominik F.
                                #453
                                @Pittini
                                Ich habe heute folgende Fehlermeldung bekommen:
                                javascript.0
                                2022-11-23 16:29:34.016	warn	at processTimers (node:internal/timers:502:7)
                                javascript.0
                                2022-11-23 16:29:34.016	warn	at listOnTimeout (node:internal/timers:559:17)
                                javascript.0
                                2022-11-23 16:29:34.016	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
                                javascript.0
                                2022-11-23 16:29:34.016	warn	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
                                javascript.0
                                2022-11-23 16:29:34.015	warn	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
                                javascript.0
                                2022-11-23 16:29:34.015	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1595:34)
                                javascript.0
                                2022-11-23 16:29:34.015	warn	at Object.<anonymous> (script.js.common.Timer:621:13)
                                javascript.0
                                2022-11-23 16:29:34.015	warn	at DoAction (script.js.common.Timer:776:25)
                                javascript.0
                                2022-11-23 16:29:34.015	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
                                javascript.0
                                2022-11-23 16:29:34.009	warn	You are assigning a string to the state "scene.0.Beleuchtung.Weihnachtsbeleuchtung_Innen" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                                Ich verstehe hierbei nicht, warum ein String gesendet wurde. In Vis habe ich Einschalten angegeben und dann sollte doch True übergeben werden oder?
                                P L 2 Antworten Letzte Antwort
                                  @Pittini
                                  javascript.0
                                  javascript.0
                                  javascript.0
                                  javascript.0
                                  javascript.0
                                  javascript.0
                                  javascript.0
                                  javascript.0
                                  javascript.0
                                  javascript.0
                                  Pittini
                                  schrieb am zuletzt editiert von Pittini
                                  #454
                                  @dominik-f Sehr seltsam. Ja, bei Einschalten wird true gesendet, das kannste auch sehen wenns nicht ausgeblendet wär (Spalte "sende" in meinem pic). Hab grad keine Idee zu dem Prob, musst mal beobachten. Kannst auch versuchen statt "EInschalten" das "Wert senden" zu nehmen und dort true einzutragen.
                                  • P Pittini
                                    Dominik F.D Offline
                                    Dominik F.D Offline
                                    Dominik F.
                                    #455
                                    @pittini
                                    Habs mal eingeblendet und dort steht auch das true gesendet wird. Ich werde es mal beobachten. Es war auch das erste Mal, dass dieser Fehler aufgetaucht ist. Vielleicht war es einfach ein Zusammenspiel unglücklicher Umstände^^
                                    • P Pittini
                                      @fuxxz2 sagte in [Vorlage] Flexibles Timerskript + Vis:
                                      ich habe nun so viele Timer, dass die neuen nicht mehr angezeigt werden. Bei mir kann ich die Tabelle nicht scrollen :(
                                      Ist da was bei mir falsch oder ist das normal? Wie kann ich die Timer nun zu Gesicht bekommen?
                                      Ja, da is bei Dir was komisch, die Vorlage ist so angelegt dass Scrollen geht, sobald ein Überlauf da ist (auto). Kannst ja mal kontrollieren, bzw. permanent anmachen:
                                      Btw. Eine alphabetische Sortierung ist nicht möglich oder?
                                      Nein, ist nicht drin oder geplant.
                                      diwoma
                                      #456
                                      Hi pittini,
                                      arbeitest Du noch aktiv am Script?
                                      Die Sortierung scheint doch gefragt zu sein.
                                      Und es betrifft eigentlich nur die Liste, die ja als HTML-Table codiert aufgebaut wird.
                                      Die Nummer des Timers ist für die Anzeige eigentlich nicht relevant, ausser das er unique ist und den Index darstellt und damit den DP definiert, der editiert wird.
                                      Ich denke an ein Stringfeld, in das man irgendwelche Werte schreibt (z.b. 01.01.02, Pool-01, usw), den Wert zusätzlich als Datenpunkt (z.b. "Sort") des Timers schreibt und vor der Erstellung der VIS-Tabelle das Array danach sortiert. Eventuell die Timer-Nummer noch als zusätzlichen Vergleich in die Sortierung einbinden, bei leeren oder gleichen Stringwerten.
                                      Damit wäre der indexer "x", zwar nicht mehr die Timernummer, aber den könnte man aus den Datenpunkt ja extrahieren.
                                      Siehst Du darin unüberwindliche oder auch nur große Probleme?
                                      Ansonsten würde ich es mit meinen bescheidenen Fähigkeiten in JS mal versuchen.
                                      -- diwoma
                                      • D diwoma
                                        Hi pittini,
                                        Pittini
                                        #457
                                        @diwoma sagte in [Vorlage] Flexibles Timerskript + Vis:
                                        Hi pittini,
                                        Nicht wirklich. Es tut was ich brauch.
                                        Machbar ist (fast) alles.
                                        Ja klar, hau rein.
                                        D 3 Antworten Letzte Antwort
                                        • F Offline
                                          FuXXz2
                                          #458
                                          Hi zusammen,
                                          kann mir jemand Helfen, folgende Meldungen zu behandeln? :)
                                          In der Aufzählung für den Timer sind Aliase und wenn diese geschaltet werden, gibt es nen Eintrag ins Log.
                                          Er fängt an mit alias.0.Licht.Ankleide existiert nicht, das stimmt auch, denn es heißt alias.0.Licht.Ankleide.Fenster, so wie es im Datenpunkt unter dem
                                          entsprechenden Timer auch zu sehen ist.
                                          Trotzdem macht er aber folgende Fehler.
                                          javascript.0
                                          	2022-11-28 15:29:00.031	error	at processTimers (node:internal/timers:502:7)
                                          javascript.0
                                          	2022-11-28 15:29:00.031	error	at listOnTimeout (node:internal/timers:559:17)
                                          javascript.0
                                          	2022-11-28 15:29:00.031	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
                                          javascript.0
                                          	2022-11-28 15:29:00.031	error	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
                                          javascript.0
                                          	2022-11-28 15:29:00.030	error	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
                                          javascript.0
                                          	2022-11-28 15:29:00.030	error	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1595:34)
                                          javascript.0
                                          	2022-11-28 15:29:00.030	error	at Object.<anonymous> (script.js.Aktiv.automatik.PittiniTimer_2_2_0:621:13)
                                          javascript.0
                                          	2022-11-28 15:29:00.030	error	at DoAction (script.js.Aktiv.automatik.PittiniTimer_2_2_0:810:64)
                                          javascript.0
                                          	2022-11-28 15:29:00.030	error	at GetDeviceName (script.js.Aktiv.automatik.PittiniTimer_2_2_0:500:41)
                                          javascript.0
                                          	2022-11-28 15:29:00.029	error	Error in callback: TypeError: Cannot read properties of null (reading 'common')
                                          javascript.0
                                          	2022-11-28 15:29:00.027	warn	script.js.Aktiv.automatik.PittiniTimer_2_2_0: Object "alias.0.Licht.Ankleide" does not exist
                                          Dominik F.D P 2 Antworten Letzte Antwort
