  4. Modbus Verbindungsfehler
39 Beiträge 4 Kommentatoren 4.2k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    @ducis sagte in Modbus Verbindungsfehler:
    Beim Ping findet der RPi gar nichts.
    Nicht mal die Fritzbox
    oder ... mal ein Neustart durchführen
    sudo reboot
    ducis
    Neustart habe ich schon gemacht.
    • D ducis
      GlasfaserG Offline
      GlasfaserG Offline
      @ducis
      kann man nicht lesen ... bitte die Ausgabe in Code-Tags </> einfügen .
      was sagt noch
      ip a
      D 2 Antworten Letzte Antwort
        @ducis
        was sagt noch
        ip a
        ducis
        pi@raspberrypi3:~ $ sudo cat /etc/network/interfaces
        # interfaces(5) file used by ifup(8) and ifdown(8)
        # Include files from /etc/network/interfaces.d:
        source /etc/network/interfaces.d/*
        pi@raspberrypi3:~ $ sudo cat /etc/dhcpcd.conf
        # A sample configuration for dhcpcd.
        # See dhcpcd.conf(5) for details.
        # Allow users of this group to interact with dhcpcd via the control socket.
        #controlgroup wheel
        # Inform the DHCP server of our hostname for DDNS.
        hostname
        # Use the hardware address of the interface for the Client ID.
        clientid
        # or
        # Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
        # Some non-RFC compliant DHCP servers do not reply with this set.
        # In this case, comment out duid and enable clientid above.
        #duid
        # Persist interface configuration when dhcpcd exits.
        persistent
        # Rapid commit support.
        # Safe to enable by default because it requires the equivalent option set
        # on the server to actually work.
        option rapid_commit
        # A list of options to request from the DHCP server.
        option domain_name_servers, domain_name, domain_search, host_name
        option classless_static_routes
        # Respect the network MTU. This is applied to DHCP routes.
        option interface_mtu
        # Most distributions have NTP support.
        #option ntp_servers
        # A ServerID is required by RFC2131.
        require dhcp_server_identifier
        # Generate SLAAC address using the Hardware Address of the interface
        #slaac hwaddr
        # OR generate Stable Private IPv6 Addresses based from the DUID
        slaac private
        # Example static IP configuration:
        #interface eth0
        #static ip_address=192.168.0.10/24
        #static ip6_address=fd51:42f8:caae:d92e::ff/64
        #static routers=192.168.0.1
        #static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
        # It is possible to fall back to a static IP if DHCP fails:
        # define static profile
        #profile static_eth0
        #static ip_address=192.168.1.23/24
        #static routers=192.168.1.1
        #static domain_name_servers=192.168.1.1
        # fallback to static profile on eth0
        #interface eth0
        #fallback static_eth0
        pi@raspberrypi3:~ $ ip a
        1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
            link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
            inet 127.0.0.1/8 scope host lo
               valid_lft forever preferred_lft forever
            inet6 ::1/128 scope host
        2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
            link/ether b8:27:eb:73:50:f1 brd ff:ff:ff:ff:ff:ff
            inet 192.168.2.43/24 brd 192.168.2.255 scope global dynamic noprefixroute eth0
               valid_lft 862524sec preferred_lft 754524sec
            inet6 2003:cf:7f17:7300:d004:f30:ccf8:38ae/64 scope global dynamic mngtmpaddr noprefixroute
               valid_lft 6958sec preferred_lft 1026sec
            inet6 fe80::9d79:21a8:d93e:8d0e/64 scope link
        pi@raspberrypi3:~ $
          @ducis
          was sagt noch
          ip a
          ducis
          @glasfaser Danke für deine Mühen. Ich mach jetzt erstmal Ende.
          • D ducis
            ducis
            Also ich habe mich jetzt nochmal drangemacht.
            Über die Konsole und Putty kann ich meine Geräte per Ping erreichen.
            Dann habe ich den Adapter Ping in ioBroker installiert. Wenn ich mir dann die ObjektIDs ansehe, habe ich unter indicator reachable nur false zu stehen.aaa7.JPG
            Also irgendwie funktioniert das von IOBroker aus nicht.
            • D ducis
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              Meine ping Objekte sehen ganz anders aus:
              Ist das auch wirklich der ping Adapter.
              Danke.
              • bahnuhrB bahnuhr
                GlasfaserG Offline
                GlasfaserG Offline
                @bahnuhr sagte in Modbus Verbindungsfehler:
                Meine sehen genauso aus wie deine ....... ;)
                er hat zusätzlich in der Instanz , "Erweitere Information" dazu angewählt
                  ducis
                  Jap. Trotzdem kann ich die Geräte über die Konsole anpingen nur in ioBroker nicht....
                  D GlasfaserG 2 Antworten Letzte Antwort
                  • D ducis
                    ducis
                    Das kann nur irgendeine Kleinigkeit sein. Ich bekomme ja eine Verbindung nur antworten die Slaves mit einem Fehler...und dann disconnect
                    • D ducis
                      GlasfaserG Offline
                      GlasfaserG Offline
                      ist dein ioBroker in einem Docker !?
                        ducis
                        @glasfaser Nein. Einen Docker habe ich noch nie benutzt
                        • D ducis
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @ducis
                          Zeige nochmal die Einstellungen ...
                          bei Aliases hast du den Haken rausgenommen
                          Prüfe mit dem Register :
                          19025 oder 19027
                            @ducis
                            19025 oder 19027
                            ducis
                            der kommt gar nicht zu Abfragen des Registers.
                            • D ducis
                              ducis
                              schrieb am zuletzt editiert von ducis
                              4f056515-1d33-428d-8a78-add4be7b5a14-image.png @ducis
                              nicht wundern. ich habe auf 192.168.2.223 und 224 einen Modbusslave drauf
                              • GlasfaserG Offline
                                GlasfaserG Offline
                                @ducis
                                ich sehe kein Screenshot zum Holding Register.
                                Eventuell ist es auch wie oben erwähnt nicht über TCP sondern über "RTU over TCP"
                                  @ducis
                                  ducis
                                  ich habe ne Menge einfach ausprobiert. Mit "RTU over TCP" ist der gleiche Fehler
                                    GlasfaserG Offline
                                    @ducis
                                    Nur mal so ... das war auch schonmal ... das durch das Rumtesten alles ducheinader war in der Instanz 0.
                                    Installiere eine zusätzliche Instanz.1 und teste mit der !?
                                      @ducis
                                      ducis
                                      @glasfaser mannnnnnnn. :-))) das wars. Hab die Instanz gelöscht und neu angelegt. Jetzt gehts.
                                      Mega Dank.
                                      Muss jetzt zu meiner Frau. Beste Grüße👍 😊
