  4. Modbus Verbindungsfehler
39 Beiträge 4 Kommentatoren 4.2k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    @ducis
    kann man nicht lesen ... bitte die Ausgabe in Code-Tags </> einfügen .
    was sagt noch
    ip a
    ducis
    pi@raspberrypi3:~ $ sudo cat /etc/network/interfaces
    # interfaces(5) file used by ifup(8) and ifdown(8)
    # Include files from /etc/network/interfaces.d:
    source /etc/network/interfaces.d/*
    pi@raspberrypi3:~ $ sudo cat /etc/dhcpcd.conf
    # A sample configuration for dhcpcd.
    # See dhcpcd.conf(5) for details.
    # Allow users of this group to interact with dhcpcd via the control socket.
    #controlgroup wheel
    # Inform the DHCP server of our hostname for DDNS.
    hostname
    # Use the hardware address of the interface for the Client ID.
    clientid
    # or
    # Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
    # Some non-RFC compliant DHCP servers do not reply with this set.
    # In this case, comment out duid and enable clientid above.
    #duid
    # Persist interface configuration when dhcpcd exits.
    persistent
    # Rapid commit support.
    # Safe to enable by default because it requires the equivalent option set
    # on the server to actually work.
    option rapid_commit
    # A list of options to request from the DHCP server.
    option domain_name_servers, domain_name, domain_search, host_name
    option classless_static_routes
    # Respect the network MTU. This is applied to DHCP routes.
    option interface_mtu
    # Most distributions have NTP support.
    #option ntp_servers
    # A ServerID is required by RFC2131.
    require dhcp_server_identifier
    # Generate SLAAC address using the Hardware Address of the interface
    #slaac hwaddr
    # OR generate Stable Private IPv6 Addresses based from the DUID
    slaac private
    # Example static IP configuration:
    #interface eth0
    #static ip_address=192.168.0.10/24
    #static ip6_address=fd51:42f8:caae:d92e::ff/64
    #static routers=192.168.0.1
    #static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
    # It is possible to fall back to a static IP if DHCP fails:
    # define static profile
    #profile static_eth0
    #static ip_address=192.168.1.23/24
    #static routers=192.168.1.1
    #static domain_name_servers=192.168.1.1
    # fallback to static profile on eth0
    #interface eth0
    #fallback static_eth0
    pi@raspberrypi3:~ $ ip a
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
        inet 127.0.0.1/8 scope host lo
           valid_lft forever preferred_lft forever
        inet6 ::1/128 scope host
    2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
        link/ether b8:27:eb:73:50:f1 brd ff:ff:ff:ff:ff:ff
        inet 192.168.2.43/24 brd 192.168.2.255 scope global dynamic noprefixroute eth0
           valid_lft 862524sec preferred_lft 754524sec
        inet6 2003:cf:7f17:7300:d004:f30:ccf8:38ae/64 scope global dynamic mngtmpaddr noprefixroute
           valid_lft 6958sec preferred_lft 1026sec
        inet6 fe80::9d79:21a8:d93e:8d0e/64 scope link
    pi@raspberrypi3:~ $
      @ducis
      was sagt noch
      ip a
      ducis
      @glasfaser Danke für deine Mühen. Ich mach jetzt erstmal Ende.
      • D ducis
        ducis
        Also ich habe mich jetzt nochmal drangemacht.
        Über die Konsole und Putty kann ich meine Geräte per Ping erreichen.
        Dann habe ich den Adapter Ping in ioBroker installiert. Wenn ich mir dann die ObjektIDs ansehe, habe ich unter indicator reachable nur false zu stehen.aaa7.JPG
        Also irgendwie funktioniert das von IOBroker aus nicht.
        • D ducis
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          @ducis sagte in Modbus Verbindungsfehler:
          Meine ping Objekte sehen ganz anders aus:
          Ist das auch wirklich der ping Adapter.
          Danke.
          • bahnuhrB bahnuhr
            GlasfaserG Offline
            GlasfaserG Offline
            @bahnuhr sagte in Modbus Verbindungsfehler:
            Meine sehen genauso aus wie deine ....... ;)
            er hat zusätzlich in der Instanz , "Erweitere Information" dazu angewählt
              ducis
              Jap. Trotzdem kann ich die Geräte über die Konsole anpingen nur in ioBroker nicht....
              D GlasfaserG 2 Antworten Letzte Antwort
              • D ducis
                ducis
                Das kann nur irgendeine Kleinigkeit sein. Ich bekomme ja eine Verbindung nur antworten die Slaves mit einem Fehler...und dann disconnect
                • D ducis
                  GlasfaserG Offline
                  GlasfaserG Offline
                  ist dein ioBroker in einem Docker !?
                    ducis
                    @glasfaser Nein. Einen Docker habe ich noch nie benutzt
                    • D ducis
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @ducis
                      Zeige nochmal die Einstellungen ...
                      bei Aliases hast du den Haken rausgenommen
                      Prüfe mit dem Register :
                      19025 oder 19027
                        @ducis
                        19025 oder 19027
                        ducis
                        der kommt gar nicht zu Abfragen des Registers.
                        • D ducis
                          ducis
                          schrieb am zuletzt editiert von ducis
                          4f056515-1d33-428d-8a78-add4be7b5a14-image.png @ducis
                          nicht wundern. ich habe auf 192.168.2.223 und 224 einen Modbusslave drauf
                          • GlasfaserG Offline
                            GlasfaserG Offline
                            @ducis
                            ich sehe kein Screenshot zum Holding Register.
                            Eventuell ist es auch wie oben erwähnt nicht über TCP sondern über "RTU over TCP"
                              @ducis
                              ducis
                              ich habe ne Menge einfach ausprobiert. Mit "RTU over TCP" ist der gleiche Fehler
                                GlasfaserG Offline
                                @ducis
                                Nur mal so ... das war auch schonmal ... das durch das Rumtesten alles ducheinader war in der Instanz 0.
                                Installiere eine zusätzliche Instanz.1 und teste mit der !?
                                  @ducis
                                  ducis
                                  @glasfaser mannnnnnnn. :-))) das wars. Hab die Instanz gelöscht und neu angelegt. Jetzt gehts.
                                  Mega Dank.
                                  Muss jetzt zu meiner Frau. Beste Grüße👍 😊
