Fehler mit hm.rpc
Nun alles neu aufgesetzt, und die Fehler sind nachwievor da, der HM-rega.0 Adapter ist grün:
hm-rpc.1 2022-10-15 14:30:21.770 error Init not possible, going to stop: Unknown XML-RPC tag 'TITLE' hm-rpc.1 2022-10-15 14:30:21.735 info xmlrpc client is trying to connect to 192.168.178.25:2010/ with ["http://192.168.178.62:2010","iobroker:hm-rpcxxxx"] hm-rpc.1 2022-10-15 14:30:21.734 info xmlrpc server is trying to listen on 192.168.178.62:2010 hm-rpc.1 2022-10-15 14:30:21.640 info starting. Version 1.15.12 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.17.1, js-controller: 4.0.23 host.iobroker 2022-10-15 14:30:20.086 info instance system.adapter.hm-rpc.1 started with pid 10909 hm-rpc.0 2022-10-15 14:30:20.021 error Init not possible, going to stop: Unknown XML-RPC tag 'TITLE' hm-rpc.0 2022-10-15 14:30:19.987 info xmlrpc client is trying to connect to 192.168.178.25:2001/ with ["http://192.168.178.62:2001","iobroker:hm-rpcxxx"] hm-rpc.0 2022-10-15 14:30:19.985 info xmlrpc server is trying to listen on 192.168.178.62:2001 hm-rpc.0 2022-10-15 14:30:19.888 info starting. Version 1.15.12 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.17.1, js-controller: 4.0.23 host.iobroker 2022-10-15 14:30:18.318 info instance system.adapter.hm-rpc.0 started with pid 10894 host.iobroker 2022-10-15 14:30:02.248 info instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) daswetter.0 2022-10-15 14:30:02.236 info cleaned everything up... daswetter.0 2022-10-15 14:30:01.716 info Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment daswetter.0 2022-10-15 14:30:01.679 info starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.17.1, js-controller: 4.0.23 host.iobroker 2022-10-15 14:30:00.042 info instance system.adapter.daswetter.0 started with pid 10879 host.iobroker 2022-10-15 14:29:50.063 info Restart adapter system.adapter.hm-rpc.1 because enabled host.iobroker 2022-10-15 14:29:50.062 info instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR) hm-rpc.1 2022-10-15 14:29:49.523 info Terminated (NO_ERROR): Without reason hm-rpc.1 2022-10-15 14:29:49.521 info terminating hm-rpc.1 2022-10-15 14:29:49.472 error Cannot call init: [http://192.168.178.62:2010, ""] Unknown XML-RPC tag 'TITLE' hm-rpc.1 2022-10-15 14:29:49.462 info xmlrpc -> 192.168.178.25:2010/ init ["http://192.168.178.62:2010",""] hm-rpc.1 2022-10-15 14:29:49.447 error Init not possible, going to stop: Unknown XML-RPC tag 'TITLE' host.iobroker 2022-10-15 14:29:48.288 info Restart adapter system.adapter.hm-rpc.0 because enabled host.iobroker 2022-10-15 14:29:48.287 info instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR) hm-rpc.0 2022-10-15 14:29:47.736 info Terminated (NO_ERROR): Without reason hm-rpc.0 2022-10-15 14:29:47.734 info terminating hm-rpc.0 2022-10-15 14:29:47.688 error Cannot call init: [http://192.168.178.62:2001, ""] Unknown XML-RPC tag 'TITLE' hm-rpc.0 2022-10-15 14:29:47.680 info xmlrpc -> 192.168.178.25:2001/ init ["http://192.168.178.62:2001",""] -
@glasfaser said in Fehler mit hm.rpc:
@jan201 sagte in Fehler mit hm.rpc:
Welches ist denn die Callback Adresse?
Di von deinem Iobroker
so oder welche adresse?
so
im Prinzip ja, kenne mich aber mit Containern nicht aus. Da könnte es möglicherweise die IP vom Host sein
@homoran sagte in Fehler mit hm.rpc:
@jan201 sagte in Fehler mit hm.rpc:Nun alles neu aufgesetzt,
wieder als Container in Proxmox?
Ist das jetzt ein Container !???
nein als VM ,so wie in der anleitung gegeben.
Ok .. sonst würden die Ports fehler in den Container Einstellungen .
Und was ist jetzt !?
Leider funktioniert es nicht.
Firewall:
Homematic XML-RPC API: Vollzugriff
Remote Homematic-Script API: Vollzugriffbitte immer zeigen! keine Nacherzählung
und das zeigen
So der Adapter ist nun grün nachdem ich unter "Zusätlichen Einstellungen" HTTPS benutzen angeklickt habe und meinen Benutzernamen und Passwort eingetragen habe.
Ist das denn richtig das da nur diese paar Werte zum vorschein kommen?
das können wir dir nicht sagen, da du uns noch nicht die Konfiguration von hm-rpc.1 gezeigt hast
@homoran said in Fehler mit hm.rpc:
das wären dann diese
hier nimmst du https!
istcdas in der ccu auch konfiguriert? -
istcdas in der ccu auch konfiguriert?@homoran
Ich glaube um hier vernünftig helfen zu können braucht man mal eine Komplett Übersicht.also Screenshot:
- firewall Regel der ccu
- Einstellungen ccu bzgl. http oder https
- config von hm-rega
- config von hm-rpc
So ist es nur ein ständiges Nachfrage, wo immer neue Sachverhalte auftauchen.
- config von hm-rpc
