  4. Fehler mit hm.rpc
Fehler mit hm.rpc
57 Beiträge 7 Kommentatoren 6.9k Aufrufe 4 Beobachtet
  • J Jan201
    Nun alles neu aufgesetzt, und die Fehler sind nachwievor da, der HM-rega.0 Adapter ist grün:
    hm-rpc.1
    	2022-10-15 14:30:21.770	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    hm-rpc.1
    	2022-10-15 14:30:21.735	info	xmlrpc client is trying to connect to 192.168.178.25:2010/ with ["http://192.168.178.62:2010","iobroker:hm-rpcxxxx"]
    hm-rpc.1
    	2022-10-15 14:30:21.734	info	xmlrpc server is trying to listen on 192.168.178.62:2010
    hm-rpc.1
    	2022-10-15 14:30:21.640	info	starting. Version 1.15.12 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.17.1, js-controller: 4.0.23
    host.iobroker
    	2022-10-15 14:30:20.086	info	instance system.adapter.hm-rpc.1 started with pid 10909
    hm-rpc.0
    	2022-10-15 14:30:20.021	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    hm-rpc.0
    	2022-10-15 14:30:19.987	info	xmlrpc client is trying to connect to 192.168.178.25:2001/ with ["http://192.168.178.62:2001","iobroker:hm-rpcxxx"]
    hm-rpc.0
    	2022-10-15 14:30:19.985	info	xmlrpc server is trying to listen on 192.168.178.62:2001
    hm-rpc.0
    	2022-10-15 14:30:19.888	info	starting. Version 1.15.12 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.17.1, js-controller: 4.0.23
    host.iobroker
    	2022-10-15 14:30:18.318	info	instance system.adapter.hm-rpc.0 started with pid 10894
    host.iobroker
    	2022-10-15 14:30:02.248	info	instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    daswetter.0
    	2022-10-15 14:30:02.236	info	cleaned everything up...
    daswetter.0
    	2022-10-15 14:30:01.716	info	Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    daswetter.0
    	2022-10-15 14:30:01.679	info	starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.17.1, js-controller: 4.0.23
    host.iobroker
    	2022-10-15 14:30:00.042	info	instance system.adapter.daswetter.0 started with pid 10879
    host.iobroker
    	2022-10-15 14:29:50.063	info	Restart adapter system.adapter.hm-rpc.1 because enabled
    host.iobroker
    	2022-10-15 14:29:50.062	info	instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
    hm-rpc.1
    	2022-10-15 14:29:49.523	info	Terminated (NO_ERROR): Without reason
    hm-rpc.1
    	2022-10-15 14:29:49.521	info	terminating
    hm-rpc.1
    	2022-10-15 14:29:49.472	error	Cannot call init: [http://192.168.178.62:2010, ""] Unknown XML-RPC tag 'TITLE'
    hm-rpc.1
    	2022-10-15 14:29:49.462	info	xmlrpc -> 192.168.178.25:2010/ init ["http://192.168.178.62:2010",""]
    hm-rpc.1
    	2022-10-15 14:29:49.447	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    host.iobroker
    	2022-10-15 14:29:48.288	info	Restart adapter system.adapter.hm-rpc.0 because enabled
    host.iobroker
    	2022-10-15 14:29:48.287	info	instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
    hm-rpc.0
    	2022-10-15 14:29:47.736	info	Terminated (NO_ERROR): Without reason
    hm-rpc.0
    	2022-10-15 14:29:47.734	info	terminating
    hm-rpc.0
    	2022-10-15 14:29:47.688	error	Cannot call init: [http://192.168.178.62:2001, ""] Unknown XML-RPC tag 'TITLE'
    hm-rpc.0
    	2022-10-15 14:29:47.680	info	xmlrpc -> 192.168.178.25:2001/ init ["http://192.168.178.62:2001",""]
    GlasfaserG Offline
    GlasfaserG Offline
    @jan201 sagte in Fehler mit hm.rpc:
    Nun alles neu aufgesetzt, und die Fehler sind nachwievor da:
    Ja ... habe ich schon oben geschrieben :
    @glasfaser sagte in Fehler mit hm.rpc:
    der Fehler im Log hat nichts mit NodeJS zu tun.
    So nochmal :
    War der Fehler schon vorher
    oder
    hast du den Adapter erst installiert
    HomoranH J 2 Antworten Letzte Antwort
    • GlasfaserG Glasfaser
      So nochmal :
      oder
      So nochmal :
      oder
      und...
      @Jan201 hast du ein update an der ccu gemacht?
        So nochmal :
        oder
        Jan201
        @glasfaser said in Fehler mit hm.rpc:
        So nochmal :
        oder
        Das ist alles quasi frisch. Habe erst vor kurzem die CCU3 bekommen und wollte diese nun in iobroker integrieren. HomeMatic Firmware ist 3.65.11.
        Firewall:
        Homematic XML-RPC API: Vollzugriff
        Remote Homematic-Script API: Vollzugriff
        |Hardwaresystem:| NUC|
        |Arbeitsspeicher:| 8GB |
        |Festplattenart:| 250gb SSD |
        |Betriebssystem:| Proxmox , Ubuntu 21.10 |
        |Node-Version:| vv20.15.1 |
        |Nodejs-Version:| vv20.15.1 |
        |NPM-Version:| 10.7.0 |
        GlasfaserG HomoranH 2 Antworten Letzte Antwort
        • J Jan201
          So nochmal :
          oder
          Firewall:
          GlasfaserG Offline
          GlasfaserG Offline
          Du gibst an ... was wir viel weiter unten erfahren haben Docker .
          Hast du unter zusätzliche Einstellungen die Adapter Callback Adresse eingetragen
          • J Jan201
            So nochmal :
            oder
            Firewall:
            Firewall:
            bitte immer zeigen! keine Nacherzählung
              Jan201
              Nee da fehlt etwas. Welches ist denn die Callback Adresse?
              • J Jan201
                GlasfaserG Offline
                GlasfaserG Offline
                Di von deinem Iobroker
                • J Jan201
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  host.iobroker
                  hm-rpc.0
                  hm-rpc.0
                  hm-rpc.0
                  hm-rpc.0
                  host.iobroker
                  host.iobroker
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  host.iobroker
                  host.iobroker
                  hm-rpc.0
                  hm-rpc.0
                  hm-rpc.0
                  hm-rpc.0
                  wieder als Container in Proxmox?
                    Jan201
                    so oder welche adresse?
                    • J Jan201
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Ja , so
                      • J Jan201
                        so
                        im Prinzip ja, kenne mich aber mit Containern nicht aus. Da könnte es möglicherweise die IP vom Host sein
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @Jan201
                          @homoran sagte in Fehler mit hm.rpc:
                          Ist das jetzt ein Container !???
                            @Jan201
                            Jan201
                            @Jan201
                            nein als VM ,so wie in der anleitung gegeben.
                            • J Jan201
                              @Jan201
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Ok .. sonst würden die Ports fehler in den Container Einstellungen .
                              Und was ist jetzt !?
                              • J Jan201
                                @Jan201
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @jan201
                                EDIT :
                                  Jan201
                                  Leider funktioniert es nicht.
                                  • J Jan201
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @jan201
                                    Zeige doch mal die aktuellen Fehler Logs dazu und deine Einstellungen zu den Adaptern.
                                      Firewall:
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @Jan201
                                      und das zeigen
                                        @Jan201
                                        und das zeigen
                                        Jan201
                                        So der Adapter ist nun grün nachdem ich unter "Zusätlichen Einstellungen" HTTPS benutzen angeklickt habe und meinen Benutzernamen und Passwort eingetragen habe.
                                        Ist das denn richtig das da nur diese paar Werte zum vorschein kommen? 04.jpg
                                        • J Jan201
                                          das können wir dir nicht sagen, da du uns noch nicht die Konfiguration von hm-rpc.1 gezeigt hast
