  4. Innogy Adapter im lokalen Netzt bleibt Gelb
    5.7k
118 Beiträge 5 Kommentatoren 16.7k Aufrufe 4 Beobachtet
    @scout1978 sagte in Innogy Adapter im lokalen Netzt bleibt Gelb:
    Möchtest Du das Ergebnis aus der Konsole? Was sind CodeTags?
    Ja. CodeTags:
    Text zwischen die Steuerzeichen kopieren.
    scout1978
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v                                       && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update &&                                       apt policy nodejs
    aarch64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.17.0
    v16.17.0
    8.15.0
    4.0.23
    pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp                                      io i2c spi iobroker
    /home/pi
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 https://phoscon.de/apt/deconz bullseye InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://repos.influxdata.com/debian bullseye InRelease
    Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:7 https://packages.grafana.com/oss/deb stable InRelease
    Reading package lists... Done
    13 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: Target Packages (main/binary-arm64/Packages) is configured multiple times in                                       /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:                                      2
    W: Target Packages (main/binary-armhf/Packages) is configured multiple times in                                       /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:                                      2
    W: Target Packages (main/binary-all/Packages) is configured multiple times in /e                                      tc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target Translations (main/i18n/Translation-en_GB) is configured multiple time                                      s in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.                                      list:2
    W: Target Translations (main/i18n/Translation-en) is configured multiple times i                                      n /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.lis                                      t:2
    W: Target Packages (main/binary-arm64/Packages) is configured multiple times in                                       /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:                                      3
    W: Target Packages (main/binary-armhf/Packages) is configured multiple times in                                       /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:                                      3
    W: Target Packages (main/binary-all/Packages) is configured multiple times in /e                                      tc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
    W: Target Translations (main/i18n/Translation-en_GB) is configured multiple time                                      s in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.                                      list:3
    W: Target Translations (main/i18n/Translation-en) is configured multiple times i                                      n /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.lis                                      t:3
    nodejs:
     Installed: 16.17.0-deb-1nodesource1
     Candidate: 16.17.1-deb-1nodesource1
     Version table:
        16.17.1-deb-1nodesource1 500
           500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
    *** 16.17.0-deb-1nodesource1 100
        12.22.12~dfsg-1~deb11u1 500
           500 http://security.debian.org/debian-security bullseye-security/main ar                                      m64 Packages
    pi@raspberrypi-Iobroker:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v                                       && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update &&                                       apt policy nodejs
    aarch64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.17.0
    v16.17.0
    8.15.0
    4.0.23
    pi
    /home/pi
    W: Target Packages (main/binary-armhf/Packages) is configured multiple times in                                       /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:                                      ^C@raspberrypi-Iobroker:~ $.debian.org/debian-security bullseye-security/main ar
    • S scout1978
      aarch64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.0
      v16.17.0
      8.15.0
      4.0.23
      pi
      /home/pi
      nodejs:
       Version table:
      aarch64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.0
      v16.17.0
      8.15.0
      4.0.23
      pi
      /home/pi
      OT, aber lösch die Doublette in der Datei /etc/apt/sources.list.d/grafana.list
      3e3957d5-5884-4dfa-b9fd-6ca27262f41b-grafik.png ```
        scout1978
        Muss die Doublette gleich raus? Das wird dann für mich nämlich schon die nächte Baustelle. Bin da nicht so ganz firm.Brauchst du den Code nochmals in den Klammern?
        • S scout1978
          @scout1978
          Lösch die Zeile halt einfach raus.
          Mit nano z.B.
          sudo nano  /etc/apt/sources.list.d/grafana.list
            @scout1978
            Mit nano z.B.
            scout1978
            @thomas-braun said in Innogy Adapter im lokalen Netzt bleibt Gelb:
            ok hat geklappt
            • S scout1978
              ok hat geklappt
              @scout1978
              Dann patch jetzt dein System durch, inkl. upgrade von nodejs.
              iob stop
              sudo apt update
              sudo apt full-upgrade
              sudo reboot
              • S scout1978
                der "Fehler" war nach dem @Thomas-Braun keine neue Zeile für di code-tags zu nehmen. hab ich gerade korrigiert
                  scout1978
                  Jetzt hab ich ausversehen node Js v18.11.0 erwischt, muss erst wieder zurück finden
                  • S scout1978
                    @scout1978
                    Wer hat denn IRGENDWAS von nodejs18 geschrieben?
                    Das ist in deinen Quellen überhaupt nicht aktiv gewesen, das KANNST du gar nicht 'erwischen'.
                    Du solltest NUR die vier Zeilen abarbeiten. Dann wäre die aktuelle Version von node16 eingespielt worden.
                      @scout1978
                      scout1978
                      alles erledigt node Js aktuell und die 4 Zeilen abgearbeitet
                      • S scout1978
                        @scout1978
                        Nix nacherzählen, Fakten liefern:
                          @scout1978
                          scout1978
                          aarch64
                          /usr/bin/nodejs
                          /usr/local/bin/node
                          /usr/local/bin/npm
                          v18.11.0
                          v16.18.0
                          8.19.2
                          4.0.23
                          pi
                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                          /home/pi
                          Hit:3 https://repos.influxdata.com/debian bullseye InRelease
                          Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                          Hit:6 https://phoscon.de/apt/deconz bullseye InRelease
                          All packages are up to date.
                          nodejs:
                            Installed: 18.11.0-deb-1nodesource1
                            Candidate: 18.11.0-deb-1nodesource1
                            Version table:
                           *** 18.11.0-deb-1nodesource1 100
                                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                          pi@raspberrypi-Iobroker:~ $ :~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          aarch64
                          /usr/bin/nodejs
                          /usr/local/bin/node
                          /usr/local/bin/npm
                          v18.11.0
                          v16.18.0
                          8.19.2
                          4.0.23
                          pi
                          /home/pi
                          pi@raspberrypi-Iobroker:~ $.debian.org/debian-security bullseye-
                          • S scout1978
                            aarch64
                            /usr/bin/nodejs
                            /usr/local/bin/node
                            /usr/local/bin/npm
                            v18.11.0
                            v16.18.0
                            8.19.2
                            4.0.23
                            pi
                            /home/pi
                            nodejs:
                              Version table:
                            aarch64
                            /usr/bin/nodejs
                            /usr/local/bin/node
                            /usr/local/bin/npm
                            v18.11.0
                            v16.18.0
                            8.19.2
                            4.0.23
                            pi
                            /home/pi
                            @scout1978
                            Kannst du mir mal sagen wie du jetzt node18.11.0 und 16.18.0 'installiert' hast?
                              scout1978
                              nein
                              • S scout1978
                                nein
                                @scout1978
                                Warum nicht? Ist doch erst wenige Minuten her.
                                  @scout1978
                                  scout1978
                                  So lieber Thomas wie du wohl festgestellt hast bin ich kein Profi, und hangel mich hier irgendwie durch.
                                  Vielen Dank für Deine Hilfe aber ich glaube auf die Art komme ich hier nicht weiter.
                                  • S scout1978
                                    @scout1978
                                    Wie bist du denn zu den beiden Versionen gehangelt?
                                    Irgendeine Anleitung befolgt? Welche? Von alleine kommt der Kram ja nicht auf dein System.
                                      @scout1978
                                      scout1978
                                      Habe wie im Iobroker Masterkurs das update gemacht und die falsche Version eingegeben.Danach nach einem Youtube Video versucht das wieder zu ändern.
                                      • S scout1978
                                        @scout1978
                                        Das yt-Machwerk führt zu jedenfalls zu großem Quatsch.
                                        Zieh es danach wieder gerade:
                                        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                                          @scout1978
                                          scout1978
                                          Guten Morgen
                                          Habe versucht das gerade zu ziehen. würde das so passen?
                                          pi@raspberrypi-Iobroker:/opt/iobroker $ node -v
                                          v16.18.0
                                          pi@raspberrypi-Iobroker:/opt/iobroker $ uname -m && type -P nodejs node npm && n                                      odejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt u                                      pdate &> /dev/null && sudo apt update && apt policy nodejs
                                          aarch64
                                          /usr/local/bin/node
                                          /usr/local/bin/npm
                                          pi@raspberrypi-Iobroker:/opt/iobroker $ npm ls
                                          iobroker.inst@3.0.0 /opt/iobroker
                                          ├── @types/caseless@0.12.2 extraneous
                                          ├── @types/request@2.48.8 extraneous
                                          ├── @types/tough-cookie@4.0.2 extraneous
                                          ├── coffeescript@1.12.7 extraneous
                                          ├── iobroker.admin@6.2.22
                                          ├── iobroker.alexa2@3.19.9
                                          ├── iobroker.backitup@2.4.12
                                          ├── iobroker.cloud@4.2.2
                                          ├── iobroker.daswetter@3.1.3
                                          ├── iobroker.device-reminder@1.2.9
                                          ├── iobroker.devices@1.0.12
                                          ├── iobroker.discovery@3.0.5
                                          ├── iobroker.dwd@2.8.3
                                          ├── iobroker.eusec@0.9.4
                                          ├── iobroker.go-e@1.0.23
                                          ├── iobroker.heatingcontrol@2.8.7
                                          ├── iobroker.hm-rega@3.0.40
                                          ├── iobroker.hm-rpc@1.15.12
                                          ├── iobroker.influxdb@3.1.8
                                          ├── iobroker.info@1.9.19
                                          ├── iobroker.innogy-smarthome@0.4.7
                                          ├── iobroker.iot@1.11.9
                                          ├── iobroker.iqontrol@2.0.1
                                          ├── iobroker.javascript@6.0.3
                                          ├── iobroker.js-controller@4.0.23
                                          ├── iobroker.nuki-extended@2.5.0
                                          ├── iobroker.oilfox@4.1.2
                                          ├── iobroker.psa@0.0.11
                                          ├── iobroker.shelly@6.0.0
                                          ├── iobroker.smartcontrol@1.2.1
                                          ├── iobroker.telegram@1.14.1
                                          ├── iobroker.tr-064@4.2.16
                                          ├── iobroker.viessmannapi@2.0.9
                                          ├── iobroker.web@5.2.0
                                          ├── iobroker.zigbee@1.7.5
                                          ├── jsonata@1.8.6 extraneous
                                          ├── node-inspect@2.0.0 extraneous
                                          ├── picocolors@1.0.0 extraneous
                                          ├── virtual-tsc@0.6.2 extraneous
                                          └── wake_on_lan@1.0.0 extraneous
