  4. Innogy Adapter im lokalen Netzt bleibt Gelb
    5.7k
118 Beiträge 5 Kommentatoren 16.7k Aufrufe 4 Beobachtet
  • S scout1978
    Ja Entschuldigung. Möchtest Du das Ergebnis aus der Konsole? Was sind CodeTags?
    @scout1978 sagte in Innogy Adapter im lokalen Netzt bleibt Gelb:
    Ja. CodeTags:
    Text zwischen die Steuerzeichen kopieren.
      Ja. CodeTags:
      scout1978
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v                                       && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update &&                                       apt policy nodejs
      aarch64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.0
      v16.17.0
      8.15.0
      4.0.23
      pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp                                      io i2c spi iobroker
      /home/pi
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 https://phoscon.de/apt/deconz bullseye InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://repos.influxdata.com/debian bullseye InRelease
      Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:7 https://packages.grafana.com/oss/deb stable InRelease
      Reading package lists... Done
      13 packages can be upgraded. Run 'apt list --upgradable' to see them.
      W: Target Packages (main/binary-arm64/Packages) is configured multiple times in                                       /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:                                      2
      W: Target Packages (main/binary-armhf/Packages) is configured multiple times in                                       /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:                                      2
      W: Target Packages (main/binary-all/Packages) is configured multiple times in /e                                      tc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Translations (main/i18n/Translation-en_GB) is configured multiple time                                      s in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.                                      list:2
      W: Target Translations (main/i18n/Translation-en) is configured multiple times i                                      n /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.lis                                      t:2
      W: Target Packages (main/binary-arm64/Packages) is configured multiple times in                                       /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:                                      3
      W: Target Packages (main/binary-armhf/Packages) is configured multiple times in                                       /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:                                      3
      W: Target Packages (main/binary-all/Packages) is configured multiple times in /e                                      tc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
      W: Target Translations (main/i18n/Translation-en_GB) is configured multiple time                                      s in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.                                      list:3
      W: Target Translations (main/i18n/Translation-en) is configured multiple times i                                      n /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.lis                                      t:3
      nodejs:
       Installed: 16.17.0-deb-1nodesource1
       Candidate: 16.17.1-deb-1nodesource1
       Version table:
          16.17.1-deb-1nodesource1 500
             500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
      *** 16.17.0-deb-1nodesource1 100
          12.22.12~dfsg-1~deb11u1 500
             500 http://security.debian.org/debian-security bullseye-security/main ar                                      m64 Packages
      pi@raspberrypi-Iobroker:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v                                       && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update &&                                       apt policy nodejs
      aarch64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.0
      v16.17.0
      8.15.0
      4.0.23
      pi
      /home/pi
      W: Target Packages (main/binary-armhf/Packages) is configured multiple times in                                       /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:                                      ^C@raspberrypi-Iobroker:~ $.debian.org/debian-security bullseye-security/main ar
      • S scout1978
        aarch64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.0
        v16.17.0
        8.15.0
        4.0.23
        pi
        /home/pi
        nodejs:
         Version table:
        aarch64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.0
        v16.17.0
        8.15.0
        4.0.23
        pi
        /home/pi
        OT, aber lösch die Doublette in der Datei /etc/apt/sources.list.d/grafana.list
        3e3957d5-5884-4dfa-b9fd-6ca27262f41b-grafik.png ```
          scout1978
          Muss die Doublette gleich raus? Das wird dann für mich nämlich schon die nächte Baustelle. Bin da nicht so ganz firm.Brauchst du den Code nochmals in den Klammern?
          • S scout1978
            @scout1978
            Lösch die Zeile halt einfach raus.
            Mit nano z.B.
            sudo nano  /etc/apt/sources.list.d/grafana.list
              @scout1978
              Mit nano z.B.
              scout1978
              @thomas-braun said in Innogy Adapter im lokalen Netzt bleibt Gelb:
              ok hat geklappt
              • S scout1978
                ok hat geklappt
                @scout1978
                Dann patch jetzt dein System durch, inkl. upgrade von nodejs.
                iob stop
                sudo apt update
                sudo apt full-upgrade
                sudo reboot
                • S scout1978
                  der "Fehler" war nach dem @Thomas-Braun keine neue Zeile für di code-tags zu nehmen. hab ich gerade korrigiert
                    scout1978
                    Jetzt hab ich ausversehen node Js v18.11.0 erwischt, muss erst wieder zurück finden
                    • S scout1978
                      @scout1978
                      Wer hat denn IRGENDWAS von nodejs18 geschrieben?
                      Das ist in deinen Quellen überhaupt nicht aktiv gewesen, das KANNST du gar nicht 'erwischen'.
                      Du solltest NUR die vier Zeilen abarbeiten. Dann wäre die aktuelle Version von node16 eingespielt worden.
                        @scout1978
                        scout1978
                        alles erledigt node Js aktuell und die 4 Zeilen abgearbeitet
                        • S scout1978
                          @scout1978
                          Nix nacherzählen, Fakten liefern:
                            @scout1978
                            scout1978
                            aarch64
                            /usr/bin/nodejs
                            /usr/local/bin/node
                            /usr/local/bin/npm
                            v18.11.0
                            v16.18.0
                            8.19.2
                            4.0.23
                            pi
                            pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                            /home/pi
                            Hit:3 https://repos.influxdata.com/debian bullseye InRelease
                            Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                            Hit:6 https://phoscon.de/apt/deconz bullseye InRelease
                            All packages are up to date.
                            nodejs:
                              Installed: 18.11.0-deb-1nodesource1
                              Candidate: 18.11.0-deb-1nodesource1
                              Version table:
                             *** 18.11.0-deb-1nodesource1 100
                                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                            pi@raspberrypi-Iobroker:~ $ :~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            aarch64
                            /usr/bin/nodejs
                            /usr/local/bin/node
                            /usr/local/bin/npm
                            v18.11.0
                            v16.18.0
                            8.19.2
                            4.0.23
                            pi
                            /home/pi
                            pi@raspberrypi-Iobroker:~ $.debian.org/debian-security bullseye-
                            • S scout1978
                              aarch64
                              /usr/bin/nodejs
                              /usr/local/bin/node
                              /usr/local/bin/npm
                              v18.11.0
                              v16.18.0
                              8.19.2
                              4.0.23
                              pi
                              /home/pi
                              nodejs:
                                Version table:
                              aarch64
                              /usr/bin/nodejs
                              /usr/local/bin/node
                              /usr/local/bin/npm
                              v18.11.0
                              v16.18.0
                              8.19.2
                              4.0.23
                              pi
                              /home/pi
                              @scout1978
                              Kannst du mir mal sagen wie du jetzt node18.11.0 und 16.18.0 'installiert' hast?
                                scout1978
                                nein
                                • S scout1978
                                  nein
                                  @scout1978
                                  Warum nicht? Ist doch erst wenige Minuten her.
                                    @scout1978
                                    scout1978
                                    So lieber Thomas wie du wohl festgestellt hast bin ich kein Profi, und hangel mich hier irgendwie durch.
                                    Vielen Dank für Deine Hilfe aber ich glaube auf die Art komme ich hier nicht weiter.
                                    • S scout1978
                                      @scout1978
                                      Wie bist du denn zu den beiden Versionen gehangelt?
                                      Irgendeine Anleitung befolgt? Welche? Von alleine kommt der Kram ja nicht auf dein System.
                                        @scout1978
                                        scout1978
                                        Habe wie im Iobroker Masterkurs das update gemacht und die falsche Version eingegeben.Danach nach einem Youtube Video versucht das wieder zu ändern.
                                        • S scout1978
                                          @scout1978
                                          Das yt-Machwerk führt zu jedenfalls zu großem Quatsch.
                                          Zieh es danach wieder gerade:
                                          https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
