  3. Off Topic
  4. [Gelöst] Ubuntu updaten
64 Beiträge 6 Kommentatoren 7.0k Aufrufe 4 Beobachtet
  • KusselinK Kusselin
    @thomas-braun sagte in Ubuntu updaten:
    sudo apt full-upgrade
    nee thomas.....das klappt so nicht...das wäre zu einfach :-)
     sudo apt update
    Hit:1 http://ppa.launchpad.net/ondrej/php/ubuntu impish InRelease
    Ign:2 http://archive.ubuntu.com/ubuntu impish InRelease
    Ign:3 http://archive.ubuntu.com/ubuntu impish-updates InRelease
    Ign:4 http://archive.ubuntu.com/ubuntu impish-security InRelease
    Err:5 http://archive.ubuntu.com/ubuntu impish Release
      404  Not Found [IP: 91.189.91.39 80]
    Err:6 http://archive.ubuntu.com/ubuntu impish-updates Release
    Err:7 http://archive.ubuntu.com/ubuntu impish-security Release
    Reading package lists... Done
    E: The repository 'http://archive.ubuntu.com/ubuntu impish Release' no longer has a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    E: The repository 'http://archive.ubuntu.com/ubuntu impish-updates Release' no longer has a Release file.
    E: The repository 'http://archive.ubuntu.com/ubuntu impish-security Release' no longer has a Release file.
    root@Nextcloud-live:~# sudo apt full-upgrade
    Calculating upgrade... Done
    The following packages will be upgraded:
      apt apt-utils isc-dhcp-client isc-dhcp-common libapt-pkg6.0 libkeyutils1
      libnss-systemd libpam-systemd libsystemd0 libudev1 python3-distupgrade
      systemd systemd-sysv systemd-timesyncd ubuntu-advantage-tools
      ubuntu-release-upgrader-core udev
    17 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 10.4 MB of archives.
    After this operation, 32.8 kB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Err:1 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libnss-systemd amd64 248.3-1ubuntu8.6
      404  Not Found [IP: 185.125.190.39 80]
    Err:2 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libsystemd0 amd64 248.3-1ubuntu8.6
    Err:3 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd-timesyncd amd64 248.3-1ubuntu8.6
    Err:4 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd-sysv amd64 248.3-1ubuntu8.6
    Err:5 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libpam-systemd amd64 248.3-1ubuntu8.6
    Err:6 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd amd64 248.3-1ubuntu8.6
    Err:7 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 udev amd64 248.3-1ubuntu8.6
    Err:8 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libudev1 amd64 248.3-1ubuntu8.6
    Err:9 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libapt-pkg6.0 amd64 2.3.9ubuntu0.1
    Err:10 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 apt amd64 2.3.9ubuntu0.1
    Err:11 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 apt-utils amd64 2.3.9ubuntu0.1
    Err:12 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libkeyutils1 amd64 1.6.1-2ubuntu2.1
    Err:13 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 isc-dhcp-client amd64 4.4.1-2.3ubuntu1.1
    Err:14 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 isc-dhcp-common amd64 4.4.1-2.3ubuntu1.1
    Err:15 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 ubuntu-advantage-tools amd64 27.9~21.10.1
    Err:16 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 ubuntu-release-upgrader-core all 1:21.10.10
    Err:17 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 python3-distupgrade all 1:21.10.10
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libnss-systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libsystemd0_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd-timesyncd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd-sysv_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libpam-systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/udev_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libudev1_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/libapt-pkg6.0_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt-utils_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/k/keyutils/libkeyutils1_1.6.1-2ubuntu2.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-client_4.4.1-2.3ubuntu1.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-common_4.4.1-2.3ubuntu1.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-advantage-tools/ubuntu-advantage-tools_27.9%7e21.10.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/ubuntu-release-upgrader-core_21.10.10_all.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/python3-distupgrade_21.10.10_all.deb  404  Not Found [IP: 185.125.190.39 80]
    E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
    @kusselin
    Kannst aber auch hier mal schauen:
    https://help.ubuntu.com/community/EOLUpgrades
      @kusselin
      Installier es neu und halte da dann das EndOfLife im Auge und spring vorher auf den Nachfolger.
      KusselinK Offline
      KusselinK Offline
      Kusselin
      @kusselin
      andree Möglichkeit wie neuinstallation gibts nicht?
        @kusselin
        @kusselin
        Steht im dem Link drin:
        Aber auch dort wird geschrieben:
        Reinstalling is usually easier and faster, especially if you would have to upgrade through several releases.
          @kusselin
          crunchipC Abwesend
          crunchipC Abwesend
          @kusselin hatte das kürzlich auch bei einer VM gemacht, sourceslist anpassen aufs aktuelle Ubuntu und danach das full update, geht ohne Probleme
          HomoranH KusselinK 2 Antworten Letzte Antwort
            @crunchip sagte in Ubuntu updaten:
            war da das alte Repo auch nicht mehr erreichbar?
              KusselinK Offline
              KusselinK Offline
              Kusselin
              das hier:
              ## EOL upgrade sources.list
              # Required
              deb http://old-releases.ubuntu.com/ubuntu/ CODENAME main restricted universe multiverse
              deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-updates main restricted universe multiverse
              deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-security main restricted universe multiverse
              # Optional
              #deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-backports main restricted universe multiverse
              muss in die source list.....
              Bitte an euch...wo bzw. welche pfad ist das /etc/......?
              und muss ich das alte dann komplett rausnehmen aus der source list udn das hier neu rein?
                das hier:
                # Required
                # Optional
                @kusselin
                Das ist die /etc/apt/sources.list
                In deinem Fall muss die so aussehen:
                deb http://old-releases.ubuntu.com/ubuntu/ impish main restricted universe multiverse
                deb http://old-releases.ubuntu.com/ubuntu/ impish-updates main restricted universe multiverse
                deb http://old-releases.ubuntu.com/ubuntu/ impish-security main restricted universe multiverse
                Weitere .list-Dateien (finden sich in /etc/apt/sources.list.d/ ) dann ggf. auch anpassen. Mindestens nach dem Upgrade auf den dann gültigen CODENAME (weiß gerade nicht bei welchem Viech die Ubuntus sind)
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @homoran ja
                  • KusselinK Offline
                    KusselinK Offline
                    Kusselin
                    o.k.die source list habe ich gefunden während du das hier geschrieben hast..
                    meine sieht jetzt so aus:
                    deb http://archive.ubuntu.com/ubuntu impish main restricted universe multiverse
                    deb http://archive.ubuntu.com/ubuntu impish-updates main restricted universe multiverse
                    deb http://archive.ubuntu.com/ubuntu impish-security main restricted universe multiverse
                    und die aändere ich komplett in:
                    dann speichern und udn apt-get update udn danach apt-get upgrade....richtig?
                    was ich jetzt aber noch nicht gerafft habe ist das mit dem Codename??
                    Wo und wie muss ich den verwednen?
                    Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                      @homoran ja
                      @crunchip
                      Ja, geht auch. Unter Umständen.
                      'do-release-upgrade' macht aber u. U. noch anderes als 'nur' die Quellen umstellen. Daher würde ich immer versuchen über diesen Weg zu gehen.
                        @kusselin sagte in Ubuntu updaten:
                        Hast du denn in
                        ls -lA /etc/apt/sources.list.d
                        weitere Dateien drin? Vermultich die nodesource.list.
                          @kusselin
                          Wenn die sources.list geändert ist:
                          sudo apt-get update
                          sudo apt-get dist-upgrade
                          sudo do-release-upgrade
                            richtig
                            nicht wirklich.
                            du sollst statt impish den aktuellen CODENAMEN eingeben.
                            prüf mal. das könnte CANONICAL sein. ich kenne mich bei UBUNTU nicht aus
                              richtig
                              nicht wirklich.
                              Nein, das ist schon richtig mit 'impish'.
                              Der vorgesehene Upgrade-Vorgang über das 'do-release-upgrade'-Skript setzt die alte Versionsbezeichnung voraus.
                              Die wird im Zuge des Upgrades durch das Skript auf den jetzt aktuellen angepasst.
                                @thomas-braun dann hab ich nix gesagt und auch nix editiert
                                • KusselinK Offline
                                  KusselinK Offline
                                  Kusselin
                                  so wie von thomas hats jetzt funktioniert.... :-)
                                  heisst jetzt nichts mehr ändern an der Source list?
                                  Habe die alten sachen in der Source list auskommentiert mi #
                                    @kusselin
                                    Ist das Upgrade jetzt durch?
                                    sudo apt update
                                    sagt?
                                    • KusselinK Offline
                                      KusselinK Offline
                                      Kusselin
                                       sudo apt update
                                      Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
                                      Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                                      Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                                      1 package can be upgraded. Run 'apt list --upgradable' to see it.
                                      passt jetzt oder?
                                         sudo apt update
                                        passt jetzt oder?
                                        @kusselin
                                        Und die anderen .list-Dateien?
                                        ls -lA /etc/apt/sources.list.d/
                                        • KusselinK Offline
                                          KusselinK Offline
                                          Kusselin
                                          total 8
                                          -rw-r--r-- 1 root root 158 Oct 14 13:47 ondrej-ubuntu-php-impish.list
                                          -rw-r--r-- 1 root root 126 Oct 14 13:47 ondrej-ubuntu-php-impish.list.distUpgrade
