  4. ioBroker nach Restore nicht mehr erreichbar
    5.7k
backuprestore
19 Beiträge 4 Kommentatoren 2.0k Aufrufe 4 Beobachtet
    @hmanfred zu der Meldung gibt es einen Thread.
    was kommt denn bei dem aufgeforderten Vorgehen raus?
    unmittelbar bei einem Restore oder dem (n) ersten Aufruf(en) könnte das aber normal sein.
    hmanfred
    ​ [2022-10-05T13:00:31.057Z] ws connection error: CLOSE_ABNORMAL
    error @ :8081/socket.io/socket.io.js:68
    ​ [2022-10-05T13:00:31.058Z] Start reconnect 0
    7821.a0b80bed.chunk.js:12 [2022-10-05T13:00:31.058Z] ws connection error: CLOSE_ABNORMAL
    (anonymous) @ 7821.a0b80bed.chunk.js:12
    7821.a0b80bed.chunk.js:12 [2022-10-05T13:00:31.120Z] Start reconnect 0
    ​ [2022-10-05T13:00:31.147Z] Try to connect
    7821.a0b80bed.chunk.js:12 [2022-10-05T13:00:31.150Z] Try to connect
    ​ WebSocket connection to 'ws://192.168.1.122:8081//adapter/backitup?sid=1664974831147' failed:
    SocketClient.connect @ :8081/socket.io/socket.io.js:140
    ​ [2022-10-05T13:00:33.193Z] Start reconnect 1
    ​ [2022-10-05T13:00:33.194Z] ws connection error: CLOSE_ABNORMAL
    ​ [2022-10-05T13:00:33.194Z] Reconnect is already running 1
    7821.a0b80bed.chunk.js:12 [2022-10-05T13:00:34.163Z] No READY flag received in 3 seconds. Re-init
    socket.io.js:396 WebSocket connection to 'ws://192.168.1.122:8081/?sid=1664974831150&name=admin' failed: WebSocket is closed before the connection is established.
    SocketClient.close @ socket.io.js:396
    7821.a0b80bed.chunk.js:12 [2022-10-05T13:00:34.163Z] Start reconnect 1
    7821.a0b80bed.chunk.js:12 [2022-10-05T13:00:34.164Z] ws connection error: CLOSE_ABNORMAL
    27821.a0b80bed.chunk.js:12 [2022-10-05T13:00:34.164Z] Reconnect is already running 1
    ​ [2022-10-05T13:00:34.205Z] Try to connect
    7821.a0b80bed.chunk.js:12 [2022-10-05T13:00:35.164Z] Try to connect
    socket.io.js:140 WebSocket connection to 'ws://192.168.1.122:8081/?sid=1664974835164&name=admin' failed:
    usw. Das geht dann endlos so weiter.
    Noch etwas -Zwischenablage03.jpg die Konsole der VM zeigt folgende Meldung (keine Ahnung wann die entstand):
    • H hmanfred
      @hmanfred sagte in ioBroker nach Restore nicht mehr erreichbar:
      die Konsole der VM
      läuft unter Proxmox in einem Container.
      was denn nun?
      folgende Meldung
      hab ich keine Ahnung von
      H 1 Antwort Letzte Antwort
        die Konsole der VM
        was denn nun?
        folgende Meldung
        hmanfred
        @homoran sagte in ioBroker nach Restore nicht mehr erreichbar:
        die Konsole der VM
        was denn nun?
        Sorry für die späte Antwort. Ich bin momentan zu sehr in anderen Dingen eingespannt...
        Die Prodiktivmaschine läuft in einem Container. Der Restore wurde in einer "echten" VM gemacht. Dort steht auch die oben erwähnte Meldung.
        Die VM hat inzwischen eine Uptime von fast 9 Tagen. Das WebUi von ioBroker ist nicht erreichbar.
        ioBroker status sagt:
        Ich hoffe, jemend hier kann mir - mit meinem begrenzten Linux-Wissen - helfen, dem Problem auf die Spur zu kommen.
        • H hmanfred
          die Konsole der VM
          was denn nun?
          @hmanfred was sagt iobroker list instances ?
            hmanfred
            Außer admin und backitup stehen alle auf "disabled". Das ist wohl die richtige Spur...
            Nach "iobroker start all" laufen sie nun alle.
            Web ist auf Port 8082 erreichbar, admin auf 8081 aber nicht.
            Liegt das an der nicht passenden IP-Aresse? Beim admin-Adapter steht (mit "list instances") "bind: 192.168.1.20". Das ist die IP der Produktivmaschine. Die mit dem Restore hat eine andere, mit der ich sie allerdings versuche anzusprechen.
            • H Offline
              hmanfred
              schrieb am zuletzt editiert von hmanfred
              Läuft! 😁
              Ursache war offensichtlich ein falsches Setup des Admin-Adapters in der Produktivmaschine. Dort war der Zugriff nicht auf 0.0.0.0 sondern auf die IP der Maschine engestellt - die Hilfe zum Adapter sagt, dass unbedingt 0.0.0.0 gelassen werden soll. Weiß der Deibel, warum das verstellt war.
              Nach Änderung ein Backup gemacht, in der neuen Maschine engespielt - läuft.
              Danke @Homoran - du hast mich letztendlich auf die richtige Spur gebracht.
              • H hmanfred
                keine Nacherzählungen, immer zeigen!
                  hmanfred
                  Nun denn:
                  Hier war unter "IP-Adresse" die Adresse des Hosts (bei mir 192.168.1.20) eingestellt, was beim Backup/Restore übernommen wurde und offensiochtlich zu den Problemen führte.
                  • H Offline
                    hmanfred
                    Leider läuft aber nun noch nicht alles.
                    Nach Shutdown der alten Produktivmaschine habe ich bei der neuen die IP auf die altbekannte (192.168.1.20) umgestellt. Alle Adapter starten. Nur VIS läuft nicht - ich komme weder an die Weboberfläche noch in den Editor. Klick auf den Schraubenschlüssel zeigt:
                    Irgendwelche Tipps?
                    DJMarc75D crunchipC 2 Antworten Letzte Antwort
                    • H hmanfred
                      Irgendwelche Tipps?
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      @hmanfred
                      iobroker upload all
                      Lehrling seit 1975 !!!
                      • H hmanfred
                        Irgendwelche Tipps?
                        crunchipC Offline
                        crunchipC Offline
                        Wo, in der VM, statisch?
                          hmanfred
                          @crunchip sagte in ioBroker nach Restore nicht mehr erreichbar:
                          Richtig, in der /etc/network/interfaces
                          • DJMarc75D DJMarc75
                            @hmanfred
                            iobroker upload all
                            hmanfred
                            @djmarc75 sagte in ioBroker nach Restore nicht mehr erreichbar:
                            @hmanfred
                            iobroker upload all
                            Funktioniert! Danke!!!
