4.8k Beiträge 4 Kommentatoren 2.9m Aufrufe 4 Beobachtet
  • Damrak2022D Damrak2022
    @mickym Danke
    mickymM Online
    mickymM Online
    mickym
    #917
    @damrak2022 Na normal ist das nicht - schau mal im Log, ob was abgestürzt war.
    • mickymM mickym
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      #918
      @mickym Hier ein Auszug aus dem Lg:
      node-red.0
      2022-09-28 16:43:50.294	info	b875c1a1cb845312: Automatic objects creation is not enabled. You can enable it in the node configuration
      node-red.0
      2022-09-28 16:43:50.292	info	b875c1a1cb845312: "ioBroker in" Cannot set state of non-existing object "hue.0.Dimmschalter.battery".
      node-red.0
      2022-09-28 16:43:48.130	warn	28 Sep 16:43:48 - [warn] Projects disabled : editorTheme.projects.enabled=false
      node-red.0
      2022-09-28 16:43:39.437	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      node-red.0
      2022-09-28 16:43:38.167	warn	Cannot enable the dynamic object read as admin has authentication
      node-red.0
      2022-09-28 16:43:38.039	info	starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v16.17.0, js-controller: 4.0.23
      host.homebridge
      2022-09-28 16:43:35.706	info	instance system.adapter.node-red.0 started with pid 276468
      host.homebridge
      2022-09-28 16:43:33.709	info	instance system.adapter.node-red.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      node-red.0
      2022-09-28 16:43:33.078	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      host.homebridge
      2022-09-28 16:43:32.570	info	stopInstance timeout 5000 system.adapter.node-red.0 killing pid 107629
      node-red.0
      2022-09-28 16:43:27.881	info	node-red exited with 0
      node-red.0
      2022-09-28 16:43:27.578	info	kill node-red task
      host.homebridge
      2022-09-28 16:43:27.568	info	stopInstance system.adapter.node-red.0 (force=false, process=true)
      node-red.0
      2022-09-28 16:41:34.517	info	b875c1a1cb845312: Automatic objects creation is not enabled. You can enable it in the node configuration
      node-red.0
      2022-09-28 16:41:34.514	info	b875c1a1cb845312: "ioBroker in" Cannot set state of non-existing object "hue.0.Dimmschalter.battery".
      host.homebridge
      2022-09-28 16:40:30.952	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      ical.0
      2022-09-28 16:40:30.413	info	Terminated (NO_ERROR): With
      Mit besten Grüßen
      Andy
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        node-red.0
        host.homebridge
        host.homebridge
        node-red.0
        host.homebridge
        node-red.0
        node-red.0
        host.homebridge
        node-red.0
        node-red.0
        host.homebridge
        ical.0
        mickymM Online
        mickymM Online
        mickym
        #919
        @damrak2022 Na Du hast halt doch wieder irgendwas mit Authentifizierung gemacht . da kann ich Dir nicht helfen, weil bei mir ist das alles immer ausgeschaltet.
        Und in einer iobroker-IN Node hast Du einen Topic angegeben, den es anscheinend nicht gibt:
        Du kannst bei den Flows mal
        b875c1a1cb845312
        suchen - dann sollte es Dir die betreffende node anzeigen.
        • mickymM mickym
          b875c1a1cb845312
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          #920
          @mickym Ja, das ist der wo ich die Batterie austauschen muss.
          Mit besten Grüßen
          Andy
            mickymM Online
            mickymM Online
            mickym
            #921
            @damrak2022 Ja aber den State/Datenpunkt scheint es nicht zu geben.
            • mickymM mickym
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #922
              @mickym Nein, im Moment nicht.
              Mit besten Grüßen
              Andy
                mickymM Online
                mickymM Online
                mickym
                #923
                @damrak2022 dann deaktiviere diese Nodes - macht doch keinen Sinn - wenn Du Nodes ohne Funktion aktiv hast.
                • mickymM mickym
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #924
                  @mickym Okay, ich dachte halt das kann ich auch lassen, weil es morgen ja wieder eingebunden wird
                  Mit besten Grüßen
                  Andy
                    mickymM Online
                    mickymM Online
                    mickym
                    #925
                    @damrak2022 Na ja bricht nichts zusammen - aber wenn Du die Node deaktiviert hast dann siehst ja auch gleich, wo noch was zu tun ist.
                    • mickymM mickym
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #926
                      @mickym Zu tun und lernen habe ich genug🙂
                      Mit besten Grüßen
                      Andy
                        mickymM Online
                        mickymM Online
                        mickym
                        #927
                        @damrak2022
                        So was habe ich halt nicht - weil ich keine Anmeldung benutze - keine Ahnung - aber das würde für mich bedeuten, wenn ich das richtig interpretiere, dass Du keine Wildcards nutzen kannst - und das wäre für mich ein absolutes NoGo.
                        • mickymM mickym
                          @damrak2022
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #928
                          @mickym Das ist jetzt weg, da ich diesen Google Mist wieder entfernt habe.
                          Mit besten Grüßen
                          Andy
                          • mickymM mickym
                            @damrak2022
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            #929
                            @mickym Guten Morgen, eine Frage Micky:
                            Die openwethermap node gibt mir folgende Daten aus:
                            Die 4 Markierten Werte möchte ich jeweils in einer Gauge Node darstellen.
                            Also habe ich hinter die openweathermap node eine Switch Node gehängt, aber irgendwie klappt das noch nicht.
                            In der Vorlage die ich habe sieht die Payload auch etwas anders aus, da hier der DWD verwendet wird - siehe hier:
                            Bei mir sieht der Flow momentan so aus:
                            Ich habe es auch mit der Change node versucht, aber da habe ich wohl noch dickeFehler drin.
                            Kannst Du mir einen Denkanstoß geben?
                            Mit besten Grüßen
                            Andy
                              mickymM Online
                              mickymM Online
                              mickym
                              #930
                              @damrak2022 Ja in diesem Fall ist die switch Node falsch. Besser wäre Du hättest 4 Change Nodes verwendet und die payload auf den Pfad von der Nachrichteneigenschaft gesetzt, die Dich interessiert. Das Pfad kopieren aus dem Debug Fenster haben wir schon gemacht. ;)
                              Aber das ist wieder in Beispiel, dass Dir noch etwas Verständnis für die Nodes fehlt. ;)
                              • mickymM mickym
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                #931
                                @mickym Okay, danke, ich biege das nachher hin. Momentan bin ich im Stress - siehe Chat
                                Mit besten Grüßen
                                Andy
                                • mickymM mickym
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  #932
                                  @mickym Genau mit dem Verständnis tue ich mich schwer.
                                  Was muss ich jetzt in de Change Node eintragen um den ersten Wert "weather" anzuzeigen.
                                  Habe schon einiges versucht, bekomme im Dashboard aber keinen Wert, bzw. keine Meldung angezeigt
                                  Mit besten Grüßen
                                  Andy
                                    mickymM Online
                                    mickymM Online
                                    mickym
                                    #933
                                    @damrak2022 Nun wie gesagt Du setzt die neue payload auf die Eigenschaft der alten payload. Dafür kopierst Du den Pfad aus der Debug Node.
                                    und natürlich mit einer debug Node prüfen, ob was rauskommt. ;)
                                    Theoretisch brauchst Du nicht mal eine Change Node - Du kannst auch in der Textnode - den vollständigen Pfad zur Eigenschaft eingeben - dann ist es noch einfacher. ;)
                                    Machs einfach mal MIT Change Node und einmal OHNE Change Node - damit Du auch verstehst - was passiert.
                                    Bei der gauge Node - musst eh in eine payload wandeln - da diese nur die payload untersucht.
                                    • mickymM mickym
                                      Damrak2022D Offline
                                      Damrak2022D Offline
                                      Damrak2022
                                      #934
                                      @mickym Ja, das geht alles, wie nicht anders zu erwarte war bei Erklärungen von Dir🙂
                                      Wenn ich mich recht erinnere ist Deine Wetter Ansicht viel schöner
                                      Mit besten Grüßen
                                      Andy
                                        mickymM Online
                                        mickymM Online
                                        mickym
                                        #935
                                        @damrak2022 Nun da stecken ja auch einige Tage bzw. Wochen Arbeit dahinter. Den Thread habe ich dir doch verlinkt - entweder per PN oder hier.
                                        • mickymM mickym
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #936
                                          @mickym War nur eine Feststellung, Da wage ich mich wohl noch nicht dran. Ich glaube da ist Frust vorprogrammiert.
                                          Mit besten Grüßen
                                          Andy
