  4. Adapter updaten nicht mehr nach Update auf Node.js 16.17.0
    5.6k
94 Beiträge 7 Kommentatoren 17.0k Aufrufe 6 Beobachtet
  • I iobrokerle
    Immer noch 😖
    pi@raspberry-iob:/opt/iobroker $ iobroker add ble --debug
    NPM version: 8.15.0
    Installing iobroker.ble@0.13.0... (System call)
    npm WARN old lockfile
    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm WARN old lockfile This is a one-time fix-up, please be patient...
    npm WARN tarball tarball data for iobroker.icons-ultimate-png@https://github.com/ioBroker/ioBroker.icons-ultimate-png/tarball/master (sha512-ZauMOfdp4ublYvWRd6mFp64dZ9T5k7z0aX/GcX3ljGziXyNVFtV3iUADNWoBGOk/vLPawTV7w2JpbMmTsHKNMQ==) seems to be corrupted. Trying again.
    npm ERR! code EINTEGRITY
    npm ERR! sha512-ZauMOfdp4ublYvWRd6mFp64dZ9T5k7z0aX/GcX3ljGziXyNVFtV3iUADNWoBGOk/vLPawTV7w2JpbMmTsHKNMQ== integrity checksum failed when using sha512: wanted sha512-ZauMOfdp4ublYvWRd6mFp64dZ9T5k7z0aX/GcX3ljGziXyNVFtV3iUADNWoBGOk/vLPawTV7w2JpbMmTsHKNMQ== but got sha512-drue5OEPkI+l3Uiatv6ltEKCEFrMcVteIy3oYdt2Y1Nc/aS3bLXuYGt7RkKgTz9a2suOqKCsA4UWBn7y9vPRuw==. (1670356 bytes)
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-25T13_51_31_032Z-debug-0.log
    host.raspberry-iob Cannot install iobroker.ble@0.13.0: 1
    @iobrokerle sagte in Adapter updaten nicht mehr nach Update auf Node.js 16.17.0:
    Dann schmeiß den
    Adapter raus.
    I 1 Antwort Letzte Antwort
      Dann schmeiß den
      Adapter raus.
      I Offline
      I Offline
      iobrokerle
      schrieb am zuletzt editiert von iobrokerle
      Will auch nicht 😠
      $ iobroker del icons-ultimate-png
      Delete adapter "icons-ultimate-png"
      host.raspberry-iob Counted 1 meta of icons-ultimate-png
      host.raspberry-iob Counted 1 adapter for icons-ultimate-png
      host.raspberry-iob Counted 1 states of system.adapter.icons-ultimate-png
      host.raspberry-iob Counted 1 states (system.adapter.icons-ultimate-png.*) from states
      host.raspberry-iob file icons-ultimate-png deleted
      host.raspberry-iob file icons-ultimate-png.admin deleted
      host.raspberry-iob object icons-ultimate-png deleted
      host.raspberry-iob object icons-ultimate-png.admin deleted
      host.raspberry-iob Deleting 3 object(s).
      host.raspberry-iob Deleting 1 state(s).
      Error deleting adapter icons-ultimate-png from disk: host.raspberry-iob: Cannot uninstall iobroker.icons-ultimate-png: 1
      You might have to delete it yourself!
      Process exited with code 0
      Bei der Adapterübersicht ist er aber trotzdem drausen
      • I iobrokerle
        Will auch nicht 😠
        Wenn du den brauchst:
        iob add icons-ultimate-png --debug
          I Offline
          I Offline
          iobrokerle
          NPM version: 8.15.0
          npm WARN tarball tarball data for iobroker.vis-jqui-mfd@https://github.com/ioBroker/ioBroker.vis-jqui-mfd/tarball/master (sha512-INXgmBMn8dXk+ySYR6Hx+ZAC8x36xGKAk8IKet0N8m4xe/Q4EiwzCsOlMbtQsWG/PrtUDopnvLMqNB3EDQnCHg==) seems to be corrupted. Trying again.
          npm ERR! sha512-INXgmBMn8dXk+ySYR6Hx+ZAC8x36xGKAk8IKet0N8m4xe/Q4EiwzCsOlMbtQsWG/PrtUDopnvLMqNB3EDQnCHg== integrity checksum failed when using sha512: wanted sha512-INXgmBMn8dXk+ySYR6Hx+ZAC8x36xGKAk8IKet0N8m4xe/Q4EiwzCsOlMbtQsWG/PrtUDopnvLMqNB3EDQnCHg== but got sha512-aIDxplY3tckVzKezokybf2Ki4MQdHn7DKw+ipKbVUvmkmT88o3KFhxEie1xLO5bF3zDUAAhayGPASuYSacYieQ==. (285658 bytes)
          npm ERR!     /home/iobroker/.npm/_logs/2022-09-25T14_01_13_021Z-debug-0.log
          • I iobrokerle
            NPM version: 8.15.0
            @iobrokerle
            sudo -H -u iobroker npm cache clear --force
              @iobrokerle
              I Offline
              I Offline
              iobrokerle
              @thomas-braun said in Adapter updaten nicht mehr nach Update auf Node.js 16.17.0:
              icons-ultimate-png
              icons-ultimate-png Installation hat funktioniert und ist auch nach de Start in den Adaptern dabei.
              Das oben war der Versuch BLE zu installieren.
              $ iobroker add ble --host raspberry-iob
              NPM version: 8.15.0
              ERROR: Process exited with code 25
              • I iobrokerle
                icons-ultimate-png
                NPM version: 8.15.0
                iobroker add ble --host raspberry-iob --debug
                  I Offline
                  I Offline
                  iobrokerle
                  Immer das gleiche:
                  pi@raspberry-iob:/opt/iobroker $ iobroker add ble --host raspberry-iob --debug
                  NPM version: 8.15.0
                  npm ERR!     /home/iobroker/.npm/_logs/2022-09-25T14_06_26_239Z-debug-0.log
                  • I iobrokerle
                    Immer das gleiche:
                    NPM version: 8.15.0
                    EINTEGRITY
                    schmeiss doch das
                    old lockfile
                    raus
                      EINTEGRITY
                      schmeiss doch das
                      old lockfile
                      raus
                      I Offline
                      I Offline
                      iobrokerle
                      @homoran sagte in Adapter updaten nicht mehr nach Update auf Node.js 16.17.0:
                      EINTEGRITY
                      Wie am besten?
                      • I iobrokerle
                        EINTEGRITY
                        Wie am besten?
                        I Offline
                        I Offline
                        iobrokerle
                        EINTEGRITY
                        Wie am besten?
                        Ok, altes files ist weg und BLE konnte installiert werden.
                        VIELEN DANK
                        Aber er lässt sich halt nicht Starten.
                        Zur Vorgeschichte: Ich musste node.js updaten für einen andere Adapter. Alles genau nach Anleitung aus dem Forum. Danach startete der BLE nicht mehr.
                        -Verbunden mit Host OK
                        -Lebenszeichen OK
                        -Verbunden mit Gerät oder Dienst nOK
                        Daraufhin den BLE runtergeworfen und wollte diesen neu installieren. Dann bin ich hier gelandet. BLE ist mittlerweile drauf aber:
                        -Verbunden mit Host nOK
                        -Lebenszeichen nOK
                        2022-09-25 17:26:48.783 error Terminating because A dependency requires a rebuild.
                        Jetzt weiß ich nicht weiter. Mit node.js 12 lief alles noch....
                        • I iobrokerle
                          EINTEGRITY
                          Wie am besten?
                          VIELEN DANK
                          -Lebenszeichen OK
                          -Lebenszeichen nOK
                          da müsste noch mehr stehen, zumindest im debug mode
                            I Offline
                            I Offline
                            iobrokerle
                            @homoran Das kommt direkt aus dem iobroker Protkoll.
                            Wie kann ich das im putty abfragen?
                            ble.0
                            2022-09-25 18:40:48.507	error	Terminating because A dependency requires a rebuild.
                            ble.0
                            2022-09-25 18:40:47.844	info	starting scanner process...
                            ble.0
                            2022-09-25 18:40:47.821	info	monitored services: fe95
                            ble.0
                            2022-09-25 18:40:47.818	info	enabled plugins: Xiaomi, _default
                            ble.0
                            2022-09-25 18:40:47.816	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                            ble.0
                            2022-09-25 18:40:47.750	info	starting. Version 0.13.0 in /opt/iobroker/node_modules/iobroker.ble, node: v16.17.1, js-controller: 4.0.23
                            • I iobrokerle
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              ble.0
                              aber da muss auch stehen wer das sagt.
                              diesen dann auf debug stellen und nochmal versuchen
                              ODER
                              über di Konsole iobroker upgrade ble --debug
                                ODER
                                I Offline
                                I Offline
                                iobrokerle
                                host.raspberry-iob
                                2022-09-25 18:47:36.281	info	Rebuild for adapter system.adapter.ble.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                host.raspberry-iob
                                2022-09-25 18:47:36.281	info	instance system.adapter.ble.0 requested a rebuild of its dependencies and will be restarted after that is done.
                                ble.0
                                2022-09-25 18:47:36.193	error	Terminating because A dependency requires a rebuild.
                                ble.0
                                2022-09-25 18:47:35.538	info	starting scanner process...
                                ble.0
                                2022-09-25 18:47:35.517	info	monitored services: fe95
                                ble.0
                                2022-09-25 18:47:35.515	info	enabled plugins: Xiaomi, _default
                                ble.0
                                2022-09-25 18:47:35.514	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                                ble.0
                                2022-09-25 18:47:35.449	info	starting. Version 0.13.0 in /opt/iobroker/node_modules/iobroker.ble, node: v16.17.1, js-controller: 4.0.23
                                host.raspberry-iob
                                2022-09-25 18:47:33.249	info	instance system.adapter.ble.0 started with pid 25050
                                pi@raspberry-iob:/ $ iobroker upgrade ble --debug
                                Adapter "ble"            is up to date.
                                • I iobrokerle
                                  host.raspberry-iob
                                  host.raspberry-iob
                                  ble.0
                                  ble.0
                                  ble.0
                                  ble.0
                                  ble.0
                                  ble.0
                                  host.raspberry-iob
                                  hast du das mal gemacht?
                                    I Offline
                                    I Offline
                                    iobrokerle
                                    pi@raspberry-iob:/opt/iobroker/node_modules/iobroker.ble $ npm install --production
                                    npm WARN config production Use `--omit=dev` instead.
                                    added 67 packages, and audited 80 packages in 2m
                                    6 packages are looking for funding
                                      run `npm fund` for details
                                    found 0 vulnerabilities
                                    LÄUFT - nochmals vielen DANK für eure Mühe
                                    • I iobrokerle
                                      I Offline
                                      I Offline
                                      iobrokerle
                                      #66
                                      @Thomas-Braun
                                      @Homoran
                                      War zu schön. Lief alles bis 21.05 Uhr und dann wieder das:
                                      ble.0
                                      2022-09-25 21:05:03.914	error	Terminating because A dependency requires a rebuild.
                                      ble.0
                                      2022-09-25 21:05:03.270	info	starting scanner process...
                                      ble.0
                                      2022-09-25 21:05:03.248	info	monitored services: fe95
                                      ble.0
                                      2022-09-25 21:05:03.247	info	enabled plugins: Xiaomi, _default
                                      ble.0
                                      2022-09-25 21:05:03.245	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                                      ble.0
                                      2022-09-25 21:05:03.174	info	starting. Version 0.13.0 in /opt/iobroker/node_modules/iobroker.ble, node: v16.17.1, js-controller: 4.0.23
                                      Ich habe rein gar nichts gemacht. Nur zufällig reingeschaut.
                                      -Lebenszeichen nOK
                                      -Verbunden mit Gerät oder Dienst OK
                                      • I iobrokerle
                                        @Thomas-Braun
                                        @Homoran
                                        ble.0
                                        ble.0
                                        ble.0
                                        ble.0
                                        ble.0
                                        ble.0
                                        -Lebenszeichen nOK
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        #67
                                        @iobrokerle
                                        Nochmal in
                                        cd /opt/iobroker/node_modules/iobroker.ble
                                        dann
                                        npm install --omit=dev
                                        und
                                        sudo reboot
                                        • GlasfaserG Glasfaser
                                          @iobrokerle
                                          Nochmal in
                                          dann
                                          und
                                          sudo reboot
                                          I Offline
                                          I Offline
                                          iobrokerle
                                          #68
                                          @glasfaser sagte in Adapter updaten nicht mehr nach Update auf Node.js 16.17.0:
                                          sudo reboot
                                          DANKE, für den Moment läuft es.
                                          Weiß man woran das liegen könnte?
                                          Schönen Abend noch.
                                          iobrokerle
