    6.7k
2.9k Beiträge 248 Kommentatoren 2.0m Aufrufe 123 Beobachtet
  • Z Zuki
    @glasfaser
    Der Admin scheint zu laufen... Ist aber leider nicht erreichbar.
    22-09-19 15:20:00.232  - info: host.iobroker 3 instances found
    2022-09-19 15:20:00.241  - info: host.iobroker starting 3 instances
    2022-09-19 15:20:00.275  - info: host.iobroker instance system.adapter.admin.0 started with pid 421
    2022-09-19 15:20:01.858  - info: admin.0 (421) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.17.0, js-controller: 4.0.23
    2022-09-19 15:20:01.895  - info: admin.0 (421) requesting all states
    2022-09-19 15:20:01.896  - info: admin.0 (421) requesting all objects
    2022-09-19 15:20:02.103  - info: admin.0 (421) received all objects
    2022-09-19 15:20:02.206  - info: admin.0 (421) Request actual repository...
    2022-09-19 15:20:02.220  - info: admin.0 (421) http server listening on port 8081
    2022-09-19 15:20:02.221  - info: admin.0 (421) Use link "http://localhost:8081" to configure.
    2022-09-19 15:20:02.327  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-09-19 15:20:03.685  - info: admin.0 (421) Repository received successfully.
    2022-09-19 15:20:04.266  - info: host.iobroker instance system.adapter.discovery.0 started with pid 436
    2022-09-19 15:20:05.574  - info: discovery.0 (436) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.17.0, js-controller: 4.0.23
    2022-09-19 15:20:08.263  - info: host.iobroker instance system.adapter.backitup.0 started with pid 464
    2022-09-19 15:20:09.707  - info: backitup.0 (464) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.17.0, js-controller: 4.0.23
    2022-09-19 15:20:09.754  - info: backitup.0 (464) [iobroker] backup was activated at 02:40 every 1 day(s)
    GlasfaserG Offline
    GlasfaserG Offline
    #2596
    @zuki sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
    mehr Instanzen hast du nicht !?
    Gab es schon das Problem dass der ioBroker innerhalb des Dockers nicht starten zu scheint?
    Was hast du vorher gehabt !?
    wie nicht erreichbar , Fehler im Browser oder ...!?
    iobroker list instances
    • Z Zuki
      @glasfaser
      GlasfaserG Offline
      GlasfaserG Offline
      #2597
      @zuki
      Hast du wieder das Problem mit SSL
      https://forum.iobroker.net/post/580437
      iobroker set admin.0 --secure false
      Z 1 Antwort Letzte Antwort
      • Z Zuki
        Ich habe noch ein wenig mit dem Hostnamen probiert aber das scheint leider nicht das Kernproblem zu sein.
        Auch mit einem "legalen" Hostname bleibt das ioBroker Startup (Step 5) hängen.
        -----                Step 4 of 5: Applying special settings                -----
        Some adapters have special requirements/ settings which can be activated by the use of environment variables.
        For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
        Z-Wave is activated by ENV.
        Running setup script...
        [setup_zwave.sh] Openzwave is NOT installed. Going to install it now... Done.
        Done.
        -----                    Step 5 of 5: ioBroker startup                     -----
        Starting ioBroker...
        host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
        host.iobroker check instance "system.adapter.discovery.0" for host "iobroker"
        host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
        object system.meta.uuid created: dd8a9d53-2fb8-4053-bc5c-efe297ccf068
        hollywootH Offline
        hollywootH Offline
        hollywoot
        #2598
        @zuki
        Wie sieht deine compose aus?
        Und was sagt iobroker status?
        • GlasfaserG Glasfaser
          @zuki
          Z Offline
          Z Offline
          Zuki
          #2599
          @glasfaser sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
          @zuki
          Boah...
          :man-facepalming:
          Danke. Das ist das Problem wenn der Spaß einfach läuft und man nach Ewigkeiten mal wieder rum spielt ;-)
          Gut das es Hilfe in Foren gibt und das Internet nichts vergisst.
          • Z Zuki
            @zuki
            Boah...
            :man-facepalming:
            GlasfaserG Offline
            GlasfaserG Offline
            #2600
            Danke.
            Kein Thema ... ;)
            dein
            host.iobroker_productive
            kam mir bekannt vor ... deshalb konnte ich mich an den Thread erinnern :)
              Danke.
              Kein Thema ... ;)
              dein
              Telefisch
              #2601
              Hallo Forum,
              ich habe meinen ioB seit geraumer Zeit auf einer Synology mittels Docker laufen.
              Jetzt wollte ich eine MariaDB Datenbank hinzufügen, bekomme aber vom SQL Adapter immer nur unreachable.
              Ich gehe doch recht in der Annahme, dass ich bei Host die IP der Syno eingeben sollte?
              Der ioB läuft mit MACVLAN unter einer anderen IP, localhost ist damit dann ja raus…?
              Also Port hab ich verschiedene Ports probiert, witzigerweise war standard 3307 eingestellt, in alle tutorials heißt es immer 3306?
              Mit dem PHPmyadmin kann ich aus der Syno direkt auf die DB zugreifen.
              Einen eigenen user habe ich auch bereits probiert, genauso wie natürlich root.
              Also Eingaben wir folgt:
              DBTyp : MySQL
              Host: IP der Syno
              Port 3306, 3307 etc…
              Datenbankname wie unter myAdmin angelegt
              User und Passwort wie angelegt, alternativ root probiert
              Naja der Rest ist ja eh selbsterklärend.
              Fehler ist immer
              Error: connect EHOSTUNREACH IP-Adresse:Portnummer
              Synology DS916+ (Docker), 2x Echo, 2x Dot, 2x Show
              hollywootH andreA 2 Antworten Letzte Antwort
              • T Telefisch
                Hallo Forum,
                DBTyp : MySQL
                Host: IP der Syno
                Fehler ist immer
                hollywootH Offline
                hollywootH Offline
                hollywoot
                schrieb am zuletzt editiert von hollywoot
                #2602
                @telefisch
                Ich meine mich erinnern zu können, dass du aus dem macvlan den eigentlichen Host nicht erreichen kannst.
                Geh mal im iobroker auf die cli und versuche deine Syno zu pingen.
                Entweder nutzt du dann den Hackentrick (guck mal hier: https://www.synology-forum.de/threads/macvlan-zugriff-auf-den-host.103178/) , damit du den Host erreichen kannst oder aber du packst den iobroker und die mariadb in ein gemeinsames Docker-Network.
                • hollywootH hollywoot
                  @telefisch
                  Telefisch
                  #2603
                  @hollywoot
                  Danke für den Hinweis, ich kapiere es aber nicht.
                  ich muss also (sinnvollerweise über Portainer) eine bridge anlegen.
                  Host Adresse ist 192.168.178.2, Docker-ioBroker ist 192.168.178.4.
                  Was muss ich in dei drei Felder eintragen?
                  Hab gefühlt alle sinnvollen Kombinationen durch aber ich finde irgendwie keine Lösung.
                  hollywootH 1 Antwort Letzte Antwort
                  • T Telefisch
                    @hollywoot
                    hollywootH Offline
                    hollywootH Offline
                    hollywoot
                    #2604
                    @telefisch
                    Ich habe mir in auf der Syno ein Shell-Script gebaut und führe dies mit der Syno-Aufgabenplanung beim Boot aus.
                    Hier mal das Script:
                    #!/bin/sh
                    ip link add mynet-shim link eth0 type macvlan mode bridge
                    ip addr add <IP-für-die-Bridge>/32 dev mynet-shim
                    ip link set mynet-shim up
                    ip route add <Syno-IP>/32 dev mynet-shim
                      @telefisch
                      #!/bin/sh
                      Telefisch
                      schrieb am zuletzt editiert von Telefisch
                      #2605
                      @hollywoot
                      Danke für das Script aber wie muss denn die IP für die Bridge lauten?
                      Ist das dann eine bestimmte oder irgend eine aus dem IP-Kreis der Syno bzw. des Containers?
                      Ich checks einfach nicht.
                      Bei dem ganzen probieren hab ich mir natürlich direkt mal meine komplette ioB Installation gelöscht.
                      Das Restore dauert etwas…
                      • T Telefisch
                        @hollywoot
                        hollywootH Offline
                        hollywootH Offline
                        hollywoot
                        #2606
                        @telefisch
                        Wäre ja grundsätzlich nicht verkehrt wenn man wenigstens ein klitzekleines Bisschen versteht was man da tut 🙂
                        Wieso machst du es mit einem macvlan? Hau das Ding doch einfach stinknormal über die Host-IP rein...
                        Naja, sei es drum.
                        Nimm eine freie IP aus deinem Netzwerk. Die Syno ist dann ja quasi ebenfalls, zu Ihrer eigentlichen IP, über diese Bridge-IP zu erreichen. Das hat jetzt grundsätzlich erstmal wenig mit dem macvlan zu tun.
                        Deine bridge kriegt dann bspw die 192.168.178.200.
                        Nimm am besten eine IP, die nicht über den DHCP (deiner Fritzbox?!) vergeben werden könnte.
                        Oder schränk den DHCP Kreis der Fritze ein. ZB erst ab 50-199.
                        So hättest du alle IP bis zur 50 zur manuellen Vergabe offen.
                        Zum Thema Restore:
                        Jopp, kann dauern. Wobei dauern auch relativ ist.
                        Mit meiner sehr großen ioBroker Installation auf der Arbeit brauche ich für einen fullrestore etwa 30min.
                        • T Telefisch
                          Hallo Forum,
                          DBTyp : MySQL
                          Host: IP der Syno
                          Fehler ist immer
                          andreA Offline
                          andreA Offline
                          andre
                          #2607
                          @telefisch Ich gehe mal davon aus, deine MariaDB läuft auf der Synology und nicht als Docker Container.
                          Dein ioBroker wenn ich richtig verstanden habe, mit eigener IP im MACVLAN.
                          Problem: Du kannst aus dem Container heraus die DiskStation nicht erreichen.
                          Lösung: Dem ioBroker Container einfach das (oder ein eigenes) Bridge Netzwerk hinzufügen. Dann ist die DiskStation über das Gateway in diesem Netzwerk erreichbar:
                          Das ist m. E. der einfachste Weg. Natürlich kann (und sollte) man ein eigenes Bridge Netzwerk anlegen. Außerdem gibt es auch die Möglichkeit das Routing zu verbiegen...
                          MfG,
                          André
                          T 2 Antworten Letzte Antwort
                          • andreA andre
                            MfG,
                            André
                            Telefisch
                            #2608
                            @andre
                            ok, das Problem von grade eben wäre gelöst, hatte nen Tippfehler im Netzwerk.
                            Mit der Bridge probiere ich sobald iob wieder läuft.
                            Danke Euch erstmal für Euren Support.
                            • andreA andre
                              MfG,
                              André
                              Telefisch
                              #2609
                              @hollywoot Du hast Recht, ich bin strunzdoof...
                              Network Interface falsch geschrieben :man-facepalming:
                              • T Telefisch
                                hollywootH Offline
                                hollywootH Offline
                                hollywoot
                                #2610
                                @telefisch
                                ich habe niemals behauptet, Du wärest "strunzdoof" oder Ähnliches.
                                Würde ich auch nicht tun!
                                Ich stelle mir nur immer wieder bei solchen Problemen die Frage: Warum so kompliziert? Warum nicht über das Host-/Bridgenetzwerk einfach über die Syno ins Netz laufen lassen?
                                Und zu Deiner Lösung:
                                Manchmal sind's die kleinen Dinge :P
                                  @telefisch
                                  Telefisch
                                  #2611
                                  @hollywoot
                                  Naja
                                  „ Wäre ja grundsätzlich nicht verkehrt wenn man wenigstens ein klitzekleines Bisschen versteht was man da tut“
                                  ist aber schon sehr nah dran…
                                  Wenn ich überlege, dass ich seit über 25 Jahren Computer miteinander verbinde und meine zugegebenermaßen kleine Firma komplett allein adminsitriere, kann ich wohl mit fug und Recht behaupt zu wissen was ich tue.
                                  Aber man kann eben auch nicht alles wissen und manchmal hat man eben auch nen Brett vorm Kopp.
                                  So what,
                                  danke für Eure Geduld
                                    michisa86888
                                    #2612
                                    ich habe damals meine IoBroker Installation nicht ausserhalb vom Container eingereichtet.
                                    Also kein Host/volume eingerichtet. Dies würde ich aber gerne möglichst einfach ändern. Natürlich ohne eine komplette Neuinstallation machen zu müssen. Wie bekomme ich das am besten hin?
                                    Mein aktueller Pfad sieht so aus:
                                    Ich würde das gerne nach /volume1/docker/iobroker mounten.
                                    hollywootH R 2 Antworten Letzte Antwort
                                    • M michisa86888
                                      hollywootH Offline
                                      hollywootH Offline
                                      hollywoot
                                      #2613
                                      @michisa86888
                                      Am sichersten wäre die Backup/Restore Methode. Ist auch gleichzeitig die einfachste Variante :)
                                      • M michisa86888
                                        rewenode
                                        schrieb am zuletzt editiert von rewenode
                                        #2614
                                        @michisa86888 Du kannst doch das komplette /opt/iobroker vom Docker Volume in ein Host-Laufwerk kopieren. Dann das neue Hostverzeichnis bei der Containererstellung entsprechend mounten.
                                        Gib mal copy docker volume to host bei deiner Suchmaschine ein, da solltest du sofort fündig werden.
                                        Ich sehe gerade, hier wirst du auch fündig: https://forum.iobroker.net/post/880564
                                        • G Offline
                                          Grace13
                                          #2615
                                          Ich bin habe Probleme meine Shellys mit Mqtt mit dem Iobroker zu verbinden. Das ganze läuft in Docker auf einem Lenovo ThinkCenter.
                                          Netzwerkseitig hab ich ein Mikrotik hexS im Einsatz der mein Netz in VLAN unterteilt.
                                          Ich vermute eigentlich das es eher was mit dem Mikrotik, als Docker bzw Portainer zu tun hat. Bin aber etwas ratlos wo ich die Infos herbekomme..
