  3. Off Topic
  4. Grafana
  5. Grafana Installation - Fehler grafana-rpi:armhf
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
91 Beiträge 5 Kommentatoren 12.2k Aufrufe 4 Beobachtet
  • H heli-wolf
    nach dem ersten Befehl
    systemctl status grafana-server.service
    kam folgendes:
    Warning: The unit file, source configuration file or drop-ins of grafana-server>
    ● grafana-server.service - Grafana instance
         Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
         Active: failed (Result: signal) since Mon 2022-09-12 19:52:17 CEST; 1h 27m>
           Docs: http://docs.grafana.org
        Process: 15830 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --p>
       Main PID: 15830 (code=killed, signal=SYS)
            CPU: 68ms
    Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Scheduled restart >
    Sep 12 19:52:17 iobroker systemd[1]: Stopped Grafana instance.
    Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Start request repe>
    Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Failed with result>
    Sep 12 19:52:17 iobroker systemd[1]: Failed to start Grafana instance.
    iobroker@iobroker:~ $
    @heli-wolf
    Mach das Mäusekinofenster von puTTY mal breiter. Da fehlt die rechte Hälfte.
    Dann
    H 1 Antwort Letzte Antwort
      @heli-wolf
      Dann
      heli-wolf
      @thomas-braun said in Grafana Installation - Fehler grafana-rpi:armhf:
      iobroker@iobroker:~ $ systemctl status grafana-server.service
           Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
           Active: failed (Result: signal) since Mon 2022-09-12 19:52:17 CEST; 1h 31min ago
              CPU: 68ms
      Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
      Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Start request repeated too quickly.
      Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Failed with result 'signal'.
      • H heli-wolf
                CPU: 68ms
        @heli-wolf
        Boote die Kiste mal durch.
        sudo reboot
        Und dann nochmal
          @heli-wolf
          sudo reboot
          Und dann nochmal
          heli-wolf
               Active: active (running) since Mon 2022-09-12 21:26:33 CEST; 24s ago
             Main PID: 650 (grafana-server)
                Tasks: 15 (limit: 8986)
                  CPU: 2.987s
               CGroup: /system.slice/grafana-server.service
                       └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini ->
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-1>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=20>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=202>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmana>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T2>
          lines 1-20/20 (END)
                  CPU: 2.987s
                       └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gat>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=20>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="r>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starti>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finish>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for st>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server List>
          lines 1-20/20 (END)
                  CPU: 2.987s
                       └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/va>
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gateway initialization"
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=2022-09-12T21:26:50+02:00
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="registering usage stat providers" usageStatsProvidersLen=2
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path=/run/grafana/grafana-server.pid pid=650
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starting to provision alerting"
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finished to provision alerting"
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for startup"
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage starting"
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg="starting MultiOrg Alertmanager"
          Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
          lines 1-20/20 (END)
          • H heli-wolf
                    CPU: 2.987s
            lines 1-20/20 (END)
                    CPU: 2.987s
            lines 1-20/20 (END)
                    CPU: 2.987s
            lines 1-20/20 (END)
            @heli-wolf
            Läuft.
            sudo apt update
            um zu schauen ob apt/dpkg jetzt auch sauber ist.
              @heli-wolf
              Läuft.
              sudo apt update
              heli-wolf
              sudo apt update
              iobroker@iobroker:~ $ sudo apt update
              Hit:1 http://deb.debian.org/debian bullseye InRelease
              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 https://packages.grafana.com/oss/deb stable InRelease
              Hit:6 https://repos.influxdata.com/debian bullseye InRelease
              Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
              Reading package lists... Done
              All packages are up to date.
              • H heli-wolf
                sudo apt update
                @heli-wolf
                Gut.
                Und
                apt policy grafana*
                spuckt jetzt auch die Versionen aus den Repos aus und nicht mehr die .deb-Dateien?
                  @heli-wolf
                  Gut.
                  Und
                  apt policy grafana*
                  heli-wolf
                  apt policy grafana*
                  iobroker@iobroker:~ $ apt policy grafana*
                  N: Unable to locate package grafana_9.1.4_armhf.deb
                  N: Unable to locate package grafana-rpi_7.5.0_armhf.deb
                  N: Unable to locate package grafana-rpi_9.1.4_armhf.deb
                  • H heli-wolf
                    apt policy grafana*
                    @heli-wolf
                    Nochmal. Wo hast du die drei genannten Dateien her und wo hast du die abgelegt und wie hast du die installiert?
                      @heli-wolf
                      heli-wolf
                      Das war ein Onlinekurs von Stefan auf Verdrahtet.com
                      Die Installation war:
                      wget https://dl.grafana.com/oss/release/grafana-rpi_7.5.0_armhf.deb
                      sudo dpkg -i grafana-rpi_7.5.0_armhf.deb
                      sudo /bin/systemctl enable grafana-server
                      sudo /bin/systemctl start grafana-server
                      und die anderen Beiden habe ich von diversen Internetrecherchen ebenfalls versucht.
                      • H heli-wolf
                        #66
                        @heli-wolf
                        Mit Verlaub...
                        Ganz große Grütze wird da verzapft.
                        Dann leg dir die Datein nochmal genau dorthin wo sie zuerst waren.
                        Du hast die zwischenzeitlich gelöscht, vermute ich?
                          @heli-wolf
                          Mit Verlaub...
                          heli-wolf
                          #67
                          sollte ich die drei befehle nochmals ausführen?
                          sudo dpkg -i grafana-rpi_9.1.4_armhf.deb
                          den dritten weiß ich nicht mehr wo der her ist
                          • H heli-wolf
                            #68
                            @heli-wolf
                            NEIN!
                            -i bedeutet Installieren, das willst du ja gerade nicht.
                            dpkg -l grafana
                            dpkg -l grafana-rpi
                              @heli-wolf
                              NEIN!
                              dpkg -l grafana
                              dpkg -l grafana-rpi
                              heli-wolf
                              #69
                              iobroker@iobroker:~ $ dpkg -l grafana
                              Desired=Unknown/Install/Remove/Purge/Hold
                              | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
                              |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
                              ||/ Name           Version      Architecture Description
                              ii  grafana        9.1.4        arm64        Grafana
                              iobroker@iobroker:~ $ dpkg -l grafana-rpi
                              dpkg-query: no packages found matching grafana-rpi
                              • H heli-wolf
                                #70
                                @heli-wolf
                                Irgendwo hängt der .deb-Mist noch drin. Ich weiß nur nicht wo, weil man eigentlich nie Pakete auf diese Art installiert, man nutzt immer apt oder apt-get oder sonst einen 'intelligenten' Paketmanager, aber nicht dpkg.
                                Wenn du also nochmal irgendwo dpkg -i oder sowas lesen solltest: Mach die Seite gleich zu, ist zu 99% Quark.
                                sudo apt-get clean
                                versuchen.
                                  @heli-wolf
                                  sudo apt-get clean
                                  versuchen.
                                  heli-wolf
                                  #71
                                  iobroker@iobroker:~ $ sudo apt-get clean
                                  • H heli-wolf
                                    #72
                                    @heli-wolf
                                    Kommt jetzt bei
                                    apt policy grafana*
                                    was anderes als die drei gestrandeten deb-files?
                                      @heli-wolf
                                      Kommt jetzt bei
                                      apt policy grafana*
                                      heli-wolf
                                      #73
                                      apt policy grafana*
                                      • H heli-wolf
                                        apt policy grafana*
                                        #74
                                        @heli-wolf
                                        apt-cache showpkg grafana-rpi
                                          @heli-wolf
                                          heli-wolf
                                          #75
                                           Description Language:
                                                           File: /var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages
                                                            MD5: ae5be29cb6f62180c4b5d1500e319aca
                                          6.1.3 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                          6.1.2 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                          6.1.1 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                          6.1.0 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                          Reverse Depends:
                                          Dependencies:
                                          9.1.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null))
                                          7.4.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.3.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.3.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.3.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.3.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.2.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.2.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.2.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.1.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.1.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.1.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.1.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.1.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.1.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.0.6 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.0.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.0.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.0.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.0.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.0.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          7.0.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.7.6 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.7.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.7.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.7.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.7.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.7.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.6.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.6.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.6.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.5.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.5.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.5.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.5.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.4.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.4.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.4.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.4.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.4.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.4.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.3.7 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.3.6 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.3.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.3.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.3.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.3.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.3.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.3.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.2.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.2.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.2.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.2.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.2.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.2.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.1.6 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.1.5 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.1.4 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.1.3 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.1.2 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.1.1 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          6.1.0 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                          Provides:
                                          9.1.0 -
                                          7.4.0 -
                                          7.3.3 -
                                          7.3.2 -
                                          7.3.1 -
                                          7.3.0 -
                                          7.2.2 -
                                          7.2.1 -
                                          7.2.0 -
                                          7.1.5 -
                                          7.1.4 -
                                          7.1.3 -
                                          7.1.2 -
                                          7.1.1 -
                                          7.1.0 -
                                          7.0.6 -
                                          7.0.5 -
                                          7.0.4 -
                                          7.0.3 -
                                          7.0.2 -
                                          7.0.1 -
                                          7.0.0 -
                                          6.7.6 -
                                          6.7.4 -
                                          6.7.3 -
                                          6.7.2 -
                                          6.7.1 -
                                          6.7.0 -
                                          6.6.2 -
                                          6.6.1 -
                                          6.6.0 -
                                          6.5.3 -
                                          6.5.2 -
                                          6.5.1 -
                                          6.5.0 -
                                          6.4.5 -
                                          6.4.4 -
                                          6.4.3 -
                                          6.4.2 -
                                          6.4.1 -
                                          6.4.0 -
                                          6.3.7 -
                                          6.3.6 -
                                          6.3.5 -
                                          6.3.4 -
                                          6.3.3 -
                                          6.3.2 -
                                          6.3.1 -
                                          6.3.0 -
                                          6.2.5 -
                                          6.2.4 -
                                          6.2.3 -
                                          6.2.2 -
                                          6.2.1 -
                                          6.2.0 -
                                          6.1.6 -
                                          6.1.5 -
                                          6.1.4 -
                                          6.1.3 -
                                          6.1.2 -
                                          6.1.1 -
                                          6.1.0 -
                                          Reverse Provides:
                                          Hier wird mir gar nicht die gesamte Liste angezeigt.
