  3. Off Topic
  4. Grafana
  5. Grafana Installation - Fehler grafana-rpi:armhf
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
91 Beiträge 5 Kommentatoren 12.2k Aufrufe 4 Beobachtet
    @heli-wolf
    Boote die Kiste mal durch.
    sudo reboot
    Und dann nochmal
    systemctl status grafana-server.service
    heli-wolf
    @thomas-braun said in Grafana Installation - Fehler grafana-rpi:armhf:
    iobroker@iobroker:~ $ systemctl status grafana-server.service
    ● grafana-server.service - Grafana instance
         Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
         Active: active (running) since Mon 2022-09-12 21:26:33 CEST; 24s ago
           Docs: http://docs.grafana.org
       Main PID: 650 (grafana-server)
          Tasks: 15 (limit: 8986)
            CPU: 2.987s
         CGroup: /system.slice/grafana-server.service
                 └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini ->
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-1>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=20>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=202>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmana>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T2>
    lines 1-20/20 (END)
         Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
            CPU: 2.987s
                 └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gat>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=20>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="r>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starti>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finish>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for st>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server List>
    lines 1-20/20 (END)
            CPU: 2.987s
                 └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/va>
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gateway initialization"
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=2022-09-12T21:26:50+02:00
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="registering usage stat providers" usageStatsProvidersLen=2
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path=/run/grafana/grafana-server.pid pid=650
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starting to provision alerting"
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finished to provision alerting"
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for startup"
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage starting"
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg="starting MultiOrg Alertmanager"
    Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
    lines 1-20/20 (END)
    • H heli-wolf
              CPU: 2.987s
      lines 1-20/20 (END)
              CPU: 2.987s
      lines 1-20/20 (END)
              CPU: 2.987s
      lines 1-20/20 (END)
      @heli-wolf
      Läuft.
      sudo apt update
      um zu schauen ob apt/dpkg jetzt auch sauber ist.
      H 1 Antwort Letzte Antwort
        @heli-wolf
        Läuft.
        sudo apt update
        heli-wolf
        sudo apt update
        iobroker@iobroker:~ $ sudo apt update
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://packages.grafana.com/oss/deb stable InRelease
        Hit:6 https://repos.influxdata.com/debian bullseye InRelease
        Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
        Reading package lists... Done
        All packages are up to date.
        • H heli-wolf
          sudo apt update
          @heli-wolf
          Gut.
          Und
          apt policy grafana*
          spuckt jetzt auch die Versionen aus den Repos aus und nicht mehr die .deb-Dateien?
            @heli-wolf
            Gut.
            Und
            apt policy grafana*
            heli-wolf
            apt policy grafana*
            iobroker@iobroker:~ $ apt policy grafana*
            N: Unable to locate package grafana_9.1.4_armhf.deb
            N: Unable to locate package grafana-rpi_7.5.0_armhf.deb
            N: Unable to locate package grafana-rpi_9.1.4_armhf.deb
            • H heli-wolf
              apt policy grafana*
              @heli-wolf
              Nochmal. Wo hast du die drei genannten Dateien her und wo hast du die abgelegt und wie hast du die installiert?
                @heli-wolf
                heli-wolf
                Das war ein Onlinekurs von Stefan auf Verdrahtet.com
                Die Installation war:
                wget https://dl.grafana.com/oss/release/grafana-rpi_7.5.0_armhf.deb
                sudo dpkg -i grafana-rpi_7.5.0_armhf.deb
                sudo /bin/systemctl enable grafana-server
                sudo /bin/systemctl start grafana-server
                und die anderen Beiden habe ich von diversen Internetrecherchen ebenfalls versucht.
                • H heli-wolf
                  #66
                  @heli-wolf
                  Mit Verlaub...
                  Ganz große Grütze wird da verzapft.
                  Dann leg dir die Datein nochmal genau dorthin wo sie zuerst waren.
                  Du hast die zwischenzeitlich gelöscht, vermute ich?
                    @heli-wolf
                    Mit Verlaub...
                    heli-wolf
                    #67
                    sollte ich die drei befehle nochmals ausführen?
                    sudo dpkg -i grafana-rpi_9.1.4_armhf.deb
                    den dritten weiß ich nicht mehr wo der her ist
                    • H heli-wolf
                      #68
                      @heli-wolf
                      NEIN!
                      -i bedeutet Installieren, das willst du ja gerade nicht.
                      dpkg -l grafana
                      dpkg -l grafana-rpi
                        @heli-wolf
                        NEIN!
                        dpkg -l grafana
                        dpkg -l grafana-rpi
                        heli-wolf
                        #69
                        iobroker@iobroker:~ $ dpkg -l grafana
                        Desired=Unknown/Install/Remove/Purge/Hold
                        | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
                        |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
                        ||/ Name           Version      Architecture Description
                        ii  grafana        9.1.4        arm64        Grafana
                        iobroker@iobroker:~ $ dpkg -l grafana-rpi
                        dpkg-query: no packages found matching grafana-rpi
                        • H heli-wolf
                          #70
                          @heli-wolf
                          Irgendwo hängt der .deb-Mist noch drin. Ich weiß nur nicht wo, weil man eigentlich nie Pakete auf diese Art installiert, man nutzt immer apt oder apt-get oder sonst einen 'intelligenten' Paketmanager, aber nicht dpkg.
                          Wenn du also nochmal irgendwo dpkg -i oder sowas lesen solltest: Mach die Seite gleich zu, ist zu 99% Quark.
                          sudo apt-get clean
                          versuchen.
                            @heli-wolf
                            sudo apt-get clean
                            versuchen.
                            heli-wolf
                            #71
                            iobroker@iobroker:~ $ sudo apt-get clean
                            • H heli-wolf
                              #72
                              @heli-wolf
                              Kommt jetzt bei
                              apt policy grafana*
                              was anderes als die drei gestrandeten deb-files?
                                @heli-wolf
                                Kommt jetzt bei
                                apt policy grafana*
                                heli-wolf
                                #73
                                apt policy grafana*
                                • H heli-wolf
                                  apt policy grafana*
                                  #74
                                  @heli-wolf
                                  apt-cache showpkg grafana-rpi
                                    @heli-wolf
                                    heli-wolf
                                    #75
                                     Description Language:
                                                     File: /var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages
                                                      MD5: ae5be29cb6f62180c4b5d1500e319aca
                                    6.1.3 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                    6.1.2 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                    6.1.1 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                    6.1.0 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                    Reverse Depends:
                                    Dependencies:
                                    9.1.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null))
                                    7.4.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.3.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.3.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.3.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.3.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.2.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.2.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.2.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.1.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.1.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.1.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.1.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.1.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.1.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.0.6 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.0.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.0.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.0.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.0.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.0.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    7.0.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.7.6 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.7.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.7.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.7.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.7.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.7.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.6.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.6.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.6.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.5.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.5.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.5.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.5.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.4.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.4.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.4.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.4.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.4.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.4.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.3.7 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.3.6 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.3.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.3.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.3.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.3.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.3.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.3.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.2.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.2.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.2.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.2.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.2.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.2.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.1.6 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.1.5 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.1.4 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.1.3 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.1.2 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.1.1 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    6.1.0 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                    Provides:
                                    9.1.0 -
                                    7.4.0 -
                                    7.3.3 -
                                    7.3.2 -
                                    7.3.1 -
                                    7.3.0 -
                                    7.2.2 -
                                    7.2.1 -
                                    7.2.0 -
                                    7.1.5 -
                                    7.1.4 -
                                    7.1.3 -
                                    7.1.2 -
                                    7.1.1 -
                                    7.1.0 -
                                    7.0.6 -
                                    7.0.5 -
                                    7.0.4 -
                                    7.0.3 -
                                    7.0.2 -
                                    7.0.1 -
                                    7.0.0 -
                                    6.7.6 -
                                    6.7.4 -
                                    6.7.3 -
                                    6.7.2 -
                                    6.7.1 -
                                    6.7.0 -
                                    6.6.2 -
                                    6.6.1 -
                                    6.6.0 -
                                    6.5.3 -
                                    6.5.2 -
                                    6.5.1 -
                                    6.5.0 -
                                    6.4.5 -
                                    6.4.4 -
                                    6.4.3 -
                                    6.4.2 -
                                    6.4.1 -
                                    6.4.0 -
                                    6.3.7 -
                                    6.3.6 -
                                    6.3.5 -
                                    6.3.4 -
                                    6.3.3 -
                                    6.3.2 -
                                    6.3.1 -
                                    6.3.0 -
                                    6.2.5 -
                                    6.2.4 -
                                    6.2.3 -
                                    6.2.2 -
                                    6.2.1 -
                                    6.2.0 -
                                    6.1.6 -
                                    6.1.5 -
                                    6.1.4 -
                                    6.1.3 -
                                    6.1.2 -
                                    6.1.1 -
                                    6.1.0 -
                                    Reverse Provides:
                                    Hier wird mir gar nicht die gesamte Liste angezeigt.
                                    • H heli-wolf
                                      Reverse Depends:
                                      Dependencies:
                                      Provides:
                                      9.1.0 -
                                      7.4.0 -
                                      7.3.3 -
                                      7.3.2 -
                                      7.3.1 -
                                      7.3.0 -
                                      7.2.2 -
                                      7.2.1 -
                                      7.2.0 -
                                      7.1.5 -
                                      7.1.4 -
                                      7.1.3 -
                                      7.1.2 -
                                      7.1.1 -
                                      7.1.0 -
                                      7.0.6 -
                                      7.0.5 -
                                      7.0.4 -
                                      7.0.3 -
                                      7.0.2 -
                                      7.0.1 -
                                      7.0.0 -
                                      6.7.6 -
                                      6.7.4 -
                                      6.7.3 -
                                      6.7.2 -
                                      6.7.1 -
                                      6.7.0 -
                                      6.6.2 -
                                      6.6.1 -
                                      6.6.0 -
                                      6.5.3 -
                                      6.5.2 -
                                      6.5.1 -
                                      6.5.0 -
                                      6.4.5 -
                                      6.4.4 -
                                      6.4.3 -
                                      6.4.2 -
                                      6.4.1 -
                                      6.4.0 -
                                      6.3.7 -
                                      6.3.6 -
                                      6.3.5 -
                                      6.3.4 -
                                      6.3.3 -
                                      6.3.2 -
                                      6.3.1 -
                                      6.3.0 -
                                      6.2.5 -
                                      6.2.4 -
                                      6.2.3 -
                                      6.2.2 -
                                      6.2.1 -
                                      6.2.0 -
                                      6.1.6 -
                                      6.1.5 -
                                      6.1.4 -
                                      6.1.3 -
                                      6.1.2 -
                                      6.1.1 -
                                      6.1.0 -
                                      Reverse Provides:
                                      #76
                                      @heli-wolf
                                      Frag den verdrahtet-Typen, wie man das sauber bekommt.
                                      Wobei... Besser nicht. Nachher kommt da noch mehr Murks bei herum.
                                        @heli-wolf
                                        heli-wolf
                                        #77
                                        den habe ich mit meinem Problem schon kontaktiert. Seither höre und lese ich nichts mehr von ihm.
                                        • H heli-wolf
                                          #78
                                          @heli-wolf
                                          apt policy grafana
