  3. Off Topic
  4. Grafana
  5. Grafana Installation - Fehler grafana-rpi:armhf
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
91 Beiträge 5 Kommentatoren 12.2k Aufrufe 4 Beobachtet
    @heli-wolf sagte in Grafana Installation - Fehler grafana-rpi:armhf:
    sudo apt install grafana
    sudo apt autoremove
    heli-wolf
    @thomas-braun said in Grafana Installation - Fehler grafana-rpi:armhf:
    sudo apt autoremove
    iobroker@iobroker:~ $ sudo apt install grafana
    Reading package lists... Done
    The following packages were automatically installed and are no longer required:
      libbrotli1:armhf libexpat1:armhf libfontconfig1:armhf libfreetype6:armhf
      libpng16-16:armhf libuuid1:armhf zlib1g:armhf
    Use 'sudo apt autoremove' to remove them.
    The following NEW packages will be installed:
      grafana
    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
    Need to get 0 B/76.8 MB of archives.
    After this operation, 271 MB of additional disk space will be used.
    (Reading database ... 47950 files and directories currently installed.)
    Preparing to unpack .../grafana_9.1.4_arm64.deb ...
    Unpacking grafana (9.1.4) ...
    Setting up grafana (9.1.4) ...
    ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
     sudo /bin/systemctl daemon-reload
     sudo /bin/systemctl enable grafana-server
    ### You can start grafana-server by executing
     sudo /bin/systemctl start grafana-server
    iobroker@iobroker:~ $ sudo apt autoremove
    The following packages will be REMOVED:
    0 upgraded, 0 newly installed, 7 to remove and 0 not upgraded.
    After this operation, 2,598 kB disk space will be freed.
    Do you want to continue? [Y/n] y
    (Reading database ... 54954 files and directories currently installed.)
    Removing libfontconfig1:armhf (2.13.1-4.2) ...
    Removing libfreetype6:armhf (2.10.4+dfsg-1+deb11u1) ...
    Removing libbrotli1:armhf (1.0.9-2+b2) ...
    Removing libexpat1:armhf (2.2.10-2+deb11u3) ...
    Removing libpng16-16:armhf (1.6.37-3) ...
    Removing libuuid1:armhf (2.36.1-8+deb11u1) ...
    Removing zlib1g:armhf (1:1.2.11.dfsg-2+deb11u2) ...
    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u4) ...
    • H heli-wolf
      sudo apt autoremove
        grafana
      systemctl status grafana-server.service
      sudo systemctl daemon-reload
      sudo systemctl enable grafana-server
      H 1 Antwort Letzte Antwort
        heli-wolf
        nach dem ersten Befehl
        kam folgendes:
        Warning: The unit file, source configuration file or drop-ins of grafana-server>
        ● grafana-server.service - Grafana instance
             Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
             Active: failed (Result: signal) since Mon 2022-09-12 19:52:17 CEST; 1h 27m>
               Docs: http://docs.grafana.org
            Process: 15830 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --p>
           Main PID: 15830 (code=killed, signal=SYS)
                CPU: 68ms
        Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Scheduled restart >
        Sep 12 19:52:17 iobroker systemd[1]: Stopped Grafana instance.
        Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Start request repe>
        Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Failed with result>
        Sep 12 19:52:17 iobroker systemd[1]: Failed to start Grafana instance.
        H Thomas BraunT 2 Antworten Letzte Antwort
        • H heli-wolf
          kam folgendes:
                  CPU: 68ms
          heli-wolf
          @heli-wolf
          rest lief ohne Probleme:
          iobroker@iobroker:~ $ sudo systemctl daemon-reload
          [sudo] password for iobroker:
          iobroker@iobroker:~ $ sudo systemctl enable grafana-server
          Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
          Executing: /lib/systemd/systemd-sysv-install enable grafana-server
          • H heli-wolf
            kam folgendes:
                    CPU: 68ms
            @heli-wolf
            Mach das Mäusekinofenster von puTTY mal breiter. Da fehlt die rechte Hälfte.
            Dann
              @heli-wolf
              Dann
              heli-wolf
              iobroker@iobroker:~ $ systemctl status grafana-server.service
                   Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
                   Active: failed (Result: signal) since Mon 2022-09-12 19:52:17 CEST; 1h 31min ago
                      CPU: 68ms
              Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
              Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Start request repeated too quickly.
              Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Failed with result 'signal'.
              • H heli-wolf
                        CPU: 68ms
                @heli-wolf
                Boote die Kiste mal durch.
                sudo reboot
                Und dann nochmal
                  @heli-wolf
                  sudo reboot
                  Und dann nochmal
                  heli-wolf
                       Active: active (running) since Mon 2022-09-12 21:26:33 CEST; 24s ago
                     Main PID: 650 (grafana-server)
                        Tasks: 15 (limit: 8986)
                          CPU: 2.987s
                       CGroup: /system.slice/grafana-server.service
                               └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini ->
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-1>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=20>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=202>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmana>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T2>
                  lines 1-20/20 (END)
                          CPU: 2.987s
                               └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gat>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=20>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="r>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starti>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finish>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for st>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server List>
                  lines 1-20/20 (END)
                          CPU: 2.987s
                               └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/va>
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gateway initialization"
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=2022-09-12T21:26:50+02:00
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="registering usage stat providers" usageStatsProvidersLen=2
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path=/run/grafana/grafana-server.pid pid=650
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starting to provision alerting"
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finished to provision alerting"
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for startup"
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage starting"
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg="starting MultiOrg Alertmanager"
                  Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
                  lines 1-20/20 (END)
                  • H heli-wolf
                            CPU: 2.987s
                    lines 1-20/20 (END)
                            CPU: 2.987s
                    lines 1-20/20 (END)
                            CPU: 2.987s
                    lines 1-20/20 (END)
                    @heli-wolf
                    Läuft.
                    sudo apt update
                    um zu schauen ob apt/dpkg jetzt auch sauber ist.
                      @heli-wolf
                      Läuft.
                      sudo apt update
                      heli-wolf
                      sudo apt update
                      iobroker@iobroker:~ $ sudo apt update
                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                      Hit:6 https://repos.influxdata.com/debian bullseye InRelease
                      Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                      All packages are up to date.
                      • H heli-wolf
                        sudo apt update
                        @heli-wolf
                        Gut.
                        Und
                        apt policy grafana*
                        spuckt jetzt auch die Versionen aus den Repos aus und nicht mehr die .deb-Dateien?
                          @heli-wolf
                          Gut.
                          Und
                          apt policy grafana*
                          heli-wolf
                          apt policy grafana*
                          iobroker@iobroker:~ $ apt policy grafana*
                          N: Unable to locate package grafana_9.1.4_armhf.deb
                          N: Unable to locate package grafana-rpi_7.5.0_armhf.deb
                          N: Unable to locate package grafana-rpi_9.1.4_armhf.deb
                          • H heli-wolf
                            apt policy grafana*
                            @heli-wolf
                            Nochmal. Wo hast du die drei genannten Dateien her und wo hast du die abgelegt und wie hast du die installiert?
                              @heli-wolf
                              heli-wolf
                              Das war ein Onlinekurs von Stefan auf Verdrahtet.com
                              Die Installation war:
                              wget https://dl.grafana.com/oss/release/grafana-rpi_7.5.0_armhf.deb
                              sudo dpkg -i grafana-rpi_7.5.0_armhf.deb
                              und die anderen Beiden habe ich von diversen Internetrecherchen ebenfalls versucht.
                              • H heli-wolf
                                #66
                                @heli-wolf
                                Mit Verlaub...
                                Ganz große Grütze wird da verzapft.
                                Dann leg dir die Datein nochmal genau dorthin wo sie zuerst waren.
                                Du hast die zwischenzeitlich gelöscht, vermute ich?
                                  @heli-wolf
                                  Mit Verlaub...
                                  heli-wolf
                                  #67
                                  sollte ich die drei befehle nochmals ausführen?
                                  sudo dpkg -i grafana-rpi_9.1.4_armhf.deb
                                  den dritten weiß ich nicht mehr wo der her ist
                                  • H heli-wolf
                                    #68
                                    @heli-wolf
                                    NEIN!
                                    -i bedeutet Installieren, das willst du ja gerade nicht.
                                    dpkg -l grafana
                                    dpkg -l grafana-rpi
                                      @heli-wolf
                                      NEIN!
                                      dpkg -l grafana
                                      dpkg -l grafana-rpi
                                      heli-wolf
                                      #69
                                      iobroker@iobroker:~ $ dpkg -l grafana
                                      Desired=Unknown/Install/Remove/Purge/Hold
                                      | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
                                      |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
                                      ||/ Name           Version      Architecture Description
                                      ii  grafana        9.1.4        arm64        Grafana
                                      iobroker@iobroker:~ $ dpkg -l grafana-rpi
                                      dpkg-query: no packages found matching grafana-rpi
                                      • H heli-wolf
                                        #70
                                        @heli-wolf
                                        Irgendwo hängt der .deb-Mist noch drin. Ich weiß nur nicht wo, weil man eigentlich nie Pakete auf diese Art installiert, man nutzt immer apt oder apt-get oder sonst einen 'intelligenten' Paketmanager, aber nicht dpkg.
                                        Wenn du also nochmal irgendwo dpkg -i oder sowas lesen solltest: Mach die Seite gleich zu, ist zu 99% Quark.
                                        sudo apt-get clean
                                        versuchen.
                                          @heli-wolf
                                          sudo apt-get clean
                                          versuchen.
                                          heli-wolf
                                          #71
                                          iobroker@iobroker:~ $ sudo apt-get clean
