  3. Off Topic
  4. Grafana
  5. Grafana Installation - Fehler grafana-rpi:armhf
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
91 Beiträge 5 Kommentatoren 12.2k Aufrufe 4 Beobachtet
    @heli-wolf
    apt install grafana-rpi --dry-run
    heli-wolf
    @thomas-braun said in Grafana Installation - Fehler grafana-rpi:armhf:
    iobroker@iobroker:~ $ apt install grafana-rpi --dry-run
    NOTE: This is only a simulation!
          apt needs root privileges for real execution.
          Keep also in mind that locking is deactivated,
          so don't depend on the relevance to the real current situation!
    Reading package lists... Done
    The following NEW packages will be installed:
      grafana-rpi:armhf
    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
    Inst grafana-rpi:armhf (9.1.0 grafana stable:stable [armhf])
    Conf grafana-rpi:armhf (9.1.0 grafana stable:stable [armhf])
    • H heli-wolf
        grafana-rpi:armhf
      @heli-wolf
      .k
      apt install grafana --dry-run
      H 1 Antwort Letzte Antwort
        @heli-wolf
        .k
        heli-wolf
        iobroker@iobroker:~ $ apt install grafana --dry-run
        The following packages were automatically installed and are no longer required:
          libbrotli1:armhf libexpat1:armhf libfontconfig1:armhf libfreetype6:armhf
          libpng16-16:armhf libuuid1:armhf zlib1g:armhf
        Use 'apt autoremove' to remove them.
          grafana
        Inst grafana (9.1.4 grafana stable:stable [arm64])
        Conf grafana (9.1.4 grafana stable:stable [arm64])
        • H heli-wolf
            grafana
          @heli-wolf sagte in Grafana Installation - Fehler grafana-rpi:armhf:
          sudo apt install grafana
          sudo apt autoremove
            sudo apt autoremove
            heli-wolf
            sudo apt autoremove
            iobroker@iobroker:~ $ sudo apt install grafana
            Use 'sudo apt autoremove' to remove them.
              grafana
            Need to get 0 B/76.8 MB of archives.
            After this operation, 271 MB of additional disk space will be used.
            (Reading database ... 47950 files and directories currently installed.)
            Preparing to unpack .../grafana_9.1.4_arm64.deb ...
            Unpacking grafana (9.1.4) ...
            Setting up grafana (9.1.4) ...
            ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
             sudo /bin/systemctl daemon-reload
             sudo /bin/systemctl enable grafana-server
            ### You can start grafana-server by executing
             sudo /bin/systemctl start grafana-server
            iobroker@iobroker:~ $ sudo apt autoremove
            The following packages will be REMOVED:
            0 upgraded, 0 newly installed, 7 to remove and 0 not upgraded.
            After this operation, 2,598 kB disk space will be freed.
            Do you want to continue? [Y/n] y
            (Reading database ... 54954 files and directories currently installed.)
            Removing libfontconfig1:armhf (2.13.1-4.2) ...
            Removing libfreetype6:armhf (2.10.4+dfsg-1+deb11u1) ...
            Removing libbrotli1:armhf (1.0.9-2+b2) ...
            Removing libexpat1:armhf (2.2.10-2+deb11u3) ...
            Removing libpng16-16:armhf (1.6.37-3) ...
            Removing libuuid1:armhf (2.36.1-8+deb11u1) ...
            Removing zlib1g:armhf (1:1.2.11.dfsg-2+deb11u2) ...
            Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u4) ...
            • H heli-wolf
              sudo apt autoremove
                grafana
              systemctl status grafana-server.service
              sudo systemctl daemon-reload
              sudo systemctl enable grafana-server
                heli-wolf
                nach dem ersten Befehl
                kam folgendes:
                Warning: The unit file, source configuration file or drop-ins of grafana-server>
                ● grafana-server.service - Grafana instance
                     Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
                     Active: failed (Result: signal) since Mon 2022-09-12 19:52:17 CEST; 1h 27m>
                       Docs: http://docs.grafana.org
                    Process: 15830 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --p>
                   Main PID: 15830 (code=killed, signal=SYS)
                        CPU: 68ms
                Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Scheduled restart >
                Sep 12 19:52:17 iobroker systemd[1]: Stopped Grafana instance.
                Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Start request repe>
                Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Failed with result>
                Sep 12 19:52:17 iobroker systemd[1]: Failed to start Grafana instance.
                H Thomas BraunT 2 Antworten Letzte Antwort
                • H heli-wolf
                  kam folgendes:
                          CPU: 68ms
                  heli-wolf
                  @heli-wolf
                  rest lief ohne Probleme:
                  iobroker@iobroker:~ $ sudo systemctl daemon-reload
                  [sudo] password for iobroker:
                  iobroker@iobroker:~ $ sudo systemctl enable grafana-server
                  Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
                  Executing: /lib/systemd/systemd-sysv-install enable grafana-server
                  • H heli-wolf
                    kam folgendes:
                            CPU: 68ms
                    @heli-wolf
                    Mach das Mäusekinofenster von puTTY mal breiter. Da fehlt die rechte Hälfte.
                    Dann
                      @heli-wolf
                      Dann
                      heli-wolf
                      iobroker@iobroker:~ $ systemctl status grafana-server.service
                           Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
                           Active: failed (Result: signal) since Mon 2022-09-12 19:52:17 CEST; 1h 31min ago
                              CPU: 68ms
                      Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
                      Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Start request repeated too quickly.
                      Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Failed with result 'signal'.
                      • H heli-wolf
                                CPU: 68ms
                        @heli-wolf
                        Boote die Kiste mal durch.
                        sudo reboot
                        Und dann nochmal
                          @heli-wolf
                          sudo reboot
                          Und dann nochmal
                          heli-wolf
                               Active: active (running) since Mon 2022-09-12 21:26:33 CEST; 24s ago
                             Main PID: 650 (grafana-server)
                                Tasks: 15 (limit: 8986)
                                  CPU: 2.987s
                               CGroup: /system.slice/grafana-server.service
                                       └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini ->
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-1>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=20>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=202>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmana>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T2>
                          lines 1-20/20 (END)
                                  CPU: 2.987s
                                       └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gat>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=20>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="r>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starti>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finish>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for st>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server List>
                          lines 1-20/20 (END)
                                  CPU: 2.987s
                                       └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/va>
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gateway initialization"
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=2022-09-12T21:26:50+02:00
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="registering usage stat providers" usageStatsProvidersLen=2
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path=/run/grafana/grafana-server.pid pid=650
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starting to provision alerting"
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finished to provision alerting"
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for startup"
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage starting"
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg="starting MultiOrg Alertmanager"
                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
                          lines 1-20/20 (END)
                          • H heli-wolf
                                    CPU: 2.987s
                            lines 1-20/20 (END)
                                    CPU: 2.987s
                            lines 1-20/20 (END)
                                    CPU: 2.987s
                            lines 1-20/20 (END)
                            @heli-wolf
                            Läuft.
                            sudo apt update
                            um zu schauen ob apt/dpkg jetzt auch sauber ist.
                              @heli-wolf
                              Läuft.
                              sudo apt update
                              heli-wolf
                              sudo apt update
                              iobroker@iobroker:~ $ sudo apt update
                              Hit:1 http://deb.debian.org/debian bullseye InRelease
                              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                              Hit:6 https://repos.influxdata.com/debian bullseye InRelease
                              Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                              All packages are up to date.
                              • H heli-wolf
                                sudo apt update
                                @heli-wolf
                                Gut.
                                Und
                                apt policy grafana*
                                spuckt jetzt auch die Versionen aus den Repos aus und nicht mehr die .deb-Dateien?
                                  @heli-wolf
                                  Gut.
                                  Und
                                  apt policy grafana*
                                  heli-wolf
                                  apt policy grafana*
                                  iobroker@iobroker:~ $ apt policy grafana*
                                  N: Unable to locate package grafana_9.1.4_armhf.deb
                                  N: Unable to locate package grafana-rpi_7.5.0_armhf.deb
                                  N: Unable to locate package grafana-rpi_9.1.4_armhf.deb
                                  • H heli-wolf
                                    apt policy grafana*
                                    @heli-wolf
                                    Nochmal. Wo hast du die drei genannten Dateien her und wo hast du die abgelegt und wie hast du die installiert?
                                      @heli-wolf
                                      heli-wolf
                                      Das war ein Onlinekurs von Stefan auf Verdrahtet.com
                                      Die Installation war:
                                      wget https://dl.grafana.com/oss/release/grafana-rpi_7.5.0_armhf.deb
                                      sudo dpkg -i grafana-rpi_7.5.0_armhf.deb
                                      und die anderen Beiden habe ich von diversen Internetrecherchen ebenfalls versucht.
                                      • H heli-wolf
                                        #66
                                        @heli-wolf
                                        Mit Verlaub...
                                        Ganz große Grütze wird da verzapft.
                                        Dann leg dir die Datein nochmal genau dorthin wo sie zuerst waren.
                                        Du hast die zwischenzeitlich gelöscht, vermute ich?
                                          @heli-wolf
                                          Mit Verlaub...
                                          heli-wolf
                                          #67
                                          sollte ich die drei befehle nochmals ausführen?
                                          sudo dpkg -i grafana-rpi_9.1.4_armhf.deb
                                          den dritten weiß ich nicht mehr wo der her ist
