  4. ESPhome: Gerät online im Adapter, aber nicht als Datenpunkt
    5.8k
19 Beiträge 3 Kommentatoren 964 Aufrufe 3 Beobachtet
    @roelli
    Zeig doch mal bitte was bei EDIT drin steht.
    Roelli
    @noah3112
    Gerne:
    esphome:
    esp8266:
      board: esp01_1m
    # Enable logging
    logger:
    # Enable Home Assistant API
    api:
    ota:
      password: "7760e54b97ffe17d3962f019cf3c2ec5"
    wifi:
      ssid: !secret wifi_ssid
      password: !secret wifi_password
      # Enable fallback hotspot (captive portal) in case wifi connection fails
      ap:
        ssid: "Mmwave Fallback Hotspot"
        password: "JqxV1HsoRIC3"
    substitutions:
      device_name: mmwave-sensor
    captive_portal:
    web_server:
      port: 80
      version: 2
      include_internal: true
    http_request:
      useragent: esphome/$device_name
      timeout: 2s
    switch:
      - platform: safe_mode
        internal: true
    binary_sensor:
    - platform: gpio
      pin:
        number: GPIO16
        mode: INPUT_PULLDOWN
    uart:
      tx_pin: GPIO4
      rx_pin: GPIO5
      baud_rate: 115200
      debug:
        direction: BOTH
        dummy_receiver: true
        after:
          delimiter: "\n"
        sequence:
          - lambda: UARTDebug::log_string(direction, bytes);
    number:
      - platform: template
        min_value: 0
        max_value: 1350
        initial_value: 315
        optimistic: true
        step: 15
        restore_value: true
        unit_of_measurement: cm
        set_action:
          - uart.write: "sensorStop"
          - delay: 1s
          - uart.write: !lambda
                          int cm = (int)ceil(x / 15.0);
                          std::string cms = "detRangeCfg -1 0 " + to_string(cm);
                          return std::vector<unsigned char>(cms.begin(), cms.end());
          - delay: 1s
          - uart.write: "saveCfg 0x45670123 0xCDEF89AB 0x956128C6 0xDF54AC89"
          - delay: 1s
          - uart.write: "sensorStart"
        min_value: 0
        max_value: 65000
        initial_value: 12500
        optimistic: true
        step: 25
        restore_value: true
        unit_of_measurement: ms
        set_action:
          - delay: 1s
                          int ms = (int)ceil(x / 25.0);
                          std::string mss = "outputLatency -1 0 " + to_string(ms);
                          return std::vector<unsigned char>(mss.begin(), mss.end());
          - delay: 1s
          - delay: 1s
    button:
      - platform: restart
        name: Restart $device_name
        on_press:
          - delay: 1s
          - uart.write: "factoryReset 0x45670123 0xCDEF89AB 0x956128C6 0xDF54AC89"
          - delay: 3s
    NUC6i7KYK M.2 32GB RAM mit Proxmox
    14 AccessPoints, 5 Switches 115 Adapter, 67913 Objekte, 57954 Zustände,126x Shelly, 26 Thermostate, Fire Tablets, DMX, USV, 18x echodot, 9xKlima, 4x heizung, beamer, 6x IP Speed dome, AiOnTheEdge, Tasmota Wemos, Fingerabdrucksensoren, VOIP TFE, Türsteuerung, BMZ,EMA
    R ? 2 Antworten Letzte Antwort
    • R Roelli
      @noah3112
      Gerne:
      esphome:
      esp8266:
        board: esp01_1m
      # Enable logging
      logger:
      api:
      ota:
      wifi:
        ap:
      substitutions:
      captive_portal:
      web_server:
        port: 80
        version: 2
      http_request:
        timeout: 2s
      switch:
          internal: true
      binary_sensor:
      - platform: gpio
        pin:
          number: GPIO16
      uart:
        tx_pin: GPIO4
        rx_pin: GPIO5
        baud_rate: 115200
        debug:
          direction: BOTH
          after:
            delimiter: "\n"
          sequence:
      number:
          min_value: 0
          max_value: 1350
          initial_value: 315
          optimistic: true
          step: 15
          restore_value: true
          set_action:
            - delay: 1s
            - delay: 1s
            - delay: 1s
          min_value: 0
          max_value: 65000
          optimistic: true
          step: 25
          restore_value: true
          set_action:
            - delay: 1s
            - delay: 1s
            - delay: 1s
      button:
        - platform: restart
          on_press:
            - delay: 1s
            - delay: 3s
      Roelli
      Iobroker Log schreibt noch folgendes:
      ESPHome client 192.168.1.123 TypeError: Cannot read properties of undefined (reading 'deserializeBinary')
      draexlerD 1 Antwort Letzte Antwort
      • R Roelli
        draexlerD Offline
        draexlerD Offline
        draexler
        @roelli Du darfst keinen „Button“ verwenden. Das wird noch nicht unterstützt. Muss einen „Switch“ verwenden. Der triggert dann kurz auf true und geht dann wieder auf false.
        • R Roelli
          @noah3112
          Gerne:
          esphome:
          esp8266:
            board: esp01_1m
          # Enable logging
          logger:
          api:
          ota:
          wifi:
            ap:
          substitutions:
          captive_portal:
          web_server:
            port: 80
            version: 2
          http_request:
            timeout: 2s
          switch:
              internal: true
          binary_sensor:
          - platform: gpio
            pin:
              number: GPIO16
          uart:
            tx_pin: GPIO4
            rx_pin: GPIO5
            baud_rate: 115200
            debug:
              direction: BOTH
              after:
                delimiter: "\n"
              sequence:
          number:
              min_value: 0
              max_value: 1350
              initial_value: 315
              optimistic: true
              step: 15
              restore_value: true
              set_action:
                - delay: 1s
                - delay: 1s
                - delay: 1s
              min_value: 0
              max_value: 65000
              optimistic: true
              step: 25
              restore_value: true
              set_action:
                - delay: 1s
                - delay: 1s
                - delay: 1s
          button:
            - platform: restart
              on_press:
                - delay: 1s
                - delay: 3s
          @roelli sagte in ESPhome: Gerät online im Adapter, aber nicht als Datenpunkt:
          binary_sensor:
          • platform: gpio
            pin:
            number: GPIO16
          Hier stimmt die Formatierung nicht ganz, aber das sollte der Editor eigentlich anmeckern. Das mit dem Soft Button sollte eigentlich passen. Ist das File selbst erstellt oder Copy Paste?
          R 1 Antwort Letzte Antwort
            binary_sensor:
            • platform: gpio
              pin:
              number: GPIO16
            Roelli
            @noah3112 sagte in ESPhome: Gerät online im Adapter, aber nicht als Datenpunkt:
            Hab ich hier geklaut: https://gist.github.com/EverythingSmartHome/4f8c9d8e94bffb44c7b7965f172b6470
            Weil ich diesen Radarsensor benutzen will: https://www.youtube.com/watch?v=VEqWlOeJ2YA
            Ich habe allerdings immer noch nicht verstanden was ich tun muss damit's funktioniert?
            Was muss man denn ändern?
            binary_sensor:
            - platform: gpio
              pin:
                number: GPIO16
            (ich hab mal rumgepfuscht und Sachen aus'm Netz da eingebaut, aber dann kommt bei der Prüfung schon eine Fehlermeldung)
            draexlerD ? 2 Antworten Letzte Antwort
            • R Roelli
              binary_sensor:
              - platform: gpio
                pin:
                  number: GPIO16
              draexlerD Offline
              draexlerD Offline
              draexler
              @roelli entfern mal den ganzen Letzten Teil „Button“ und schau ob zumindest dann die Fehlermeldung im Log weg ist.
              • draexlerD draexler
                Roelli
                @draexler Fehlermeldung im LOG von iobroker bleibt. (hatte alles hinter dem Button gelöscht)
                • R Roelli
                  binary_sensor:
                  - platform: gpio
                    pin:
                      number: GPIO16
                  @roelli Die Leerzeichen sind bei YAML sehr wichtig bzw müssen eingehalten werden.
                  binary_sensor:
                    - platform: gpio
                      pin:
                        number: D3
                        inverted: true
                        mode:
                          input: true
                          pullup: true
                  Hier mal ein Beispiel das muss bei dir noch korrigiert werden.
                  • R Roelli
                    @roelli Wie gesagt das mit dem Button sollte funktionieren. Hatte auch schon einen Soft Reset im Einsatz finde das Beispiel leider gerade nicht.
                      Roelli
                      schrieb am zuletzt editiert von Roelli
                      @noah3112
                      Hier meckert er noch:
                      • R Roelli
                        @noah3112
                        @roelli Das ist wiederum von deinem eingesetzten Board abhängig. In dem Beispiel was ich dir geschickt habe war ein D1 mini im Einsatz...
                        esp8266:
                          board: d1_mini
                        Bei dir ist es anscheinend ein esp1!?
                        Da gibt es den Pin D3 nicht bzw kann nicht genutzt werden.
                          esp8266:
                            board: d1_mini
                          Roelli
                          @noah3112
                          Ich hab den wemos D1 mini.
                          Der Eingang ist definitiv D0.
                          (Laut Pinout vom wemos D1 mini ist D0 auch gleichzeitig Pin4, oder GPIO16)
                          • R Roelli
                            @noah3112
                            @roelli Was mir noch aufgefallen ist. Ich hatte das nur als Beispiel für die Formatierung, das passt also so überhaupt nicht für deine Anwendung. Hier wird ein GPIO Hardware Anschluss genutzt für einen Taster der an Pin D3 hängt. In deinem "Programm" ist es ein Software Button. Also nicht für dein Projekt übernehmen.
                            • R Roelli
                              @noah3112
                              @roelli Aber dann stimmt doch hier schon etwas nicht...
                              esphome:
                              esp8266:
                                board: esp01_1m
                                esphome:
                                esp8266:
                                  board: esp01_1m
                                Roelli
                                @noah3112
                                Ha! Wenn man die richtige Hardware einstellt, dann geht das Ding sogar online!
                                Einen Schritt weiter! 👍
                                Nur der interessante "true/false" Wert wird noch nicht angezeigt. 😕
                                esphome:
                                esp8266:
                                  board: d1_mini
                                # Enable logging
                                logger:
                                api:
                                ota:
                                wifi:
                                  ap:
                                substitutions:
                                captive_portal:
                                web_server:
                                  port: 80
                                  version: 2
                                http_request:
                                  timeout: 2s
                                switch:
                                    internal: true
                                binary_sensor:
                                - platform: gpio
                                  pin:
                                    number: GPIO16
                                uart:
                                  tx_pin: GPIO4
                                  rx_pin: GPIO5
                                  baud_rate: 115200
                                  debug:
                                    direction: BOTH
                                    after:
                                      delimiter: "\n"
                                    sequence:
                                number:
                                    min_value: 0
                                    max_value: 1350
                                    initial_value: 315
                                    optimistic: true
                                    step: 15
                                    restore_value: true
                                    set_action:
                                      - delay: 1s
                                      - delay: 1s
                                      - delay: 1s
                                    min_value: 0
                                    max_value: 65000
                                    optimistic: true
                                    step: 25
                                    restore_value: true
                                    set_action:
                                      - delay: 1s
                                      - delay: 1s
                                      - delay: 1s
                                button:
                                  - platform: restart
                                    on_press:
                                      - delay: 1s
                                      - delay: 3s
                                • R Roelli
                                  @noah3112
                                  esphome:
                                  esp8266:
                                    board: d1_mini
                                  # Enable logging
                                  logger:
                                  api:
                                  ota:
                                  wifi:
                                    ap:
                                  substitutions:
                                  captive_portal:
                                  web_server:
                                    port: 80
                                    version: 2
                                  http_request:
                                    timeout: 2s
                                  switch:
                                      internal: true
                                  binary_sensor:
                                  - platform: gpio
                                    pin:
                                      number: GPIO16
                                  uart:
                                    tx_pin: GPIO4
                                    rx_pin: GPIO5
                                    baud_rate: 115200
                                    debug:
                                      direction: BOTH
                                      after:
                                        delimiter: "\n"
                                      sequence:
                                  number:
                                      min_value: 0
                                      max_value: 1350
                                      initial_value: 315
                                      optimistic: true
                                      step: 15
                                      restore_value: true
                                      set_action:
                                        - delay: 1s
                                        - delay: 1s
                                        - delay: 1s
                                      min_value: 0
                                      max_value: 65000
                                      optimistic: true
                                      step: 25
                                      restore_value: true
                                      set_action:
                                        - delay: 1s
                                        - delay: 1s
                                        - delay: 1s
                                  button:
                                    - platform: restart
                                      on_press:
                                        - delay: 1s
                                        - delay: 3s
                                  Roelli
                                  Hmm... bei anderen gehts auch nicht. Liegt wohl an iobroker.
                                  https://bytemeta.vip/repo/DrozmotiX/ioBroker.esphome/issues/136
                                  • R Roelli
                                    @roelli Okay dann musst du wohl auf Home Assistant umsteigen ;-) Es ist ja bekannt das noch nicht alles so funktioniert wie bei HA...leider. Für meine Anwendungen hat es bis jetzt immer ausgereicht. Den Sensor über einen anderen Weg einzubinden schon gescheckt?
