  4. ESPhome: Gerät online im Adapter, aber nicht als Datenpunkt
    5.8k
19 Beiträge 3 Kommentatoren 964 Aufrufe 3 Beobachtet
  • R Roelli
    @noah3112
    Gerne:
    esphome:
    esp8266:
      board: esp01_1m
    # Enable logging
    logger:
    # Enable Home Assistant API
    api:
    ota:
      password: "7760e54b97ffe17d3962f019cf3c2ec5"
    wifi:
      ssid: !secret wifi_ssid
      password: !secret wifi_password
      # Enable fallback hotspot (captive portal) in case wifi connection fails
      ap:
        ssid: "Mmwave Fallback Hotspot"
        password: "JqxV1HsoRIC3"
    substitutions:
      device_name: mmwave-sensor
    captive_portal:
    web_server:
      port: 80
      version: 2
      include_internal: true
    http_request:
      useragent: esphome/$device_name
      timeout: 2s
    switch:
      - platform: safe_mode
        internal: true
    binary_sensor:
    - platform: gpio
      pin:
        number: GPIO16
        mode: INPUT_PULLDOWN
    uart:
      tx_pin: GPIO4
      rx_pin: GPIO5
      baud_rate: 115200
      debug:
        direction: BOTH
        dummy_receiver: true
        after:
          delimiter: "\n"
        sequence:
          - lambda: UARTDebug::log_string(direction, bytes);
    number:
      - platform: template
        min_value: 0
        max_value: 1350
        initial_value: 315
        optimistic: true
        step: 15
        restore_value: true
        unit_of_measurement: cm
        set_action:
          - uart.write: "sensorStop"
          - delay: 1s
          - uart.write: !lambda
                          int cm = (int)ceil(x / 15.0);
                          std::string cms = "detRangeCfg -1 0 " + to_string(cm);
                          return std::vector<unsigned char>(cms.begin(), cms.end());
          - delay: 1s
          - uart.write: "saveCfg 0x45670123 0xCDEF89AB 0x956128C6 0xDF54AC89"
          - delay: 1s
          - uart.write: "sensorStart"
        min_value: 0
        max_value: 65000
        initial_value: 12500
        optimistic: true
        step: 25
        restore_value: true
        unit_of_measurement: ms
        set_action:
          - delay: 1s
                          int ms = (int)ceil(x / 25.0);
                          std::string mss = "outputLatency -1 0 " + to_string(ms);
                          return std::vector<unsigned char>(mss.begin(), mss.end());
          - delay: 1s
          - delay: 1s
    button:
      - platform: restart
        name: Restart $device_name
        on_press:
          - delay: 1s
          - uart.write: "factoryReset 0x45670123 0xCDEF89AB 0x956128C6 0xDF54AC89"
          - delay: 3s
    Roelli
    Iobroker Log schreibt noch folgendes:
    ESPHome client 192.168.1.123 TypeError: Cannot read properties of undefined (reading 'deserializeBinary')
    NUC6i7KYK M.2 32GB RAM mit Proxmox
    14 AccessPoints, 5 Switches 115 Adapter, 67913 Objekte, 57954 Zustände,126x Shelly, 26 Thermostate, Fire Tablets, DMX, USV, 18x echodot, 9xKlima, 4x heizung, beamer, 6x IP Speed dome, AiOnTheEdge, Tasmota Wemos, Fingerabdrucksensoren, VOIP TFE, Türsteuerung, BMZ,EMA
    draexlerD 1 Antwort Letzte Antwort
    • R Roelli
      draexlerD Offline
      draexlerD Offline
      draexler
      @roelli Du darfst keinen „Button“ verwenden. Das wird noch nicht unterstützt. Muss einen „Switch“ verwenden. Der triggert dann kurz auf true und geht dann wieder auf false.
      • R Roelli
        @noah3112
        Gerne:
        esphome:
        esp8266:
          board: esp01_1m
        # Enable logging
        logger:
        api:
        ota:
        wifi:
          ap:
        substitutions:
        captive_portal:
        web_server:
          port: 80
          version: 2
        http_request:
          timeout: 2s
        switch:
            internal: true
        binary_sensor:
        - platform: gpio
          pin:
            number: GPIO16
        uart:
          tx_pin: GPIO4
          rx_pin: GPIO5
          baud_rate: 115200
          debug:
            direction: BOTH
            after:
              delimiter: "\n"
            sequence:
        number:
            min_value: 0
            max_value: 1350
            initial_value: 315
            optimistic: true
            step: 15
            restore_value: true
            set_action:
              - delay: 1s
              - delay: 1s
              - delay: 1s
            min_value: 0
            max_value: 65000
            optimistic: true
            step: 25
            restore_value: true
            set_action:
              - delay: 1s
              - delay: 1s
              - delay: 1s
        button:
          - platform: restart
            on_press:
              - delay: 1s
              - delay: 3s
        @roelli sagte in ESPhome: Gerät online im Adapter, aber nicht als Datenpunkt:
        binary_sensor:
        • platform: gpio
          pin:
          number: GPIO16
        Hier stimmt die Formatierung nicht ganz, aber das sollte der Editor eigentlich anmeckern. Das mit dem Soft Button sollte eigentlich passen. Ist das File selbst erstellt oder Copy Paste?
        R 1 Antwort Letzte Antwort
          binary_sensor:
          • platform: gpio
            pin:
            number: GPIO16
          Roelli
          @noah3112 sagte in ESPhome: Gerät online im Adapter, aber nicht als Datenpunkt:
          Hab ich hier geklaut: https://gist.github.com/EverythingSmartHome/4f8c9d8e94bffb44c7b7965f172b6470
          Weil ich diesen Radarsensor benutzen will: https://www.youtube.com/watch?v=VEqWlOeJ2YA
          Ich habe allerdings immer noch nicht verstanden was ich tun muss damit's funktioniert?
          Was muss man denn ändern?
          binary_sensor:
          - platform: gpio
            pin:
              number: GPIO16
          (ich hab mal rumgepfuscht und Sachen aus'm Netz da eingebaut, aber dann kommt bei der Prüfung schon eine Fehlermeldung)
          draexlerD ? 2 Antworten Letzte Antwort
          • R Roelli
            binary_sensor:
            - platform: gpio
              pin:
                number: GPIO16
            draexlerD Offline
            draexlerD Offline
            draexler
            @roelli entfern mal den ganzen Letzten Teil „Button“ und schau ob zumindest dann die Fehlermeldung im Log weg ist.
            • draexlerD draexler
              Roelli
              @draexler Fehlermeldung im LOG von iobroker bleibt. (hatte alles hinter dem Button gelöscht)
              • R Roelli
                binary_sensor:
                - platform: gpio
                  pin:
                    number: GPIO16
                @roelli Die Leerzeichen sind bei YAML sehr wichtig bzw müssen eingehalten werden.
                binary_sensor:
                  - platform: gpio
                    pin:
                      number: D3
                      inverted: true
                      mode:
                        input: true
                        pullup: true
                Hier mal ein Beispiel das muss bei dir noch korrigiert werden.
                • R Roelli
                  @roelli Wie gesagt das mit dem Button sollte funktionieren. Hatte auch schon einen Soft Reset im Einsatz finde das Beispiel leider gerade nicht.
                    Roelli
                    schrieb am zuletzt editiert von Roelli
                    @noah3112
                    Hier meckert er noch:
                    • R Roelli
                      @noah3112
                      @roelli Das ist wiederum von deinem eingesetzten Board abhängig. In dem Beispiel was ich dir geschickt habe war ein D1 mini im Einsatz...
                      esp8266:
                        board: d1_mini
                      Bei dir ist es anscheinend ein esp1!?
                      Da gibt es den Pin D3 nicht bzw kann nicht genutzt werden.
                        esp8266:
                          board: d1_mini
                        Roelli
                        @noah3112
                        Ich hab den wemos D1 mini.
                        Der Eingang ist definitiv D0.
                        (Laut Pinout vom wemos D1 mini ist D0 auch gleichzeitig Pin4, oder GPIO16)
                        • R Roelli
                          @noah3112
                          @roelli Was mir noch aufgefallen ist. Ich hatte das nur als Beispiel für die Formatierung, das passt also so überhaupt nicht für deine Anwendung. Hier wird ein GPIO Hardware Anschluss genutzt für einen Taster der an Pin D3 hängt. In deinem "Programm" ist es ein Software Button. Also nicht für dein Projekt übernehmen.
                          • R Roelli
                            @noah3112
                            @roelli Aber dann stimmt doch hier schon etwas nicht...
                            esphome:
                            esp8266:
                              board: esp01_1m
                              esphome:
                              esp8266:
                                board: esp01_1m
                              Roelli
                              @noah3112
                              Ha! Wenn man die richtige Hardware einstellt, dann geht das Ding sogar online!
                              Einen Schritt weiter! 👍
                              Nur der interessante "true/false" Wert wird noch nicht angezeigt. 😕
                              esphome:
                              esp8266:
                                board: d1_mini
                              # Enable logging
                              logger:
                              api:
                              ota:
                              wifi:
                                ap:
                              substitutions:
                              captive_portal:
                              web_server:
                                port: 80
                                version: 2
                              http_request:
                                timeout: 2s
                              switch:
                                  internal: true
                              binary_sensor:
                              - platform: gpio
                                pin:
                                  number: GPIO16
                              uart:
                                tx_pin: GPIO4
                                rx_pin: GPIO5
                                baud_rate: 115200
                                debug:
                                  direction: BOTH
                                  after:
                                    delimiter: "\n"
                                  sequence:
                              number:
                                  min_value: 0
                                  max_value: 1350
                                  initial_value: 315
                                  optimistic: true
                                  step: 15
                                  restore_value: true
                                  set_action:
                                    - delay: 1s
                                    - delay: 1s
                                    - delay: 1s
                                  min_value: 0
                                  max_value: 65000
                                  optimistic: true
                                  step: 25
                                  restore_value: true
                                  set_action:
                                    - delay: 1s
                                    - delay: 1s
                                    - delay: 1s
                              button:
                                - platform: restart
                                  on_press:
                                    - delay: 1s
                                    - delay: 3s
                              • R Roelli
                                @noah3112
                                esphome:
                                esp8266:
                                  board: d1_mini
                                # Enable logging
                                logger:
                                api:
                                ota:
                                wifi:
                                  ap:
                                substitutions:
                                captive_portal:
                                web_server:
                                  port: 80
                                  version: 2
                                http_request:
                                  timeout: 2s
                                switch:
                                    internal: true
                                binary_sensor:
                                - platform: gpio
                                  pin:
                                    number: GPIO16
                                uart:
                                  tx_pin: GPIO4
                                  rx_pin: GPIO5
                                  baud_rate: 115200
                                  debug:
                                    direction: BOTH
                                    after:
                                      delimiter: "\n"
                                    sequence:
                                number:
                                    min_value: 0
                                    max_value: 1350
                                    initial_value: 315
                                    optimistic: true
                                    step: 15
                                    restore_value: true
                                    set_action:
                                      - delay: 1s
                                      - delay: 1s
                                      - delay: 1s
                                    min_value: 0
                                    max_value: 65000
                                    optimistic: true
                                    step: 25
                                    restore_value: true
                                    set_action:
                                      - delay: 1s
                                      - delay: 1s
                                      - delay: 1s
                                button:
                                  - platform: restart
                                    on_press:
                                      - delay: 1s
                                      - delay: 3s
                                Roelli
                                Hmm... bei anderen gehts auch nicht. Liegt wohl an iobroker.
                                https://bytemeta.vip/repo/DrozmotiX/ioBroker.esphome/issues/136
                                • R Roelli
                                  @roelli Okay dann musst du wohl auf Home Assistant umsteigen ;-) Es ist ja bekannt das noch nicht alles so funktioniert wie bei HA...leider. Für meine Anwendungen hat es bis jetzt immer ausgereicht. Den Sensor über einen anderen Weg einzubinden schon gescheckt?
