  4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
    1.0k
    6.1k
391 Beiträge 33 Kommentatoren 105.1k Aufrufe 33 Beobachtet
  • David G.D David G.
    bei mir mag er das irgendwie nicht installieren.
    pi@pi:~ $ curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
    Detected operating system as raspbian/bullseye.
    Checking for curl...
    Detected curl...
    Checking for gpg...
    Detected gpg...
    Running apt-get update... done.
    Installing apt-transport-https... done.
    Installing /etc/apt/sources.list.d/ookla_speedtest-cli.list...done.Importing packagecloud gpg key... done.
    The repository is setup! You can now install packages.
    pi@pi:~ $ sudo apt update                                          Ign:1 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Err:4 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release
      404  Not Found [IP: 54.183.164.179 443]
    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists... Done
    E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    pi@pi:~ $ sudo apt install speedtest
    E: Unable to locate package speedtest
    pi@pi:~ $ lsb_release -a
    No LSB modules are available.
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    GNU nano 5.4  /etc/apt/sources.list.d/nodesource.list            deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nod>deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb>
    #94
    @david-g
    uname -a
    cat /etc/apt/sources.list.d/nodesource.list
      Detected curl...
      Checking for gpg...
      Detected gpg...
      Release:        11
      Codename:       bullseye
      #95
      @david-g
      Trag das mal so ein:
      echad@chet:~ $ cat /etc/apt/sources.list.d/ookla_speedtest-cli.list
      # this file was generated by packagecloud.io for
      # the repository at https://packagecloud.io/ookla/speedtest-cli
      deb [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
      deb-src [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
      echad@chet:~ $
      Also statt raspbian debian eintragen. Da ist das Installationsskript immer noch unsauber und passt nicht für Raspberry OS.
        @david-g
        echad@chet:~ $
        David G.D Online
        David G.D Online
        David G.
        #96
        So klappt es,
        vielen Dank.
        Dann begebe ich mich nachher mal an das Skript.
        • David G.D Online
          David G.D Online
          David G.
          #97
          Habe mal eine ganz allgemeine Frage zum Skript.
          Die Datenpunkte werden ja im javascript.0 angelegt.
          Jetzt hab ich hier schon ein paar mal gelesen, dass man für eigene Datenpunkte eher den userdata.0 bevorzugen soll.
          Macht das für so ein Skript auch mehr Sinn?
            #98
            @david-g eigene Datenpunkte unter 0_userdata.0 haben den Vorteil, dass wenn du z.Bsp. die Javascript-Instanz loeschen wuerdest deine Datenpunkte erhalten bleibn, incl. History.. daher wenn moeglich, immer eigene Datenpunkte in userdata anlegen.
            Zeile 28 dann anstatt
            var datenpunkt = "Speedtest.";
            in
            var datenpunkt = "0_userdata.0.Speedtest.";
            • David G.D Online
              David G.D Online
              David G.
              #99
              Habt ihr auch, dass das Skript mehrfach läuft, wenn ihr Änderungen vorgenommen habt?
              Hatte 1-2 mal den shedule geändert und ein paar Server getestet.
              Als die Testergebnisse dann viel zu gering waren habe ich im Log (und der History) gesehen, dass der Test innerhalb einer Sekunde 8 mal gestartet wird, regelmäßig.
              liv-in-skyL NegaleinN 2 Antworten Letzte Antwort
                liv-in-skyL Offline
                liv-in-skyL Offline
                #100
                @david-g starte die javascript instanz neu - evtl hängt da noch was im system
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #101
                  @david-g sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                  Ja, gibt dazu ein Issue!
                  Häng dich dort auch ran.
                  ° Fixer ---> iob fix
                  G 1 Antwort Letzte Antwort
                  • NegaleinN Negalein
                    guergen
                    #102
                    Ich kann den Schlüssel nicht importieren:
                    +-▒▒{▒ϓ▒▒ N#9▒Z▒▒▒u▒T▒  ▒▒▒+▒}▒L▒(
                    ▒O;}▒yC^▒6▒MCl3▒▒▒GC▒ﵨ?a▒▒▒4▒▒▒~▒▒4ȻH.7▒.d▒*-bash: Syntaxfehler beim unerwarteten Symbol »|«
                    iob@iob:~$ PuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTY
                    Danach kommt folgende Meldung:
                    iob@iob:~$ sudo apt update
                    OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                    OK:2 http://ftp.de.debian.org/debian bullseye InRelease
                    OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                    OK:4 http://ftp.de.debian.org/debian bullseye-updates InRelease
                    Holen:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease [24,5 kB]
                    Fehl:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                      Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
                    W: GPG-Fehler: https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
                    E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease« ist nicht signiert.
                    N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                    N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                    iob@iob:~$
                    Schreibe ich das in eine Zeile
                    iob@iob:~$ curl -fsSL https://packagecloud.io/ookla/speedtest-cli/gpgkey | gpg --dearmor~ | sudo tee /etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg
                    Bekomme ich folgende Meldung:
                    Ungültige Option "--dearmor~"
                    (23) Failed writing body
                    Wo steckt der Fehler?
                    • G guergen
                      iob@iob:~$
                      #103
                      @guergen sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                      --dearmor~
                      Muss
                      --dearmor
                      lauten.
                        --dearmor~
                        Muss
                        --dearmor
                        lauten.
                        guergen
                        #104
                        @thomas-braun Hmmmh... Endet auch in einem PuTTYPuTTY....
                        • G guergen
                          #105
                          @guergen
                          Hä?
                          curl -fsSL https://packagecloud.io/ookla/speedtest-cli/gpgkey | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg
                          Eingeben, vollständige Ein- und Ausgaben posten.
                            @guergen
                            Hä?
                            guergen
                            #106
                            @thomas-braun sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                            iob@iob:~$ curl -fsSL https://packagecloud.io/ookla/speedtest-cli/gpgkey | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg
                            `eO▒A▒▒ ~▒▒▒>▒▒▒▒0y6k▒▒▒y▒▒▒8▒#▒▒n▒▒-▒ޕ▒ޢz▒SYQ▒S▒▒▒▒▒▒▒▒▒▒\▒Ne5N▒▒▒o▒▒,K}▒▒▒▒7z lw▒ھ▒|▒▒k▒U▒▒▒x▒8▒E▒X͚▒z^▒gv▒8▒▒▒@J▒F▒8▒EǞP▒▒i'▒▒▒▒Q▒x▒~>X4�"A▒▒
                            ▒▒▒1▒▒▒5▒X▒▒▒,w▒▒▒R|▒Ɩq/▒▒▒s▒ՀMk3▒}8}▒*▒▒▒h▒ZX▒▒G▒▒▒▒"
                            ▒▒os+h 1N▒ۙ▒▒▒ʔ▒w▒_s▒▒▒B▒▒!▒▒ÿ▒▒▒▒▒▒▒▒[X)vz▒▒▒▒▒;▒[▒▒aސ▒▒▒!▒▒▒2▒畝▒=9א▒`[.▒▒+▒K▒cpp▒▒驧▒▒_▒w▒=▒▒>mk=@▒▒F▒x_▒Kcg▒▒▒▒▒▒D▒Q5'▒▒▒V▒▒▒]▒@Ji
                            r▒▒7}▒▒▒r▒▒7▒▒;▒▒uYV▒▒#-wx▒▒K▒▒;▒▒▒
                            ▒▒▒qyR#▒Sz▒8▒▒▒!▒▒▒ᝋ▒ ▒5▒phttps://packagecloud.io/ookla/speedtest-cli (https://packagecloud.io/docs#gpg_signing) <support@packagecloud.io>▒N
                            8!▒%▒▒:~V▒,▒1▒9▒▒#▒▒`eO
                                    1▒9▒▒#▒▒▒▒▒H▒▒=i▒%▒▒8|▒▒T1h▒▒▒Ks'▒▒0▒e▒"▒m▒9▒▒Y;҅▒ġRq▒T▒r▒euڦ#Źʶ▒▒▒▒/▒▒▒▒▒&▒姑▒4ya▒▒B▒sA▒▒y▒T[▒b▒▒@▒e▒▒▒#*% S▒
                            ▒V
                            ▒▒2▒v}▒▒J-J▒▒? ▒.▒~▒▒b▒W▒B▒G▒▒bB▒z<▒▒▒Iȕ▒a7▒l▒▒▒R▒&4Oāu▒▒▒▒u▒▒=
                            ▒▒?▒&▒▒▒?▒֛]I▒t▒▒▒yXH+▒!▒▒t▒▒:▒▒Q▒F▒m▒0▒/▒O<▒▒H&▒▒sb▒▒▒d
        ▒▒Pa▒e}▒6▒▒U▒▒6▒▒▒▒[▒▒▒|6▒Y▒s▒▒▒▒&▒j'▒O▒▒Ht▒P▒$qo1̵L~▒0▒M▒!▒▒▒q▒,▒=-▒▒t▒▒Mf,͠▒)e▒Ę▒x▒s▒▒TK$▒▒>?aY▒)▒&▒▒▒▒▒▒▒▒▒G▒▒▒▒G▒▒ɴ▒hn▒▒P▒▒+TP▒▒.▒▒}2y        ▒,▒▒▒غ4▒"=▒
                            V▒ *ۗ[*▒a*▒▒t{cA;▒F▒6▒▒▒ǫ▒Eʡ
                            `eO▒:▒t▒#▒▒K~i▒▒▒SܫVDP▒▒W▒4*)}▒▒▒▒+3KI▒@p▒_▒▒
        ▒F˧֧▒Eu▒▒▒B=▒D▒´Gy▒v▒▒▒X▒s8▒▒.Zy▒oeh#▒▒▒▒▒R$▒▒(
                            ."▒c▒▒▒Q▒!SRjӣ▒▒0▒PP1EF▒▒H▒z2i'p▒V▒▒▒[>▒o▒Hw▒wat▒▒~?▒l)▒▒{t▒U~▒$▒)FC▒▒@▒▒r▒W▒▒▒1▒&▒e▒7▒ݡ▒▒W(J▒ `X▒U▒▒▒▒{m▒}▒@▒p▒▒▒▒4▒й▒N%1▒▒@0x`#
                            ▒▒▒I3JA▒▒▒▒~▒▒L؈▒▒@)M؟3▒eNR~P▒c>9▒`0p▒▒▒"{▒▒▒▒)▒▒@▒▒
                            ▒�,▒▒▒▒+▒?▒▒:جw▒▒▒▒ld▒Ќ▒?´▒▒~BB▒ih▒D▒▒/▒▒V▒?s▒x▒▒D▒▒▒▒▒▒!▒)▒M▒֛'▒#_V▒7W▒▒▒zXyM'I(        H▒.!.▒F▒▒▒LZ▒\▒l{-O▒▒V▒z▒
                             !▒%▒▒:~V▒,▒1▒9▒▒#▒▒`eO 1▒9▒▒#▒▒▒t
                            !▒7▒▒▒&▒▒"'▒a«▒mW`eO
                                    ▒a«▒mW+▒}V▒▒▒▒▒▒"}▒|Huw▒▒▒;&u;▒▒▒▒n1u▒▒▒▒B▒D▒▒▒▒Hi▒.▒&XjV▒~e_▒▒f^G▒▒▒]-▒▒
                            4r}▒▒OVӒ^'▒     Խ▒▒▒▒:)4\▒h▒▒▒Ϝ▒▒d▒Ҥ▒Yh▒▒1      ▒`▒▒▒▒b▒▒▒▒t▒TP▒d▒▒Yg^▒▒▒gB▒"Ļu a▒▒F^▒"▒=▒u▒;▒▒|n▒Y▒▒۬t5
        R▒▒V▒▒▒▒t▒▒▒▒▒▒V)=▒.▒xAA.r(3▒▒▒?▒▒?_d▒▒▒▒6▒▒▒▒▒▒V▒▒L▒▒ ▒V▒H▒l▒
                            ▒(▒Rּ▒/▒▒=▒^}▒▒$~ܪ▒C!Zw ▒▒TL▒▒g▒▒▒P▒[5k▒ ▒▒▒▒▒▒7[pk$H▒%E▒f▒U▒+▒▒)▒|叆▒춑▒\z.▒▒r▒▒װRШ▒B{t▒5▒▒t▒v;"▒5qI▒ TD▒f4▒▒á▒G▒▒▒r▒▒s▒▒▒=W▒h▒0Xi▒=^<;e▒▒▒S->▒▒▒0}Yk▒▒C▒i▒tr▒!▒Ώ▒▒▒m▒{▒t)ÛS▒▒  ▒▒▒ʯWaf▒r▒▒~z▒▒▒▒;▒▒,▒▒▒▒xd▒t▒▒QL▒²▒▒▒g9▒b^▒▒T▒▒x)▒%
                            ▒▒▒`▒&▒F▒▒$л▒▒g{▒l▒▒@▒+^G/@▒ݗ▒▒▒▒▒▒O▒cmG▒Q8{%▒▒>▒o▒a▒▒c5▒nTC{Ap▒h▒≈ɪ▒▒x▒B▒▒@(▒▒"▒Ƒ▒▒"▒$▒p▒▒▒▒▒i;`▒▒▒▒@▒W▒vgA▒-lBW▒8▒▒q▒▒(;▒▒▒۴զ▒is-▒▒▒▒^k▒^#u<▒y<▒▒▒)▒9▒I▒/▒l][▒ݱ~a"%{*Z▒
                            챔▒▒▒R▒y▒▒_▒▒9u[2▒▒▒j▒▒▒`▒▒/
                            ▒O;}▒yC^▒6▒MCl3▒▒▒GC▒ﵨ?a▒▒▒4▒▒▒~▒▒4ȻH.7▒.d▒*iob@iob:~$ PuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTY^C
                            ▒V
                            Kann ich nur mit StRg "C" abbrechen
                            SKBS 1 Antwort Letzte Antwort
                            • G guergen
                              ▒V
                              ▒V
                              SKBS Offline
                              SKBS Offline
                              SKB
                              #107
                              @guergen Schau mal, ob dein Zeichensatz in Putty passt. Sieht mir schwer danach aus, als wenn dieser nicht stimmt :)
                              https://seeseekey.net/archive/110592/#:~:text=Stattdessen muss bei PuTTY gesucht werden.&text=Um das Problem zu beheben,fehlerhaften Zeichen der Vergangenheit an.
                              • SKBS SKB
                                guergen
                                #108
                                @skb Steht auf UTF-8
                                Egtl. Richtig...
                                Mit Iso-8859-15 wird es auch nicht besser
                                Hat keiner eine Idee?
                                • G guergen
                                  Egtl. Richtig...
                                  #109
                                  @guergen
                                  locale
                                  sagt?
                                    @guergen
                                    locale
                                    sagt?
                                    guergen
                                    #110
                                    iob@iob:~$ locale
                                    LANG=de_DE.UTF-8
                                    LANGUAGE=
                                    LC_CTYPE="de_DE.UTF-8"
                                    LC_NUMERIC="de_DE.UTF-8"
                                    LC_TIME="de_DE.UTF-8"
                                    LC_COLLATE="de_DE.UTF-8"
                                    LC_MONETARY="de_DE.UTF-8"
                                    LC_MESSAGES="de_DE.UTF-8"
                                    LC_PAPER="de_DE.UTF-8"
                                    LC_NAME="de_DE.UTF-8"
                                    LC_ADDRESS="de_DE.UTF-8"
                                    LC_TELEPHONE="de_DE.UTF-8"
                                    LC_MEASUREMENT="de_DE.UTF-8"
                                    LC_IDENTIFICATION="de_DE.UTF-8"
                                    LC_ALL=
                                    iob@iob:~$
                                      m0uh
                                      schrieb am zuletzt editiert von m0uh
                                      #111
                                      code_textpi@raspberrypi:~ $ sudo apt update
                                      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                                      Hit:3 https://phoscon.de/apt/deconz buster InRelease
                                      Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
                                      Hit:5 https://apt.hyperion-project.org buster InRelease
                                      Hit:6 https://repos.influxdata.com/debian buster InRelease
                                      Hit:7 https://packages.grafana.com/enterprise/deb stable InRelease
                                      Hit:8 https://archive.raspbian.org/raspbian bullseye InRelease
                                      Hit:9 https://www.pivccu.de/piVCCU testing InRelease
                                      Ign:10 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease
                                      Err:11 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release
                                        404  Not Found [IP: 2600:1f1c:2e5:6901:914d:db70:ee4c:8e5f 443]
                                      pi@raspberrypi:~ $ sudo apt install speedtest
                                      pi@raspberrypi:~ $
                                      Scheinbar gibts kein File mehr über den Paketmanager? Any idea?
                                      EDIT:
                                      Hab mal in der sourceliste aus raspian -> debian gemacht und schon funktionierts
                                      • M m0uh
                                        pi@raspberrypi:~ $
                                        EDIT:
                                        #112
                                        @m0uh
                                        Da ist auch sonst Chaos drin.
                                        Nie Releases mischen. Entweder ist das Buster oder Bullseye.
                                        Wenn das da jetzt bei dir ein 'Bullseye / Debian 11' ist
                                        (Prüfen mit
                                        cat /etc/debian_version
                                        stell das mit den drei Zeilen alles richtig:
                                        sudo sed -i 's/bullseye\/updates/bullseye-security/g' /etc/apt/sources.list
                                        sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list
                                        sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list.d/*
                                        • F Offline
                                          Fauli85
                                          #113
                                          So ich hoffe, das ich das jetzt hier richtig mache (werde einfach zu alt).
                                          Erst mal ein Frohes neues nachträglich.
                                          Ich versuche jetzt schon gute 3 Tage den Speedtest zum laufen zu bekommen.
                                          Gut 2 Tage habe ich gebraucht um mein Unbuntu auf den neusten stand zubringen :) aber jetzt läuft es.
                                          Auch den Speedtest habe ich Installiert bekommen und im Terminal gibt er auch die Daten aus.
                                          JS- Script kopiert und die Zeile geändert (warum alle schreiben Zeile 210 - wenn es doch 216 ist - keine Plan)
                                          In Zeile 32 noch die ID geändert (München 27345)
                                          Aber ich bekomme im IoBroker Objekte keine Daten.
                                          Laut Protokoll fehlt was... aber was -ich finde auch nichts im Netz und sorry nach 3 Tagen Suche darf ich hoffentlich mal um Hilfe Fragen :).
                                          javascript.0
                                          	2023-01-03 19:36:58.035	error	script.js.common.Speedtest: Speedtest konnte nicht ausgeführt werden! exec is not available. Please enable "Enable Exec" option in instance settings
                                          javascript.0
                                          	2023-01-03 19:36:58.034	error	exec is not available. Please enable "Enable Exec" option in instance settings
                                          Danke schon mal vorab für die Hilfe, sollten noch andere Infos benötigt werden - jeder Zeit gerne :)
                                          Gruß eric
                                          SKBS Thomas BraunT 3 Antworten Letzte Antwort
