  4. JavaScript
  5. Erster Versuch ein JSON zu erzeugen
35 Beiträge 2 Kommentatoren 3.7k Aufrufe 1 Beobachtet
    @chris76e sagte: kommt das im Log
    Dann verschiebe mal Zeile 11 unter Zeile 12 (else if).
    Chris76eC Online
    Chris76eC Online
    Chris76e
    Da ist das selbe....
    00:43:45.727	info	javascript.0 (649) script.js.common.JSON.JASONSP: null
    00:43:45.728	info	javascript.0 (649) script.js.common.JSON.JASONSP: undefined
    const idTable = '0_userdata.0.JSON.Spülmaschiene'; // ID JSON-Tabelle
    const idStatus = 'homeconnect.0.011040388898000963.status.BSH_Common_Status_OperationState';
    const idProg = 'homeconnect.0.011040388898000963.programs.active.BSH_Common_Root_ActiveProgram';
    var table = [];
    if(getState(idTable).val) table = JSON.parse(getState(idTable).val);
    var obj = {};
    on(idStatus, function(dp) {
        if(dp.state.val == 'BSH.Common.EnumType.OperationState.Run') {
            obj.Start = formatDate(new Date(), 'DD.MM.YY hh:mm');
        } else if(dp.oldState.val == 'BSH.Common.EnumType.OperationState.Run') {
            obj.Programm = getObject(idProg).common.states[getState(idProg).val];
            obj.Ende = formatDate(new Date(), 'DD.MM.YY hh:mm');
            table.push(obj);
            if(table.length > 10) table.shift();
            setState(idTable, JSON.stringify(table), true);
            log(getState(idProg).val);
            log(getObject(idProg).common.states[getState(idProg).val]);
    • Chris76eC Online
      Chris76eC Online
      Chris76e
      Vieleicht hilft das dir noch weiter, die Objektdaten von
        "type": "state",
        "common": {
          "name": "BSH_Common_Root_ActiveProgram",
          "type": "string",
          "role": "indicator",
          "write": true,
          "read": true,
          "states": {
            "Dishcare.Dishwasher.Program.Intensiv70": "Intensiv 70°",
            "Dishcare.Dishwasher.Program.Auto2": "Auto 45-65°",
            "Dishcare.Dishwasher.Program.Eco50": "Eco 50°",
            "Dishcare.Dishwasher.Program.Quick45": "Speed 45°",
            "Dishcare.Dishwasher.Program.PreRinse": "Vorspülen",
            "Dishcare.Dishwasher.Program.Quick65": "Speed 65°",
            "Dishcare.Dishwasher.Program.MachineCare": "Maschinenpflege"
          "custom": {
            "history.0": {
              "enabled": true,
              "aliasId": "",
              "debounceTime": 0,
              "blockTime": 0,
              "changesOnly": false,
              "changesRelogInterval": 0,
              "changesMinDelta": 0,
              "ignoreBelowNumber": "",
              "disableSkippedValueLogging": false,
              "retention": 31536000,
              "customRetentionDuration": 365,
              "maxLength": 10,
              "enableDebugLogs": false,
              "debounce": 0
        "native": {},
        "_id": "homeconnect.0.011040388898000963.programs.active.BSH_Common_Root_ActiveProgram",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
        "from": "system.adapter.homeconnect.0",
        "user": "system.user.admin",
        "ts": 1662416101983
        Chris76eC Online
        Chris76eC Online
        Chris76e
        schrieb am zuletzt editiert von Chris76e
        Bin jetzt einwenig weiter gekommen, wenn ich den DP
        homeconnect.0.011040388898000963.programs.selected.BSH_Common_Root_SelectedProgram
        nehme, dann wird der erkannt.
        Aber mit der Schleife ist nochwas nicht richtig. Hier werden Daten überschrieben
            "Start": "06.09.22 00:42",
            "Ende": "06.09.22 00:43"
            "Start": "06.09.22 09:25",
            "Ende": "06.09.22 09:25",
            "Programm": "Eco 50°"
            "Start": "06.09.22 09:28",
            "Ende": "06.09.22 09:28",
            "Programm": "Speed 45°"
        const idProg = 'homeconnect.0.011040388898000963.programs.selected.BSH_Common_Root_SelectedProgram';
        var table = [];
        var obj = {};
                table.push(obj);
        Chris76eC 1 Antwort Letzte Antwort
        • Chris76eC Chris76e
          var table = [];
          var obj = {};
                  table.push(obj);
          Chris76eC Online
          Chris76eC Online
          Chris76e
          Habe vermutlich zuschnell das Programm am GS gestoppt.
          Habe es jetzt einwenig länger laufen lassen und dann wird richtig geschrieben.
              "Start": "06.09.22 10:09",
              "Programm": "Auto 45-65°",
              "Ende": "06.09.22 10:11"
              "Start": "06.09.22 10:13",
              "Programm": "Eco 50°",
              "Ende": "06.09.22 10:20"
            @chris76e sagte: fehlt also noch das Programm
            Ohne Error- oder Warn-Log?
            Füge mal Logs ein (hinter Zeile 11):
            Chris76eC Online
            Chris76eC Online
            Chris76e
            Kannst du dir nochmal bitte die schleife anschauen? Irgendwas stimmt da doch nicht.
            Es werden weiter Dopelte Einträge gemacht, bzw. alte Einträge überschrieben.
                "Start": "06.09.22 09:49",
                "Programm": "Intensiv 70°",
                "Ende": "06.09.22 09:49"
                "Start": "06.09.22 10:31",
                "Ende": "06.09.22 15:08"
              @chris76e sagte: Es werden weiter Dopelte Einträge gemacht
              Das kann nur am Verhalten des Datenpunktes "homeconnect.0.011040388898000963.status.BSH_Common_Status_OperationState" liegen". Logge mal den Wert bei jedem Trigger-Ereignis.
                Chris76eC Online
                Chris76eC Online
                Chris76e
                Hier der Eintrag aus dem Log
                1. Start war noch ohne log vom Ende
                20:19:34.230	info	javascript.0 (649) script.js.common.JSON.JASONSP: BSH.Common.EnumType.OperationState.Run
                20:19:34.231	info	javascript.0 (649) script.js.common.JSON.JASONSP: Run
                20:19:34.231	info	javascript.0 (649) script.js.common.JSON.JASONSP: Dishcare.Dishwasher.Program.MachineCare
                20:19:34.231	info	javascript.0 (649) script.js.common.JSON.JASONSP: Maschinenpflege
                20:27:19.463	info	javascript.0 (649) Stop script script.js.common.JSON.JASONSP
                20:27:19.466	info	javascript.0 (649) Start javascript script.js.common.JSON.JASONSP
                20:27:19.479	info	javascript.0 (649) script.js.common.JSON.JASONSP: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                20:28:02.079	info	javascript.0 (649) script.js.common.JSON.JASONSP: BSH.Common.EnumType.OperationState.Run
                20:28:02.081	info	javascript.0 (649) script.js.common.JSON.JASONSP: Run
                20:28:02.082	info	javascript.0 (649) script.js.common.JSON.JASONSP: Dishcare.Dishwasher.Program.Quick45
                20:28:02.082	info	javascript.0 (649) script.js.common.JSON.JASONSP: Speed 45°
                20:30:16.619	info	javascript.0 (649) script.js.common.JSON.JASONSP: BSH.Common.EnumType.OperationState.Aborting
                20:30:16.619	info	javascript.0 (649) script.js.common.JSON.JASONSP: Aborting
                20:32:02.233	info	javascript.0 (649) script.js.common.JSON.JASONSP: BSH.Common.EnumType.OperationState.Run
                20:32:02.234	info	javascript.0 (649) script.js.common.JSON.JASONSP: Run
                20:32:02.234	info	javascript.0 (649) script.js.common.JSON.JASONSP: Dishcare.Dishwasher.Program.MachineCare
                20:32:02.234	info	javascript.0 (649) script.js.common.JSON.JASONSP: Maschinenpflege
                20:33:17.902	info	javascript.0 (649) script.js.common.JSON.JASONSP: BSH.Common.EnumType.OperationState.Aborting
                20:33:17.902	info	javascript.0 (649) script.js.common.JSON.JASONSP: Aborting
                Und so sieht die JSON aus
                    "Start": "06.09.22 20:19",
                    "Programm": "Maschinenpflege",
                    "Ende": "06.09.22 20:25"
                    "Start": "06.09.22 20:32",
                    "Ende": "06.09.22 20:33"
                Hier stand auch mal zwischenzeitlich der Eintrag von 20:28 mit Speed 45°
                  @chris76e
                  Aus dem Log sehe ich, dass "Run" nur als kurzer Impuls gemeldet wird und danach das Programm, beendet durch "Aborting". Dann versuche es mal so:
                  // const idProg = 'homeconnect.0.011040388898000963.programs.active.BSH_Common_Root_ActiveProgram';
                  var table = [];
                  var obj = {};
                          obj.Programm = dp.common.states[dp.state.val];
                      } else if (dp.state.val == 'BSH.Common.EnumType.OperationState.Aborting') {
                          table.push(obj);
                    @chris76e
                    var table = [];
                    var obj = {};
                            table.push(obj);
                    Chris76eC Online
                    Chris76eC Online
                    Chris76e
                    Wo kommt jetzt der DP herr? Fehlt da nicht was?
                      @chris76e sagte: Wo kommt jetzt der DP herr?
                      Aus dem Trigger: Enthält den Zustand "laufendes Programm" nach "Run".
                        Chris76eC Online
                        Chris76eC Online
                        Chris76e
                        Mit der Version wird nichts geschrieben, bekomme auch keine Fehlermeldung.
                          @chris76e sagte: Mit der Version wird nichts geschrieben
                          Wurde obj außerhalb des Triggers deklariert? Habe ich oben korrigiert.
                            Chris76eC Online
                            Chris76eC Online
                            Chris76e
                            ist geändert, aber macht immer noch nichts.
                              @chris76e sagte: ist geändert, aber macht immer noch nichts.
                              @chris76e sagte in Erster Versuch ein JSON zu erzeugen:
                              Das ist wirklich der Wert des Trigger-Datenpunktes. Es sind zumindest zwei Log-Ausgaben. Logge mal nur den Trigger-Wert:
                                  log(dp.state.val);
                              Alle anderen Logs kommentiere aus.
                                    log(dp.state.val);
                                Chris76eC Online
                                Chris76eC Online
                                Chris76e
                                log sieht so aus
                                23:48:20.661	info	javascript.0 (649) script.js.common.JSON.JASONTest: BSH.Common.EnumType.OperationState.Ready
                                23:48:25.593	info	javascript.0 (649) script.js.common.JSON.JASONTest: BSH.Common.EnumType.OperationState.Run
                                23:49:37.318	info	javascript.0 (649) script.js.common.JSON.JASONTest: BSH.Common.EnumType.OperationState.Aborting
                                23:50:02.051	info	javascript.0 (649) script.js.common.JSON.JASONTest: BSH.Common.EnumType.OperationState.Ready
                                Wird aber nichts geschrieben
                                  log sieht so aus
                                  @chris76e
                                  Habe mich hier durch die weiteren Logs täuschen lassen, da sie nicht gekennzeichnet sind.
                                  Weshalb das Skript doppelte Einträge erzeugt, erschließt sich mir bisher nicht. Deshalb erzeuge bitte Logs mit Datenpunkt-Kennung:
                                  const idAktiv = 'homeconnect.0.011040388898000963.programs.active.BSH_Common_Root_ActiveProgram';
                                  var table = [];
                                  var obj = {};
                                  on(idAktiv, function(dp) {
                                      log('Aktiv: ' + dp.state.val);
                                      log('gewählt: ' + getState(idProg).val);
                                      log('alter Status: ' + dp.oldState.val);
                                      log('neuer Status: ' + dp.state.val);
                                          table.push(obj);
                                    @chris76e
                                    var table = [];
                                    var obj = {};
                                            table.push(obj);
                                    Chris76eC Online
                                    Chris76eC Online
                                    Chris76e
                                    Hier der log von 2 Abgebrochenen Durchgänge:
                                    08:58:09.745	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: gewählt: Dishcare.Dishwasher.Program.Eco50
                                    08:58:09.745	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: alter Status: BSH.Common.EnumType.OperationState.Ready
                                    08:58:09.746	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: neuer Status: BSH.Common.EnumType.OperationState.Run
                                    08:58:09.746	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: Dishcare.Dishwasher.Program.Eco50
                                    08:58:09.746	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: Eco 50°
                                    08:58:09.918	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: aktiv: Dishcare.Dishwasher.Program.Eco50
                                    09:00:36.446	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: aktiv: null
                                    09:00:36.847	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: gewählt: Dishcare.Dishwasher.Program.Eco50
                                    09:00:36.847	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: alter Status: BSH.Common.EnumType.OperationState.Run
                                    09:00:36.847	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: neuer Status: BSH.Common.EnumType.OperationState.Aborting
                                    09:01:03.132	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: gewählt: Dishcare.Dishwasher.Program.Eco50
                                    09:01:03.132	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: alter Status: BSH.Common.EnumType.OperationState.Aborting
                                    09:01:03.133	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: neuer Status: BSH.Common.EnumType.OperationState.Ready
                                    09:09:34.041	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: gewählt: Dishcare.Dishwasher.Program.Quick65
                                    09:09:34.042	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: alter Status: BSH.Common.EnumType.OperationState.Ready
                                    09:09:34.042	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: neuer Status: BSH.Common.EnumType.OperationState.Run
                                    09:09:34.042	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: Dishcare.Dishwasher.Program.Quick65
                                    09:09:34.042	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: Speed 65°
                                    09:09:34.107	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: aktiv: Dishcare.Dishwasher.Program.Quick65
                                    09:10:56.316	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: aktiv: null
                                    09:10:56.480	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: gewählt: Dishcare.Dishwasher.Program.Quick65
                                    09:10:56.480	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: alter Status: BSH.Common.EnumType.OperationState.Run
                                    09:10:56.480	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: neuer Status: BSH.Common.EnumType.OperationState.Aborting
                                    09:11:20.331	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: gewählt: Dishcare.Dishwasher.Program.Quick65
                                    09:11:20.332	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: alter Status: BSH.Common.EnumType.OperationState.Aborting
                                    09:11:20.332	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: neuer Status: BSH.Common.EnumType.OperationState.Ready
                                    So sieht die JSON nach dem 1. aus:
                                        "Start": "06.09.22 23:48",
                                        "Ende": "06.09.22 23:49"
                                        "Start": "07.09.22 08:58",
                                        "Ende": "07.09.22 09:00"
                                    und so nach dem 2.
                                        "Start": "07.09.22 09:09",
                                        "Programm": "Speed 65°",
                                        "Ende": "07.09.22 09:10"
                                      und so nach dem 2.
                                      @chris76e
                                      Aus dem Log erkennt man, dass "ActiveProgram" zu Beginn und zu Ende triggert - am Ende mit Wert null. Damit kann man das Programm vereinfachen:
                                      // const idStatus = 'homeconnect.0.011040388898000963.status.BSH_Common_Status_OperationState';
                                      // const idProg = 'homeconnect.0.011040388898000963.programs.selected.BSH_Common_Root_SelectedProgram';
                                      var table = [];
                                      var obj = {};
                                          if(dp.state.val) {
                                              obj = {};
                                          } else {
                                      //        log(table);
                                              table.push(obj);
                                      //        log(table);
                                        @chris76e
                                        var table = [];
                                        var obj = {};
                                            if(dp.state.val) {
                                                obj = {};
                                            } else {
                                        //        log(table);
                                                table.push(obj);
                                        //        log(table);
                                        Chris76eC Online
                                        Chris76eC Online
                                        Chris76e
                                        Wird immer noch überschrieben....
                                        10:20:10.018	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: [{'Start':'06.09.22 23:48','Programm':'Intensiv 70°','Ende':'06.09.22 23:49'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'}]
                                        10:20:10.018	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: [{'Start':'06.09.22 23:48','Programm':'Intensiv 70°','Ende':'06.09.22 23:49'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 10:16','Programm':'Eco 50°','Ende':'07.09.22 10:20'}]
                                        10:23:40.013	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: [{'Start':'06.09.22 23:48','Programm':'Intensiv 70°','Ende':'06.09.22 23:49'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 10:21','Programm':'Eco 50°','Ende':'07.09.22 10:23'}]
                                        10:23:40.013	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: [{'Start':'06.09.22 23:48','Programm':'Intensiv 70°','Ende':'06.09.22 23:49'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 10:21','Programm':'Eco 50°','Ende':'07.09.22 10:23'},{'Start':'07.09.22 10:21','Programm':'Eco 50°','Ende':'07.09.22 10:23'}]
                                          @chris76e sagte: Wird immer noch überschrieben....
                                          Muss ich noch mal schauen.
