  4. Ich kann nichts mehr installieren / updaten
    6.7k
80 Beiträge 6 Kommentatoren 12.4k Aufrufe 5 Beobachtet
    @fiso sagte in Ich kann nichts mehr installieren / updaten:
    mein Motto lautet eigentlich "Never change a running system".
    Das ist ja auch kein Motto, das ist Blödsinn.
    reindeer-webR Offline
    reindeer-web
    Kannst du mir vielleicht bei der Behebung dieser Fehler behilflich sein?
    root@iobroker:/opt/iobroker# npm -v
    8.18.0
    root@iobroker:/opt/iobroker# npm ls | grep -E 'github.com|ERR'
    ├── iobroker.fully-tablet-control@0.3.6-1 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#8e2b16fdbe6bc210ecc7a6ed2aa648bc12af6ab8)
    ├── iobroker.homepilot20@0.0.32 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#a56acd4b7a5b2498201de8a2b6976e8f0e49de1b)
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: array.prototype.findindex@2.2.0 /opt/iobroker/node_modules/array.prototype.findindex
    npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
    npm ERR! extraneous: cli@0.4.5 /opt/iobroker/node_modules/cli
    npm ERR! extraneous: cliff@0.1.10 /opt/iobroker/node_modules/cliff
    npm ERR! extraneous: decimal.js@10.4.0 /opt/iobroker/node_modules/decimal.js
    npm ERR! extraneous: es-abstract@1.20.1 /opt/iobroker/node_modules/es-abstract
    npm ERR! extraneous: es-shim-unscopables@1.0.0 /opt/iobroker/node_modules/es-shim-unscopables
    npm ERR! extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
    npm ERR! extraneous: eventemitter3@3.1.2 /opt/iobroker/node_modules/eventemitter3
    npm ERR! extraneous: file-type@3.9.0 /opt/iobroker/node_modules/file-type
    npm ERR! extraneous: function.prototype.name@1.1.5 /opt/iobroker/node_modules/function.prototype.name
    npm ERR! extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
    npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
    npm ERR! extraneous: get-symbol-description@1.0.0 /opt/iobroker/node_modules/get-symbol-description
    npm ERR! extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
    npm ERR! extraneous: has-property-descriptors@1.0.0 /opt/iobroker/node_modules/has-property-descriptors
    npm ERR! extraneous: has-tostringtag@1.0.0 /opt/iobroker/node_modules/has-tostringtag
    npm ERR! extraneous: homebridge-plugin-wrapper@2.3.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
    npm ERR! extraneous: internal-slot@1.0.3 /opt/iobroker/node_modules/internal-slot
    npm ERR! invalid: iobroker.node-red@3.3.1 /opt/iobroker/node_modules/iobroker.node-red
    npm ERR! missing: iobroker.telegram@1.13.0, required by iobroker.inst@3.0.0
    npm ERR! extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
    npm ERR! extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
    npm ERR! extraneous: is-callable@1.2.4 /opt/iobroker/node_modules/is-callable
    npm ERR! extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
    npm ERR! extraneous: is-negative-zero@2.0.2 /opt/iobroker/node_modules/is-negative-zero
    npm ERR! extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
    npm ERR! extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
    npm ERR! extraneous: is-shared-array-buffer@1.0.2 /opt/iobroker/node_modules/is-shared-array-buffer
    npm ERR! extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
    npm ERR! extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
    npm ERR! extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
    npm ERR! extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
    npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
    npm ERR! extraneous: node-telegram-bot-api@0.57.0 /opt/iobroker/node_modules/node-telegram-bot-api
    npm ERR! extraneous: pkginfo@0.3.1 /opt/iobroker/node_modules/pkginfo
    npm ERR! extraneous: pseudomap@1.0.2 /opt/iobroker/node_modules/pseudomap
    npm ERR! extraneous: regexp.prototype.flags@1.4.3 /opt/iobroker/node_modules/regexp.prototype.flags
    npm ERR! extraneous: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
    npm ERR! extraneous: string-argv@0.3.1 /opt/iobroker/node_modules/string-argv
    npm ERR! extraneous: string.prototype.trimend@1.0.5 /opt/iobroker/node_modules/string.prototype.trimend
    npm ERR! extraneous: string.prototype.trimstart@1.0.5 /opt/iobroker/node_modules/string.prototype.trimstart
    npm ERR! extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
    npm ERR! extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
    npm ERR!     /opt/iobroker/.npm/_logs/2022-08-31T09_48_00_014Z-debug-0.log
    • reindeer-webR reindeer-web
      8.18.0
      @reindeer-web sagte in Ich kann nichts mehr installieren / updaten:
      bitte mehr Infos zu deinem System.
      Außerdem warum du
      root@iobroker:/op
      als root unterwegs bist un warum und wie du auf
      npm -v 8.18.0
      kommst, auch in Verbindung mit welcher node Version
      reindeer-webR 1 Antwort Letzte Antwort
        Außerdem warum du
        root@iobroker:/op
        npm -v 8.18.0
        reindeer-web
        iobroker läuft in einem Container auf einem qnap NAS.
        Ich greife darauf mit der console vom portainer zu.
        Diese Infos liefert die admin-Oberfläche vom iobroker.
        Plattform: docker
        RAM: 7.6 GB
        Node.js: v16.17.0
        NPM: v8.18.0
        In der console werden übrigens die gleichen Versionen angezeigt.
        Wie könnte ich mich denn mit einem Benutzer in putty einloggen?
          Plattform: docker
          RAM: 7.6 GB
          Node.js: v16.17.0
          NPM: v8.18.0
          Node.js: v16.17.0
          NPM: v8.18.0
          das passt nicht, und die Antwort darauf
          @homoran sagte in Ich kann nichts mehr installieren / updaten:
          npm -v 8.18.0
          kommst,
          fehlt auch noch
            Node.js: v16.17.0
            NPM: v8.18.0
            npm -v 8.18.0
            kommst,
            fehlt auch noch
            reindeer-web
            Wenn ich in der console "npm -v" kommt: 8.18.0
            und mit "node -v" kommt: v16.17.0
            Was passt nicht bzw. was müsste denn installiert sein?
              @reindeer-web
              nodejs 16.17.0 kommt im Paket mit npm 8.15.0 daher. Da hast du also npm irgendwie unorthodox zusätzlich installiert.
              Wie bist du denn da überhaupt unterwegs?
              Schau da mal rein:
              https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                @reindeer-web
                Schau da mal rein:
                reindeer-web
                Habe leider nicht verstanden, was ich auf deine Frage antworten soll.
                Ja, den link hatte ich mir schon angesehen, da steht sehr viel drin, was man machen und was man nicht machen soll.
                Ich weiß jetzt nicht, welche Schritte ich als erstes unternehmen soll.
                Mit dem Befehl
                npm ls | grep -E 'github|ERR'
                werden ja viele 'extraneous' ausgegeben. Soll ich die mit
                cd /opt/iobroker && npm prune
                bereinigen?
                  Mit dem Befehl
                  bereinigen?
                  @reindeer-web
                  Poste mal die Ausgabe zu
                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  Bitte in CodeTags eingebettet.
                    @reindeer-web
                    reindeer-web
                    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejsx86_64
                    -P: not found
                    nodejs is /usr/bin/nodejs
                    node is /usr/bin/node
                    npm is /usr/bin/npm
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                    Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48,4 kB]
                    Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                    Fetched 48,4 kB in 1s (37,0 kB/s)
                    Reading package lists... Done
                    61 packages can be upgraded. Run 'apt list --upgradable' to see them.
                    N: Unable to locate package nodejssudo
                    N: Unable to locate package ln
                    N: Unable to locate package /usr/bin/nodejs
                    [1] + Done(127)                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update
                      -P: not found
                      npm is /usr/bin/npm
                      @reindeer-web
                      Bitte sauber kopieren, da ist irgendwas durcheinander gelaufen.
                        @reindeer-web
                        reindeer-web
                        Da ist jetzt wirklich was durcheinander gekommen:
                        -------------------------     2022-08-31 15:48:48      -------------------------
                        -----                 Welcome to your ioBroker-container!                  -----
                        -----                    Startupscript is now running.                     -----
                        -----                          Please be patient!                          -----
                        -----                        Debugging information                         -----
                        -----                                System                                -----
                        -----                    arch:                x86_64                       -----
                        -----                             Docker-Image                             -----
                        -----                    image:               v6.0.0                       -----
                        -----                    build:               2022-02-25T23:46:04+00:00    -----
                        -----                               Versions                               -----
                        /opt/scripts/iobroker_startup.sh: line 48: /usr/bin/node: Permission denied
                        -----                    node:                                             -----
                        /usr/bin/env: ‘node’: Permission denied
                        -----                    npm:                                              -----
                        -----                                 ENV                                  -----
                        -----                    AVAHI:               false                        -----
                        -----                    PACKAGES:            nano                         -----
                        -----                    SETGID:              1000                         -----
                        -----                    SETUID:              1000                         -----
                        -----                  Step 1 of 5: Preparing container                   -----
                        Installing additional packages is set by ENV.
                        Checking the following Packages: nano...
                        nano is already installed.
                        0 upgraded, 0 newly installed, 0 to remove and 61 not upgraded.
                        Done.
                        -----             Step 2 of 5: Detecting ioBroker installation             -----
                        Existing installation of ioBroker detected in /opt/iobroker.
                        -----             Step 3 of 5: Checking ioBroker installation              -----
                        (Re)Setting folder permissions (This might take a while! Please be patient!)...
                        Done.
                        Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
                        Done.
                        error: exec: "node": executable file not found in $PATH
                        /opt/scripts/iobroker_startup.sh: line 199: [: !=: unary operator expected
                        -----                Step 4 of 5: Applying special settings                -----
                        Some adapters have special requirements/ settings which can be activated by the use of environment variables.
                        For more information take a look at readme.md on Github!
                        -----                    Step 5 of 5: ioBroker startup                     -----
                        Starting ioBroker...
                          -P: not found
                          npm is /usr/bin/npm
                          @reindeer-web
                          System auf Stand halten:
                          iob stop
                          sudo apt update
                          sudo apt full-upgrade
                            -----                                System                                -----
                            -----                    node:                                             -----
                            -----                    npm:                                              -----
                            -----                                 ENV                                  -----
                            Done.
                            Done.
                            Done.
                            #66
                            Den iobroker Fixer (oder was auch immer zu den obigen Ausgaben führt) auszuführen hatte ich aber auch nicht vorgeschlagen.
                              reindeer-web
                              #67
                              Auf jeden Fall startet iobroker jetzt nicht mehr.
                                #68
                                Keine Ahnung was du da treibst. Die Befehlskette von mir führt (sauber ausgeführt) jedenfalls nicht zu diesem Verhalten.
                                Installier nodejs nochmal.
                                  reindeer-web
                                  #69
                                  Mit welchem Befehl?
                                    Mit welchem Befehl?
                                    #70
                                    @reindeer-web
                                    Hast du dein System auf Stand?
                                    Wenn es sauber ist:
                                    sudo apt update
                                    sudo apt install --reinstall nodejs
                                      @reindeer-web
                                      Wenn es sauber ist:
                                      sudo apt update
                                      reindeer-web
                                      #71
                                      Habe es ausgeführt und dies war die Ausgabe:
                                      root@iobroker:/opt/iobroker# sudo apt update
                                      Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
                                      Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48,4 kB]
                                      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
                                      Get:4 https://deb.nodesource.com/node_16.x bullseye InRelease [4.586 B]
                                      Get:5 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [180 kB]
                                      Get:6 http://deb.debian.org/debian bullseye/main amd64 Packages [8.182 kB]
                                      Get:7 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages [775 B]
                                      Get:8 http://deb.debian.org/debian bullseye-updates/main amd64 Packages [2.596 B]
                                      Fetched 8.578 kB in 5s (1.793 kB/s)
                                      All packages are up to date.
                                      root@iobroker:/opt/iobroker# sudo apt install --reinstall nodejs
                                      0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
                                      Need to get 27,1 MB of archives.
                                      After this operation, 0 B of additional disk space will be used.
                                      Get:1 https://deb.nodesource.com/node_16.x bullseye/main amd64 nodejs amd64 16.17.0-deb-1nodesource1 [27,1 MB]
                                      Fetched 27,1 MB in 4s (6.749 kB/s)
                                      debconf: unable to initialize frontend: Dialog
                                      debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 78, <> line 1.)
                                      debconf: falling back to frontend: Readline
                                      (Reading database ... 30393 files and directories currently installed.)
                                      Preparing to unpack .../nodejs_16.17.0-deb-1nodesource1_amd64.deb ...
                                      Unpacking nodejs (16.17.0-deb-1nodesource1) over (16.17.0-deb-1nodesource1) ...
                                      Setting up nodejs (16.17.0-deb-1nodesource1) ...
                                      iobroker läuft jetzt wieder
                                        Jan1
                                        #72
                                        @reindeer-web
                                        warum kommt man eigentlich immer auf die Idee, wenn man schon als root user unterwegs ist, in sudo zu verwenden?
                                        • J Jan1
                                          @reindeer-web
                                          #73
                                          @jan1
                                          Die Frage ist eher, warum man auf die Idee kommt unnötigerweise überhaupt mit dem root herumzuhampeln.
                                          Dann passieren so krumme Dinge wie hier gesehen nämlich nochmal so schnell.
