  4. ERROR: Process exited with code 25
    5.1k
updateerror
147 Beiträge 11 Kommentatoren 50.2k Aufrufe 10 Beobachtet
    @d3ltoroxp
    Ja, ggf. auch noch Unterverzeichnisse beackern.
    D3ltoroxpD Offline
    D3ltoroxpD Offline
    D3ltoroxp
    schrieb am zuletzt editiert von D3ltoroxp
    #88
    Sodele, das scheint schon mal geklappt zu haben.
    Ist die Meldung so ok ?
    smarthome@iobroker:/opt/iobroker$ cd /opt/iobroker && npm prune
    npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
    npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
    added 104 packages, removed 105 packages, and changed 107 packages in 9s
    117 packages are looking for funding
      run `npm fund` for details
    Und das sieht nun so aus.
    smarthome@iobroker:/opt/iobroker$ npm ls | grep -E 'github|ERR'
    ├── iobroker.device-watcher@0.0.6 (git+ssh://git@github.com/ciddi89/ioBroker.device-watcher.git#97c46db03ddc94d4e23b13ec6947ff2b9acc3077)
    ├── iobroker.fully-tablet-control@0.3.6-1 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#765ee8e1f0efcd737098394ec22df34c1c3fadec)
    ├── iobroker.labcom@0.0.3 (git+ssh://git@github.com/LemonShock/ioBroker.labcom.git#4a6a73bb61731c98540b1a0391196f6261e7eb14)
    EDIT::
    Scheint nun wieder zu klappen konnte die Adapter updaten. Nur bei NodeRed kommt wieder der gleiche Fehler.
    • D3ltoroxpD D3ltoroxp
      EDIT::
      #89
      @d3ltoroxp
      Ja, bei node-red klemmt was.
      D3ltoroxpD 1 Antwort Letzte Antwort
        @d3ltoroxp
        D3ltoroxpD Offline
        D3ltoroxpD Offline
        D3ltoroxp
        #90
        @thomas-braun said in ERROR: Process exited with code 25:
        @d3ltoroxp
        Indem Fall müsste ich das löschen ? Aber dann ist auch alles weg, was ich darin installiert habe, die Pakete usw. Ich könnte noch meine Nodes speichern die ich erstellt habe.
        Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
          @d3ltoroxp
          #91
          @d3ltoroxp
          Keine Ahnung von node-red und wie man da irgendwas sichert. Ich würde es aber nochmal ganz frisch installieren.
            @d3ltoroxp
            GlasfaserG Offline
            GlasfaserG Offline
            #92
            @d3ltoroxp
            Zu Node-Red
            https://forum.iobroker.net/topic/24333/node-red-fullbackup/7?_=1660990232256
              @msiemers sagte in ERROR: Process exited with code 25:
              Aber das geht aktuell gerade nicht anders.
              Warum? Auf Ubuntu sollte ein root Login nicht gehen, ein User Login geht immer. Ist eine Grundeigenschaft von Ubuntu.
              Zum Thrma: Lösch die Verzeichnisse.
              msiemers
              #93
              Welches Verzeichnis soll ich löschen?
              Beim Update eines Adapters kommt nur:
              $ iobroker upgrade sql@2.1.8 --debug
              Update sql from @2.1.7 to @2.1.8
              NPM version: 8.15.0
              Installing iobroker.sql@2.1.8... (System call)
              npm ERR! code ENOTEMPTY
              host.smarthome Cannot install iobroker.sql@2.1.8: 217
              • M msiemers
                NPM version: 8.15.0
                #94
                @msiemers
                In einem Terminal ausgeführt? Oder im Admin?
                Mach es im Terminal.
                  @msiemers
                  msiemers
                  #95
                  Schon im Terminal.
                  Ich habe nun immer wieder das Problem, das die versteckten Datei Probleme mache. Diese fangen ja mit einem Punkt an. Gibt es eine Möglichkeit die alle in der Installation zu löschen, oder darf man das nicht. Ich habe schon versucht einige händisch zu löschen aber leider ohne Erfolg. Das ist viel zu aufwändig. Gefühlt will er bei jedem Updates eines anderen Adapters auch andere versteckte Dateien gelöscht haben.
                  Thomas BraunT D3ltoroxpD 2 Antworten Letzte Antwort
                  • M msiemers
                    Schon im Terminal.
                    #96
                    @msiemers
                    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2
                    • M msiemers
                      Schon im Terminal.
                      D3ltoroxpD Offline
                      D3ltoroxpD Offline
                      D3ltoroxp
                      #97
                      @msiemers Hast du das hier mit verfolgt ? Etwas weiter oben steht das selbige von mir und Thomas hat auch eine Antwort darauf gegeben in seiner Anleitung unter Teil 2 kann man das löschen lassen.
                      Den Rest musst du von Hand machen.
                      Geht aber auch über WINSCP ist etwas schneller.
                        msiemers
                        #98
                        @D3ltoroxp
                        Ja ich lese schon mit. Wollte gerade schreiben, das der Befehl hier nicht funktioniert:
                        for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
                        Ich habe diesen schon eingesetzt und bekomme immer die Meldung das der Pfad oder das Verzeichnis nicht gefunden werden kann.
                        • M msiemers
                          @D3ltoroxp
                          #99
                          wo ist hier?
                          aus dem Schnipsel kann man es nicht erkennen
                          • M msiemers
                            @D3ltoroxp
                            #100
                            @msiemers
                            In welchem Verzeichnis? Liegen da passende Verzeichnisse drin?
                            Ist das da ein Container oder eine VM oder ähnliches?
                              @msiemers
                              msiemers
                              #101
                              Der iobroker läuft in einem LXC Ubuntu Container unter Proxmox.
                              in welchem Verzeichnis stehend sollte man den Befehl denn ausführen? Die versteckten Dateien liegen ja in der verschiedensten Verzeichnissen.
                              Ich habe glaube ich gerade über eine Stunde versucht den Admin Adapter zu aktualisieren und es kann immer wieder die Meldung das irgendwelche . Dateien gelöscht werden sollen.
                              Thomas BraunT GlasfaserG HomoranH 3 Antworten Letzte Antwort
                              • M msiemers
                                #102
                                @msiemers
                                Möglich das die Shell in Containern mit RegEx nichts anfangen kann. Ein weiterer Grund für mich die Müllcontainer zu meiden.
                                • M msiemers
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #103
                                  Steht alles mehrfach hier im Thread !!
                                  Das Verzeichniss wird dir doch dazu angezeigt !
                                  • GlasfaserG Glasfaser
                                    msiemers
                                    #104
                                    @glasfaser das mag ja sein. Aber ich habe wie gesagt gefühlt schon in 50 Verzeichnissen die Dateien gelöscht.
                                    • M msiemers
                                      #105
                                      das führt mich erst recht zu der eben gestellten Frage:
                                      wo hast du es ausgeführt?
                                        @msiemers
                                        msiemers
                                        #106
                                        @thomas-braun ich kann doch nicht anderes machen, als in dem node_modules Verzeichnis diesen Befehl abzusetzen, oder muss ich auch dafür wieder in jeden Unterverzeichnis?
                                          msiemers
                                          #107
                                          @homoran in /opt/iobroker/node_modules bzw. in diversen Unterverzeichnissen.
