  4. ZigBee neue Version 1.7.x
    5.9k
1.7backupiconszigbee
217 Beiträge 40 Kommentatoren 48.0k Aufrufe 47 Beobachtet
  • JLegJ Offline
    JLegJ Offline
    JLeg
    #76
    @asgothian - 2 Tage enach dem Update auf 1.7.5 (plus nodejs 14=>16) ist zum ersten mal überhaupt der Zigbee-Adapter "einfach so" ausgestiegen:
    2022-07-14 00:17:51.456  - ESC[31merrorESC[39m: zigbee.0 (10020) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-07-14 00:17:51.464  - ESC[31merrorESC[39m: zigbee.0 (10020) unhandled promise rejection: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/package.json'
    2022-07-14 00:17:51.465  - ESC[31merrorESC[39m: zigbee.0 (10020) Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/package.json'
    2022-07-14 00:17:51.465  - ESC[31merrorESC[39m: zigbee.0 (10020) Exception-Code: ENOENT: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/package.json'
    2022-07-14 00:17:51.473  - ESC[32minfoESC[39m: zigbee.0 (10020) cleaned everything up...
    2022-07-14 00:17:51.589  - ESC[32minfoESC[39m: zigbee.0 (10020) Zigbee: disabling joining new devices.
    2022-07-14 00:17:51.974  - ESC[32minfoESC[39m: zigbee.0 (10020) terminating
    2022-07-14 00:17:51.977  - ESC[33mwarnESC[39m: zigbee.0 (10020) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-07-14 00:17:52.130  - ESC[31merrorESC[39m: zigbee.0 (10020) Failed to stop zigbee (Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/package.json')
    er scheint im falschen Directory zu suchen? K.A wodurch das ausgelöst wurde, zu der Zeit hat jedenfalls niemand rumgespielt... :)
    • JLegJ JLeg
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #77
      @jleg sagte in ZigBee neue Version 1.7.x:
      Wie kommst du darauf das er im falschen Directory sucht ? Je nach dem wie du installiert hast kann das das korrekte Directory sein. Ich gehe eher davon aus das du ein Problem mit dem Dateisystem hast.
      Ansonsten ist die Lösung:
      • zigbee Adapter deinstallieren
      • verbleibende Versionen des Zigbee-Herdsman und Zigbee-Herdsman-Converters entfernen
      • Zigbee Adapter neu installieren
      A.
      JLegJ 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        A.
        JLegJ Offline
        JLegJ Offline
        JLeg
        #78
        @asgothian sagte in ZigBee neue Version 1.7.x:
        Naja - weil ich das geprüft habe? Es ist ja alles da, aber eben eine Ebene höher (also auf derselben wie iobroker.zigbee selbst), und - hatte ich vergessen zu erwähnen - Zigbee funktioniert hervorragend, auch jetzt nach dem Neustart wieder. Herdsman & Co. werden also ‚normalerweise‘ gefunden, bis eben auf diesen merkwürdigen Aussetzer…
        • ? Offline
          #79
          Ja ich weiß die Anzeige der Batterie ist ein heißes Thema aber mit der 1.7.6 hat sich da was geändert? Wo vorher alles mit 99 & 100 % war ist nun von 30 bis 100, sind alles Xiaomi Geräte.
            arteckA Offline
            arteckA Offline
            arteck
            #80
            @brainbug ja der Converter ist wieder zu der alten Berechnung zurück..
            https://github.com/ioBroker/ioBroker.zigbee/issues/1482
            • ? Offline
              #81
              Ich hab mir zum testen den Aqara P1 gekauft weil dieser eigentlich eine Erkennungszeit bietet und hier zu steht in den Objekten:
              Time interval for detecting actions. Press pairing button right before changing this otherwise it will fail.
              Hat jemand diesen Sensor und kann mir sagen wie man die detection_interval ändert? Es bleibt, wie beim anlernen, auf 30s trotz Änderung.
                Supernils
                schrieb am zuletzt editiert von Supernils
                #82
                einer von meinen Aqara Temperatur-Sensoren ist "disconnected". Ich habe Probleme diesen wieder ins Netz zu bekommen. Pairing geht nicht, da keine Rückmeldung vom Sensor erfolgt. Löschen geht auch nicht. Sollte ich ein erzwungenes Löschen durchführen?
                Edit: Hat sich erledigt
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #83
                  @brainbug die sind intern begrentzt.. die kannst du nicht beliebig Einstellen
                  • arteckA arteck
                    #84
                    @arteck das geht dann wohl nur mit dem originalen Gateway. Weil da hab ich ein Video dazu gesehen: https://youtu.be/gTZ4C4_iD6k ab ca. 3:00 Aber die originalen 30sec sind auch schon besser.
                    AsgothianA T 2 Antworten Letzte Antwort
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #85
                      @brainbug sagte in ZigBee neue Version 1.7.x:
                      Das geht auch mit dem originalen Gateway nicht. Die eigentliche Funktion wird durch das Gateway ausgeführt.
                      A.
                      • David G.D Online
                        David G.D Online
                        David G.
                        #86
                        ich habe nochmal eine kleine Frage zum wechsel vom Koordinator.
                        Nutze den sonoff zigbee 3.0 usb dongle plus.
                        Habe mir jetzt mal einen Backupkoordinator bestellt.
                        Zum testen habe ich mal mein Backup von einer anderen HDD hochgefahren und einfach den neueb Stick angeschlossen (vor dem booten).
                        Der Zigbeeadapter wird grün, bekommt jedoch die Geräte nicht angepingt. Die Signalstärke steht auf überall auf 10.
                        Sollte man anders vorgehen? Habe das System ca 5min laufen lassen (länger hatte Stress gegeben ^^).
                        • David G.D David G.
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #87
                          @david-g das andere Netz hast du abgeschaltet und die einstellungen sind alle gleich ??
                          • arteckA arteck
                            David G.D Online
                            David G.D Online
                            David G.
                            #88
                            @arteck
                            Ja, habe ich.
                            Hab nur einen Raspberry.
                            Den hab ich runtergefahren und meine Backup-SD reingesteckt, Koordinator gewechselt und hochgefahren.
                            Auf der Backup-SD ist ein ca 2 Wochen altes iobroker Backup eingespielt. Läuft mit dem "Haupt" Koordinator problemlos.
                            Firmware am Stick hab ich nicht kontrolliert. Wird soweit ich weiß immer mit der Koordinatorfirmware ausgeliefert (sonst würde der Adapter auch nicht grün oder?).
                              @arteck
                              Ja, habe ich.
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #89
                              @david-g hast du das LOG noch.. vom Adapterstart
                              David G.D 2 Antworten Letzte Antwort
                              • arteckA arteck
                                David G.D Online
                                David G.D Online
                                David G.
                                #90
                                @arteck
                                Leider nicht.
                                Teste es heute nachmittag nochmal.
                                Da ist keiner im Haus den es nervt, wenn etwas nicht geht.
                                • arteckA arteck
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  #91
                                  @arteck
                                  Hab es doch schon geschafft.
                                  So sieht der Start vom Adapter aus:
                                  zigbee.0
                                  2022-07-31 09:25:14.969	warn	DeviceAvailability:Failed to ping 0xf0d1b8000013d3a8 Panel TW Z3
                                  zigbee.0
                                  2022-07-31 09:25:14.939	warn	DeviceAvailability:Failed to ping 0xbc33acfffeb20bf5 TRADFRI bulb GU10 WW 400lm
                                  zigbee.0
                                  2022-07-31 09:25:14.704	warn	DeviceAvailability:Failed to ping 0x84fd27fffed0858b TRADFRI bulb GU10 WS 400lm
                                  zigbee.0
                                  2022-07-31 09:25:14.451	warn	DeviceAvailability:Failed to ping 0x60a423fffeed446c TRADFRI bulb GU10 WW 400lm
                                  zigbee.0
                                  2022-07-31 09:25:14.403	warn	DeviceAvailability:Failed to ping 0x60a423fffef0ff05 TRADFRI bulb GU10 WW 400lm
                                  zigbee.0
                                  2022-07-31 09:25:14.317	warn	DeviceAvailability:Failed to ping 0x804b50fffea8bebd TRADFRI bulb GU10 WS 400lm
                                  zigbee.0
                                  2022-07-31 09:25:14.254	warn	DeviceAvailability:Failed to ping 0xcc86ecfffe952a0e TRADFRI bulb GU10 WS 400lm
                                  zigbee.0
                                  2022-07-31 09:25:14.243	warn	DeviceAvailability:Failed to ping 0xbc33acfffec026df TRADFRI bulb GU10 WW 400lm
                                  zigbee.0
                                  2022-07-31 09:25:14.174	warn	DeviceAvailability:Failed to ping 0xbc33acfffe5f8ea0 TRADFRI bulb E14 WS opal 600lm
                                  zigbee.0
                                  2022-07-31 09:25:13.981	warn	DeviceAvailability:Failed to ping 0xbc33acfffea94381 TRADFRI bulb GU10 WW 400lm
                                  zigbee.0
                                  2022-07-31 09:25:13.941	warn	DeviceAvailability:Failed to ping 0xd0cf5efffeeedcb2 TRADFRI bulb GU10 WS 400lm
                                  zigbee.0
                                  2022-07-31 09:25:13.771	warn	DeviceAvailability:Failed to ping 0x2c1165fffe17366c TRADFRIbulbE27WWclear250lm
                                  zigbee.0
                                  2022-07-31 09:25:13.649	warn	DeviceAvailability:Failed to ping 0x7cb03eaa00afc5ce Plug 01
                                  zigbee.0
                                  2022-07-31 09:25:13.536	warn	DeviceAvailability:Failed to ping 0xbc33acfffe9b50d6 TRADFRI bulb GU10 WW 400lm
                                  zigbee.0
                                  2022-07-31 09:24:50.227	info	Zigbee started
                                  zigbee.0
                                  2022-07-31 09:24:50.222	info	0x00124b002519401e (addr 5935): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                                  zigbee.0
                                  2022-07-31 09:24:50.220	info	0x00124b002513bb34 (addr 37306): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                                  zigbee.0
                                  2022-07-31 09:24:50.217	info	0xf0d1b8000013d3a8 (addr 23290): 4058075181472 - LEDVANCE SMART+ panel 60 x 60cm tunable white (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.214	info	0x842e14fffe78cb20 (addr 46126): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                                  zigbee.0
                                  2022-07-31 09:24:50.213	info	0xbc33acfffec026df (addr 64479): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.181	info	0xbc33acfffe9b50d6 (addr 48925): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.179	info	0xbc33acfffea94381 (addr 47468): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.176	info	0x804b50fffefb471f (addr 29106): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                                  zigbee.0
                                  2022-07-31 09:24:50.173	info	0xbc33acfffeb20bf5 (addr 22639): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.171	info	0x60a423fffef0ff05 (addr 49702): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.168	info	0x60a423fffeed446c (addr 19589): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.166	info	0xbc33acfffe5f8ea0 (addr 57424): LED1733G7 - IKEA TRADFRI LED bulb E14 600 lumen, dimmable, white spectrum, opal white (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.163	info	0xcc86ecfffe952a0e (addr 41784): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.161	info	0x84fd27fffed0858b (addr 32917): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.157	info	0x804b50fffea8bebd (addr 25499): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.155	info	0xd0cf5efffeeedcb2 (addr 21634): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.152	info	0x2c1165fffe17366c (addr 16013): LED1934G3_E27 - IKEA TRADFRI LED bulb E27 WW clear 250 lumen, dimmable (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.143	info	0x7cb03eaa00afc5ce (addr 13786): AB3257001NJ - OSRAM Smart+ plug (Router)
                                  zigbee.0
                                  2022-07-31 09:24:50.093	info	Currently 18 devices are joined:
                                  zigbee.0
                                  2022-07-31 09:24:50.079	info	--> transmitPower : high
                                  zigbee.0
                                  2022-07-31 09:24:50.052	info	Unable to disable LED, unsupported function.
                                  zigbee.0
                                  2022-07-31 09:24:50.040	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                                  zigbee.0
                                  2022-07-31 09:24:46.983	info	Installed Version: iobroker.zigbee@1.7.5
                                  zigbee.0
                                  2022-07-31 09:24:45.958	info	Starting Zigbee npm ...
                                  zigbee.0
                                  2022-07-31 09:24:45.955	info	delete old Backup files. keep only last 10
                                  zigbee.0
                                  2022-07-31 09:24:45.624	info	starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
                                  Wenn ich eine Gruppe oder ein einzelnes Gerät schalten möchte:
                                  zigbee.0
                                  2022-07-31 09:29:15.864	warn	Send command to 0xbc33acfffe5f8ea0 failed with: Code 205 (No network route)
                                  zigbee.0
                                  2022-07-31 09:28:55.040	warn	unread state change for group members ["0x60a423fffef0ff05","0xbc33acfffeb20bf5"]
                                  P. S.:
                                  3 Gu10 sind wirklich Stromlos.
                                    @arteck
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    P. S.:
                                    #92
                                    @david-g
                                    Setz den Port auf den Link aus /dev/serial/by-id
                                    nicht auf /dev/ttyUSBx
                                    • David G.D Online
                                      David G.D Online
                                      David G.
                                      #93
                                      Ist abgeändert.
                                      Problem bleibt 1 zu 1 bestehen.
                                      EDIT:
                                      Hab grade folgendes festgestellt. Kann das sein?
                                      Habe eine einzelne Birne Stromlos gemacht. Danach hat sich der Adapter selber neugestartet.
                                      Nun kann ich alle Birnen steuern.
                                      Wenn ich den Adapter jetzt nochmal neustarte bekommt er die Geräte auch nicht angepingt. Lassen sich dann jedoch nach kurzer Zeit schalten.
                                      EDIT2
                                      Wenn ich die Geräte vom Strom nehme, scheinen sie sich danach zu verbinden.
                                      Den Absturz vom Adapter hatte ich, weil noch nicht die aktuelle git Version installiert war (das ikea Problem).
                                      Beobachte es mal
                                        Ist abgeändert.
                                        EDIT:
                                        EDIT2
                                        Beobachte es mal
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #94
                                        @david-g sagte in ZigBee neue Version 1.7.x:
                                        in offi 1.7.5 ist es beoben.. da brauchst du nicht von GIT installieren
                                          Tassos
                                          #95
                                          Hallo ,Ich bin neu hier und weiß nicht wie ich ein thema eröffne.
                                          Ich habe ein Problem und bin am verzweifeln. Ich möchte einen Gateway für bewesserung verbinden mit meinem w-lan und es geht nicht,ich habe den Rainpoint gateway und habe alles richtig gemacht,ich habe auch einen zweiten vewrsucht ,immer wieder das gleiche,er sucht und sucht 2 minuten und nichts
