  4. iob startet nach nodejs-Update nicht mehr
    5.8k
35 Beiträge 4 Kommentatoren 3.2k Aufrufe 3 Beobachtet
    @caskstrengther jetzt bitte 2. Session im Terminal aufmachen und dort iobroker logs --watch eingeben.
    Dann in der ersten Konsole iobroker start admin
    was kommt in beiden Konsolen?
    CaskstrengtherC Offline
    Caskstrengther
    Im Watch-Fenster hagelt es diese Fehlermeldungen, auch wenn ich den Adminadapter noch gar nicht manuell gestartet habe.
    pi@raspberrypi:~ $ iobroker logs --watch
    2022-07-15 14:33:37.276  - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    2022-07-15 14:33:41.905  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
    2022-07-15 14:33:41.911  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-07-15 14:33:41.912  - info: host.raspberrypi hostname: raspberrypi, node: v16.16.0
    2022-07-15 14:33:41.913  - info: host.raspberrypi ip addresses: 192.168.178.67 fd00::d155:2e63:d52a:d39a 2003:f3:570c:8a00:e48b:95ee:ad42:b8f1 fe80::8f98:52a3:156e:d67f
    2022-07-15 14:33:44.027  - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    2022-07-15 14:35:12.062  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
    2022-07-15 14:35:12.068  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-07-15 14:35:12.069  - info: host.raspberrypi hostname: raspberrypi, node: v16.16.0
    2022-07-15 14:35:12.070  - info: host.raspberrypi ip addresses: 192.168.178.67 fd00::d155:2e63:d52a:d39a 2003:f3:570c:8a00:e48b:95ee:ad42:b8f1 fe80::8f98:52a3:156e:d67f
    2022-07-15 14:35:42.091  - error: host.raspberrypi No connection to databases possible, restart
    2022-07-15 14:35:42.105  - info: host.raspberrypi iobroker _restart
    2022-07-15 14:35:47.721  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
    2022-07-15 14:35:47.727  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-07-15 14:35:47.728  - info: host.raspberrypi hostname: raspberrypi, node: v16.16.0
    2022-07-15 14:35:47.729  - info: host.raspberrypi ip addresses: 192.168.178.67 fd00::d155:2e63:d52a:d39a 2003:f3:570c:8a00:e48b:95ee:ad42:b8f1 fe80::8f98:52a3:156e:d67f
    2022-07-15 14:36:17.763  - error: host.raspberrypi No connection to databases possible, restart
    2022-07-15 14:36:17.777  - info: host.raspberrypi iobroker _restart
    2022-07-15 14:36:23.430  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
    2022-07-15 14:36:23.436  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-07-15 14:36:23.437  - info: host.raspberrypi hostname: raspberrypi, node: v16.16.0
    2022-07-15 14:36:23.438  - info: host.raspberrypi ip addresses: 192.168.178.67 fd00::d155:2e63:d52a:d39a 2003:f3:570c:8a00:e48b:95ee:ad42:b8f1 fe80::8f98:52a3:156e:d67f
    2022-07-15 14:36:53.459  - error: host.raspberrypi No connection to databases possible, restart
    2022-07-15 14:36:53.473  - info: host.raspberrypi iobroker _restart
    2022-07-15 14:36:58.956  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
    2022-07-15 14:36:58.962  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-07-15 14:36:58.963  - info: host.raspberrypi hostname: raspberrypi, node: v16.16.0
    2022-07-15 14:36:58.964  - info: host.raspberrypi ip addresses: 192.168.178.67 fd00::d155:2e63:d52a:d39a 2003:f3:570c:8a00:e48b:95ee:ad42:b8f1 fe80::8f98:52a3:156e:d67f
    Das andere Fenster meldet:
    • CaskstrengtherC Caskstrengther
      @caskstrengther
      systemctl status iobroker
      CaskstrengtherC 1 Antwort Letzte Antwort
      • crunchipC Abwesend
        crunchipC Abwesend
        @caskstrengther eventuell hilft es https://forum.iobroker.net/post/824315
          @caskstrengther
          Caskstrengther
          pi@raspberrypi:/opt/iobroker/iobroker-data $ systemctl status iobroker
          ● iobroker.service - ioBroker Server
             Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
             Active: active (running) since Sat 2022-07-16 14:11:00 CEST; 22s ago
               Docs: http://iobroker.net
           Main PID: 16965 (iobroker.js-con)
              Tasks: 11 (limit: 4915)
             CGroup: /system.slice/iobroker.service
                     └─16965 iobroker.js-controller
          Jul 16 14:11:00 raspberrypi systemd[1]: Started ioBroker Server.
          CaskstrengtherC Thomas BraunT 2 Antworten Letzte Antwort
            Caskstrengther
            @caskstrengther
            Ich habe mir mal die Dateien im iobroker-Verzeichnis angesehen.
            Ist es normal, das "objects.jsonl" sooooo groß ist?
            pi@raspberrypi:/opt/iobroker/iobroker-data $ ls -lisa
            insgesamt 1112584
            395214       4 drwxrwxr-x+  7 iobroker iobroker       4096 Jul 16 14:12 .
            130047       4 drwxrwxr-x+  6 iobroker iobroker       4096 Jul 15 16:52 ..
            390150       4 drwxrwxr-x+  2 iobroker iobroker       4096 Jul 15 02:45 backitup
            395217      12 drwxrwxr-x+  2 iobroker iobroker      12288 Jul 15 14:11 backup-objects
            395265       4 drwxrwxr-x+ 16 iobroker iobroker       4096 Feb 23 11:41 files
            395215       8 -rw-rwxr--+  1 iobroker iobroker       4718 Mai 10 20:18 iobroker.json
            395366       4 -rw-rwxr--+  1 iobroker iobroker          3 Jul 15 14:21 notifications.json
            391718    5432 -rw-rwxr--+  1 iobroker iobroker    5558617 Feb  7 13:11 objects.json.bak.migrated
            391766 1097960 -rw-rwxr--+  1 iobroker iobroker 1124304666 Jul 15 16:39 objects.jsonl
            525495       4 drwxrwxr-x+  2 iobroker iobroker       4096 Jul 16 14:13 objects.jsonl.lock
            389882    5432 -rw-rwxr--+  1 iobroker iobroker    5558617 Feb  7 13:11 objects.json.migrated
            393958     412 -rw-rwxr--+  1 iobroker iobroker     420176 Feb  7 13:10 states.json.bak.migrated
            388621       0 -rw-rwxr--+  1 iobroker iobroker          0 Aug 27  2021 states.json.broken
            388908    2888 -rw-rwxr--+  1 iobroker iobroker    2956555 Jul 15 16:39 states.jsonl
            388622     412 -rw-rwxr--+  1 iobroker iobroker     420205 Feb  7 13:11 states.json.migrated
            396939       4 drwxrwxr-x+  2 iobroker iobroker       4096 Mär 12  2021 yahka.0.hapdata
              @caskstrengther sagte in iob startet nach nodejs-Update nicht mehr:
              Nicht mehr?
              Das sollte eigentlich mehr ausspucken. Bei mir:
                   Active: active (running) since Thu 2022-07-14 01:39:03 CEST; 2 days ago
                 Main PID: 535 (iobroker.js-con)
                    Tasks: 370 (limit: 8986)
                      CPU: 12h 54min 54.233s
                           ├─   535 iobroker.js-controller
                           ├─   754 io.history.0
                           ├─   968 io.whatsapp-cmb.0
                           ├─  1013 io.mihome-vacuum.0
                           ├─  1028 io.mihome.0
                           ├─  1056 io.rpi2.0
                           ├─  1116 io.tr-064.0
                           ├─  1131 io.zigbee.0
                           ├─  1142 io.backitup.0
                           ├─  1188 io.ble.0
                           ├─  1203 /usr/bin/node /opt/iobroker/node_modules/iobroker.ble/build/scanProcess -s
                           ├─  1210 io.echarts.0
                           ├─  1225 io.followthesun.0
                           ├─  1247 io.govee.0
                           ├─  1262 io.info.0
                           ├─  1285 io.iot.0
                           ├─  1371 io.miio.0
                           ├─  1556 io.nina.0
                           ├─  1877 io.pi-hole.0
                           ├─  1903 io.sainlogic.0
                           ├─  1918 io.simple-api.0
                           ├─  1974 io.socketio.0
                           ├─  1989 io.switchbot-hub.0
                           ├─  2004 io.tado.0
                           ├─  2044 io.tradfri.0
                           ├─  2098 io.web.0
                           ├─  2117 io.ws.0
                           ├─  2132 io.tankerkoenig.0
                           ├─  2256 io.nuki-extended.0
                           ├─ 44628 io.trashschedule.0
                           ├─ 52883 io.admin.0
                           ├─ 60253 io.alexa2.0
                           ├─136025 io.javascript.0
                           └─202094 io.parcel.0
              Jul 16 03:43:00 chet sudo[172541]: iobroker : PWD=/opt/iobroker/node_modules/iobroker.backitup ; USER=root ; COMMAND=/usr/bin/umount /opt/iobroker/backups
              Jul 16 03:43:00 chet sudo[172541]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
              Jul 16 03:43:00 chet sudo[172541]: pam_unix(sudo:session): session closed for user root
              Und das ist nicht mal die komplette Ausgabe.
                @caskstrengther
                insgesamt 1112584
                @caskstrengther
                Wie groß ist die Datei denn?
                Die lisa heißt besser lisah oder lh
                Dann ist das auch übersichtlicher.
                  @caskstrengther
                  insgesamt 1112584
                  @caskstrengther
                  Schau mal hier rein:
                  https://forum.iobroker.net/topic/56379/zu-viele-objekte/5
                    Nicht mehr?
                                 ├─   754 io.history.0
                                 ├─  1028 io.mihome.0
                                 ├─  1056 io.rpi2.0
                                 ├─  1116 io.tr-064.0
                                 ├─  1131 io.zigbee.0
                                 ├─  1188 io.ble.0
                                 ├─  1247 io.govee.0
                                 ├─  1262 io.info.0
                                 ├─  1285 io.iot.0
                                 ├─  1371 io.miio.0
                                 ├─  1556 io.nina.0
                                 ├─  2004 io.tado.0
                                 ├─  2098 io.web.0
                                 ├─  2117 io.ws.0
                                 ├─ 52883 io.admin.0
                    Caskstrengther
                    Nein - nochmal:
                       Active: active (running) since Sat 2022-07-16 14:24:04 CEST; 22s ago
                     Main PID: 17479 (iobroker.js-con)
                               └─17479 iobroker.js-controller
                    Jul 16 14:24:04 raspberrypi systemd[1]: Started ioBroker Server.
                      @caskstrengther
                      Caskstrengther
                      Diese Datei ist 1,1GB groß?!?
                      pi@raspberrypi:/opt/iobroker/iobroker-data $ ls -lh
                      insgesamt 1,1G
                      drwxrwxr-x+  2 iobroker iobroker 4,0K Jul 15 02:45 backitup
                      drwxrwxr-x+  2 iobroker iobroker  12K Jul 15 14:11 backup-objects
                      drwxrwxr-x+ 16 iobroker iobroker 4,0K Feb 23 11:41 files
                      -rw-rwxr--+  1 iobroker iobroker 4,7K Mai 10 20:18 iobroker.json
                      -rw-rwxr--+  1 iobroker iobroker 5,4M Feb  7 13:11 objects.json.bak.migrated
                      -rw-rwxr--+  1 iobroker iobroker 1,1G Jul 15 16:39 objects.jsonl
                      drwxrwxr-x+  2 iobroker iobroker 4,0K Jul 16 14:26 objects.jsonl.lock
                      -rw-rwxr--+  1 iobroker iobroker 5,4M Feb  7 13:11 objects.json.migrated
                      -rw-rwxr--+  1 iobroker iobroker 411K Feb  7 13:10 states.json.bak.migrated
                      -rw-rwxr--+  1 iobroker iobroker 2,9M Jul 15 16:39 states.jsonl
                      -rw-rwxr--+  1 iobroker iobroker 411K Feb  7 13:11 states.json.migrated
                      drwxrwxr-x+  2 iobroker iobroker 4,0K Mär 12  2021 yahka.0.hapdata
                        insgesamt 1,1G
                        Deutlich zu groß um damit umgehen zu können.
                        iobroker list adapters
                        bitte zeigen. Ist da einer der 'üblichen Verdächtigen' wie ble, fronius, withings oder (da war noch irgendein Adapter...) installiert?
                          Caskstrengther
                          Ich hatte vorher einmal das hier gemacht...
                          pi@raspberrypi:/opt/iobroker/iobroker-data $ iobroker list instances
                          ... und bei der Größe der Datei ist mir die Fehlermeldung irgendwie auch klar.
                          Jetzt Dein Befehl:
                          pi@raspberrypi:/opt/iobroker/iobroker-data $ iobroker list adapters
                          The same...
                            Jetzt Dein Befehl:
                            The same...
                            Caskstrengther
                            @caskstrengther
                            Ich Verzeichnis "backup-objects" ist das gepackte GZ-File 1000fach kleiner...
                              @caskstrengther
                              @caskstrengther
                              Ja, diese Daten kann man ganz gut komprimieren.
                                @caskstrengther
                                Caskstrengther
                                Soll ich eine Sicherung der Datei aus "backup-objects" einfach mal zurückspielen?
                                  @caskstrengther
                                  Die wird sich wieder aufblasen.
                                  Mach es über die Kommandozeile, wenn das noch funktioniert:
                                  https://forum.iobroker.net/topic/56379/zu-viele-objekte/3
                                    @caskstrengther
                                    Caskstrengther
                                    Die Kommandos funktionieren leider nicht - selbe Meldung:
                                    pi@raspberrypi:/opt/iobroker/iobroker-data $ iob list instances
                                    Was sind das eigentlich für *migrated-Dateien im Verzeichnis? Kann ich die nicht einfach zurückspielen?
                                    insgesamt 1,1G
                                    -rw-rwxr--+  1 pi       pi       6,7M Jul 16 14:48 2022-07-15_08-11_objects.jsonl
                                    drwxrwxr-x+  2 iobroker iobroker  12K Jul 16 14:44 backup-objects
                                    Hier sieht man z.B. auch, dass die "objects.jsonl" von vor dem Update (oberste Datei) eine Größe von 6,7MB hatte.
                                    Die aktuelle ist 1,1GB groß...
                                      insgesamt 1,1G
                                      Caskstrengther
                                      @caskstrengther
                                      ich konnte das Problem nun lösen.
                                      Ich habe aus dem Unterverzeichnis "backup-objects" die vor dem Update gesicherten Dateien "objects.jsonl" und "states.jsonl" zurückgespielt, einen "iob fix" laufen lassen - anschließend startete der iobroker wieder.
                                      Danach wieder "iob stop", "iob update", "iob upgrade self" und "iob start" - alles sieht gut aus.
                                      Ich danke Euch allen, die sich so sehr um die Lösung meines Problems gekümmert haben! 💋
