  4. iob startet nach nodejs-Update nicht mehr
    5.8k
35 Beiträge 4 Kommentatoren 3.2k Aufrufe 3 Beobachtet
    @caskstrengther sagte in iob startet nach nodejs-Update nicht mehr:
    systemctl status iobroker
    Nicht mehr?
    Das sollte eigentlich mehr ausspucken. Bei mir:
    ● iobroker.service - ioBroker Server
         Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
         Active: active (running) since Thu 2022-07-14 01:39:03 CEST; 2 days ago
           Docs: http://iobroker.net
       Main PID: 535 (iobroker.js-con)
          Tasks: 370 (limit: 8986)
            CPU: 12h 54min 54.233s
         CGroup: /system.slice/iobroker.service
                 ├─   535 iobroker.js-controller
                 ├─   754 io.history.0
                 ├─   968 io.whatsapp-cmb.0
                 ├─  1013 io.mihome-vacuum.0
                 ├─  1028 io.mihome.0
                 ├─  1056 io.rpi2.0
                 ├─  1116 io.tr-064.0
                 ├─  1131 io.zigbee.0
                 ├─  1142 io.backitup.0
                 ├─  1188 io.ble.0
                 ├─  1203 /usr/bin/node /opt/iobroker/node_modules/iobroker.ble/build/scanProcess -s
                 ├─  1210 io.echarts.0
                 ├─  1225 io.followthesun.0
                 ├─  1247 io.govee.0
                 ├─  1262 io.info.0
                 ├─  1285 io.iot.0
                 ├─  1371 io.miio.0
                 ├─  1556 io.nina.0
                 ├─  1877 io.pi-hole.0
                 ├─  1903 io.sainlogic.0
                 ├─  1918 io.simple-api.0
                 ├─  1974 io.socketio.0
                 ├─  1989 io.switchbot-hub.0
                 ├─  2004 io.tado.0
                 ├─  2044 io.tradfri.0
                 ├─  2098 io.web.0
                 ├─  2117 io.ws.0
                 ├─  2132 io.tankerkoenig.0
                 ├─  2256 io.nuki-extended.0
                 ├─ 44628 io.trashschedule.0
                 ├─ 52883 io.admin.0
                 ├─ 60253 io.alexa2.0
                 ├─136025 io.javascript.0
                 └─202094 io.parcel.0
    Jul 16 03:43:00 chet sudo[172541]: iobroker : PWD=/opt/iobroker/node_modules/iobroker.backitup ; USER=root ; COMMAND=/usr/bin/umount /opt/iobroker/backups
    Jul 16 03:43:00 chet sudo[172541]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Jul 16 03:43:00 chet sudo[172541]: pam_unix(sudo:session): session closed for user root
    Und das ist nicht mal die komplette Ausgabe.
    CaskstrengtherC Offline
    Caskstrengther
    Nein - nochmal:
    pi@raspberrypi:/opt/iobroker/iobroker-data $ systemctl status iobroker
       Active: active (running) since Sat 2022-07-16 14:24:04 CEST; 22s ago
     Main PID: 17479 (iobroker.js-con)
        Tasks: 11 (limit: 4915)
               └─17479 iobroker.js-controller
    Jul 16 14:24:04 raspberrypi systemd[1]: Started ioBroker Server.
      @caskstrengther
      Wie groß ist die Datei denn?
      Die lisa heißt besser lisah oder lh
      Dann ist das auch übersichtlicher.
      Caskstrengther
      Diese Datei ist 1,1GB groß?!?
      pi@raspberrypi:/opt/iobroker/iobroker-data $ ls -lh
      insgesamt 1,1G
      drwxrwxr-x+  2 iobroker iobroker 4,0K Jul 15 02:45 backitup
      drwxrwxr-x+  2 iobroker iobroker  12K Jul 15 14:11 backup-objects
      drwxrwxr-x+ 16 iobroker iobroker 4,0K Feb 23 11:41 files
      -rw-rwxr--+  1 iobroker iobroker 4,7K Mai 10 20:18 iobroker.json
      -rw-rwxr--+  1 iobroker iobroker    3 Jul 15 14:21 notifications.json
      -rw-rwxr--+  1 iobroker iobroker 5,4M Feb  7 13:11 objects.json.bak.migrated
      -rw-rwxr--+  1 iobroker iobroker 1,1G Jul 15 16:39 objects.jsonl
      drwxrwxr-x+  2 iobroker iobroker 4,0K Jul 16 14:26 objects.jsonl.lock
      -rw-rwxr--+  1 iobroker iobroker 5,4M Feb  7 13:11 objects.json.migrated
      -rw-rwxr--+  1 iobroker iobroker 411K Feb  7 13:10 states.json.bak.migrated
      -rw-rwxr--+  1 iobroker iobroker    0 Aug 27  2021 states.json.broken
      -rw-rwxr--+  1 iobroker iobroker 2,9M Jul 15 16:39 states.jsonl
      -rw-rwxr--+  1 iobroker iobroker 411K Feb  7 13:11 states.json.migrated
      drwxrwxr-x+  2 iobroker iobroker 4,0K Mär 12  2021 yahka.0.hapdata
      • CaskstrengtherC Caskstrengther
        insgesamt 1,1G
        Deutlich zu groß um damit umgehen zu können.
        iobroker list adapters
        bitte zeigen. Ist da einer der 'üblichen Verdächtigen' wie ble, fronius, withings oder (da war noch irgendein Adapter...) installiert?
        CaskstrengtherC 1 Antwort Letzte Antwort
          Caskstrengther
          Ich hatte vorher einmal das hier gemacht...
          pi@raspberrypi:/opt/iobroker/iobroker-data $ iobroker list instances
          Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
          ... und bei der Größe der Datei ist mir die Fehlermeldung irgendwie auch klar.
          Jetzt Dein Befehl:
          pi@raspberrypi:/opt/iobroker/iobroker-data $ iobroker list adapters
          The same...
            Jetzt Dein Befehl:
            The same...
            Caskstrengther
            @caskstrengther
            Ich Verzeichnis "backup-objects" ist das gepackte GZ-File 1000fach kleiner...
              @caskstrengther
              @caskstrengther
              Ja, diese Daten kann man ganz gut komprimieren.
                @caskstrengther
                Caskstrengther
                Soll ich eine Sicherung der Datei aus "backup-objects" einfach mal zurückspielen?
                  @caskstrengther
                  Die wird sich wieder aufblasen.
                  Mach es über die Kommandozeile, wenn das noch funktioniert:
                  https://forum.iobroker.net/topic/56379/zu-viele-objekte/3
                    @caskstrengther
                    Caskstrengther
                    Die Kommandos funktionieren leider nicht - selbe Meldung:
                    pi@raspberrypi:/opt/iobroker/iobroker-data $ iob list instances
                    Was sind das eigentlich für *migrated-Dateien im Verzeichnis? Kann ich die nicht einfach zurückspielen?
                    insgesamt 1,1G
                    -rw-rwxr--+  1 pi       pi       6,7M Jul 16 14:48 2022-07-15_08-11_objects.jsonl
                    drwxrwxr-x+  2 iobroker iobroker  12K Jul 16 14:44 backup-objects
                    Hier sieht man z.B. auch, dass die "objects.jsonl" von vor dem Update (oberste Datei) eine Größe von 6,7MB hatte.
                    Die aktuelle ist 1,1GB groß...
                      insgesamt 1,1G
                      Caskstrengther
                      @caskstrengther
                      ich konnte das Problem nun lösen.
                      Ich habe aus dem Unterverzeichnis "backup-objects" die vor dem Update gesicherten Dateien "objects.jsonl" und "states.jsonl" zurückgespielt, einen "iob fix" laufen lassen - anschließend startete der iobroker wieder.
                      Danach wieder "iob stop", "iob update", "iob upgrade self" und "iob start" - alles sieht gut aus.
                      Ich danke Euch allen, die sich so sehr um die Lösung meines Problems gekümmert haben! 💋
