  4. Test Adapter fb-checkpresence v1.1.x
    1.0k
    6.1k
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 382.2k Aufrufe 78 Beobachtet
  • DiginixD Diginix
    @afuerhoff Konnte heute die GIT Version testen.
    devicelist:
        "List":
            "Item": [
                "Index": "67",
                "IPAddress": "192.168.179.5",
                "MACAddress": "08:C5:E1:52:4F:05",
                "Active": "1",
                "HostName": "Samsung-S9",
                "InterfaceType": "802.11",
                "X_AVM-DE_Port": "0",
                "X_AVM-DE_Speed": "0",
                "X_AVM-DE_UpdateAvailable": "0",
                "X_AVM-DE_UpdateSuccessful": "unknown",
                "X_AVM-DE_InfoURL": "",
                "X_AVM-DE_Model": "",
                "X_AVM-DE_URL": "",
                "X_AVM-DE_Guest": "1",
                "X_AVM-DE_VPN": "0",
                "X_AVM-DE_WANAccess": "granted",
                "X_AVM-DE_Disallow": "0"
                "Index": "112",
                "MACAddress": "48:51:B7:17:9F:17",
                "Active": "1",
                "HostName": "deichnb0190",
                "X_AVM-DE_URL": "",
    devicelist2:
        "status": "new",
        "dp": "fb-devices.Samsung-S9",
        "hn": "Samsung-S9",
        "hnOrg": "Samsung-S9",
        "mac": "5A:96:B1:65:45:72",
        "ip": "192.168.2.120",
        "active": false,
        "data":
            "Index": "66",
            "IPAddress": "192.168.2.120",
            "MACAddress": "5A:96:B1:65:45:72",
            "Active": "0",
            "InterfaceType": "",
            "X_AVM-DE_URL": "",
            "X_AVM-DE_Guest": "0",
        "interfaceType": "",
        "speed": 0,
        "guest": false
        "status": "new",
        "hn": "Samsung-S9",
        "mac": "08:C5:E1:52:4F:05",
        "ip": "192.168.179.5",
        "active": true,
        "data":
            "Index": "67",
            "Active": "1",
            "X_AVM-DE_URL": "",
        "interfaceType": "802.11",
        "speed": 0,
        "guest": true
        "status": "new",
        "dp": "fb-devices.deichnb0190",
        "hn": "deichnb0190",
        "hnOrg": "deichnb0190",
        "mac": "48:51:B7:17:9F:17",
        "active": true,
        "data":
            "Index": "112",
            "Active": "1",
            "X_AVM-DE_URL": "",
        "speed": 0,
        "guest": true
        "status": "unchanged",
        "active": true,
        "data":
            "Index": "112",
            "Active": "1",
            "X_AVM-DE_URL": "",
        "speed": 0,
        "guest": true
    Samsung-S9 ist sonst nie im GästeWLAN, aber für den Test immer als weiteres Gerät und tauch immer nur einmal in den Objekten auf. deichnb0190 ist weiterhin immer zwei mal in den Objekten.
    Bin gespannt ob devicelist2 Aufschluss gibt.
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    #743
    @diginix sagte in Test Adapter fb-checkpresence v1.1.x:
    Hallo, ich habe eine neue Version auf Github hochgeladen. Bitte testen, ob das Guest Problem behoben ist.
    DiginixD 2 Antworten Letzte Antwort
    • afuerhoffA afuerhoff
      DiginixD Offline
      DiginixD Offline
      Diginix
      #744
      @afuerhoff 1.1.18 von git installiert. Morgen wird das Gastnetz wieder verwendet, dann kann ich testen.
      ..:: So long! Tom ::..
        DiginixD Offline
        DiginixD Offline
        Diginix
        #745
        @afuerhoff Mit der letzten Git Version sind die doppelte Gastnetz Geräte verschwunden.
        Hast du nun einfach alles doppelte auf unique gefiltert oder die echte Ursache gefunden? ;-)
        • DiginixD Diginix
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          #746
          @diginix
          Ich vergleich die Liste der aus der Fritzbox ausgelesenen Devices mit der Liste der angelegten Datenpunkte und generiere daraus eine neue Liste. Neue Devices werden daraus dann z.B angelegt.
          In der Funktion hatte ich einen Fehler, den ich aber nicht selbst nachstellen konnte. Das muss bei dir eine ganz spezielle Konstellation im Netzwerk gewesen sein. Der Fehler ist schon seit etlichen Versionen drin und keinem aufgefallen.
          Danke für Deine Tests🙂
          • afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            #747
            die Version 1.1.19 ist in Kürze im Latest.
            Änderungen:
            • Fehler doppelte Guest Devices behoben
              afuerhoffA Offline
              afuerhoff
              #748
              Hallo, auf Github ist eine Testversion hochgeladen. Mit der kann man die Presence Prüfung manuell anstoßen. Wenn die Funktion aus einem Script gesendet wurde, ist jeder weitere Versuch für 10s gesperrt. Falls erfolgreich, dann kommt true zurück. Wenn gesperrt dann false.
              Viel Spaß beim Testen. Bin gespannt auf euer Feedback.
              sendTo('fb-checkpresence.0', 'triggerPresence', {}
              , function (result) {
              log(result, 'info');
              • G Offline
                gammler2003
                #749
                heute wollte ich die Familienmitglieder ändern. Ich klicke auf "Familienmitglied hinzufügen", das neue Fenster öffnet sich aber es wird nichts angezeigt und ich kann nichts suchen. Ich meine in der Vergangenheit wurden direkt die bekannten Geräte der Fritzbox angezeigt. Auch nach einer Eingabe ändern sich nichts.
                Mache ich etwas falsch oder ist dieser Fehler bekannt? Falls es sich um einen Fehler handelt, gibt es Ideen wie ich dieses behebe.
                Vielen Dank vorab für eure Hilfe.
                afuerhoffA Thomas BraunT 2 Antworten Letzte Antwort
                • G gammler2003
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  #750
                  @gammler2003
                  der Adapter lief aber zu dem Zeitpunkt korrekt?
                  Adapter neu gestartet und nachdem grün nochmal versucht?
                  • G gammler2003
                    #751
                    @gammler2003
                    Welche Version beim Admin? Für Version 6.2.x gibt es ein Issue. Man kann einige Einstellungen in den Adaptern nicht ändern und speichern.
                    G 1 Antwort Letzte Antwort
                      @gammler2003
                      gammler2003
                      #752
                      @thomas-braun 5.3.8
                      @afuerhoff Adapter lief super und war grün. Neustart (Adapter, ioBroker) hat nichts gebracht. Habe ihn dann komplett deinstalliert und wieder installiert und nun funktioniert es wieder.
                      Vielen Dank euch beiden!
                      • E Offline
                        earl80
                        schrieb am zuletzt editiert von earl80
                        #753
                        Hallo, ich habe gestern wegen VPN Wireguard von der 7490 auf die Fritzbox 7590 (5 GHz WIFI) mit der Laborsoftware 7.39 gewechselt. Seither habe ich das Problem, dass ich im Mesh (also im Mesh Repeater Netzwerk mit 2,4 GHz-Band) nicht mehr als presence - egal ob mit MAC, IP, oder Name - angezeigt werde. Wenn ich in der Fritzbox u. nicht im Repeater eingebucht bin, funktioniert es... Bei der 7490 hatte ich solche Probleme noch nicht. Sind Probleme mit der FW u. der 7590 bekannt? Oder liegt es vll. am WiFi Band, da die 7590 5Ghz hat, der Repeater aber nur 2,4Ghz, oder was könnte das Problem sein?
                        • E earl80
                          afuerhoffA Offline
                          afuerhoffA Offline
                          afuerhoff
                          #754
                          @earl80
                          Sind die Mesh Repeater richtig angemeldet an der Fritzbox?
                          E 2 Antworten Letzte Antwort
                            @earl80
                            earl80
                            #755
                            @afuerhoff Ich denke ja.
                            Ich habe heute auch den neuen Repeater Fritz 1200 bekommen und eingebunden, weil ich dachte/hoffte, dass es an den unterschiedlichen WLAN Frequenzen liegt. Aber im Mesh werde ich leider nicht als Presence angezeigt...
                              @earl80
                              earl80
                              #756
                              @afuerhoff Mir ist gerade aufgefallen, dass mit dem neuen Repeater die Anzahl der Geräte bei Family Members stimmt. So passt es also nur bei den eigentlichen Namen nicht. Jetzt kann ich die Skripte anpassen, kurios ist es dennoch...
                                afuerhoffA Offline
                                afuerhoff
                                #757
                                Hallo, mir ist gerade aufgefallen, dass beim Drücken des Buttons "Familienmitglieder hinzufügen" die in der Tabelle vorhandenen Familienmitglieder nicht korrekt in der Dialogbox angehakt werden. Dies passiert in Abhängigkeit der Einstellung MAC, IP oder Hostname.
                                Ebenfalls gibt es wohl ein Problem, dass die Dialogbox nicht korrekt angezeigt werden soll.
                                Es taucht dort ein doppelter Header auf.
                                Kann das einer von euch nachvollziehen?
                                Danke im Voraus für Rückmeldungen.
                                ? ? 2 Antworten Letzte Antwort
                                  #758
                                  @afuerhoff ja ist bei mir auch:
                                    #759
                                    @afuerhoff also bei mir ist alles bestens, keine Anzeigefehler oder so.
                                    Version 1.1.19
                                      afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #760
                                      @brainbug sagte in Test Adapter fb-checkpresence v1.1.x:
                                      Benutzt Du einen speziellen Browser?
                                        #761
                                        @afuerhoff Chrome wie auf jedem Gerät.
                                          afuerhoffA Offline
                                          afuerhoffA Offline
                                          afuerhoff
                                          #762
                                          @brainbug
                                          Ich nutze auch Chrome und habe den Fehler nicht. Bin gerade überfragt woran es liegen könnte.
