  4. HAM (homebridge-ewlink) seit einer Woche tot
    5.8k
48 Beiträge 4 Kommentatoren 3.3k Aufrufe 2 Beobachtet
  • haselchenH haselchen
    @wolfgangfb
    Wie sieht deine Einstellung im Adapter aus?
    Hast du das Log vom Adapterstart und kannst es hier mal bitte zeigen?
    W Offline
    W Offline
    WolfgangFB
    @haselchen sagte in HAM (homebridge-ewlink) seit einer Woche tot:
    @wolfgangfb
    Wrapper-Modus
    Unsicheren Homebridge Modus verwenden in inaktiv.
    Zusaätzliche npm Module: homebridge-ewlink
    Konfiguration:
      "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
      "accessories": [
      "platforms": [
          "platform": "eWeLink",
          "name": "eWeLink",
          "countryCode": "49",
          "username": "xxx@yyyy",
          "password": "xxxxxxxxx"
    2022-07-13 19:43:34.369  - info: ham.0 (13082) Got terminate signal TERMINATE_YOURSELF
    2022-07-13 19:43:34.377  - info: ham.0 (13082) cleaned everything up...
    2022-07-13 19:43:34.458  - info: ham.0 (13082) terminating
    2022-07-13 19:43:34.460  - info: ham.0 (13082) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-07-13 19:43:35.179  - info: host.raspberrypi instance system.adapter.ham.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-07-13 19:43:51.341  - info: ham.0 (27203) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v14.19.1, js-controller: 4.0.21
    2022-07-13 19:43:51.383  - info: ham.0 (27203) Install/Update the following Libraries: homebridge-ewelink
    2022-07-13 19:43:51.384  - info: ham.0 (27203) Install/Update homebridge-ewelink
    2022-07-13 19:43:51.385  - info: ham.0 (27203) All Libraries installed/updated
    2022-07-13 19:43:54.236  - info: ham.0 (27203) updateDev Zaehler-1: name = Zaehler-1 /type= 1
    2022-07-13 19:43:54.239  - info: ham.0 (27203) updateChannel Zaehler-1.Accessory-Information: name =
    2022-07-13 19:43:54.242  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.Identify: value = true /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
    2022-07-13 19:43:54.243  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.Manufacturer: value = coolkit /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
    2022-07-13 19:43:54.243  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.Model: value = PSF-X67 (PSF-B67-GL) /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
    2022-07-13 19:43:54.244  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.Name: value = Zaehler-1 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
    2022-07-13 19:43:54.246  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.Serial-Number: value = 1001553941SWX /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
    2022-07-13 19:43:54.247  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.Firmware-Revision: value = 3.5.0 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
    2022-07-13 19:43:54.248  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.Configured-Name: value = Zaehler-1 /common= {"type":"string","read":true,"write":true,"role":"text","name":"Configured Name","unit":""}
    2022-07-13 19:43:54.250  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.Accessory-Flags: value = 0 /common= {"type":"number","min":0,"max":4294967295,"read":true,"write":false,"role":"value","name":"Accessory Flags","unit":""}
    2022-07-13 19:43:54.251  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.App-Matching-Identifier: value =  /common= {"type":"string","read":true,"write":false,"role":"text","name":"App Matching Identifier","unit":""}
    2022-07-13 19:43:54.253  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.Configured-Name: value =  /common= {"type":"string","read":true,"write":true,"role":"text","name":"Configured Name","unit":""}
    2022-07-13 19:43:54.254  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.Hardware-Finish: value =  /common= {"type":"string","read":true,"write":false,"role":"text","name":"Hardware Finish","unit":""}
    2022-07-13 19:43:54.255  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.Hardware-Revision: value =  /common= {"type":"string","read":true,"write":false,"role":"text","name":"Hardware Revision","unit":""}
    2022-07-13 19:43:54.256  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.Product-Data: value =  /common= {"type":"string","read":true,"write":false,"role":"text","name":"Product Data","unit":""}
    2022-07-13 19:43:54.257  - info: ham.0 (27203) updateState Zaehler-1.Accessory-Information.Software-Revision: value =  /common= {"type":"string","read":true,"write":false,"role":"text","name":"Software Revision","unit":""}
    2022-07-13 19:43:54.258  - info: ham.0 (27203) updateChannel Zaehler-1.Switch: name =
    2022-07-13 19:43:54.259  - info: ham.0 (27203) updateState Zaehler-1.Switch.On: value = false /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
    2022-07-13 19:43:54.259  - info: ham.0 (27203) updateState Zaehler-1.Switch.Outlet-In-Use: value = false /common= {"type":"boolean","read":true,"write":false,"role":"sensor","name":"Outlet In Use","unit":""}
    2022-07-13 19:43:54.260  - info: ham.0 (27203) updateState Zaehler-1.Switch.Current-Consumption: value = 0 /common= {"type":"number","unit":"W","min":0,"max":65535,"read":true,"write":false,"role":"value","name":"Current Consumption"}
    2022-07-13 19:43:54.261  - info: ham.0 (27203) updateState Zaehler-1.Switch.Electric-Current: value = 0 /common= {"type":"number","unit":"A","min":0,"max":100000000000,"read":true,"write":false,"role":"value","name":"Electric Current"}
    2022-07-13 19:43:54.261  - info: ham.0 (27203) updateState Zaehler-1.Switch.Voltage: value = 235 /common= {"type":"number","unit":"V","min":0,"max":100000000000,"read":true,"write":false,"role":"value","name":"Voltage"}
    2022-07-13 19:43:54.262  - info: ham.0 (27203) updateState Zaehler-1.Switch.Name: value =  /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
    2022-07-13 19:43:54.263  - info: ham.0 (27203) updateChannel Zaehler-1.Zaehler-1-History: name = Zaehler-1 History
    2022-07-13 19:43:54.264  - info: ham.0 (27203) updateState Zaehler-1.Zaehler-1-History.Name: value = Zaehler-1 History /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
    2022-07-13 19:43:54.264  - info: ham.0 (27203) updateState Zaehler-1.Zaehler-1-History.S2R1: value = 2zcSAAAAAAAf5WQoAQ4B3wfADwAAAAAAAAAAAQE= /common= {"type":"string","read":true,"write":false,"role":"text","name":"S2R1","unit":""}
    2022-07-13 19:43:54.265  - info: ham.0 (27203) updateState Zaehler-1.Zaehler-1-History.S2R2: value = null /common= {"type":"string","read":true,"write":false,"role":"text","name":"S2R2","unit":""}
    2022-07-13 19:43:54.265  - info: ham.0 (27203) updateState Zaehler-1.Zaehler-1-History.S2W1: value = null /common= {"type":"string","read":false,"write":true,"role":"text","name":"S2W1","unit":""}
    2022-07-13 19:43:54.266  - info: ham.0 (27203) updateState Zaehler-1.Zaehler-1-History.S2W2: value = null /common= {"type":"string","read":false,"write":true,"role":"text","name":"S2W2","unit":""}
    2022-07-13 19:43:54.274  - info: ham.0 (27203) updateDev DUALR3-2: name = DUALR3-2 /type= 1
    2022-07-13 19:43:54.275  - info: ham.0 (27203) updateChannel DUALR3-2.Accessory-Information: name =
    2022-07-13 19:43:54.276  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.Identify: value = true /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
    2022-07-13 19:43:54.277  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.Manufacturer: value = SONOFF /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
    2022-07-13 19:43:54.277  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.Model: value = DUALR3 (E32-2SW-P0) /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
    2022-07-13 19:43:54.279  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.Name: value = DUALR3-2 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
    2022-07-13 19:43:54.279  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.Serial-Number: value = 10014aa094SW0 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
    2022-07-13 19:43:54.280  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.Firmware-Revision: value = 1.4.0 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
    2022-07-13 19:43:54.281  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.Configured-Name: value = DUALR3-2 /common= {"type":"string","read":true,"write":true,"role":"text","name":"Configured Name","unit":""}
    2022-07-13 19:43:54.282  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.Accessory-Flags: value = 0 /common= {"type":"number","min":0,"max":4294967295,"read":true,"write":false,"role":"value","name":"Accessory Flags","unit":""}
    2022-07-13 19:43:54.282  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.App-Matching-Identifier: value =  /common= {"type":"string","read":true,"write":false,"role":"text","name":"App Matching Identifier","unit":""}
    2022-07-13 19:43:54.283  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.Configured-Name: value =  /common= {"type":"string","read":true,"write":true,"role":"text","name":"Configured Name","unit":""}
    2022-07-13 19:43:54.284  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.Hardware-Finish: value =  /common= {"type":"string","read":true,"write":false,"role":"text","name":"Hardware Finish","unit":""}
    2022-07-13 19:43:54.284  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.Hardware-Revision: value =  /common= {"type":"string","read":true,"write":false,"role":"text","name":"Hardware Revision","unit":""}
    2022-07-13 19:43:54.285  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.Product-Data: value =  /common= {"type":"string","read":true,"write":false,"role":"text","name":"Product Data","unit":""}
    2022-07-13 19:43:54.286  - info: ham.0 (27203) updateState DUALR3-2.Accessory-Information.Software-Revision: value =  /common= {"type":"string","read":true,"write":false,"role":"text","name":"Software Revision","unit":""}
    2022-07-13 19:43:54.286  - info: ham.0 (27203) updateChannel DUALR3-2.Switch: name =
    2022-07-13 19:43:54.287  - info: ham.0 (27203) updateState DUALR3-2.Switch.On: value = true /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
    2022-07-13 19:43:54.288  - info: ham.0 (27203) updateState DUALR3-2.Switch.Name: value =  /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
    2022-07-13 19:43:54.289  - info: ham.0 (27203) updateChannel DUALR3-2.DUALR3-2-History: name = DUALR3-2 History
    Das geht dann noch ewig so weiter, es kommt aber kein Fehler.
    • W WolfgangFB
      @wolfgangfb
      Wrapper-Modus
      Konfiguration:
        "accessories": [
        "platforms": [
            "name": "eWeLink",
      haselchenH Offline
      haselchenH Offline
      haselchen
      @wolfgangfb
      Okay, da würde jetzt von meiner Seite aus gesehen ne Menge Arbeit drinstecken.
      Angefangen von der Adapter Version (aktuell bei Dir 4.0.2) bis zum JS Controller 4.0.21 und dann noch die NodeVersion (entweder hochziehen auf 14.20 oder 16.16.)
      Davon hängt dann z.B. die Installation später ab, welche homebridge-ewelink Version.
      Dann müsste man deine Konfig modifizieren.
      Wie gesagt, aus meiner Sicht. Ich hab mich x Tage damit beschäftigt wegen unserer Beregnungsanlage.
      W 1 Antwort Letzte Antwort
        @wolfgangfb
        W Offline
        W Offline
        WolfgangFB
        @haselchen
        Ich habe jetzt mal eben auf einem zweiten Raspi mit IO-Broker Bastelinstallation den HAM Adapter (in Version 5.0.1) installiert. Hat auf den ersten Blick auch sofort alles geklappt. Nur kommen auch da keine Werte an und was mich stutzig macht ist, dass ein Sonoff, Relais, das ich letzte Woche hinzugefügt habe, in den Geräten überhaupt nicht auftaucht. Für mich sieht das so aus, als ob die Cloud permanent einen Stand von vor einer Woche senden würde.
        • W WolfgangFB
          @haselchen
          haselchenH Offline
          haselchenH Offline
          haselchen
          @wolfgangfb
          Deswegen sage ich ja, müsste man alles mal auf links drehen.
          Deine Konfig z.B.
          Die müsste eigentlich noch die Spezifikationen Deines/Deiner Geräte beinhalten.
          Die Zeile mit 49, der Länderkennung, kannste löschen.
          Hier ist die Anleitung für eine vernünftige Konfig
          https://github.com/bwp91/homebridge-ewelink/wiki/Configuration.
          Meine sieht so aus, für ein Sonoff 4ch Pro2
            "accessories": [],
            "platforms": [
                "name": "eWeLink",
                "mode": "auto",
                "username": "XXXXXX",
                "password": "XXXXXXX",
                "multiDevices": [
                    "deviceId": "1000bacfb4",
                    "deviceModel": "4ch",
                    "showAs": "default"
            @wolfgangfb
            Deine Konfig z.B.
              "accessories": [],
              "platforms": [
                  "name": "eWeLink",
                  "mode": "auto",
                  "multiDevices": [
                      "showAs": "default"
            W Offline
            W Offline
            WolfgangFB
            @haselchen
            Nur mal blöd nachgefragt: Bei Dir kannst Du die ewlink Devices über IO-Broker steuern und bekommst auch die richtigen Zustände angezeigt?
            • W WolfgangFB
              @haselchen
              haselchenH Offline
              haselchenH Offline
              haselchen
              @wolfgangfb
              Ja, läuft alles .
              Ist zwar bis dahin, wie du selber siehst, erstmal nen gebastel, aber das Ergebnis ist klasse.
              Hatte das vorher über Node Red und das war ne Katastrophe , weil jedes Node in den Account musste und irgendwann geblockt wurde.
                @wolfgangfb
                Ja, läuft alles .
                W Offline
                W Offline
                WolfgangFB
                @haselchen
                Ich habe jetzt nochmal alles wie im Video von elzershark gemacht und ich bekomme einen Fehler:
                ERR! 404 Not Found - GET https://registry.npmjs.org/homebridge-ewlink - Not found npm ERR! 404 npm ERR! 404 'homebridge-ewlink@latest' is not in the npm registry. npm ERR! 404 You should bug the author to publish it (or use the name yourself!) npm ERR! 404 npm ERR! 404 Note that you can also install from a npm ERR! 404 tarball, folder, http url, or git url.
                Wie kann ich das beheben?
                • W WolfgangFB
                  @haselchen
                  @wolfgangfb
                  Guter Rat: Vergiss dem Mumpitz den der Elstertyp da immer verzapft. Das ist fast durchweg Grütze.
                  Den zusätzlichen Adapter trägt man im ham-Adapter ein, ich würde das auch ohne Versionsangabe frei laufen lassen.
                  Dir fehlt auch ein e im Adapternamen. Mit ewElink funktioniert das auch
                  Hast du mal mit dem supertollen Elsterfrickel-Mega-Tool auf dein System eingedroschen? Das Ding ist Murks im Quadrat.
                    @wolfgangfb
                    W Offline
                    W Offline
                    WolfgangFB
                    So, ich habe jetzt nach Anleitung von Thomas NodeJS und NPM aktualisiert (16.16.0 und 8.11.0). Dann habe ich ham deinstalliert und neu installiert Das Ergebnis ist das gleiche. Das Sonoff R3, das ich letzte Woche in die Cloud aufgenommen habe fehlt und die anderen Geräte zeigen nicht den aktuellen Status an.
                    Dann habe ich den Raspi nochmal neu gestartet und jetzt startet der IO-Broker überhaupt nicht mehr :-( Was ist da jetzt verbogen? iobroker fix bring keine Besserung.
                    pi@raspberrypi202:~ $ iobroker status
                    node:internal/modules/cjs/loader:936
                      throw err;
                    Error: Cannot find module 'semver'
                    Require stack:
                    - /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js
                    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                        at Module.require (node:internal/modules/cjs/loader:1005:19)
                        at require (node:internal/modules/cjs/helpers:102:18)
                        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:5:19)
                        at Module._compile (node:internal/modules/cjs/loader:1105:14)
                        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
                        at Module.load (node:internal/modules/cjs/loader:981:32)
                        at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                        at Module.require (node:internal/modules/cjs/loader:1005:19) {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: [
                        '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js',
                        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    • W WolfgangFB
                        throw err;
                      Require stack:
                        requireStack: [
                      @wolfgangfb
                      nodeJS sauber?
                      uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      prüfen.
                      Wenn ja:
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install iobroker.js-controller
                        @wolfgangfb
                        nodeJS sauber?
                        prüfen.
                        Wenn ja:
                        cd /opt/iobroker
                        W Offline
                        W Offline
                        WolfgangFB
                        @thomas-braun sagte in HAM (homebridge-ewlink) seit einer Woche tot:
                        @wolfgangfb
                        nodeJS sauber?
                        prüfen.
                        pi@raspberrypi202:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.16.0
                        v16.16.0
                        8.11.0
                        pi
                        /home/pi
                        OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                        OK:3 https://linux.teamviewer.com/deb stable InRelease
                        OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                        OK:5 https://repos.influxdata.com/debian stretch InRelease
                        OK:6 https://packages.grafana.com/oss/deb stable InRelease
                        Alle Pakete sind aktuell.
                        W: Das Laden der konfigurierten Datei »ui/binary-armhf/Packages« wird übersprungen, da das Depot »http://archive.raspberrypi.org/debian bullseye InRelease« die Komponente »ui« nicht enthält. (Schreibfehler bei der Angabe der Komponente in sources.list?)
                        W: Das Laden der konfigurierten Datei »ui/i18n/Translation-de_DE« wird übersprungen, da das Depot »http://archive.raspberrypi.org/debian bullseye InRelease« die Komponente »ui« nicht enthält. (Schreibfehler bei der Angabe der Komponente in sources.list?)
                        W: Das Laden der konfigurierten Datei »ui/i18n/Translation-en« wird übersprungen, da das Depot »http://archive.raspberrypi.org/debian bullseye InRelease« die Komponente »ui« nicht enthält. (Schreibfehler bei der Angabe der Komponente in sources.list?)
                        W: Das Laden der konfigurierten Datei »ui/i18n/Translation-de« wird übersprungen, da das Depot »http://archive.raspberrypi.org/debian bullseye InRelease« die Komponente »ui« nicht enthält. (Schreibfehler bei der Angabe der Komponente in sources.list?)
                        nodejs:
                          Installiert:           16.16.0-deb-1nodesource1
                          Installationskandidat: 16.16.0-deb-1nodesource1
                          Versionstabelle:
                         *** 16.16.0-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                             12.22.12~dfsg-1~deb11u1 500
                        Zählt das als sauber?
                        Wenn ja:
                        cd /opt/iobroker
                        Hat funktioniert.
                        Jetzt wollte ich noch den js-controller aktualisieren, bekomme aber diese Fehlermeldung:
                        pi@raspberrypi202:~ $ iobroker upgrade self
                        Update js-controller from @3.3.18 to @4.0.23
                        NPM version: 8.11.0
                        npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                        npm ERR! code ENOTEMPTY
                        npm ERR! syscall rename
                        npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                        npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                        npm ERR!     /home/iobroker/.npm/_logs/2022-07-14T13_53_16_823Z-debug-0.log
                        host.raspberrypi202 Cannot install iobroker.js-controller@4.0.23: 217
                        • W WolfgangFB
                          @wolfgangfb
                          nodeJS sauber?
                          prüfen.
                          armv7l
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.16.0
                          v16.16.0
                          8.11.0
                          pi
                          /home/pi
                          nodejs:
                            Versionstabelle:
                          Wenn ja:
                          cd /opt/iobroker
                          Hat funktioniert.
                          NPM version: 8.11.0
                          npm ERR! errno -39
                          @wolfgangfb sagte in HAM (homebridge-ewlink) seit einer Woche tot:
                          Jein. Das influxdb-Repo hört auf stretch, das muss aber auf bullseye lauten.
                          Und die sources.list enthält einen Eintrag 'ui', den es aber nicht mehr gibt (Und auf Servern eh nicht relevant wäre, da ja gar keine GUI läuft...)
                          Das gleiche gilt für teamviewer... Kein Desktop, also auch nix zu teamviewen.
                          nodejs als solches ist aber richtig installiert.
                          Zum js-controller Upgrade:
                          rm -rf /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                            W Offline
                            W Offline
                            WolfgangFB
                            So, nachdem ich jetzt mit einigen Problemen (Fehlermeldung dass Verzeichnisse nicht leer sind etc. ) endlich js-controller 4.0.23 und ham 5.0.1 auf dem Bastel-Pi habe, kommen dort auch wieder Daten an. Jetzt muss ich mich frage, ob ich mich das auch auf dem "Echten" Pi traue.
                            Die Konfiguration klappt übrigens ohne "multiDevices"
                            Danke allen, die mir geholfen haben.
                            • W WolfgangFB
                              @wolfgangfb
                              Siehste, mit einem konsistenten, aktuell gehaltenem System funktioniert es auch.
                                @wolfgangfb
                                W Offline
                                W Offline
                                WolfgangFB
                                Na ja, im stable repository ist die ham Version 4.02 die ich auch verwende. Die 5.0.1. ist im Beta repository.
                                • W WolfgangFB
                                  @wolfgangfb
                                  Der js-controller 4.0.23 ist schon länger im stable.
                                  Vielleicht lag es auch an der Version?
                                  Wie dem auch sei, ein aktuelles System ist immer zu empfehlen als da mit alten Versionen zu ringen. Die sind ja nicht einfach so veröffentlicht worden, sondern weil es da etwas zu korrigieren und zu verbessern gab. Sonst hätte man das nicht released.
                                  Hast du deine .list-Dateien angepasst? Da blüht dir sonst das nächste Kuddelmuddel.
                                  • W Offline
                                    W Offline
                                    WolfgangFB
                                    @wolfgangfb
                                    Was meinst Du damit genau?
                                    /etc/apt/sources.list?
                                    Die sieht so aus:
                                    pi@raspberrypi202:~ $ more /etc/apt/sources.list
                                    deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
                                    # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                                    #deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
                                    was soll ich da anpassen?
                                    • W WolfgangFB
                                      @wolfgangfb
                                      Die sieht so aus:
                                      @wolfgangfb
                                      U. a. die influxdb.list
                                      Zeig mal was da jetzt Phase ist:
                                      sudo apt update
                                        @wolfgangfb
                                        sudo apt update
                                        W Offline
                                        W Offline
                                        WolfgangFB
                                        pi@raspberrypi202:~ $ sudo apt update
                                        Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                                        Holen:2 http://archive.raspberrypi.org/debian bullseye InRelease [23,7 kB]
                                        OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        OK:4 https://linux.teamviewer.com/deb stable InRelease
                                        Holen:5 https://packages.grafana.com/oss/deb stable InRelease [12,1 kB]
                                        OK:6 https://repos.influxdata.com/debian stretch InRelease
                                        Holen:7 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13,2 MB]
                                        Holen:8 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [289 kB]
                                        Holen:9 https://packages.grafana.com/oss/deb stable/main armhf Packages [35,7 kB]
                                        Es wurden 13,6 MB in 19 s geholt (708 kB/s).
                                        Aktualisierung für 8 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                        wobei ich grafana und influxdb eigentlich deinstalliert habe (zumindest habe ich das versucht).
                                        • W WolfgangFB
                                          apt policy influx* grafana
                                          sagt dir das.
                                          Trag in die /etc/apt/sources.list.d/influxdb.list das ein:
                                          deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian bullseye stable
                                          Und in der /etc/apt/sources.list.d/raspi.list löschst du ersatzlos den Eintrag ui.
