  4. Sonoff NSPanel
    6.7k
Sonoff NSPanel
1.5k Beiträge 78 Kommentatoren 881.1k Aufrufe 80 Beobachtet
  • WalW Offline
    WalW Offline
    Wal
    schrieb am zuletzt editiert von Wal
    #913
    So bin soweit fertig und es funktioniert so:
    var Wohnzimmer_Thermostat: PageThermo =
        "type": "cardThermo",
        "heading": "Wohnzimmer",
        "useColor": true,
        "subPage": false,
        "parent": undefined,
        "items": [<PageItem>{ id: "alias.0.NSPanel_WZ.Thermostat_WZ", minValue: 50, maxValue: 300 }]
    var Zisterne: PageEntities =
        "type": "cardEntities",
        "heading": "Füllstand",
        "useColor": true,
        "subPage": false,
        "items": [<PageItem>{ id: "alias.0.NSPanel_WZ.Zisterne"}]
    var button1Page: PageGrid =
        "type": "cardGrid",
        "heading": "",
        "useColor": true,
        "subPage": false,
        "items": [
    var button2Page: PageEntities =
        "heading": "",
        "useColor": true,
        "subPage": false,
        "items": [
    export const config: Config = {
        panelRecvTopic: "mqtt.0.Wohnzimmer.NSPanel_WZ.tele.RESULT",       //anpassen
        panelSendTopic: "mqtt.0.Wohnzimmer.NSPanel_WZ.cmnd.CustomSend",   //anpassen
        firstScreensaverEntity: { ScreensaverEntity: "hmip.0.devices.3014F711A000185BE9922BCF.channels.1.humidity", ScreensaverEntityIcon: "water-percent", ScreensaverEntityText: "Luft", ScreensaverEntityUnitText: "%" },
        secondScreensaverEntity: { ScreensaverEntity: "accuweather.0.Daily.Day1.Day.PrecipitationProbability", ScreensaverEntityIcon: "weather-pouring", ScreensaverEntityText: "Regen", ScreensaverEntityUnitText: "%" },
        thirdScreensaverEntity: { ScreensaverEntity: "0_userdata.0.Wetter.Windstaerke_homaticIP", ScreensaverEntityIcon: "weather-windy", ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: "bft" },
        fourthScreensaverEntity: { ScreensaverEntity: "accuweather.0.Current.UVIndex", ScreensaverEntityIcon: "solar-power", ScreensaverEntityText: "UV", ScreensaverEntityUnitText: "" },
        timeoutScreensaver: 15,
        dimmode: 8,
        active: 100, //Standard-Brightness TFT
        screenSaverDoubleClick: false,
        locale: "de-DE",                    //en-US, de-DE, nl-NL, da-DK, es-ES, fr-FR, it-IT, ru-RU, etc.
        timeFormat: "%H:%M",                //currently not used
        dateFormat: "%A, %d. %B %Y",        //currently not used
        weatherEntity: "alias.0.Wetter",
        defaultOffColor: Off,
        defaultOnColor: On,
        defaultColor: Off,
        temperatureUnit: "°C",
        pages: [
                Zisterne,
        subPages: [
        button1Page: button1Page,
        button2Page: button2Page
    Ich möchte jetzt nur das Thermostat als erste Page haben was aber leider nicht funktioniert.
    Walter
    DoorIO-Adapter
    • WalW Offline
      WalW Offline
      Wal
      #914
      Habe den Skript-Fehler gefunden:
      function GenerateThermoPage(page: PageThermo): Payload[] {
          activePage = page;
      Das activePage fehlt in der Funktion.
      Walter
      DoorIO-Adapter
      • WalW Wal
            activePage = page;
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        Most Active Forum Testing
        #915
        @wal
        und Github Bug #286 ebenfalls eleminiert. ;-)
        Gleiches bei pageMedia und pageAlarm
        WalW 1 Antwort Letzte Antwort
        • ArmilarA Armilar
          @wal
          WalW Offline
          WalW Offline
          Wal
          #916
          @armilar sagte in Sonoff NSPanel:
          @wal
          und Github Bug #286 ebenfalls elemeniert. ;-)
          function GeneratePage(page: Page): void {
              activePage = page;
              switch (page.type) {
                  case "cardEntities":
          das activePage so einfügen, da sind alle Spatzen gefangen.
          Will jetzt keinen neuen PullRequest machen.
          Walter
          DoorIO-Adapter
            Kuckuckmann
            #917
            @Wal
            Ich hätte darauf getippt, dass Du zum einen bei jeder VAR ein "parent": undefined hast und zum anderen die ggf. nicht näher definierten Button 1 + Button 2 da ggf. noch ein Problem sein könnten.
            Das undefined habe ich bei mir durch den Namen der VAR ersetzt, funktioniert eigentlich alles soweit sehr gut.
            NSPanel Dokumentation im GitHub Wiki:
              Kuckuckmann
              schrieb am zuletzt editiert von Kuckuckmann
              #918
              In eigener Sache:
              Ich habe hier eine Funktion aus einem Skript, diese scheint bei mir einen Absturz des mqtt Adapters zu verursachen:
              Deaktiviere ich den Aufruf der Funktion, habe ich keine Probleme, aktiviere ich die Notify Funktion, passiert folgendes:
              Jemand eine Idee?
              Kann es sein, dass derGrund das direkte Ansprechen der Notify Datenpunkte ist, anstatt über Aliase zu gehen?
              Und noch eine Frage: Wie kann ich den Inhalt der DP der NotifyPage leeren, ohne dass dabei eine Page aufgeht auf dem Display?
              Thx vorab
                Kuckuckmann
                #919
                @Armilar
                Wenn ich ein Alias Lampe habe, bei der ich auch Energiewerte eingebunden habe, wie kann ich das denn am einfachsten darstellen lassen? In dem einen Alias bekomme ich ON/OFF Switch, Verbrauchte Energie over all und aktueller Energieverbrauch.
                Danke für eine Hilfestellung.
                • K Kuckuckmann
                  @Armilar
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #920
                  @kuckuckmann sagte in Sonoff NSPanel:
                  @Armilar
                  Aktuell nur über eine cardEntities mit einer Lampe und 2 Infos auf die restlichen Werte. Alles andere würde eine Änderung der HMI bedeuten.
                  Wenn genug Platz in dem Anzeigenamen bis zum Switch verfügbar ist, müsste ein join der Informationen in einer Zeile auch möglich sein.
                  • ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    #921
                    In eigener Sache:
                    Jemand eine Idee?
                    Thx vorab
                    Stellt sich die Frage, was ruft die Funktion auf und dann wie oft. Kann nur mit der Funktion nicht viel anfangen.
                    Frage 2: Aktuell ist ein leeren nicht vorgesehen. Nur im Falle eines Überschreibens der Werte werden neue Angezeigt. Wenn sie dennoch leer sein müssen, dann nur über eine Erweiterung der Funktion für die pageNotify. Im Falle des Triggers könnte man mit einer kleinen Erweiterung den Wert des Datenpunktes mit "" ignorieren.
                    • ArmilarA Armilar
                      @Armilar
                      Kuckuckmann
                      #922
                      @armilar
                      Gibt es da bestimmte Infos, die man da befüllen muss?
                      Auf meiner CardEntitie kann ich auf die Zeile klicken, es kommt eine Subpage, da hab ich aber nur einen Switch ohne Beschriftung und auch sonst keine Anzeige.
                      • K Kuckuckmann
                        @armilar
                        ArmilarA Offline
                        ArmilarA Offline
                        Armilar
                        #923
                        Nein nicht falsch verstehen. In der Subpage sind aktuell keine Infos zu Energie-Verbräuchen der einzelnen Verbraucher berücksichtigt. Ich dachte daran, dass man evtl. über ein Verketten der Informationen im Namen (Dein eigener Workaround), diese Infos über das pageItem-Atribut name: "Lampe 1" + getState(Energie-Alias) mitgeben könnte.
                        Also dann in der Zeile so etwas steht:
                        Lampe 1 (4,2 W)
                        Lampe 2 (3,2 W)
                        usw.
                        Du hast da nach einer Möglichkeit gefragt ;-) . Ich habe da überhaupt keine Anwendung für. Panel dient zum Schalten von Zuständen. Ich schalte mein Licht nicht nach Verbräuchen, sondern nach Helligkeit (Bedarf).
                        • ArmilarA Armilar
                          Lampe 1 (4,2 W)
                          Lampe 2 (3,2 W)
                          usw.
                          Kuckuckmann
                          #924
                          @armilar
                          Ich verstehe was Du meinst. Danke für die Idee !
                          Was ich meinte war, dass wenn man links auf Spülmaschine klickt und dann diese Subpage bekommt, diese mit den Inhalten aus den Aliasen ja füllen könnte. Keine Ahnung ob das geht:
                          Ich fände das eine nette Aufwertung der Subpage :-)
                          LG
                          • K Kuckuckmann
                            @armilar
                            LG
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #925
                            @armilar
                            LG
                            Da die gleiche Seite auch für andere Lampentypen (Slider, Colorwheel, etc.) verwendet wird, gehe ich mal davon aus, dass es zumindest nicht in den Bereichen machbar ist. Aber vielleicht findet @joBr99 eine Möglichkeit.
                            Schreibe doch bitte ein neues Issue unter:
                            https://github.com/joBr99/nspanel-lovelace-ui/issues
                            Dann kannst du es mit ihm diskutieren und evtl. hat er ja eine Lösung.
                            • WalW Offline
                              WalW Offline
                              Wal
                              #926
                              Hier noch ein Tip:
                              function HandleMessage(typ: string, method: string, page: number, words: Array<string>): void {
                                  if (typ == "event") {
                                      switch (method) {
                                          case "startup":
                                              screensaverEnabled = false;
                                              UnsubscribeWatcher();
                                              HandleStartupProcess();
                                              pageId = 0;
                                              GeneratePage(config.pages[0]);
                                              break;
                                          case "sleepReached":
                                              screensaverEnabled = true;
                                              //if (pageId < 0)
                                                  pageId = 0;
                                              HandleScreensaver();
                                              break;
                              wenn die if Abfrage augeblendet wird, sieht man immer die erste Seite nach dem Screensaver.
                              Walter
                              DoorIO-Adapter
                                Kuckuckmann
                                #927
                                @Armilar Request ist erstellt :-)
                                Hat jemand eine Idee, wie ich bei meinem NSPanel ein Tasmota Update über den Dateiupload machen kann?
                                Bei mir bricht es jedes mal ab.
                                • K Kuckuckmann
                                  joBr99
                                  #928
                                  @Kuckuckmann
                                  Mach mal WebLog 3 in der tasmota konsole und schau dann was da fürn error steht
                                  • J joBr99
                                    @Kuckuckmann
                                    Kuckuckmann
                                    #929
                                    @jobr99
                                    Wie geht das, bzw. wie komm ich da dran?
                                    • K Kuckuckmann
                                      @jobr99
                                      TT-Tom
                                      #930
                                      @kuckuckmann
                                      Hauptmenü/Konsole/Konsole
                                      in der Konsole Weblog 3 eingeben. Update durch führen und Meldungen im Log ansehen
                                      Gruß Tom
                                      Public Transport
                                      NSPanel Adapter Wiki
                                        Kuckuckmann
                                        #931
                                        Wäre dann das:
                                        T WalW 2 Antworten Letzte Antwort
                                        • K Kuckuckmann
                                          Wäre dann das:
                                          TT-Tom
                                          #932
                                          @kuckuckmann
                                          ich würde sagen der upload hat funktioniert laut Log. hast du wirklich die Tasmota32-DE.bin runtergeladen? du hast ein ESP32 dadrin
                                          PS: du kannst den Inhalt der Konsole auch kopieren und in die Code-Tags kopieren lässt sich besser lesen.
                                          PS
                                          Gruß Tom
                                          Public Transport
