  4. Fehler beim Speichern VIS
    5.8k
35 Beiträge 8 Kommentatoren 3.6k Aufrufe 7 Beobachtet
    @michl75 sagte in Fehler beim Speichern VIS:
    das kommt
    klar!
    bei den anderen Threads auch
    michl75M Offline
    michl75M Offline
    michl75
    @homoran bin schon am guggen
    • michl75M Offline
      michl75M Offline
      michl75
      schrieb am zuletzt editiert von michl75
      Was bedeutet das? das habe ich gerade gesehen im Log...
      nfo.0
      1197	2022-07-10 09:37:02.159	error	line is not defined
      info.0
      1197	2022-07-10 09:37:02.159	error	ReferenceError: line is not defined at filterLines (/opt/iobroker/node_modules/systeminformation/lib/filesystem.js:66:9) at /opt/iobroker/node_modules/systeminformation/lib/filesystem.js:127:23 at ChildProcess.exithandler (node:child_process:390:7) at ChildProcess.emit (node:events:527:28) at ChildProcess.emit (node:domain:475:12) at maybeClose (node:internal/child_process:1092:16) at Socket.<anonymous> (node:internal/child_process:451:11) at Socket.emit (node:events:527:28) at Socket.emit (node:domain:475:12) at Pipe.<anonymous> (node:net:709:12)
      info.0
      1197	2022-07-10 09:37:02.158	error	uncaught exception: line is not defined
      EDIT:
      Radar2 habe ich komplett entfernt, Web-Socket habe ich hacken raus. Neustart gemacht... gleiches Problem immer noch
      nach Neustart kommt auch das bei Info Adapter:
      info.0
      4109	2022-07-10 09:48:01.349	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      info.0
      4109	2022-07-10 09:48:01.349	info	terminating
      info.0
      4109	2022-07-10 09:48:01.349	info	cleaned everything up...
      info.0
      4109	2022-07-10 09:48:01.341	error	line is not defined
      info.0
      4109	2022-07-10 09:48:01.340	error	ReferenceError: line is not defined at filterLines (/opt/iobroker/node_modules/systeminformation/lib/filesystem.js:66:9) at /opt/iobroker/node_modules/systeminformation/lib/filesystem.js:127:23 at ChildProcess.exithandler (node:child_process:390:7) at ChildProcess.emit (node:events:527:28) at ChildProcess.emit (node:domain:475:12) at maybeClose (node:internal/child_process:1092:16) at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
      info.0
      4109	2022-07-10 09:48:01.340	error	uncaught exception: line is not defined
      info.0
      4109	2022-07-10 09:48:01.224	info	Reading process data every 60 seconds.
      info.0
      4109	2022-07-10 09:48:01.067	info	Reading user data every 60 seconds.
      info.0
      4109	2022-07-10 09:48:00.787	info	Reading battery data every 120 seconds.
      info.0
      4109	2022-07-10 09:48:00.733	info	Reading memory data every 60 seconds.
      info.0
      4109	2022-07-10 09:48:00.704	info	Reading CPU current speed every 30 seconds.
      info.0
      4109	2022-07-10 09:48:00.688	info	Reading CPU temp data every 30 seconds.
      info.0
      4109	2022-07-10 09:48:00.681	info	cpu Temp res = {"main":null,"cores":[],"max":null,"socket":[],"chipset":null}
      info.0
      4109	2022-07-10 09:48:00.662	info	Reading CPU data every 30 seconds.
      info.0
      4109	2022-07-10 09:48:00.378	info	Reading/updating systemdata.
      info.0
      4109	2022-07-10 09:48:00.345	info	starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.15.1, js-controller: 4.0.23
      wird noch besser:
      javascript.0
      8669	2022-07-10 09:53:32.939	info	script.js.0_userdata_0.Kleinprogramme.Energieverbrauchsberechnung: registered 1 subscription and 0 schedules
      javascript.0
      8669	2022-07-10 09:53:32.936	info	Start javascript script.js.0_userdata_0.Kleinprogramme.Energieverbrauchsberechnung
      javascript.0
      8669	2022-07-10 09:53:32.934	info	script.js.0_userdata_0.Kleinprogramme.Kuhlung-Server-Aktiv: registered 1 subscription and 0 schedules
      javascript.0
      8669	2022-07-10 09:53:32.928	info	Start javascript script.js.0_userdata_0.Kleinprogramme.Kuhlung-Server-Aktiv
      javascript.0
      8669	2022-07-10 09:53:32.928	info	script.js.0_userdata_0.Kleinprogramme.Waschmaschine-Aktiv: registered 1 subscription and 0 schedules
      javascript.0
      8669	2022-07-10 09:53:32.909	info	Start javascript script.js.0_userdata_0.Kleinprogramme.Waschmaschine-Aktiv
      javascript.0
      8669	2022-07-10 09:53:32.707	info	received all states
      javascript.0
      8669	2022-07-10 09:53:32.658	info	received all objects
      javascript.0
      8669	2022-07-10 09:53:32.397	info	requesting all objects
      javascript.0
      8669	2022-07-10 09:53:32.397	info	requesting all states
      javascript.0
      8669	2022-07-10 09:53:32.205	error	Cannot install npm packet: Repuest
      javascript.0
      8669	2022-07-10 09:53:32.204	error	Cannot install Repuest: 1
      javascript.0
      8669	2022-07-10 09:53:32.199	error	npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-07-10T07_53_30_648Z-debug-0.log
      javascript.0
      javascript.0
      8669	2022-07-10 09:53:32.198	error	tarball, folder, http url, or git url.
      javascript.0
      8669	2022-07-10 09:53:32.197	error	ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404
      javascript.0
      8669	2022-07-10 09:53:32.197	error	This package name is not valid, because npm ERR! 404 1. name can no longer contain capital lettersnpm
      javascript.0
      8669	2022-07-10 09:53:32.197	error	npm ERR! 404 'Repuest@*' is not in this registry.npm ERR! 404
      javascript.0
      8669	2022-07-10 09:53:32.197	error	404 Not Found - GET https://registry.npmjs.org/Repuest - Not foundnpm ERR! 404
      javascript.0
      javascript.0
      8669	2022-07-10 09:53:32.195	error	ERR! code E404
      javascript.0
      8669	2022-07-10 09:53:32.194	error	npm
      pushover.0
      8720	2022-07-10 09:53:31.338	info	starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v16.15.1, js-controller: 4.0.23
      host.MSIO02
      2022-07-10 09:53:30.757	info	instance system.adapter.pushover.0 started with pid 8720
      javascript.0
      8669	2022-07-10 09:53:30.674	error	WARN config production Use `--omit=dev` instead.
      javascript.0
      8669	2022-07-10 09:53:30.674	error	npm
      javascript.0
      8669	2022-07-10 09:53:30.402	info	npm install Repuest --production (System call)
      javascript.0
      8669	2022-07-10 09:53:30.401	error	Cannot install Repuest: 1
      javascript.0
      8669	2022-07-10 09:53:30.397	error	npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-07-10T07_53_29_694Z-debug-0.log
      javascript.0
      javascript.0
      8669	2022-07-10 09:53:30.396	error	404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
      javascript.0
      8669	2022-07-10 09:53:30.395	error	npm ERR! 404 1. name can no longer contain capital lettersnpm ERR! 404 npm ERR!
      javascript.0
      8669	2022-07-10 09:53:30.395	error	'Repuest@*' is not in this registry.npm ERR! 404 This package name is not valid, because
      javascript.0
      8669	2022-07-10 09:53:30.395	error	404 Not Found - GET https://registry.npmjs.org/Repuest - Not foundnpm ERR! 404 npm ERR! 404
      javascript.0
      javascript.0
      8669	2022-07-10 09:53:30.393	error	ERR! code E404
      javascript.0
      8669	2022-07-10 09:53:30.392	error	npm
      javascript.0
      8669	2022-07-10 09:53:29.724	error	WARN config production Use `--omit=dev` instead.
      javascript.0
      8669	2022-07-10 09:53:29.724	error	npm
      javascript.0
      8669	2022-07-10 09:53:29.451	info	npm install Repuest --production (System call)
      javascript.0
      8669	2022-07-10 09:53:29.451	error	Cannot install Repuest: 1
      javascript.0
      8669	2022-07-10 09:53:29.447	error	npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-07-10T07_53_27_901Z-debug-0.log
      javascript.0
      8669	2022-07-10 09:53:29.446	error
      javascript.0
      8669	2022-07-10 09:53:29.445	error	404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
      javascript.0
      8669	2022-07-10 09:53:29.445	error	ERR! 404 'Repuest@*' is not in this registry.npm ERR! 404 This package name is not valid, because npm ERR! 404 1. name can no longer contain capital lettersnpm ERR!
      javascript.0
      8669	2022-07-10 09:53:29.445	error	404 Not Found - GET https://registry.npmjs.org/Repuest - Not foundnpm ERR! 404 npm
      javascript.0
      8669	2022-07-10 09:53:29.445	error	npm ERR!
      javascript.0
      8669	2022-07-10 09:53:29.443	error	E404
      javascript.0
      8669	2022-07-10 09:53:29.442	error	code
      javascript.0
      8669	2022-07-10 09:53:29.442	error	ERR!
      javascript.0
      javascript.0
      8669	2022-07-10 09:53:29.441	error	npm
      javascript.0
      8669	2022-07-10 09:53:27.932	error	production Use `--omit=dev` instead.
      javascript.0
      8669	2022-07-10 09:53:27.931	error	config
      javascript.0
      javascript.0
      8669	2022-07-10 09:53:27.931	error	WARN
      javascript.0
      8669	2022-07-10 09:53:27.930	error
      javascript.0
      8669	2022-07-10 09:53:27.929	error	npm
      Muss ich jetzt alles neu machen ?
      so macht das doch keinen spaß mehr... und wohl gemerkt, das System ist nagel neu, neuerstes Debian drauf und dann installation ohne fehler gelaufen.
      • michl75M michl75
        nfo.0
        info.0
        info.0
        EDIT:
        info.0
        info.0
        info.0
        info.0
        info.0
        info.0
        info.0
        info.0
        info.0
        info.0
        info.0
        info.0
        info.0
        info.0
        info.0
        info.0
        wird noch besser:
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        pushover.0
        host.MSIO02
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        crunchipC Abwesend
        crunchipC Abwesend
        Wie und worauf installiert?
        • michl75M Offline
          michl75M Offline
          michl75
          @crunchip
          Debian 11 - bullseye
          nach der iobroker anleitung: https://iobroker.readthedocs.io/de/latest/getting-started/installation.html#:~:text=Unter Linux (z.B. Debian oder Ubuntu) lässt sich,komplette System vor und richtet alles nötige ein%3A
          Das komische, bis gestern spät Abend lief alles ganz normal und beim erstellen (bereits viel gemacht) kommt plötlich das kein speichern mehr möglich ist. Ich habe nichts an den Adaptern oder so geändert...!
          Habe nur am Vis gearbeitet ... und dann zack
          DJMarc75D HiroPH HomoranH 3 Antworten Letzte Antwort
          • michl75M michl75
            @crunchip
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @michl75 Hast Du im Javaskript Adapter unter "zusätzliche NPM-Module" etwas eingetragen ?
            Beispiel bei mir:
            Lehrling seit 1975 !!!
            michl75M 1 Antwort Letzte Antwort
            • michl75M michl75
              @crunchip
              HiroPH Offline
              HiroPH Offline
              HiroP
              @michl75
              Ich hatte seit etwa einer Woche das gleiche Problem, nach ausprobieren sämtlicher Kombinationen (mit Socket.io, integrietem socket in web.0 usw) hat bei mir wundersamer Weise nur eins funktioniert:
              Socket.io komplett deinstalliert und im web.0 integriertes Socket + Websockets (iobroker.ws) erzwingen.
              michl75M M 2 Antworten Letzte Antwort
              • DJMarc75D DJMarc75
                Beispiel bei mir:
                michl75M Offline
                michl75M Offline
                michl75
                @djmarc75 ja so ... hab das so gemacht wie in meinem alten system.
                • HiroPH HiroP
                  @michl75
                  michl75M Offline
                  michl75M Offline
                  michl75
                  @hirop uh ... das probiere ich sofort aus
                  sage Bescheid
                  • HiroPH HiroP
                    @michl75
                    MartyBr
                    @hirop
                    Ich hatte auch das Problem. Ich habe aber nur den WS installiert und in web das entsprechende Häkchen gesetzt. socker.io habe ich nicht deinstalliert. Das hat auch sofort funktioniert.
                    Martin
                    Homematic und Homematic IP
                    • DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      request kannst Du rausnehmen da es im Adapter integriert ist.
                      • michl75M michl75
                        @michl75
                        Repuest ist falsch. Vermutlich ein Tippfehler.
                          @michl75
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          @thomas-braun sagte in Fehler beim Speichern VIS:
                          Repuest ist falsch
                          Brille auf und schon seh ich das auch 😂
                          • michl75M Offline
                            michl75M Offline
                            michl75
                            @all_die_geholfen haben :) vielen, vielen Dank !!!
                            Das mit Web-Socket hat funktioniert und das im java, mit request haeb ich raus genommen ... Er speichert wirder ab !!!
                            Ich danke euch !!!!!! Puh, ich dachte schon ich muss alles wieder neu machen....
                            Nochmals danke !!!
                            • michl75M michl75
                              @crunchip
                              was ist das denn für ein URL??
                              Das ist nicht iobroker!
                              michl75M crunchipC 2 Antworten Letzte Antwort
                                michl75M Offline
                                michl75M Offline
                                michl75
                                @homoran ich dachte schon ... fast gleicher aufbau. Gibt ne originale Anleitung dazu dann ?
                                • michl75M michl75
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  https://www.iobroker.net/#de/documentation/install/linux.md
                                  EDIT: den Befehl
                                  curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                                  sollte/kann man aber in
                                  curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
                                  ändern
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    @homoran sagte in Fehler beim Speichern VIS:
                                    © Copyright 2022, Matthias Kleine (haus-automatisierung.com)
                                      EDIT: den Befehl
                                      ändern
                                      @djmarc75 sagte in Fehler beim Speichern VIS:
                                      den Befehl
                                      brauchst du gar nicht, wenn du neu installierst. Das macht der Installer. steht auch im roten Kasten.
                                      aber werde ich mal anpassen
                                        den Befehl
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        wollte die Seite diesbezüglich ja eigentlich mal anpassen/anders formulieren, aber da sich in der Zwischenzeit soviel geändert hat(node version, Installation, user pi...), gehört die Seite komplett überarbeitet.
                                        mal sehen ob ich die tage dazu komm, allerdings hab ich mit dem Pi nicht sonderlich viel am Hut um z.b ne Schrit für Schritt Anleitung zu erstellen, ähnlich wie bei Proxmox
                                          @crunchip sagte in Fehler beim Speichern VIS:
                                          wenn du wüsstest wie oft ich das gemacht habe, weil nach jeder Änderung wieder dem einen zuviel, dem anderen zu wenig drin stand.
                                          ...und dann soll es für Neuinstallationen einfach und kurz und trotzdem für Reparaturen vollständig mit allen Eventualitäten sein.
                                          Bin mal gespannt
